[U-Boot] [PATCH v3 1/2] common: Add support for Android DT image
Android documentation recommends new image format for storing DTB/DTBO files: [1]. To support that format, this patch adds helper functions for Android DTB/DTBO format. In image-android-dt.* files you can find helper functions to work with Android DT image format, such us routines for: - printing the dump of image structure - getting the address and size of desired dtb/dtbo file
This patch uses dt_table.h file, that was added in 643cefa4d848 ("Import Android's dt_table.h for DT image format") by Alex Deymo.
[1] https://source.android.com/devices/architecture/dto/partitions
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- Changes in v3: - dropped include/dt_image.h (was sent in another patch by Alex Deymo) - rebased on top of last master
common/image-android-dt.c | 157 +++++++++++++++++++++++++++++++++++++ include/image-android-dt.h | 21 +++++ 2 files changed, 178 insertions(+) create mode 100644 common/image-android-dt.c create mode 100644 include/image-android-dt.h
diff --git a/common/image-android-dt.c b/common/image-android-dt.c new file mode 100644 index 0000000000..9b7683faab --- /dev/null +++ b/common/image-android-dt.c @@ -0,0 +1,157 @@ +/* + * (C) Copyright 2018 Linaro Ltd. + * Sam Protsenko semen.protsenko@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <image-android-dt.h> +#include <dt_table.h> +#include <common.h> +#include <linux/libfdt.h> +#include <mapmem.h> + +/** + * Check if image header is correct. + * + * @param hdr_addr Start address of DT image + * @return true if header is correct or false if header is incorrect + */ +bool android_dt_check_header(ulong hdr_addr) +{ + const struct dt_table_header *hdr; + u32 magic; + + hdr = map_sysmem(hdr_addr, sizeof(*hdr)); + magic = fdt32_to_cpu(hdr->magic); + unmap_sysmem(hdr); + + return magic == DT_TABLE_MAGIC; +} + +/** + * Get the address of FDT (dtb or dtbo) in memory by its index in image. + * + * @param hdr_addr Start address of DT image + * @param index Index of desired FDT in image (starting from 0) + * @param[out] addr If not NULL, will contain address to specified FDT + * @param[out] size If not NULL, will contain size of specified FDT + * + * @return true on success or false on error + */ +bool android_dt_get_fdt_by_index(ulong hdr_addr, u32 index, ulong *addr, + u32 *size) +{ + const struct dt_table_header *hdr; + const struct dt_table_entry *e; + u32 entry_count, entries_offset, entry_size; + ulong e_addr; + u32 dt_offset, dt_size; + + hdr = map_sysmem(hdr_addr, sizeof(*hdr)); + entry_count = fdt32_to_cpu(hdr->dt_entry_count); + entries_offset = fdt32_to_cpu(hdr->dt_entries_offset); + entry_size = fdt32_to_cpu(hdr->dt_entry_size); + unmap_sysmem(hdr); + + if (index > entry_count) { + printf("Error: index > dt_entry_count (%u > %u)\n", index, + entry_count); + return false; + } + + e_addr = hdr_addr + entries_offset + index * entry_size; + e = map_sysmem(e_addr, sizeof(*e)); + dt_offset = fdt32_to_cpu(e->dt_offset); + dt_size = fdt32_to_cpu(e->dt_size); + unmap_sysmem(e); + + if (addr) + *addr = hdr_addr + dt_offset; + if (size) + *size = dt_size; + + return true; +} + +#if !defined(CONFIG_SPL_BUILD) +static void android_dt_print_fdt_info(const struct fdt_header *fdt) +{ + u32 fdt_size; + int root_node_off; + const char *compatible = NULL; + + fdt_size = fdt_totalsize(fdt); + root_node_off = fdt_path_offset(fdt, "/"); + if (root_node_off < 0) { + printf("Error: Root