[U-Boot] [PATCH 0/3] iMX31: Add iMX31 support to boots from NAND
This serie of patches adds support to iMX31PDK board to boot directly from NAND. Notice these patches don't add support to MTD NAND Flash support to U-Boot (like reading and saving environment parameters in Flash because MTD NAND Flash driver still needs further revision).
For people willing to test it follow these simple steps:
Create a local copy of u-boot-arm/testing: $ git clone git://git.denx.de/u-boot-arm-next.git u-boot-arm $ cd u-boot-arm $ git checkout -b local_test origin/testing
Apply patches: $ patch -p1 < ../0001-iMX31-Reducing-start.S-size-to-let-boot-from-NAND.patch $ patch -p1 < ../0002-iMX31-Add-support-to-copy-NAND-Flash-code-to-RAM.patch $ patch -p1 < ../0003-iMX31-Add-support-to-iMX31PDK-board-and-let-it-boot.patch
Set up your cross-compile (we are using one from LTIB): $ export PATH="$PATH:/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/" $ export CROSS_COMPILE=arm-none-linux-gnueabi-
Compile U-Boot to iMX31PDK board: $ make mx31pdk_config $ make
Flash u-boot.bin to NAND flash (we are using ATK to do that)es doesn't add U-Boot support to erase/write on NAND.
These patches will be applied against u-boot-arm/testing, against Magnus Lilja patches.
Thanks to Kenneth Johansson about the idea to reduce start.S size.
Thanks very much to Magnus Lilja and Fabio Estevam for all the help testing these patches.
Alan Carvalho de Assis
