[U-Boot-Users] LAN chip dead on ARM Integrator/CP board
I am using an ARM Integrator/CP board with u-boot 1.1.3. It's working well except that the ethernet interface never comes up. I don't see the link lights and a "dhcp" command results in:
SMC91111: PHY auto-negotiate timed out
*** ERROR: ethaddr is not set properly!!
I compiled u-boot using the integrator cp config file. I have modified it somewhat to include some extra commands but the network portion remains the same. Also, the docs for the board state that the board has a LAN91C111 ethernet chip. Anyone encontered this issue? I did not find anything in list archives.
Regards, umar
Now isn't this is clear hint?!?
Two questions:
1) What does the above error message tell you, and why did you ignore it?
2) Why didn't you try current code?
Two questions:
1) I have tried setting up the MAC address. However that does not fix the problem. Output:
Warning: MAC addresses don't match: HW MAC address: 01:00:01:00:00:00 "ethaddr" value: 00:05:1B:00:10:4A Using MAC Address 00:05:1B:00:10:4A ping failed: host 192.168.168.157 is not alive
I have given the board a static IP address in order to bypass DHCP. Something is funky with the PHY layer because I do not see the link lights so I am not surprised no traffic is traversing the wireline. It looks as if the chip is still in reset.
2) I did download u-boot 1.1.4 but the compilation failed with my arm-linux-gcc 3.4.2 (linked w/ uclibc) compiler. Output:
make[1]: Leaving directory `/home/umar/buildroot/bootloader-arm/u-boot-1.1.4/tools' make -C examples all make[1]: Entering directory `/home/umar/buildroot/bootloader-arm/u-boot-1.1.4/examples' arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x01000000 -I/home/umar/buildroot/bootloader-arm/u-boot-1.1.4/include -fno-builtin -ffreestanding -nostdinc -isystem /home/umar/buildroot/build_arm_nofpu/staging_dir/bin-ccache/../lib/gcc/arm-linux-uclibc/3.4.2/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mabi=apcs-gnu -Wall -Wstrict-prototypes -c -o hello_world.o hello_world.c cc1: error: invalid option `abi=apcs-gnu' make[1]: *** [hello_world.o] Error 1 make[1]: Leaving directory `/home/umar/buildroot/bootloader-arm/u-boot-1.1.4/examples' make: *** [examples] Error 2
Regards, umar
In message 43A9F197.9010603@quartics.com you wrote:
- I have tried setting up the MAC address. However that does not fix
Where is this MAC address coming from? You are aware that this is an address which will NOT work?
Did you see any packets on the wire?
And which one was this?
Given the fact that your hardware MAC address is illegal (has the multicast bit set) you should not be surprised. I'm not sure what your hardware does in such a situation.
I recommend to fix your MAC addresses first.
- I did download u-boot 1.1.4 but the compilation failed with my
Patches have been posted on the list; see the archives.
Code inspection of smc91111.c shows that the driver is reading the MAC address from the ROM, if it detects one.
I did not snoop the line but the link lights are dead. I doubt sniffing packets would reveal much else.
The 'ethaddr' environment variable would override any other MAC address, real or bunk. If the chip is in a reset state then all bets are off as to the values being returned from the ROM. This could explain why the MAC address from the ROM is bad. The chip looks dead. Anyone know if there are certain FPGA settings that might need to be set on the Integrator/CP with ARM926EJS core module to wake up the LAN chip?
I applied the patch but the compiler still puked when compiling cpu/arm926ejs/start.S. It complained:
cc1: invalid option 'abi=apcs-gnu'
So I changed the cpu/arm926ejs/config.mk:
--- config.mk 2005-12-21 18:07:33.773204149 -0800 +++ config.mk.orig 2005-12-21 15:47:45.421844207 -0800 @@ -30,5 +30,5 @@ # Supply options according to compiler version # # ========================================================================= -PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32) +PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32,-mabi=apcs-gnu) PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,))
This got it to compile but 1.1.4 exhibits the same LAN problem.
Regards, umar
Regards, umar
Oops! That patch is backwards. It should be:
--- config.mk.orig 2005-12-21 15:47:45.421844207 -0800 +++ config.mk 2005-12-21 18:07:33.773204149 -0800 @@ -30,5 +30,5 @@ # Supply options according to compiler version # # ========================================================================= -PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32,-mabi=apcs-gnu) +PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32) PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,))
Regards, umar
Umar Qureshey