node not found\n"); + } else { + compatible = fdt_getprop(fdt, root_node_off, "compatible", + NULL); + } + + printf(" (FDT)size = %d\n", fdt_size); + printf(" (FDT)compatible = %s\n", + compatible ? compatible : "(unknown)"); +} + +/** + * Print information about DT image structure. + * + * @param hdr_addr Start address of DT image + */ +void android_dt_print_contents(ulong hdr_addr) +{ + const struct dt_table_header *hdr; + u32 entry_count, entries_offset, entry_size; + u32 i; + + hdr = map_sysmem(hdr_addr, sizeof(*hdr)); + entry_count = fdt32_to_cpu(hdr->dt_entry_count); + entries_offset = fdt32_to_cpu(hdr->dt_entries_offset); + entry_size = fdt32_to_cpu(hdr->dt_entry_size); + + /* Print image header info */ + printf("dt_table_header:\n"); + printf(" magic = %08x\n", fdt32_to_cpu(hdr->magic)); + printf(" total_size = %d\n", fdt32_to_cpu(hdr->total_size)); + printf(" header_size = %d\n", fdt32_to_cpu(hdr->header_size)); + printf(" dt_entry_size = %d\n", entry_size); + printf(" dt_entry_count = %d\n", entry_count); + printf(" dt_entries_offset = %d\n", entries_offset); + printf(" page_size = %d\n", fdt32_to_cpu(hdr->page_size)); + printf(" reserved[0] = %08x\n", fdt32_to_cpu(hdr->reserved[0])); + + unmap_sysmem(hdr); + + /* Print image entries info */ + for (i = 0; i < entry_count; ++i) { + const ulong e_addr = hdr_addr + entries_offset + i * entry_size; + const struct dt_table_entry *e; + const struct fdt_header *fdt; + u32 dt_offset, dt_size; + u32 j; + + e = map_sysmem(e_addr, sizeof(*e)); + dt_offset = fdt32_to_cpu(e->dt_offset); + dt_size = fdt32_to_cpu(e->dt_size); + + printf("dt_table_entry[%d]:\n", i); + printf(" dt_size = %d\n", dt_size); + printf(" dt_offset = %d\n", dt_offset); + printf(" id = %08x\n", fdt32_to_cpu(e->id)); + printf(" rev = %08x\n", fdt32_to_cpu(e->rev)); + for (j = 0; j < 4; ++j) { + printf(" custom[%d] = %08x\n", j, + fdt32_to_cpu(e->custom[j])); + } + + unmap_sysmem(e); + + /* Print FDT info for this entry */ + fdt = map_sysmem(hdr_addr + dt_offset, sizeof(*fdt)); + android_dt_print_fdt_info(fdt); + unmap_sysmem(fdt); + } +} +#endif diff --git a/include/image-android-dt.h b/include/image-android-dt.h new file mode 100644 index 0000000000..08b810d461 --- /dev/null +++ b/include/image-android-dt.h @@ -0,0 +1,21 @@ +/* + * (C) Copyright 2018 Linaro Ltd. + * Sam Protsenko semen.protsenko@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef IMAGE_ANDROID_DT_H +#define IMAGE_ANDROID_DT_H + +#include <linux/types.h> + +bool android_dt_check_header(ulong hdr_addr); +bool android_dt_get_fdt_by_index(ulong hdr_addr, u32 index, ulong *addr, + u32 *size); + +#if !defined(CONFIG_SPL_BUILD) +void android_dt_print_contents(ulong hdr_addr); +#endif + +#endif /* IMAGE_ANDROID_DT_H */
dtimg command allows user to work with Android DTB/DTBO image format. Such as, getting the address of desired DTB/DTBO file, printing the dump of the image in U-Boot shell, etc.
This command is needed to provide Android boot with new Android DT image format further.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- cmd/Kconfig | 8 +++ cmd/Makefile | 1 + cmd/dtimg.c | 142 ++++++++++++++++++++++++++++++++++++++++++++++++ common/Makefile | 4 ++ 4 files changed, 155 insertions(+) create mode 100644 cmd/dtimg.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index e283cb9a8a..5a4244dbac 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -254,6 +254,14 @@ config CMD_BOOTMENU help Add an ANSI terminal boot menu command.
