[PATCH v2 00/10] handling all DM watchdogs in watchdog_reset()
This series is an attempt at expanding the wdt-uclass provided watchdog_reset() to handle all DM watchdogs, not just the first one. As a sort of nice side effect, it turns out that doing that makes wdt-uclass fit better into the uclass model, in that we now do the work that was previously done in the ad hoc initr_watchdog for one device in .pre_probe and .post_probe hooks instead.
It also includes a patch adding a driver for a gpio-petted watchdog device (and a sandbox test of that) - it is included here because that also gives a relatively easy way to have more than one (kind of) watchdog device in the sandbox, which is then used at the end to test that watchdog_reset() behaves as expected.
It's called v2 merely because the gpio driver and associated test has been sent before; all but those two patches (8 and 9) are new. As for the changes in those compared to the first submission, they are mostly cosmetic - functionally, the only change is that it now requires the always-running property in DT.
Rasmus Villemoes (10): watchdog: wdt-uclass.c: use wdt_start() in wdt_expire_now() watchdog: wdt-uclass.c: introduce struct wdt_priv watchdog: wdt-uclass.c: neaten UCLASS_DRIVER definition watchdog: wdt-uclass.c: refactor initr_watchdog() watchdog: wdt-uclass.c: keep track of each device's running state sandbox: disable CONFIG_WATCHDOG_AUTOSTART watchdog: wdt-uclass.c: handle all DM watchdogs in watchdog_reset() watchdog: add gpio watchdog driver sandbox: add test of wdt_gpio driver sandbox: add test of wdt-uclass' watchdog_reset()
arch/sandbox/dts/test.dts | 8 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + .../watchdog/gpio-wdt.txt | 19 +++ drivers/watchdog/Kconfig | 9 + drivers/watchdog/Makefile | 1 + drivers/watchdog/gpio_wdt.c | 69 ++++++++ drivers/watchdog/wdt-uclass.c | 154 +++++++++++------- include/asm-generic/global_data.h | 6 - test/dm/wdt.c | 90 +++++++++- 10 files changed, 298 insertions(+), 62 deletions(-) create mode 100644 doc/device-tree-bindings/watchdog/gpio-wdt.txt create mode 100644 drivers/watchdog/gpio_wdt.c
wdt_start() does the "no ->start? return -ENOSYS" check, don't open-code that in wdt_expire_now().
Also, wdt_start() maintains some global (and later some per-device) state, which would get out of sync with this direct method call - not that it matters much here since the board is supposed to reset very soon.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 2687135296..634428fa24 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -118,10 +118,8 @@ int wdt_expire_now(struct udevice *dev, ulong flags) if (ops->expire_now) { return ops->expire_now(dev, flags); } else { - if (!ops->start) - return -ENOSYS; + ret = wdt_start(dev, 1, flags);
- ret = ops->start(dev, 1, flags); if (ret < 0) return ret;
On Thu, 27 May 2021 at 16:00, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Thanks, Stefan
if (!ops->start)
return -ENOSYS;
if (ret < 0) return ret;ret = ops->start(dev, 1, flags);
Viele Grüße, Stefan
As preparation for having the wdt-uclass provided watchdog_reset() function handle all DM watchdog devices, and not just the first such, introduce a uclass-owned struct to hold the reset_period and next_reset, so these become per-device instead of being static variables.
No functional change intended.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 65 ++++++++++++++++++++++++----------- 1 file changed, 45 insertions(+), 20 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 634428fa24..3b6aa3d586 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -18,15 +18,15 @@ DECLARE_GLOBAL_DATA_PTR;
#define WATCHDOG_TIMEOUT_SECS (CONFIG_WATCHDOG_TIMEOUT_MSECS / 1000)
-/* - * Reset every 1000ms, or however often is required as indicated by a - * hw_margin_ms property. - */ -static ulong reset_period = 1000; +struct wdt_priv { + u32 timeout; + ulong reset_period; + ulong next_reset; +};
int initr_watchdog(void) { - u32 timeout = WATCHDOG_TIMEOUT_SECS; + struct wdt_priv *priv; int ret;
/* @@ -42,28 +42,21 @@ int initr_watchdog(void) return 0; } } - - if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { - timeout = dev_read_u32_default(gd->watchdog_dev, "timeout-sec", - WATCHDOG_TIMEOUT_SECS); - reset_period = dev_read_u32_default(gd->watchdog_dev, - "hw_margin_ms", - 4 * reset_period) / 4; - } + priv = dev_get_uclass_priv(gd->watchdog_dev);
