[U-Boot] [PATCH] tbs2910: Disable Plan9/RTEMS bootm support
We have once again reached a point where this board does not build in some cases with supported toolchains due to reaching a size constraint. To regain some space, disable support for Plan 9 / RTEMS images with the bootm command.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/tbs2910_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 42e6f58eee19..ba29b7144d6e 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -17,6 +17,8 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " CONFIG_CMD_BOOTZ=y +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set # CONFIG_CMD_FDT is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Stefano Babic
