Re: [PATCH 06/11] net: dwc_eth_qos: Move log_debug statements on top of case block
On 3/9/24 03:11, Marek Vasut wrote:
Move the log_debug() calls on top of the bit manipulation code. No functional change.
Signed-off-by: Marek Vasut marex@denx.de
Cc: Christophe Roullier christophe.roullier@st.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Ramon Fried rfried.dev@gmail.com Cc: u-boot@dh-electronics.com Cc: uboot-stm32@st-md-mailman.stormreply.com
drivers/net/dwc_eth_qos_stm32.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/dwc_eth_qos_stm32.c b/drivers/net/dwc_eth_qos_stm32.c index 7545026b158..38037c47954 100644 --- a/drivers/net/dwc_eth_qos_stm32.c +++ b/drivers/net/dwc_eth_qos_stm32.c @@ -143,34 +143,34 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev,
switch (interface_type) { case PHY_INTERFACE_MODE_MII:
log_debug("PHY_INTERFACE_MODE_MII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); value |= SYSCFG_PMCSETR_ETH_REF_CLK_SEL;
log_debug("PHY_INTERFACE_MODE_MII\n"); break; case PHY_INTERFACE_MODE_GMII:
log_debug("PHY_INTERFACE_MODE_GMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); if (eth_clk_sel_reg) value |= SYSCFG_PMCSETR_ETH_CLK_SEL;
log_debug("PHY_INTERFACE_MODE_GMII\n"); break; case PHY_INTERFACE_MODE_RMII:
log_debug("PHY_INTERFACE_MODE_RMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RMII); if (eth_ref_clk_sel_reg) value |= SYSCFG_PMCSETR_ETH_REF_CLK_SEL;
log_debug("PHY_INTERFACE_MODE_RMII\n"); break; case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_RGMII_RXID: case PHY_INTERFACE_MODE_RGMII_TXID:
log_debug("PHY_INTERFACE_MODE_RGMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RGMII); if (eth_clk_sel_reg) value |= SYSCFG_PMCSETR_ETH_CLK_SEL;
log_debug("PHY_INTERFACE_MODE_RGMII\n"); break; default: log_debug("Do not manage %d interface\n",
Reviewed-by: Christophe ROULLIER christophe.roullier@foss.st.com
Christophe ROULLIER