if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) { printf("WDT: Not starting\n"); return 0; }
- ret = wdt_start(gd->watchdog_dev, timeout * 1000, 0); + ret = wdt_start(gd->watchdog_dev, priv->timeout * 1000, 0); if (ret != 0) { printf("WDT: Failed to start\n"); return 0; }
printf("WDT: Started with%s servicing (%ds timeout)\n", - IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", timeout); + IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout);
return 0; } @@ -137,18 +130,21 @@ int wdt_expire_now(struct udevice *dev, ulong flags) */ void watchdog_reset(void) { - static ulong next_reset; + struct wdt_priv *priv; + struct udevice *dev; ulong now;
/* Exit if GD is not ready or watchdog is not initialized yet */ if (!gd || !(gd->flags & GD_FLG_WDT_READY)) return;
+ dev = gd->watchdog_dev; + priv = dev_get_uclass_priv(dev); /* Do not reset the watchdog too often */ now = get_timer(0); - if (time_after_eq(now, next_reset)) { - next_reset = now + reset_period; - wdt_reset(gd->watchdog_dev); + if (time_after_eq(now, priv->next_reset)) { + priv->next_reset = now + priv->reset_period; + wdt_reset(dev); } } #endif @@ -175,9 +171,38 @@ static int wdt_post_bind(struct udevice *dev) return 0; }
+static int wdt_pre_probe(struct udevice *dev) +{ + u32 timeout = WATCHDOG_TIMEOUT_SECS; + /* + * Reset every 1000ms, or however often is required as + * indicated by a hw_margin_ms property. + */ + ulong reset_period = 1000; + struct wdt_priv *priv; + + if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { + timeout = dev_read_u32_default(dev, "timeout-sec", timeout); + reset_period = dev_read_u32_default(dev, "hw_margin_ms", + 4 * reset_period) / 4; + } + priv = dev_get_uclass_priv(dev); + priv->timeout = timeout; + priv->reset_period = reset_period; + /* + * Pretend this device was last reset "long" ago so the first + * watchdog_reset will actually call its ->reset method. + */ + priv->next_reset = get_timer(0); + + return 0; +} + UCLASS_DRIVER(wdt) = { .id = UCLASS_WDT, .name = "watchdog", .flags = DM_UC_FLAG_SEQ_ALIAS, .post_bind = wdt_post_bind, + .pre_probe = wdt_pre_probe, + .per_device_auto = sizeof(struct wdt_priv), };
nit below
- Reset every 1000ms, or however often is required as indicated by a
- hw_margin_ms property.
u32 timeout;
ulong reset_period;
ulong next_reset;
can you comment these?
struct wdt_priv *priv; int ret; /*
"hw_margin_ms",
priv = dev_get_uclass_priv(gd->watchdog_dev); if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) { printf("WDT: Not starting\n"); return 0; }
ret = wdt_start(gd->watchdog_dev, priv->timeout * 1000, 0); if (ret != 0) { printf("WDT: Failed to start\n"); return 0; } printf("WDT: Started with%s servicing (%ds timeout)\n",
IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout); return 0;
struct udevice *dev; ulong now; /* Exit if GD is not ready or watchdog is not initialized yet */ if (!gd || !(gd->flags & GD_FLG_WDT_READY)) return;
wdt_reset(dev); }
2.31.1
- u32 timeout;
- ulong reset_period;
- ulong next_reset;
It's nice to see this static variable finally go away.
Thanks, Stefan
"hw_margin_ms",
return 0; }
- if (time_after_eq(now, priv->next_reset)) {
} } #endifwdt_reset(dev);
- ulong reset_period = 1000;
- struct wdt_priv *priv;
- priv = dev_get_uclass_priv(dev);
- priv->timeout = timeout;
- priv->reset_period = reset_period;
- priv->next_reset = get_timer(0);
- UCLASS_DRIVER(wdt) = { .id = UCLASS_WDT, .name = "watchdog", .flags = DM_UC_FLAG_SEQ_ALIAS, .post_bind = wdt_post_bind,
- .pre_probe = wdt_pre_probe,
- .per_device_auto = sizeof(struct wdt_priv), };
Viele Grüße, Stefan
The addition of .pre_probe and .per_device_auto made this look bad. Fix it.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 3b6aa3d586..360f052227 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -199,10 +199,10 @@ static int wdt_pre_probe(struct udevice *dev) }
UCLASS_DRIVER(wdt) = { - .id = UCLASS_WDT, - .name = "watchdog", - .flags = DM_UC_FLAG_SEQ_ALIAS, - .post_bind = wdt_post_bind, + .id = UCLASS_WDT, + .name = "watchdog", + .flags = DM_UC_FLAG_SEQ_ALIAS, + .post_bind = wdt_post_bind, .pre_probe = wdt_pre_probe, .per_device_auto = sizeof(struct wdt_priv), };
Thanks, Stefan
- .id = UCLASS_WDT,
- .id = UCLASS_WDT,
- .post_bind = wdt_post_bind, .pre_probe = wdt_pre_probe, .per_device_auto = sizeof(struct wdt_priv), };
Viele Grüße, Stefan
In preparation for handling all DM watchdogs in watchdog_reset(), pull out the code which handles starting (or not) the gd->watchdog_dev device.
