[U-Boot] [PATCH 2/2] ext4: scan all directory blocks when looking up an entry
Scanning only the direct blocks of the directory file may falsely report an existing file as nonexisting, and worse can also lead to creation of a duplicate entry on file creation.
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- fs/ext4/ext4_common.c | 74 +++++++++++++++++++++++---------------------------- 1 file changed, 33 insertions(+), 41 deletions(-)
diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index 8d0013e..aa72b0d 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -500,64 +500,53 @@ static int search_dir(struct ext2_inode *parent_inode, char *dirname) { int status; int inodeno = 0; - int totalbytes; - int templength; - int direct_blk_idx; + int offset; + int blk_idx; long int blknr; - char *ptr = NULL; unsigned char *block_buffer = NULL; struct ext2_dirent *dir = NULL; struct ext_filesystem *fs = get_fs(); + uint32_t directory_blocks;
- /* read the block no allocated to a file */ - for (direct_blk_idx = 0; direct_blk_idx < INDIRECT_BLOCKS; - direct_blk_idx++) { - blknr = read_allocated_block(parent_inode, direct_blk_idx); - if (blknr == 0) - goto fail; + directory_blocks = le32_to_cpu(g_parent_inode->size) >> + LOG2_BLOCK_SIZE(ext4fs_root);
- /* read the blocks of parent inode */ - block_buffer = zalloc(fs->blksz); - if (!block_buffer) + block_buffer = zalloc(fs->blksz); + if (!block_buffer) + goto fail; + + /* get the block no allocated to a file */ + for (blk_idx = 0; blk_idx < directory_blocks; blk_idx++) { + blknr = read_allocated_block(parent_inode, blk_idx); + if (blknr == 0) goto fail;
+ /* read the directory block */ status = ext4fs_devread((lbaint_t)blknr * fs->sect_perblk, 0, fs->blksz, (char *)block_buffer); if (status == 0) goto fail;
+ offset = 0; dir = (struct ext2_dirent *)block_buffer; - ptr = (char *)dir; - totalbytes = 0; - while (le16_to_cpu(dir->direntlen) >= 0) { - /* - * blocksize-totalbytes because last directory - * length i.e.,*dir->direntlen is free availble - * space in the block that means - * it is a last entry of directory entry - */ - if (dir->inode && (strlen(dirname) == dir->namelen)) { - if (strncmp(dirname, ptr + sizeof(struct ext2_dirent), dir->namelen) == 0) { - inodeno = le32_to_cpu(dir->inode); - break; - } + while (le16_to_cpu(dir->direntlen) >= 8) { + if (dir->inode && (strlen(dirname) == dir->namelen) && + (strncmp(dirname, &dir[1], dir->namelen) == 0)) { + inodeno = le32_to_cpu(dir->inode); + break; }
- if (fs->blksz - totalbytes == le16_to_cpu(dir->direntlen)) + offset += le16_to_cpu(dir->direntlen); + if (offset >= fs->blksz) break;
- /* traversing the each directory entry */ - templength = le16_to_cpu(dir->direntlen); - totalbytes = totalbytes + templength; - dir = (struct ext2_dirent *)((char *)dir + templength); - ptr = (char *)dir; + dir = (struct ext2_dirent *)(block_buffer + offset); }
- free(block_buffer); - block_buffer = NULL; - - if (inodeno > 0) + if (inodeno > 0) { + free(block_buffer); return inodeno; + } }
fail: @@ -809,14 +798,17 @@ fail:
int ext4fs_filename_unlink(char *filename) { - short direct_blk_idx = 0; + int blk_idx; long int blknr = -1; int inodeno = -1; + uint32_t directory_blocks; + + directory_blocks = le32_to_cpu(g_parent_inode->size) >> + LOG2_BLOCK_SIZE(ext4fs_root);
/* read the block no allocated to a file */ - for (direct_blk_idx = 0; direct_blk_idx < INDIRECT_BLOCKS; - direct_blk_idx++) { - blknr = read_allocated_block(g_parent_inode, direct_blk_idx); + for (blk_idx = 0; blk_idx < directory_blocks; blk_idx++) { + blknr = read_allocated_block(g_parent_inode, blk_idx); if (blknr == 0) break; inodeno = unlink_filename(filename, blknr);
Hi Stefan,
- int totalbytes;
- int templength;
- int offset;
- int blk_idx; long int blknr;
- uint32_t directory_blocks;
direct_blk_idx++) {
direct_blk_idx);
if (blknr == 0)
goto fail;
- directory_blocks = le32_to_cpu(g_parent_inode->size) >>
if (!block_buffer)
if (!block_buffer)
goto fail;
dir = (struct ext2_dirent *)block_buffer;offset = 0;
ptr = (char *)dir;
totalbytes = 0;
directory
availble
dir->namelen)) {
inodeno =
break;
dir->namelen) &&
== 0)) {
break; }
templength);
ptr = (char *)dir;
offset); }
free(block_buffer);
if (inodeno > 0)
if (inodeno > 0) {
direct_blk_idx++) {
direct_blk_idx);
- for (blk_idx = 0; blk_idx < directory_blocks; blk_idx++) {
Reviewed-by: Lukasz Majewski l.majewski@samsung.com
Lukasz Majewski
Stefan Brüns
