[U-Boot] [PATCH] arm: socfpga: Change watchdog timeout
The current current watchdog timeout of 12 seconds is a bit small for booting into Linux, especially when using a NFS based rootfs. So lets change this timeout to a more defensive value of 30 seconds.
Also we now call the hw_watchdog_init() function so that we override the value already configured from the Preloader.
Signed-off-by: Stefan Roese sr@denx.de Cc: Vince Bridgers vbridger@opensource.altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- arch/arm/cpu/armv7/socfpga/misc.c | 9 +++++++++ include/configs/socfpga_common.h | 2 +- 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/socfpga/misc.c b/arch/arm/cpu/armv7/socfpga/misc.c index 73cffd3..ed26645 100644 --- a/arch/arm/cpu/armv7/socfpga/misc.c +++ b/arch/arm/cpu/armv7/socfpga/misc.c @@ -9,6 +9,7 @@ #include <altera.h> #include <miiphy.h> #include <netdev.h> +#include <watchdog.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h> #include <asm/arch/dwmmc.h> @@ -157,6 +158,14 @@ int arch_cpu_init(void) */ #ifndef CONFIG_HW_WATCHDOG socfpga_watchdog_reset(); +#else + /* + * In case the watchdog is enabled, make sure to (re-)configure it + * so that the defined timeout is valid. Otherwise the SPL (Preloader) + * timeout value is still active which might be too short for Linux + * booting. + */ + hw_watchdog_init(); #endif return 0; } diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 6bb9473..6b1f967 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -139,7 +139,7 @@ #define CONFIG_DESIGNWARE_WATCHDOG #define CONFIG_DW_WDT_BASE SOCFPGA_L4WD0_ADDRESS #define CONFIG_DW_WDT_CLOCK_KHZ 25000 -#define CONFIG_HW_WATCHDOG_TIMEOUT_MS 12000 +#define CONFIG_HW_WATCHDOG_TIMEOUT_MS 30000 #endif
Stefan Roese