Include the device name in various printfs.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 37 ++++++++++++++++++++--------------- 1 file changed, 21 insertions(+), 16 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 360f052227..5d5dbcd0f7 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -24,11 +24,30 @@ struct wdt_priv { ulong next_reset; };
-int initr_watchdog(void) +static void init_watchdog_dev(struct udevice *dev) { struct wdt_priv *priv; int ret;
+ priv = dev_get_uclass_priv(dev); + + if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) { + printf("WDT: Not starting %s\n", dev->name); + return; + } + + ret = wdt_start(dev, priv->timeout * 1000, 0); + if (ret != 0) { + printf("WDT: Failed to start %s\n", dev->name); + return; + } + + printf("WDT: Started %s with%s servicing (%ds timeout)\n", dev->name, + IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout); +} + +int initr_watchdog(void) +{ /* * Init watchdog: This will call the probe function of the * watchdog driver, enabling the use of the device @@ -42,21 +61,7 @@ int initr_watchdog(void) return 0; } } - priv = dev_get_uclass_priv(gd->watchdog_dev); - - if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) { - printf("WDT: Not starting\n"); - return 0; - } - - ret = wdt_start(gd->watchdog_dev, priv->timeout * 1000, 0); - if (ret != 0) { - printf("WDT: Failed to start\n"); - return 0; - } - - printf("WDT: Started with%s servicing (%ds timeout)\n", - IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout); + init_watchdog_dev(gd->watchdog_dev);
return 0; }
Thanks, Stefan
return;
- ret = wdt_start(dev, priv->timeout * 1000, 0);
- if (ret != 0) {
return;
- printf("WDT: Started %s with%s servicing (%ds timeout)\n", dev->name,
- if (ret != 0) {
return 0; }
Viele Grüße, Stefan
As a step towards handling all DM watchdogs in watchdog_reset(), use a per-device flag to keep track of whether the device has been started instead of a bit in gd->flags.
We will still need that bit to know whether we are past initr_watchdog() and hence have populated gd->watchdog_dev - incidentally, that is how it was used prior to commit 9c44ff1c5f3c.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 19 +++++++++++++++---- 1 file changed, 15 insertions(+), 4 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 5d5dbcd0f7..026b6d1eb4 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -22,6 +22,7 @@ struct wdt_priv { u32 timeout; ulong reset_period; ulong next_reset; + bool running; };
static void init_watchdog_dev(struct udevice *dev) @@ -63,6 +64,7 @@ int initr_watchdog(void) } init_watchdog_dev(gd->watchdog_dev);
+ gd->flags |= GD_FLG_WDT_READY; return 0; }
@@ -75,8 +77,11 @@ int wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) return -ENOSYS;
ret = ops->start(dev, timeout_ms, flags); - if (ret == 0) - gd->flags |= GD_FLG_WDT_READY; + if (ret == 0) { + struct wdt_priv *priv = dev_get_uclass_priv(dev); + + priv->running = true; + }
return ret; } @@ -90,8 +95,11 @@ int wdt_stop(struct udevice *dev) return -ENOSYS;
ret = ops->stop(dev); - if (ret == 0) - gd->flags &= ~GD_FLG_WDT_READY; + if (ret == 0) { + struct wdt_priv *priv = dev_get_uclass_priv(dev); + + priv->running = false; + }
return ret; } @@ -145,6 +153,9 @@ void watchdog_reset(void)
dev = gd->watchdog_dev; priv = dev_get_uclass_priv(dev); + if (!priv->running) + return; + /* Do not reset the watchdog too often */ now = get_timer(0); if (time_after_eq(now, priv->next_reset)) {
Thanks, Stefan
bool running; };
- gd->flags |= GD_FLG_WDT_READY; return 0; }
- if (ret == 0)
if (ret == 0) {
return ret; }
- if (ret == 0)
if (ret == 0) {
return ret; }
- if (!priv->running)
return;
- /* Do not reset the watchdog too often */ now = get_timer(0); if (time_after_eq(now, priv->next_reset)) {
Viele Grüße, Stefan
A later refactoring will put most of initr_watchdog() into a .post_probe function, which means that all watchdog devices end up being subject to the auto-start functionality. For the unit tests, it is more convenient if the tests are in charge of when the watchdog devices are started and stopped.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 9a373bab6f..8b934698b5 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -223,6 +223,7 @@ CONFIG_OSD=y CONFIG_SANDBOX_OSD=y CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_VIDEO_BMP_RLE8=y +# CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index bdbf714e2b..8911463d58 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -270,6 +270,7 @@ CONFIG_W1=y CONFIG_W1_GPIO=y CONFIG_W1_EEPROM=y CONFIG_W1_EEPROM_SANDBOX=y +# CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y
Thanks, Stefan
Viele Grüße, Stefan
A board can have and make use of more than one watchdog device, say one built into the SOC and an external gpio-petted one. Having wdt-uclass only handle the first is both a little arbitrary and unexpected.
So change initr_watchdog() so we visit (probe) all DM watchdog devices. This essentially boils down to making the init_watchdog_dev function into a .post_probe method.
Similarly let watchdog_reset() loop over the whole uclass - each having their own ratelimiting metadata, and a separate "is this device running" flag.
This gets rid of the watchdog_dev member of struct global_data. We do, however, still need the GD_FLG_WDT_READY set in initr_watchdog(). This is because watchdog_reset() can get called before DM is ready, and I don't think we can call uclass_get() that early.
The current code just returns 0 if "getting" the first device fails - that can of course happen because there are no devices, but it could also happen if its ->probe call failed. In keeping with that, continue with the handling of the remaining devices even if one fails to probe. This is also why we cannot use uclass_probe_all().
