Re: [U-Boot-Users] Re: how to run hello_world
Wolfgang Denk wrote:
I thought the description on this page was pretty explicit...
The only think I don't see (and have been looking for a standalone app that I am writing, is the difference between load address and entry address.
In the hello_world.c application, it's configured to run at address 0x00040004, but the load address is 0x00040000 - why in this case is there a 4 byte difference.
=> tftp 40000 /tftpboot/hello_world.bin ... => go 40004 This is another test.
I assume that this is a toolchain issue, and may be offtopic for this list.
A slightly different issue - I know that you can load up an elf image as a standalone app as well, but I don't seem to be able to pass it any command line args.
=> tftp 1000000 /tftpboot/hello_world => bootelf this is another test
fails, becuase U-boot trys to pass "this is another test" to bootelf, and it doesn't like it.
-Robin
In message 6.1.1.1.0.20041008155338.01e26910@wheresmymailserver.com you wrote:
If you create a linker map and have a look at it things might get clearer; try for example:
bash$ ${CROSS_COMPILE}ld -g -Ttext 0x40000 \
-Map hello_world.map \ -o hello_world -e hello_world hello_world.o libstubs.a \ -L/opt/eldk/3.0/usr/bin/../lib/gcc-lib/ppc-linux/3.2.2/m603 -lgcc
and then have a look at "hello_world.map":
... 86 .text 0x00040000 0xd4 hello_world.o 87 0x00040004 hello_world 88 .text 0x000400d4 0x154 libstubs.a(stubs.o) ...
As you can see, the code of hello_world() starts at 0x00040004.
Then check the assembler code generated for hello_world.c:
... 55 .section ".text" 56 .align 2 57 .globl hello_world 58 .LCL0: 59 .long .LCTOC1-.LCF0 60 .type hello_world,@function 61 hello_world: ...
As you can see, GCC places a ".long" immediately in front of the hello_world() function.
Yes, it's a tolchain issue.
Loading standalone programs using the "bootelf" comand was never tested by me. It is easily possible that there are bugs or even conceptual problems on that way. Please use the simpler & faster "go" instead.
Robin Getz
