[U-Boot] [PATCH 1/4][v2] doc:Add documentation for e500 external debugger support
This describes requirement of e500 and e500v2 processor to support external debugger.
It also provide an insight of the configuration switch required and their description.
Signed-off-by: Radu Lazarescu radu.lazarescu@freescale.com Signed-off-by: Marius Grigoras marius.grigoras@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git branch master
Changes for v2: - Recreated README.mpc85xx - Added #define in README
Tested on - SoC having E500 Family processor (P1010RDB, BSC9131RDB) - SoC having E500MC Family processor (P4080DS, P3041DS)
README | 14 ++++++++++++++ doc/README.mpc85xx | 23 +++++++++++++++++++++++ 2 files changed, 37 insertions(+), 0 deletions(-) create mode 100644 doc/README.mpc85xx
diff --git a/README b/README index 8964672..48e50ed 100644 --- a/README +++ b/README @@ -3347,6 +3347,20 @@ Low Level (hardware related) configuration options: be used if available. These functions may be faster under some conditions but may increase the binary size.
+E500 (MPC85xx) External Debug Support +------------------------------------- +-CONFIG_E500 + Enables BOOKE e500 family.It includes e500, e500v2 e500mc, + e5500 processor etc. + +- CONFIG_SYS_PPC_E500_DEBUG_TLB + Enables a temporary TLB entry to be used during boot to work + around limitations in e500v1 and e500v2 external debugger + support. This reduces the portions of the boot code where + breakpoints and single stepping do not work. The value of this + symbol should be set to the TLB1 entry to be used for this + purpose. + Freescale QE/FMAN Firmware Support: -----------------------------------
diff --git a/doc/README.mpc85xx b/doc/README.mpc85xx new file mode 100644 index 0000000..dbd74be --- /dev/null +++ b/doc/README.mpc85xx @@ -0,0 +1,23 @@ +External Debug Support +---------------------- + +Freescale's e500v1 and e500v2 cores (used in mpc85xx chips) have some +restrictions on external debugging (JTAG). In particular, for the debugger to +be able to receive control after a single step or breakpoint: + - MSR[DE] must be set + - A valid opcode must be fetchable, through the MMU, from the debug + exception vector (IVPR + IVOR15). + +To maximize the time during which this requirement is met, U-Boot sets MSR[DE] +immediately on entry and keeps it set. It also uses a temporary TLB to keep a +mapping to a valid opcode at the debug exception vector, even if we normally +don't support exception vectors being used that early, and that's not the area +where U-Boot currently executes from. + +Note that there may still be some small windows where debugging will not work, +such as in between updating IVPR and IVOR15. + +Config Switches: +---------------- + +Please refer README section "MPC85xx External Debug Support"
This is not a debug-specific option. What's wrong with putting both of these options under the existing "85xx CPU Options" section?
-Scott
Hi Scott, Thanks for reviewing it. Please find my reply in-lined.
Yes. Both CONFIG_E500 and CONFIG_SYS_PPC_E500_DEBUG_TLB can be put under "85xx CPU Options". I made separate section thinking of CONFIG_SYS_PPC_E500_DEBUG_TLB as it required for overcoming e500 v1/v2 debugging restriction.
i will send the updated patch.
--Prabhakar
Prabhakar Kushwaha
Scott Wood