If desired, it's possible to later add a per-device "u-boot,autostart" boolean property, so that one can do CONFIG_WATCHDOG_AUTOSTART per-device.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 87 ++++++++++++++++--------------- include/asm-generic/global_data.h | 6 --- 2 files changed, 46 insertions(+), 47 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 026b6d1eb4..e062a75574 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -25,44 +25,20 @@ struct wdt_priv { bool running; };
-static void init_watchdog_dev(struct udevice *dev) +int initr_watchdog(void) { - struct wdt_priv *priv; + struct udevice *dev; + struct uclass *uc; int ret;
- priv = dev_get_uclass_priv(dev); - - if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) { - printf("WDT: Not starting %s\n", dev->name); - return; - } - - ret = wdt_start(dev, priv->timeout * 1000, 0); - if (ret != 0) { - printf("WDT: Failed to start %s\n", dev->name); - return; + ret = uclass_get(UCLASS_WDT, &uc); + if (ret) { + printf("Error getting UCLASS_WDT: %d\n", ret); + return 0; }
- printf("WDT: Started %s with%s servicing (%ds timeout)\n", dev->name, - IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout); -} - -int initr_watchdog(void) -{ - /* - * Init watchdog: This will call the probe function of the - * watchdog driver, enabling the use of the device - */ - if (uclass_get_device_by_seq(UCLASS_WDT, 0, - (struct udevice **)&gd->watchdog_dev)) { - debug("WDT: Not found by seq!\n"); - if (uclass_get_device(UCLASS_WDT, 0, - (struct udevice **)&gd->watchdog_dev)) { - printf("WDT: Not found!\n"); - return 0; - } - } - init_watchdog_dev(gd->watchdog_dev); + uclass_foreach_dev(dev, uc) + device_probe(dev);
gd->flags |= GD_FLG_WDT_READY; return 0; @@ -145,22 +121,26 @@ void watchdog_reset(void) { struct wdt_priv *priv; struct udevice *dev; + struct uclass *uc; ulong now;
- dev = gd->watchdog_dev; - priv = dev_get_uclass_priv(dev); - if (!priv->running) + if (uclass_get(UCLASS_WDT, &uc)) return;
- /* Do not reset the watchdog too often */ - now = get_timer(0); - if (time_after_eq(now, priv->next_reset)) { - priv->next_reset = now + priv->reset_period; - wdt_reset(dev); + uclass_foreach_dev(dev, uc) { + priv = dev_get_uclass_priv(dev); + if (!priv->running) + continue; + /* Do not reset the watchdog too often */ + now = get_timer(0); + if (time_after_eq(now, priv->next_reset)) { + priv->next_reset = now + priv->reset_period; + wdt_reset(dev); + } } } #endif @@ -214,11 +194,36 @@ static int wdt_pre_probe(struct udevice *dev) return 0; }
+static int wdt_post_probe(struct udevice *dev) +{ + struct wdt_priv *priv; + int ret; + + priv = dev_get_uclass_priv(dev); + + if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) { + printf("WDT: Not starting %s\n", dev->name); + return 0; + } + + ret = wdt_start(dev, priv->timeout * 1000, 0); + if (ret != 0) { + printf("WDT: Failed to start %s\n", dev->name); + return 0; + } + + printf("WDT: Started %s with%s servicing (%ds timeout)\n", dev->name, + IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout); + + return 0; +} + UCLASS_DRIVER(wdt) = { .id = UCLASS_WDT, .name = "watchdog", .flags = DM_UC_FLAG_SEQ_ALIAS, .post_bind = wdt_post_bind, .pre_probe = wdt_pre_probe, + .post_probe = wdt_post_probe, .per_device_auto = sizeof(struct wdt_priv), }; diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 47921d27b1..b554016628 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -445,12 +445,6 @@ struct global_data { */ fdt_addr_t translation_offset; #endif -#if CONFIG_IS_ENABLED(WDT) - /** - * @watchdog_dev: watchdog device - */ - struct udevice *watchdog_dev; -#endif #ifdef CONFIG_GENERATE_ACPI_TABLE /** * @acpi_ctx: ACPI context pointer
Hi Rasmus,
return;
if (ret != 0) {
return;
if (ret) {
log_debug()as this should not happen
Should return error here
device_probe(dev);
If watchdog fails, should we not stop? Even if we don't, I think some sort of message should be shown so people know to fix it.
struct uclass *uc; ulong now; /* Exit if GD is not ready or watchdog is not initialized yet */ if (!gd || !(gd->flags & GD_FLG_WDT_READY)) return;
if (!priv->running)
now = get_timer(0);
wdt_reset(dev);
Don't you need to use foreach_dev_probe() ?
if (!priv->running)
continue;
now = get_timer(0);
wdt_reset(dev);
int ret;
log_debug()
if (ret != 0) {
log_debug()
I don't think it is good to start it in the post-probe. Can you do it separately, afterwards? Probing is supposed to just probe it and it should be safe to do that without side effects.
log_debug() I think
-#endif #ifdef CONFIG_GENERATE_ACPI_TABLE /** * @acpi_ctx: ACPI context pointer -- 2.31.1
Hi Simon,
Thanks for review.
return;
if (ret != 0) {
return;
if (ret) {
OK. [I assume the rationale is: don't add .text which will most likely never be used, but allow the debug statements to be easily turned on per-TU if one should ever need it.]
