[PATCH 1/2] pinctrl: k210: Fix inverted IE and OE for I2C
I2C and SCCB previously shared defaults. However, SCCB needs OE_INV and IE_INV set, but I2C cannot have those bits set. This adds a separate default for SCCB.
Signed-off-by: Sean Anderson seanga2@gmail.com Reported-by: Damien Le Moal Damien.LeMoal@wdc.com ---
drivers/pinctrl/pinctrl-kendryte.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-kendryte.c b/drivers/pinctrl/pinctrl-kendryte.c index 5ad049d955..259a0b507b 100644 --- a/drivers/pinctrl/pinctrl-kendryte.c +++ b/drivers/pinctrl/pinctrl-kendryte.c @@ -55,8 +55,9 @@
#define K210_PC_MODE_IN (K210_PC_IE | K210_PC_ST) #define K210_PC_MODE_OUT (K210_PC_DRIVE_7 | K210_PC_OE) -#define K210_PC_MODE_I2C (K210_PC_MODE_IN | K210_PC_IE_INV | K210_PC_SL | \ - K210_PC_OE | K210_PC_OE_INV | K210_PC_PU) +#define K210_PC_MODE_I2C (K210_PC_MODE_IN | K210_PC_SL | K210_PC_OE | \ + K210_PC_PU) +#define K210_PC_MODE_SCCB (K210_PC_MODE_I2C | K210_PC_OE_INV | K210_PC_IE_INV) #define K210_PC_MODE_SPI (K210_PC_MODE_IN | K210_PC_IE_INV | \ K210_PC_MODE_OUT | K210_PC_OE_INV) #define K210_PC_MODE_GPIO (K210_PC_MODE_IN | K210_PC_MODE_OUT) @@ -189,6 +190,7 @@ static const u32 k210_pc_mode_id_to_mode[] = { [K210_PC_DEFAULT_IN_TIE] = K210_PC_MODE_IN, DEFAULT(OUT), DEFAULT(I2C), + DEFAULT(SCCB), DEFAULT(SPI), DEFAULT(GPIO), [K210_PC_DEFAULT_INT13] = K210_PC_MODE_IN | K210_PC_PU, @@ -362,8 +364,8 @@ static const struct k210_pcf_info k210_pcf_infos[] = { FUNC(DVP_D5, IN), FUNC(DVP_D6, IN), FUNC(DVP_D7, IN), - FUNC(SCCB_SCLK, I2C), - FUNC(SCCB_SDA, I2C), + FUNC(SCCB_SCLK, SCCB), + FUNC(SCCB_SDA, SCCB), FUNC(UART1_CTS, IN), FUNC(UART1_DSR, IN), FUNC(UART1_DCD, IN),
This renames power domains to match the names on the k210 datasheet.
.../pinctrl/kendryte,k210-fpioa.txt | 2 +- drivers/pinctrl/pinctrl-kendryte.c | 10 +++++----- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt b/doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt index 06a9cc060f..73871f5930 100644 --- a/doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt +++ b/doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt @@ -18,7 +18,7 @@ Pin configuration nodes are documented in pinctrl-bindings.txt Required properties for pin-configuration nodes or sub-nodes are: - groups: list of power groups to which the configuration applies. Valid groups are: - A0, A1, A2, B0, B1, B2, C0, C1 + A0, A1, A2, B3, B4, B5, C6, C7 (either this or "pinmux" must be specified) - pinmux: integer array representing pin multiplexing configuration. In addition to the 256 standard functions, each pin can also output the direction diff --git a/drivers/pinctrl/pinctrl-kendryte.c b/drivers/pinctrl/pinctrl-kendryte.c index 259a0b507b..3bdafc1e6b 100644 --- a/drivers/pinctrl/pinctrl-kendryte.c +++ b/drivers/pinctrl/pinctrl-kendryte.c @@ -153,11 +153,11 @@ static const char k210_pc_group_names[][3] = { [0] = "A0", [1] = "A1", [2] = "A2", - [3] = "B0", - [4] = "B1", - [5] = "B2", - [6] = "C0", - [7] = "C1", + [3] = "B3", + [4] = "B4", + [5] = "B5", + [6] = "C6", + [7] = "C7", };
static int k210_pc_get_groups_count(struct udevice *dev)
Reviewed-by: Rick Chen rick@andestech.com
Hi Sean
Please check about the CI failure items: https://travis-ci.org/github/rickchen36/u-boot-riscv/builds/742884254
+drivers/pinctrl/pinctrl-kendryte.c:187:3: error: 'K210_PC_DEFAULT_SCCB' undeclared here (not in a function); did you mean 'K210_PC_DEFAULT_SPI'? 1282+ 187 | [K210_PC_DEFAULT_##mode] = K210_PC_MODE_##mode 1283+ | ^~~~~~~~~~~~~~~~ 1284+drivers/pinctrl/pinctrl-kendryte.c:193:2: note: in expansion of macro 'DEFAULT' 1285+ 193 | DEFAULT(SCCB), 1286+ | ^~~~~~~ 1287+drivers/pinctrl/pinctrl-kendryte.c:187:3: error: array index in initializer not of integer type 1288+drivers/pinctrl/pinctrl-kendryte.c:187:3: note: (near initialization for 'k210_pc_mode_id_to_mode') 1289+make[3]: *** [drivers/pinctrl/pinctrl-kendryte.o] Error 1 1290+make[2]: *** [drivers/pinctrl] Error 2 1291+make[1]: *** [drivers] Error 2 1292+make: *** [sub-make] Error 2 1293 riscv: + sipeed_maix_smode 1294+drivers/pinctrl/pinctrl-kendryte.c:187:3: error: 'K210_PC_DEFAULT_SCCB' undeclared here (not in a function); did you mean 'K210_PC_DEFAULT_SPI'? 1295+ 187 | [K210_PC_DEFAULT_##mode] = K210_PC_MODE_##mode 1296+ | ^~~~~~~~~~~~~~~~ 1297+drivers/pinctrl/pinctrl-kendryte.c:193:2: note: in expansion of macro 'DEFAULT' 1298+ 193 | DEFAULT(SCCB), 1299+ | ^~~~~~~ 1300+drivers/pinctrl/pinctrl-kendryte.c:187:3: error: array index in initializer not of integer type 1301+drivers/pinctrl/pinctrl-kendryte.c:187:3: note: (near initialization for 'k210_pc_mode_id_to_mode') 1302+make[3]: *** [drivers/pinctrl/pinctrl-kendryte.o] Error 1
Thanks, Rick
On 11/13/20 2:19 AM, Rick Chen wrote:
Hi Sean
Thanks, Rick
Ok, should be fixed in v2.
--Sean
Rick Chen
Sean Anderson