+config CMD_DTIMG + bool "dtimg" + help + Android DTB/DTBO image manipulation commands. Read dtb/dtbo files from + image into RAM, dump image structure information, etc. Those dtb/dtbo + files should be merged in one dtb further, which needs to be passed to + the kernel, as part of a boot process. + config CMD_ELF bool "bootelf, bootvx" default y diff --git a/cmd/Makefile b/cmd/Makefile index e0088df33b..32c3e52491 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -43,6 +43,7 @@ ifdef CONFIG_POST obj-$(CONFIG_CMD_DIAG) += diag.o endif obj-$(CONFIG_CMD_DISPLAY) += display.o +obj-$(CONFIG_CMD_DTIMG) += dtimg.o obj-$(CONFIG_CMD_ECHO) += echo.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o obj-$(CONFIG_CMD_EEPROM) += eeprom.o diff --git a/cmd/dtimg.c b/cmd/dtimg.c new file mode 100644 index 0000000000..5295a341ad --- /dev/null +++ b/cmd/dtimg.c @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2018 Linaro Ltd. + * Sam Protsenko semen.protsenko@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <image-android-dt.h> +#include <common.h> + +enum cmd_dtimg_info { + CMD_DTIMG_START = 0, + CMD_DTIMG_SIZE, +}; + +static int do_dtimg_dump(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + char *endp; + ulong hdr_addr; + + if (argc != 2) + return CMD_RET_USAGE; + + hdr_addr = simple_strtoul(argv[1], &endp, 16); + if (*endp != '\0') { + printf("Error: Wrong image address\n"); + return CMD_RET_FAILURE; + } + + if (!android_dt_check_header(hdr_addr)) { + printf("Error: DT image header is incorrect\n"); + return CMD_RET_FAILURE; + } + + android_dt_print_contents(hdr_addr); + + return CMD_RET_SUCCESS; +} + +static int dtimg_get_fdt(int argc, char * const argv[], enum cmd_dtimg_info cmd) +{ + ulong hdr_addr; + u32 index; + char *endp; + ulong fdt_addr; + u32 fdt_size; + char buf[65]; + + if (argc != 4) + return CMD_RET_USAGE; + + hdr_addr = simple_strtoul(argv[1], &endp, 16); + if (*endp != '\0') { + printf("Error: Wrong image address\n"); + return CMD_RET_FAILURE; + } + + if (!android_dt_check_header(hdr_addr)) { + printf("Error: DT image header is incorrect\n"); + return CMD_RET_FAILURE; + } + + index = simple_strtoul(argv[2], &endp, 0); + if (*endp != '\0') { + printf("Error: Wrong index\n"); + return CMD_RET_FAILURE; + } + + if (!android_dt_get_fdt_by_index(hdr_addr, index, &fdt_addr, &fdt_size)) + return CMD_RET_FAILURE; + + switch (cmd) { + case CMD_DTIMG_START: + snprintf(buf, sizeof(buf), "%lx", fdt_addr); + break; + case CMD_DTIMG_SIZE: + snprintf(buf, sizeof(buf), "%x", fdt_size); + break; + default: + printf("Error: Unknown cmd_dtimg_info value: %d\n", cmd); + return CMD_RET_FAILURE; + } + + env_set(argv[3], buf); + + return CMD_RET_SUCCESS; +} + +static int do_dtimg_start(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return dtimg_get_fdt(argc, argv, CMD_DTIMG_START); +} + +static int do_dtimg_size(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return dtimg_get_fdt(argc, argv, CMD_DTIMG_SIZE); +} + +static cmd_tbl_t cmd_dtimg_sub[] = { + U_BOOT_CMD_MKENT(dump, 2, 0, do_dtimg_dump, "", ""), + U_BOOT_CMD_MKENT(start, 4, 0, do_dtimg_start, "", ""), + U_BOOT_CMD_MKENT(size, 4, 0, do_dtimg_size, "", ""), +}; + +static int do_dtimg(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + cmd_tbl_t *cp; + + cp = find_cmd_tbl(argv[1], cmd_dtimg_sub, ARRAY_SIZE(cmd_dtimg_sub)); + + /* Strip off leading 'dtimg' command argument */ + argc--; + argv++; + + if (!cp || argc > cp->maxargs) + return CMD_RET_USAGE; + if (flag == CMD_FLAG_REPEAT && !cp->repeatable) + return CMD_RET_SUCCESS; + + return cp->cmd(cmdtp, flag, argc, argv); +} + +U_BOOT_CMD( + dtimg, CONFIG_SYS_MAXARGS, 0, do_dtimg, + "manipulate dtb/dtbo Android image", + "dump <addr>\n" + " - parse specified image and print its structure info\n" + " <addr>: image address in RAM, in hex\n" + "dtimg start <addr> <index> <varname>\n" + " - get address (hex) of FDT in the image, by index\n" + " <addr>: image address in RAM, in hex\n" + " <index>: index of desired FDT in the image\n" + " <varname>: name of variable where to store address of FDT\n" + "dtimg size <addr> <index> <varname>\n" + " - get size (hex, bytes) of FDT in the image, by index\n" + " <addr>: image address in RAM, in hex\n" + " <index>: index of desired FDT in the image\n" + " <varname>: name of variable where to store size of FDT" +); diff --git a/common/Makefile b/common/Makefile index b3da72ebb2..80bcc07bd0 100644 --- a/common/Makefile +++ b/common/Makefile @@ -108,6 +108,10 @@ obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o
+ifdef CONFIG_CMD_DTIMG +obj-y += image-android-dt.o +endif + ifdef CONFIG_CMD_EEPROM_LAYOUT obj-y += eeprom/eeprom_field.o eeprom/eeprom_layout.o endif
Hmmm, I was CC'd for v2 but not for v3 here, I hope this didn't have anything to do with my objections to this image format [0]..
Anyway let me re-iterate my issue for everyone following along at home: we have no need for this image format. We can do all this and more with FIT.
If Google wants to go off and create some new format then they are free to use it in their bootloader, but if they are going to leverage community projects like U-Boot then they should use existing standards.
Mandating (this will not be a "recommends" for long) new formats should not be accepted so easily.
Andrew
[0] https://patches.linaro.org/cover/133492/#417053
Changes in v3:
- (C) Copyright 2018 Linaro Ltd.
- Sam Protsenko semen.protsenko@linaro.org
- Check if image header is correct.
- @param hdr_addr Start address of DT image
- @return true if header is correct or false if header is incorrect
- const struct dt_table_header *hdr;
- u32 magic;
- hdr = map_sysmem(hdr_addr, sizeof(*hdr));
- magic = fdt32_to_cpu(hdr->magic);
- unmap_sysmem(hdr);
- return magic == DT_TABLE_MAGIC;
- Get the address of FDT (dtb or dtbo) in memory by its index in image.
- @param index Index of desired FDT in image (starting from 0)
- @param[out] addr If not NULL, will contain address to specified FDT
- @param[out] size If not NULL, will contain size of specified FDT
- @return true on success or false on error
u32 *size)
- const struct dt_table_entry *e;
- u32 entry_count, entries_offset, entry_size;
- ulong e_addr;
- u32 dt_offset, dt_size;
- entry_count = fdt32_to_cpu(hdr->dt_entry_count);
- entries_offset = fdt32_to_cpu(hdr->dt_entries_offset);
- entry_size = fdt32_to_cpu(hdr->dt_entry_size);
- if (index > entry_count) {
entry_count);
return false;
- e_addr = hdr_addr + entries_offset + index * entry_size;
- e = map_sysmem(e_addr, sizeof(*e));
- dt_offset = fdt32_to_cpu(e->dt_offset);
- dt_size = fdt32_to_cpu(e->dt_size);
- unmap_sysmem(e);
- if (addr)
- if (size)
*size = dt_size;
- return true;
- u32 fdt_size;
- int root_node_off;
- const char *compatible = NULL;
- fdt_size = fdt_totalsize(fdt);
- root_node_off = fdt_path_offset(fdt, "/");
- if (root_node_off < 0) {
- } else {
NULL);
- printf(" (FDT)size = %d\n", fdt_size);
- printf(" (FDT)compatible = %s\n",
- Print information about DT image structure.