And have the initr sequence stop completely instead of trying to limp along? Why? Note that I touched upon this in the commit message: The existing code doesn't pass on an error from uclass_get_device*() [which would most likely come from an underlying probe call], and returns 0 regardless from initr_watchdog(). I see no point changing that.
device_probe(dev);
I'd assume device_probe() would print an error message. If not, sure, I can add some [log_debug?] message.
if (!priv->running)
now = get_timer(0);
wdt_reset(dev);
Why? They've all been probed in initr_watchdog(). And the guts of WATHCDOG_RESET(), which can be and is called from everywhere, is certainly not the place to do anything other than actually pinging the watchdog devices.
int ret;
log_debug()
Perhaps, but this is just existing code I've moved around.
if (ret != 0) {
log_debug()
Ditto.
Eh, yes, of course I could do this in the loop in initr_watchdog() where I probe all watchdog devices, but the end result is exactly the same, and it seemed that this was a perfect fit for DM since it provided this post_probe hook. It's a no-op if CONFIG_WATCHDOG_AUTOSTART isn't set, and if it is, that precisely means the developer wanted to start handling the device(s) ASAP.
I agree in general, but watchdog devices are a bit special compared to some random USB controller or LCD display or spi master - those devices generally don't do anything unless asked to by the CPU, while a watchdog device is the other way around, it does its thing _unless_ the CPU asks it not to (often enough). Which in turn, I suppose, is the whole reason wdt-uclass has its own hook into the initr sequence - one needs to probe and possibly start handling the watchdog(s) ASAP.
BTW, next on my agenda is hooking in even earlier so the few boards that use INIT_FUNC_WATCHDOG_INIT/INIT_FUNC_WATCHDOG_RESET can just use DM and be done with it - having those INIT_FUNC_WATCHDOG_RESET in completely random places in init_sequence_f[] is a bit silly.
log_debug() I think
Ditto, existing code moved around.
Thanks, Rasmus
On 22.06.21 22:28, Rasmus Villemoes wrote:
Hi Simon,
Thanks for review.
return;
if (ret != 0) {
return;
if (ret) {
device_probe(dev);
if (!priv->running)
now = get_timer(0);
wdt_reset(dev);
int ret;
log_debug()
I would prefer to not change (remove) the currently existing output of the status of the watchdog driver. If necessary, it could be changed to log_info().
if (ret != 0) {
log_debug()
Ditto.
Nice.
log_debug() I think
Again, please don't change this to debug level.
Thanks, Stefan
Hi Rasmus,
On Tue, 22 Jun 2021 at 14:28, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Hi Simon,
Thanks for review.
return;
if (ret != 0) {
return;
if (ret) {
Yes, also the error return value should give you a clue.
Please, use log_msg_ret() on your return values.
OK, I'll leave it to you. My feeling is that failure is a good way to get a bug fixed.
device_probe(dev);
No driver model never prints messages. Yes you can use log_debuig().
if (!priv->running)
now = get_timer(0);
wdt_reset(dev);
Then you should add a comment. You are using a low-level iterator, then assuming the devices are probed.
int ret;
log_debug()
OK, well then you can leave it alone.
if (ret != 0) {
log_debug()
Ditto.
It still needs a 'start' method to make it start. Having it start on probe means the board will reset at the command line if the device is probed. Yuck.
OK.
log_debug() I think
OK.
On 26/06/2021 20.32, Simon Glass wrote:
Hi Rasmus,
No, because while sitting in the command line waiting for user input, WATCHDOG_RESET() is called something like a million times per second (or at least extremely often). For the most common case of there only being one (or zero) DM watchdogs, I'm not changing anything at all about how things behave. I'm just expanding the handling done in the wdt-uclass provided functions initr_watchdog() and watchdog_reset() to all DM watchdogs, making things more consistent. And there's CONFIG_WATCHDOG_AUTOSTART=n which as before would make the post_probe function into a no-op.
As I said, yes, I can move the call of the post_probe function into the loop in initr_watchdog (and then it wouldn't be called post_probe, but probably named something including auto_start). In practice, that won't change anything.
Stefan, what do you think? I think this is the only contentious point at this time, so I'll do whatever you think is right, then resend the patches with Simon's other feedback incorporated.
Rasmus
Hi Rasmus,
We have some rate-limiting in place since a few years (reset_period).
I'm fine with this post_probe() implementation but have no strong feelings about this. So if Simon (or someone else) does not object, then please continue this way.
Thanks, Stefan
Hi Rasmus,
On Mon, 28 Jun 2021 at 01:44, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Hi Rasmus,
From a driver model perspective, it is good practice to have a 'start'
method separate from probing. I understand that you are saying that the watchdog should always be enabled, but we can handle that with a separate method to start it. I don't think it needs to be started in the post-probe method. We can just start it later. Imagine you probe the device but then go into SDRAM init that hangs the CPU for a few seconds. We need a way to signal that we want the watchdog to start, so the board owner has a choice as to when this happens.
I also understand this is not quite how things work at present and I'm fine with copying the existing behaviour. It's just that you are introducing a driver model interface and I have pretty strong views about the separation between probe at start, with that.
A rather common kind of external watchdog circuit is one that is kept alive by toggling a gpio. Add a driver for handling such a watchdog.
The corresponding linux driver apparently has support for some watchdog circuits which can be disabled by tri-stating the gpio, but I have never actually encountered such a chip in the wild; the whole point of adding an external watchdog is usually that it is not in any way under software control. For forward-compatibility, and to make DT describe the hardware, the current driver only supports devices that have the always-running property. I went a little back and forth on whether I should fail ->probe or only ->start, and ended up deciding ->start was the right place.
