[BUG] tools/mkimage is broken on macos arm64
Hello,
I have observed that u-boot mkimage is broken on macos arm64, it generates segfault every time.
Reproducing:
My MacOS environment: % sw_vers ProductName: macOS ProductVersion: 11.6 BuildVersion: 20G165
% uname -s -r -m Darwin 20.6.0 arm64
1. Build on macos arm64 % export CPATH=/opt/homebrew/opt/openssl@1.1/include % export LIBRARY_PATH=/opt/homebrew/opt/openssl@1.1/lib % make tools
2. Versions % git log | head -n 1 commit ade37460a944aed36ae6ee634c4d4a9a22690461
% ./mkimage -V mkimage version 2022.01-rc3
3. Run % ./mkimage -f aaa bbb zsh: segmentation fault ./mkimage -f aaa bbb
(Diagnostics related to the segfault attached)
The same story for Mac homebrew’s version:
% mkimage -V mkimage version 2021.10 % mkimage -f aaa bbb zsh: segmentation fault mkimage -f aaa bbb
If do the same on normal Linux host, everything is ok (no segfault):
$ uname -s -r -m Linux 4.19.0-18-amd64 x86_64
$ ./mkimage -V mkimage version 2022.01-rc3
$ ./mkimage -f aaa bbb FATAL ERROR: Couldn't open "aaa": No such file or directory ./mkimage: Can't open bbb.tmp: No such file or directory
I added some printf debugs to imagetool.c and recompiled with debug symbols:
struct image_type_params *imagetool_get_type(int type) { struct image_type_params **curr; fprintf(stderr, "BEFORE INIT\n"); INIT_SECTION(image_type); + fprintf(stderr, "AFTER INIT\n");
+ fprintf(stderr, "1\n"); struct image_type_params **start = __start_image_type; struct image_type_params **end = __stop_image_type; + fprintf(stderr, "3\n");
for (curr = start; curr != end; curr++) { + fprintf(stderr, "%p\n", curr);
if ((*curr)->check_image_type) { if (!(*curr)->check_image_type(type)) return *curr; } } return NULL; }
% ./mkimage -f aaa bbb BEFORE INIT AFTER INIT 1 3 0x100041e48 zsh: segmentation fault (core dumped) ./mkimage -f aaa bbb
% lldb ./mkimage -c /cores/core.95889 (lldb) target create "./mkimage" --core "/cores/core.95889” ...
(lldb) bt all mkimage was compiled with optimization - stepping may behave oddly; variables may not be available. * thread #1, stop reason = signal SIGSTOP * frame #0: 0x00000001048ec168 mkimage`imagetool_get_type(type=<unavailable>) at imagetool.c:27:8 [opt] frame #1: 0x000000010490c008 mkimage`main(argc=<unavailable>, argv=<unavailable>) at mkimage.c:357:12 [opt] frame #2: 0x000000018c2f5430 libdyld.dylib`start + 4 (lldb) f 0 frame #0: 0x00000001048ec168 mkimage`imagetool_get_type(type=<unavailable>) at imagetool.c:27:8 [opt] 24 for (curr = start; curr != end; curr++) { 25 fprintf(stderr, "%p\n", curr); 26 -> 27 if ((*curr)->check_image_type) { 28 if (!(*curr)->check_image_type(type)) 29 return *curr;
And the most interesting thing, mkimage doesn’t segfault if it is launched under lldb:
% lldb ./mkimage (lldb) target create "./mkimage" Current executable set to '/Volumes/u-boot/tools/mkimage' (arm64). (lldb) r -f aaa bbb Process 95950 launched: '/Volumes/u-boot/tools/mkimage' (arm64) BEFORE INIT AFTER INIT 1 3 0x100041e48 0x100041e50 0x100041e58 sh: dtc: command not found /Volumes/u-boot/tools/mkimage: Can't open bbb.tmp: No such file or directory
On 30 Nov 2021, at 14:49, Sergey V. Lobanov sergey@lobanov.in wrote:
Hello,
Reproducing:
- Build on macos arm64
- Versions
- Run
<mkimage_2021-11-30-132645_Sergeys-MacBook-Air.crash.txt>
I’ve found that u-boot mkimage doesn’t work on macos arm64 due to ASLR mechanism.
Jessica, do you have any idea how to rewrite INIT_SECTION define to make it compatible with ASLR mechanism? (It is related to commit https://github.com/u-boot/u-boot/commit/3b142045e8a7f0ab17b6099e9226296af459... )
LLDB uses undocumented way to disable ASLR that is why mkimage works under LLDB (https://stackoverflow.com/questions/23897963/documented-way-to-disable-aslr-... ) On modern MacOS systems it is the only way to disable ASLR (use lldb or just use the code from LLDB to disable ASBR)
sergey@Sergeys-MacBook-Air tools % lldb ./mkimage (lldb) target create "./mkimage" Current executable set to '/Volumes/OpenWrt/u-boot/tools/mkimage' (arm64). (lldb) settings set target.disable-aslr false (lldb) r -f a b Process 46167 launched: '/Volumes/OpenWrt/u-boot/tools/mkimage' (arm64) BEFORE INIT AFTER INIT 1 3 0x100045e48 mkimage was compiled with optimization - stepping may behave oddly; variables may not be available. Process 46167 stopped * thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x100045e48) frame #0: 0x0000000102a9cecc mkimage`imagetool_get_type(type=8) at imagetool.c:27:27 [opt] 24 25 for (curr = start; curr != end; curr++) { 26 fprintf(stderr, "%p\n", curr); -> 27 fprintf(stderr, "%p\n", *curr); 28 29 // sleep(100000); 30 if ((*curr)->check_image_type) { Target 0: (mkimage) stopped. (lldb) exit Quitting LLDB will kill one or more processes. Do you really want to proceed: [Y/n] y
******With ASLR it generates segfault
sergey@Sergeys-MacBook-Air tools % lldb ./mkimage (lldb) target create "./mkimage" Current executable set to '/Volumes/OpenWrt/u-boot/tools/mkimage' (arm64). (lldb) r -f a b Process 46172 launched: '/Volumes/OpenWrt/u-boot/tools/mkimage' (arm64) BEFORE INIT AFTER INIT 1 3 0x100045e48 0x100044560 0x100045e50 0x100044780 0x100045e58 0x1000447d8 sh: dtc: command not found /Volumes/OpenWrt/u-boot/tools/mkimage: Can't open b.tmp: No such file or directory Process 46172 exited with status = 255 (0x000000ff)
fprintf(stderr, "3\n"); for (curr = start; curr != end; curr++) {
fprintf(stderr, "%p\n", curr); if ((*curr)->check_image_type) { if (!(*curr)->check_image_type(type)) return *curr; } } return NULL;
- thread #1, stop reason = signal SIGSTOP
- frame #0: 0x00000001048ec168 mkimage`imagetool_get_type(type=<unavailable>) at imagetool.c:27:8 [opt] frame #1: 0x000000010490c008 mkimage`main(argc=<unavailable>, argv=<unavailable>) at mkimage.c:357:12 [opt] frame #2: 0x000000018c2f5430 libdyld.dylib`start + 4
Hello,
Reproducing:
- Versions
- Run
Sergey V. Lobanov
