[U-Boot] [PATCH 1/2] Build: PXA: Fix Vpac270 build variants
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 3 --- Makefile | 16 ---------------- board/vpac270/vpac270.c | 2 +- boards.cfg | 3 +++ include/configs/vpac270.h | 12 ++++++------ 5 files changed, 10 insertions(+), 26 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 6c71943..59ff847 100755 --- a/MAKEALL +++ b/MAKEALL @@ -339,9 +339,6 @@ LIST_at91=" \ LIST_pxa="$(boards_by_cpu pxa) polaris \ trizepsiv \ - vpac270_nor_128M\ - vpac270_nor_256M\ - vpac270_onenand \ "
LIST_ixp="$(boards_by_cpu ixp) diff --git a/Makefile b/Makefile index 25e8fc8..8078d71 100644 --- a/Makefile +++ b/Makefile @@ -1018,22 +1018,6 @@ trizepsiv_config : unconfig fi; @$(MKCONFIG) -n $@ -a trizepsiv arm pxa trizepsiv
-vpac270_nor_256M_config \ -vpac270_nor_128M_config \ -vpac270_onenand_config : unconfig - @mkdir -p $(obj)include - @if [ "$(findstring onenand,$@)" ] ; then \ - echo "#define CONFIG_ONENAND_U_BOOT" \ - >>$(obj)include/config.h ; \ - echo "#define CONFIG_256M_U_BOOT" \ - >>$(obj)include/config.h ; \ - fi; - @if [ "$(findstring 256M,$@)" ] ; then \ - echo "#define CONFIG_256M_U_BOOT" \ - >>$(obj)include/config.h ; \ - fi; - @$(MKCONFIG) -n $@ -a vpac270 arm pxa vpac270 - ######################################################################### ## ARM1136 Systems ######################################################################### diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 91d8580..43bbdff 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -66,7 +66,7 @@ void dram_init_banksize(void) gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
-#ifdef CONFIG_256M_U_BOOT +#ifdef CONFIG_RAM_256M gd->bd->bi_dram[1].start = PHYS_SDRAM_2; gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; #endif diff --git a/boards.cfg b/boards.cfg index 5d43f3d..b8365f7 100644 --- a/boards.cfg +++ b/boards.cfg @@ -62,6 +62,9 @@ lubbock arm pxa palmld arm pxa palmtc arm pxa pleb2 arm pxa +vpac270_nor_128 arm pxa vpac270 - - vpac270:NOR,RAM_128M +vpac270_nor_256 arm pxa vpac270 - - vpac270:NOR,RAM_256M +vpac270_ond_256 arm pxa vpac270 - - vpac270:ONENAND,RAM_256M xaeniax arm pxa xm250 arm pxa zipitz2 arm pxa diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index fc680fc..c9d9c69 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -75,7 +75,7 @@ #undef CONFIG_LCD #define CONFIG_CMD_IDE
-#ifdef CONFIG_ONENAND_U_BOOT +#ifdef CONFIG_ONENAND #undef CONFIG_CMD_FLASH #define CONFIG_CMD_ONENAND #else @@ -165,13 +165,13 @@ #define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */
-#ifdef CONFIG_256M_U_BOOT +#ifdef CONFIG_RAM_256M #define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #2 */ #define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ #endif
#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ -#ifdef CONFIG_256M_U_BOOT +#ifdef CONFIG_RAM_256M #define CONFIG_SYS_DRAM_SIZE 0x10000000 /* 256 MB DRAM */ #else #define CONFIG_SYS_DRAM_SIZE 0x08000000 /* 128 MB DRAM */ @@ -198,7 +198,7 @@ #if defined(CONFIG_CMD_FLASH) /* NOR */ #define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */
-#ifdef CONFIG_256M_U_BOOT +#ifdef CONFIG_RAM_256M #define PHYS_FLASH_2 0x02000000 /* Flash Bank #2 */ #endif
@@ -206,7 +206,7 @@ #define CONFIG_FLASH_CFI_DRIVER 1
#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) -#ifdef CONFIG_256M_U_BOOT +#ifdef CONFIG_RAM_256M #define CONFIG_SYS_MAX_FLASH_BANKS 2 #define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } #else @@ -308,7 +308,7 @@ #define CONFIG_SYS_MSC0_VAL 0x3ffc95fa #define CONFIG_SYS_MSC1_VAL 0x02ccf974 #define CONFIG_SYS_MSC2_VAL 0x00000000 -#ifdef CONFIG_256M_U_BOOT +#ifdef CONFIG_RAM_256M #define CONFIG_SYS_MDCNFG_VAL 0x8ad30ad3 #else #define CONFIG_SYS_MDCNFG_VAL 0x88000ad3
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 5 +---- Makefile | 8 -------- board/trizepsiv/conxs.c | 2 +- boards.cfg | 2 ++ 4 files changed, 4 insertions(+), 13 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 59ff847..1a96b0f 100755 --- a/MAKEALL +++ b/MAKEALL @@ -336,10 +336,7 @@ LIST_at91=" \ ## Xscale Systems #########################################################################
-LIST_pxa="$(boards_by_cpu pxa) - polaris \ - trizepsiv \ -" +LIST_pxa="$(boards_by_cpu pxa)"
LIST_ixp="$(boards_by_cpu ixp) pdnb3 \ diff --git a/Makefile b/Makefile index 8078d71..9dcd59d 100644 --- a/Makefile +++ b/Makefile @@ -1010,14 +1010,6 @@ scpu_config: unconfig fi @$(MKCONFIG) -n $@ -a pdnb3 arm ixp pdnb3 prodrive
-polaris_config \ -trizepsiv_config : unconfig - @mkdir -p $(obj)include - @if [ "$(findstring polaris,$@)" ] ; then \ - echo "#define CONFIG_POLARIS 1" >>$(obj)include/config.h ; \ - fi; - @$(MKCONFIG) -n $@ -a trizepsiv arm pxa trizepsiv - ######################################################################### ## ARM1136 Systems ######################################################################### diff --git a/board/trizepsiv/conxs.c b/board/trizepsiv/conxs.c index 7fac73d..0c67367 100644 --- a/board/trizepsiv/conxs.c +++ b/board/trizepsiv/conxs.c @@ -45,7 +45,7 @@ extern struct serial_device serial_ffuart_device; extern struct serial_device serial_btuart_device; extern struct serial_device serial_stuart_device;
-#if CONFIG_POLARIS +#if CONFIG_MK_POLARIS #define BOOT_CONSOLE "serial_stuart" #else #define BOOT_CONSOLE "serial_ffuart" diff --git a/boards.cfg b/boards.cfg index b8365f7..97b5343 100644 --- a/boards.cfg +++ b/boards.cfg @@ -62,6 +62,8 @@ lubbock arm pxa palmld arm pxa palmtc arm pxa pleb2 arm pxa +polaris arm pxa trizepsiv - - trizepsiv:POLARIS +trizepsiv arm pxa vpac270_nor_128 arm pxa vpac270 - - vpac270:NOR,RAM_128M vpac270_nor_256 arm pxa vpac270 - - vpac270:NOR,RAM_256M vpac270_ond_256 arm pxa vpac270 - - vpac270:ONENAND,RAM_256M