The compatible string is probably a little odd as it has nothing to do with linux per se - however, I chose that to make .dts snippets reusable between device trees used with U-Boot and linux, and this is the (only) compatible string that linux' corresponding driver and DT binding accepts. I have asked whether one should/could add "wdt-gpio" to that binding, but the answer was no:
https://lore.kernel.org/lkml/CAL_JsqKEGaFpiFV_oAtE+S_bnHkg4qry+bhx2EDs=NSbVf...
If someone feels strongly about this, I can certainly remove the "linux," part from the string - it probably wouldn't the only place where one can't reuse a DT snippet as-is between linux and U-Boot.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- .../watchdog/gpio-wdt.txt | 19 +++++ drivers/watchdog/Kconfig | 9 +++ drivers/watchdog/Makefile | 1 + drivers/watchdog/gpio_wdt.c | 69 +++++++++++++++++++ 4 files changed, 98 insertions(+) create mode 100644 doc/device-tree-bindings/watchdog/gpio-wdt.txt create mode 100644 drivers/watchdog/gpio_wdt.c
diff --git a/doc/device-tree-bindings/watchdog/gpio-wdt.txt b/doc/device-tree-bindings/watchdog/gpio-wdt.txt new file mode 100644 index 0000000000..c9a8559a3e --- /dev/null +++ b/doc/device-tree-bindings/watchdog/gpio-wdt.txt @@ -0,0 +1,19 @@ +GPIO watchdog timer + +Describes a simple watchdog timer which is reset by toggling a gpio. + +Required properties: + +- compatible: Must be "linux,wdt-gpio". +- gpios: gpio to toggle when wdt driver reset method is called. +- always-running: Boolean property indicating that the watchdog cannot + be disabled. At present, U-Boot only supports this kind of GPIO + watchdog. + +Example: + + gpio-wdt { + gpios = <&gpio0 1 0>; + compatible = "linux,wdt-gpio"; + always-running; + }; diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index f0ff2612a6..6fbb5c1b6d 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -147,6 +147,15 @@ config WDT_CORTINA This driver support all CPU ISAs supported by Cortina Access CAxxxx SoCs.
+config WDT_GPIO + bool "External gpio watchdog support" + depends on WDT + depends on DM_GPIO + help + Support for external watchdog fed by toggling a gpio. See + doc/device-tree-bindings/watchdog/gpio-wdt.txt for + information on how to describe the watchdog in device tree. + config WDT_MPC8xx bool "MPC8xx watchdog timer support" depends on WDT && MPC8xx diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 5c7ef593fe..f14415bb8e 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_WDT_BOOKE) += booke_wdt.o obj-$(CONFIG_WDT_CORTINA) += cortina_wdt.o obj-$(CONFIG_WDT_ORION) += orion_wdt.o obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o +obj-$(CONFIG_WDT_GPIO) += gpio_wdt.o obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o obj-$(CONFIG_WDT_MT7620) += mt7620_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o diff --git a/drivers/watchdog/gpio_wdt.c b/drivers/watchdog/gpio_wdt.c new file mode 100644 index 0000000000..091af1d36e --- /dev/null +++ b/drivers/watchdog/gpio_wdt.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <wdt.h> +#include <asm/gpio.h> + +struct gpio_wdt_priv { + struct gpio_desc gpio; + bool always_running; + int state; +}; + +static int gpio_wdt_reset(struct udevice *dev) +{ + struct gpio_wdt_priv *priv = dev_get_priv(dev); + + priv->state = !priv->state; + + return dm_gpio_set_value(&priv->gpio, priv->state); +} + +static int gpio_wdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct gpio_wdt_priv *priv = dev_get_priv(dev); + + if (priv->always_running) + return 0; + + return -ENOSYS; +} + +static int dm_probe(struct udevice *dev) +{ + struct gpio_wdt_priv *priv = dev_get_priv(dev); + int ret; + + priv->always_running = dev_read_bool(dev, "always-running"); + ret = gpio_request_by_name(dev, "gpios", 0, &priv->gpio, GPIOD_IS_OUT); + if (ret < 0) { + dev_err(dev, "Request for wdt gpio failed: %d\n", ret); + return ret; + } + + if (priv->always_running) + ret = gpio_wdt_reset(dev); + + return ret; +} + +static const struct wdt_ops gpio_wdt_ops = { + .start = gpio_wdt_start, + .reset = gpio_wdt_reset, +}; + +static const struct udevice_id gpio_wdt_ids[] = { + { .compatible = "linux,wdt-gpio" }, + {} +}; + +U_BOOT_DRIVER(wdt_gpio) = { + .name = "wdt_gpio", + .id = UCLASS_WDT, + .of_match = gpio_wdt_ids, + .ops = &gpio_wdt_ops, + .probe = dm_probe, + .priv_auto = sizeof(struct gpio_wdt_priv), +};
- be disabled. At present, U-Boot only supports this kind of GPIO
- watchdog.