- u32 i;
- /* Print image header info */
- printf("dt_table_header:\n");
- printf(" magic = %08x\n", fdt32_to_cpu(hdr->magic));
- printf(" total_size = %d\n", fdt32_to_cpu(hdr->total_size));
- printf(" header_size = %d\n", fdt32_to_cpu(hdr->header_size));
- printf(" dt_entry_size = %d\n", entry_size);
- printf(" dt_entry_count = %d\n", entry_count);
- printf(" dt_entries_offset = %d\n", entries_offset);
- printf(" page_size = %d\n", fdt32_to_cpu(hdr->page_size));
- printf(" reserved[0] = %08x\n", fdt32_to_cpu(hdr->reserved[0]));
- /* Print image entries info */
- for (i = 0; i < entry_count; ++i) {
u32 j;
unmap_sysmem(e);
unmap_sysmem(fdt);
u32 *size);
Sorry, just forgot to add you to the list when doing "git send-email". Objections are very welcomed, though in this case I think are not related, as I'm not touching TI boards in this series. So please stick to actual objections to code quality rather than your personal preferences (which I actually share).
Once you can show me the mail from related Google representatives (or similar Android documentation) saying that they are dropping DT image format in favor of FIT image (or that FIT format is allowed for that), I will remove this code gladly, as I agree with you that FIT approach is slightly better (due to configurations). Before this, I'm convinced that this is the *only* official way to boot FDTs for Android right now, see [1] for details.
Personally, I don't see a big deal for adding one slim format. Btw, they might have some explanation why FIT format isn't applicable for Android (e.g. for A/B support or because of some other Project Treble requirements). Anyway, I'm just providing a working solution for Android requirements [1]. In case Google mandates using only DT format, I don't see the other way around.
Bottom line: let's put aside personal preferences, and merge this, just because of [1]. This way we have *flexibility* to embrace each of formats really fast: - for now we can use FIT format - if someone wants to use U-Boot for AOSP supported boards, they can use DT format - if Google agrees on FIT, anyone can switch to FIT
Andrew
Changes in v3:
u32 magic;
unmap_sysmem(hdr);
u32 *size)
ulong e_addr;
unmap_sysmem(hdr);
entry_count);
return false;
unmap_sysmem(e);
if (addr)
if (size)
*size = dt_size;
return true;
u32 fdt_size;
int root_node_off;
} else {
NULL);
u32 i;
unmap_sysmem(hdr);
u32 j;
unmap_sysmem(e);
unmap_sysmem(fdt);
u32 *size);
Code quality is not the only metric for which one can object to a patch..
If they have some explanation than you need to provide it as you are the one upstreaming this. My guess is they just didn't know about FIT at the time so made this format.
use DT format
Merging this implies approval, then Google can say "Hey, why use FIT when our format is also an upstream supported format?". And they would be right. I'm not sure we want to split the supported boot images like that.
As before, when people use it, they can upstream it, right now no upstream board uses this, for me "just in case" is not a valid reason for this to be here before we internally (TI/Linaro/Google) settle this. Even then, U-Boot is a community project, none of these companies get to mandate what gets into upstream.
Andrew
Andrew
Changes in v3:
u32 magic;
unmap_sysmem(hdr);
u32 *size)
ulong e_addr;
unmap_sysmem(hdr);
entry_count);
return false;
unmap_sysmem(e);
if (addr)
if (size)
*size = dt_size;
return true;
u32 fdt_size;
int root_node_off;
} else {
NULL);
u32 i;
unmap_sysmem(hdr);
u32 j;
unmap_sysmem(e);
unmap_sysmem(fdt);
u32 *size);
Andrew F. Davis
Sam Protsenko
