[U-Boot] [PATCH] corenet_ds: Update to use new hwconfig APIs
Hwconfig is called before relocating. Use the new hwconfig APIs.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 15 +++++++++++++-- 1 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c index 5bcf91a..9e00a61 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c @@ -33,6 +33,8 @@
static u32 serdes_prtcl_map;
+#define HWCONFIG_BUFFER_SIZE 128 + #ifdef DEBUG static const char *serdes_prtcl_str[] = { [NONE] = "NA", @@ -277,6 +279,15 @@ void fsl_serdes_init(void) const char *srds_lpd_arg; size_t arglen; #endif + char buffer[HWCONFIG_BUFFER_SIZE]; + char *buf = NULL; + + /* + * Extract hwconfig from environment since we have not properly setup + * the environment but need it for ddr config params + */ + if (getenv_f("hwconfig", buffer, sizeof(buffer)) > 0) + buf = buffer;
/* Is serdes enabled at all? */ if (!(in_be32(&gur->rcwsr[5]) & FSL_CORENET_RCWSR5_SRDS_EN)) @@ -295,8 +306,8 @@ void fsl_serdes_init(void) if (!IS_SVR_REV(get_svr(), 1, 0)) for (bank = 1; bank < ARRAY_SIZE(srds_lpd_b); bank++) { sprintf(srds_lpd_opt, "fsl_srds_lpd_b%u", bank + 1); - srds_lpd_arg = hwconfig_subarg("serdes", srds_lpd_opt, - &arglen); + srds_lpd_arg = hwconfig_subarg_f("serdes", srds_lpd_opt, + &arglen, buf); if (srds_lpd_arg) srds_lpd_b[bank] = simple_strtoul(srds_lpd_arg, NULL, 0);
applied to 85xx
- k
Kumar Gala
York Sun