+Example:
- gpio-wdt {
always-running;
+config WDT_GPIO
- bool "External gpio watchdog support"
- depends on WDT
- depends on DM_GPIO
- help
- config WDT_MPC8xx bool "MPC8xx watchdog timer support" depends on WDT && MPC8xx
AFAIK, including "common.h" is deprecated. Other than this:
Thanks, Stefan
- struct gpio_desc gpio;
- bool always_running;
- int state;
- struct gpio_wdt_priv *priv = dev_get_priv(dev);
- priv->state = !priv->state;
- return dm_gpio_set_value(&priv->gpio, priv->state);
- if (priv->always_running)
- return -ENOSYS;
- int ret;
- priv->always_running = dev_read_bool(dev, "always-running");
- ret = gpio_request_by_name(dev, "gpios", 0, &priv->gpio, GPIOD_IS_OUT);
- if (ret < 0) {
return ret;
- return ret;
- .start = gpio_wdt_start,
- .reset = gpio_wdt_reset,
- { .compatible = "linux,wdt-gpio" },
- .name = "wdt_gpio",
- .id = UCLASS_WDT,
- .of_match = gpio_wdt_ids,
- .ops = &gpio_wdt_ops,
- .probe = dm_probe,
- .priv_auto = sizeof(struct gpio_wdt_priv),
Viele Grüße, Stefan
It seems that no other test has claimed gpio_a:7 yet, so use that.
The only small wrinkle is modifying the existing wdt test to use uclass_get_device_by_driver() since we now have two UCLASS_WDT instances in play, so it's a little more robust to fetch the device by driver and not merely uclass+index.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/sandbox/dts/test.dts | 6 ++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + test/dm/wdt.c | 36 +++++++++++++++++++++++++++++++++++- 4 files changed, 43 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 5ca3bc502a..cee5b14ecb 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -755,6 +755,12 @@ }; };
+ gpio-wdt { + gpios = <&gpio_a 7 0>; + compatible = "linux,wdt-gpio"; + always-running; + }; + mbox: mbox { compatible = "sandbox,mbox"; #mbox-cells = <1>; diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 8b934698b5..3e4ee6e8e1 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -225,6 +225,7 @@ CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_VIDEO_BMP_RLE8=y # CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y +CONFIG_WDT_GPIO=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 8911463d58..faea4d763c 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -272,6 +272,7 @@ CONFIG_W1_EEPROM=y CONFIG_W1_EEPROM_SANDBOX=y # CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y +CONFIG_WDT_GPIO=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y diff --git a/test/dm/wdt.c b/test/dm/wdt.c index 24b991dff6..abff853a02 100644 --- a/test/dm/wdt.c +++ b/test/dm/wdt.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <wdt.h> +#include <asm/gpio.h> #include <asm/state.h> #include <asm/test.h> #include <dm/test.h> @@ -19,7 +20,8 @@ static int dm_test_wdt_base(struct unit_test_state *uts) struct udevice *dev; const u64 timeout = 42;
- ut_assertok(uclass_get_device(UCLASS_WDT, 0, &dev)); + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_sandbox), &dev)); ut_assertnonnull(dev); ut_asserteq(0, state->wdt.counter); ut_asserteq(false, state->wdt.running); @@ -39,3 +41,35 @@ static int dm_test_wdt_base(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_wdt_base, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +static int dm_test_wdt_gpio(struct unit_test_state *uts) +{ + /* + * The sandbox wdt gpio is "connected" to gpio bank a, offset + * 7. Use the sandbox back door to verify that the gpio-wdt + * driver behaves as expected. + */ + struct udevice *wdt, *gpio; + const u64 timeout = 42; + const int offset = 7; + int val; + + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_gpio), &wdt)); + ut_assertnonnull(wdt); + + ut_assertok(uclass_get_device_by_name(UCLASS_GPIO, "base-gpios", &gpio)); + ut_assertnonnull(gpio); + ut_assertok(wdt_start(wdt, timeout, 0)); + + val = sandbox_gpio_get_value(gpio, offset); + ut_assertok(wdt_reset(wdt)); + ut_asserteq(!val, sandbox_gpio_get_value(gpio, offset)); + ut_assertok(wdt_reset(wdt)); + ut_asserteq(val, sandbox_gpio_get_value(gpio, offset)); + + ut_asserteq(-ENOSYS, wdt_stop(wdt)); + + return 0; +} +DM_TEST(dm_test_wdt_gpio, UT_TESTF_SCAN_FDT);
(you could get the device by alias also, I suppose)
Thanks, Stefan
- gpio-wdt {
always-running;
- mbox: mbox { compatible = "sandbox,mbox"; #mbox-cells = <1>;
- ut_assertok(uclass_get_device_by_driver(UCLASS_WDT,
ut_assertnonnull(dev); ut_asserteq(0, state->wdt.counter); ut_asserteq(false, state->wdt.running);DM_DRIVER_GET(wdt_sandbox), &dev));
- struct udevice *wdt, *gpio;
- const u64 timeout = 42;
- const int offset = 7;
- int val;
- ut_assertnonnull(wdt);
- ut_assertok(uclass_get_device_by_name(UCLASS_GPIO, "base-gpios", &gpio));
- ut_assertnonnull(gpio);
