[PATCH] arm: dts: stm32mp1: Drop fastboot and stm32prog trigger gpios on DHCOM
PA13 and PA14 are used for USB power control and can't be used to enforce fastboot or stm32prog mode by pressing a button.
Defining CONFIG_FASTBOOT/CONFIG_CMD_STM32PROG without this patch applied results in fastboot/stm32prog always starting, because PA13/PA14 are always low during boot. So drop the wrong trigger gpios definitions.
Signed-off-by: Johann Neuhauser jneuhauser@dh-electronics.com
arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi index d73967ac1b5d..ee747a52bb7c 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi @@ -27,8 +27,6 @@ config { u-boot,boot-led = "heartbeat"; u-boot,error-led = "error"; - st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; - st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; dh,som-coding-gpios = <&gpiof 12 0>, <&gpiof 13 0>, <&gpiof 15 0>; dh,ddr3-coding-gpios = <&gpioz 6 0>, <&gpioz 7 0>; };
Those GPIOs also likely make no sense on DHCOM , right ?
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, June 30, 2022 5:20 PM
They would only make sense on the DHCOM PDK2, since this is the only mainline baseboard with user buttons available in U-Boot.
dh,som-coding-gpios = <&gpiof 12 0>, <&gpiof 13 0>, <&gpiof 15 0>; dh,ddr3-coding-gpios = <&gpioz 6 0>, <&gpioz 7 0>; };st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>;
The support of these buttons GPIO A13 and A14 have be done for ST boards EVx and DKx;
it is an internal request for Android support on top of OpenSTLinux.
and make no sense on DHCOM STM32MP15
USB_PWR_STAT USB Host over current indicator (active low) 174 I PA14 - USB_PWR_EN USB Host power enable signal (active low) 176 O PA13 -
moreover, if you never use these properies "st,fastboot-gpios" and "st,stm32prog-gpios" on DH boards,
you can also clean the code in board/dhelectronics/dh_stm32mp1/board.c, board_key_check() can be removed.
=> it is called board_init()
This code was initially copied from 'board/st/stm32mp1/stm32mp1.c'
but after your patch I think it is not needed.
Anyway for this device tree patch
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Applied to stm32/master, thanks!
[1/1] arm: dts: stm32mp1: Drop fastboot and stm32prog trigger gpios on DHCOM commit: 48d9eaf6826a1816c5f9839a564ea6338da609a7
Johann Neuhauser
Patrick DELAUNAY
Patrick Delaunay