- ut_assertok(wdt_start(wdt, timeout, 0));
- val = sandbox_gpio_get_value(gpio, offset);
- ut_assertok(wdt_reset(wdt));
- ut_asserteq(!val, sandbox_gpio_get_value(gpio, offset));
- ut_asserteq(val, sandbox_gpio_get_value(gpio, offset));
- ut_asserteq(-ENOSYS, wdt_stop(wdt));
Viele Grüße, Stefan
Check that the watchdog_reset() implementation in wdt-uclass behaves as expected:
- resets all activated watchdog devices - leaves unactivated/stopped devices alone - that the rate-limiting works, with a per-device threshold
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/sandbox/dts/test.dts | 2 ++ test/dm/wdt.c | 54 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 56 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index cee5b14ecb..1853b5f29a 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -758,6 +758,7 @@ gpio-wdt { gpios = <&gpio_a 7 0>; compatible = "linux,wdt-gpio"; + hw_margin_ms = <100>; always-running; };
@@ -1239,6 +1240,7 @@
wdt0: wdt@0 { compatible = "sandbox,wdt"; + hw_margin_ms = <200>; };
axi: axi@0 { diff --git a/test/dm/wdt.c b/test/dm/wdt.c index abff853a02..8997aaebc8 100644 --- a/test/dm/wdt.c +++ b/test/dm/wdt.c @@ -12,6 +12,8 @@ #include <dm/test.h> #include <test/test.h> #include <test/ut.h> +#include <linux/delay.h> +#include <watchdog.h>
/* Test that watchdog driver functions are called */ static int dm_test_wdt_base(struct unit_test_state *uts) @@ -73,3 +75,55 @@ static int dm_test_wdt_gpio(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_wdt_gpio, UT_TESTF_SCAN_FDT); + +static int dm_test_wdt_watchdog_reset(struct unit_test_state *uts) +{ + struct sandbox_state *state = state_get_current(); + struct udevice *gpio_wdt, *sandbox_wdt; + struct udevice *gpio; + const u64 timeout = 42; + const int offset = 7; + uint reset_count; + int val; + + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_gpio), &gpio_wdt)); + ut_assertnonnull(gpio_wdt); + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_sandbox), &sandbox_wdt)); + ut_assertnonnull(sandbox_wdt); + ut_assertok(uclass_get_device_by_name(UCLASS_GPIO, "base-gpios", &gpio)); + ut_assertnonnull(gpio); + + /* Neither device should be "started", so watchdog_reset() should be a no-op. */ + reset_count = state->wdt.reset_count; + val = sandbox_gpio_get_value(gpio, offset); + watchdog_reset(); + ut_asserteq(reset_count, state->wdt.reset_count); + ut_asserteq(val, sandbox_gpio_get_value(gpio, offset)); + + /* Start both devices. */ + ut_assertok(wdt_start(gpio_wdt, timeout, 0)); + ut_assertok(wdt_start(sandbox_wdt, timeout, 0)); + + /* Make sure both devices have just been pinged. */ + mdelay(100); + watchdog_reset(); + reset_count = state->wdt.reset_count; + val = sandbox_gpio_get_value(gpio, offset); + + /* The gpio watchdog should be pinged, the sandbox one not. */ + mdelay(30); + watchdog_reset(); + ut_asserteq(reset_count, state->wdt.reset_count); + ut_asserteq(!val, sandbox_gpio_get_value(gpio, offset)); + + /* After another ~30ms, both devices should get pinged. */ + mdelay(30); + watchdog_reset(); + ut_asserteq(reset_count + 1, state->wdt.reset_count); + ut_asserteq(val, sandbox_gpio_get_value(gpio, offset)); + + return 0; +} +DM_TEST(dm_test_wdt_watchdog_reset, UT_TESTF_SCAN_FDT);
I'd prefer to advance time though, rather than using mdelay().
Cool, I didn't know we could do that in sandbox. Have a pointer?
Thanks, Rasmus
Hi Rasmus,
On Tue, 22 Jun 2021 at 14:29, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
You can do anything in sandbox. It is just software :-)
See timer_test_add_offset()
Thanks, Stefan
always-running; };hw_margin_ms = <100>;
axi: axi@0 {
- struct sandbox_state *state = state_get_current();
- struct udevice *gpio_wdt, *sandbox_wdt;
- struct udevice *gpio;
- uint reset_count;
- int val;
- ut_assertnonnull(gpio_wdt);
- ut_assertnonnull(sandbox_wdt);
- /* Neither device should be "started", so watchdog_reset() should be a no-op. */
- reset_count = state->wdt.reset_count;
- watchdog_reset();
- ut_asserteq(reset_count, state->wdt.reset_count);
- /* Start both devices. */
- ut_assertok(wdt_start(gpio_wdt, timeout, 0));
- ut_assertok(wdt_start(sandbox_wdt, timeout, 0));
- /* Make sure both devices have just been pinged. */
- mdelay(100);
- watchdog_reset();
- /* The gpio watchdog should be pinged, the sandbox one not. */
- mdelay(30);
- watchdog_reset();
- /* After another ~30ms, both devices should get pinged. */
- mdelay(30);
- watchdog_reset();
- ut_asserteq(reset_count + 1, state->wdt.reset_count);
Viele Grüße, Stefan
Ping.
Hi Rasmus,
Ping.
It's on my list to review. I've postponed this a bit, since these changes will definitely not make it into the upcoming v2021.07 release.
Thanks, Stefan
Rasmus Villemoes
Stefan Roese
