[U-Boot] [PATCH 00/16] i.MX6: Engicam: Move common board code
Engicam boards have some common code, so move them as (1) SPL board_init_f and UART MUX init to common/spl.c (2) board_init, dram_init, board_late_init and mmc_late_init to common/board.c
This series also add board_fit_config_name_match to make SPL to pick suitable fdt, so reduced few defconifg files.
thanks! Jagan.
Jagan Teki (16): icorem6: Add modeboot env via board_late_init icorem6: Add mmc_late_init geam6ul: Add modeboot env via board_late_init geam6ul: Add mmc_late_init engicam: Set fdt_file env during run-time icorem6: Make SPL to pick suitable fdt engicam: Move uart mux init to SPL icorem6: Use proper iomux_ddr_regs drive strength values icorem6: Use drive strength macros i.MX6UL: geam6ul: Add SETUP_IOMUX_PADS isiot: Fix to use usdhc2_pads for mmc2 i.MX6UL: isiot: Add SETUP_IOMUX_PADS icorem6[_rqs]: Move the spl code common geam6/isiot: Move the spl code common engicam: common: Move common board code engicam: common: Move board_late_init
arch/arm/cpu/armv7/mx6/Kconfig | 6 + arch/arm/include/asm/imx-common/iomux-v3.h | 6 + board/engicam/common/Makefile | 7 + board/engicam/common/board.c | 82 +++++ board/engicam/common/board.h | 12 + board/engicam/common/spl.c | 393 +++++++++++++++++++++ board/engicam/geam6ul/geam6ul.c | 206 ++--------- board/engicam/icorem6/MAINTAINERS | 6 +- board/engicam/icorem6/icorem6.c | 330 +---------------- board/engicam/icorem6_rqs/MAINTAINERS | 3 +- board/engicam/icorem6_rqs/icorem6_rqs.c | 352 +----------------- board/engicam/isiotmx6ul/isiotmx6ul.c | 261 +++----------- configs/imx6dl_icore_mmc_defconfig | 44 --- configs/imx6dl_icore_nand_defconfig | 45 --- configs/imx6dl_icore_rqs_mmc_defconfig | 41 --- configs/imx6q_icore_nand_defconfig | 45 --- ...e_mmc_defconfig => imx6qdl_icore_mmc_defconfig} | 2 +- ...c_defconfig => imx6qdl_icore_rqs_mmc_defconfig} | 2 +- configs/imx6ul_geam_mmc_defconfig | 1 - configs/imx6ul_geam_nand_defconfig | 1 - configs/imx6ul_isiot_emmc_defconfig | 1 - configs/imx6ul_isiot_mmc_defconfig | 1 - configs/imx6ul_isiot_nand_defconfig | 1 - include/configs/imx6qdl_icore.h | 39 +- include/configs/imx6qdl_icore_rqs.h | 1 - include/configs/imx6ul_geam.h | 38 +- include/configs/imx6ul_isiot.h | 1 - 27 files changed, 655 insertions(+), 1272 deletions(-) create mode 100644 board/engicam/common/Makefile create mode 100644 board/engicam/common/board.c create mode 100644 board/engicam/common/board.h create mode 100644 board/engicam/common/spl.c delete mode 100644 configs/imx6dl_icore_mmc_defconfig delete mode 100644 configs/imx6dl_icore_nand_defconfig delete mode 100644 configs/imx6dl_icore_rqs_mmc_defconfig delete mode 100644 configs/imx6q_icore_nand_defconfig rename configs/{imx6q_icore_mmc_defconfig => imx6qdl_icore_mmc_defconfig} (96%) rename configs/{imx6q_icore_rqs_mmc_defconfig => imx6qdl_icore_rqs_mmc_defconfig} (95%)
Add runtime, modeboot env which is setting mmcboot, or nandboot based on the bootdevice so-that conditional macros b/w MMC and NAND for CONFIG_BOOTCOMMAND should be avoided in config files.
Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + board/engicam/icorem6/icorem6.c | 19 +++++++++++++++++++ include/configs/imx6qdl_icore.h | 36 ++++++++++++++++-------------------- 3 files changed, 36 insertions(+), 20 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index af6dad3..8066aaa 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -173,6 +173,7 @@ config TARGET_MX6QARM2
config TARGET_MX6Q_ICORE bool "Support Engicam i.Core" + select BOARD_LATE_INIT select MX6QDL select OF_CONTROL select DM diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index 171ec45..f78f8c9 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -205,6 +205,25 @@ int board_early_init_f(void) return 0; }
+int board_late_init(void) +{ + switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> + IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + setenv("modeboot", "mmcboot"); + break; + case IMX6_BMODE_NAND: + setenv("modeboot", "nandboot"); + break; + default: + setenv("modeboot", ""); + break; + } + + return 0; +} + int board_init(void) { /* Address of boot parameters */ diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index 5a28b15..b517e87 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -64,7 +64,7 @@ "fitboot=echo Booting FIT image from mmc ...; " \ "run mmcargs; " \ "bootm ${loadaddr}\0" \ - "mmcboot=echo Booting from mmc ...; " \ + "_mmcboot=run mmcargs; " \ "run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ "if run loadfdt; then " \ @@ -79,6 +79,20 @@ "else " \ "bootm; " \ "fi\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadfit; then " \ + "run fitboot; " \ + "else " \ + "if run loadimage; then " \ + "run _mmcboot; " \ + "fi; " \ + "fi; " \ + "fi; " \ + "fi\0" \ "nandboot=echo Booting from nand ...; " \ "if mtdparts; then " \ "echo Starting nand boot ...; " \ @@ -90,25 +104,7 @@ "nand read ${fdt_addr} dtb 0x100000; " \ "bootm ${loadaddr} - ${fdt_addr}\0"
-#ifdef CONFIG_NAND_MXS -# define CONFIG_BOOTCOMMAND "run nandboot" -#else -# define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev};" \ - "if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadfit; then " \ - "run fitboot; " \ - "else " \ - "if run loadimage; then " \ - "run mmcboot; " \ - "fi; " \ - "fi; " \ - "fi; " \ - "fi" -#endif +#define CONFIG_BOOTCOMMAND "run $modeboot"
/* Miscellaneous configurable options */ #define CONFIG_SYS_MEMTEST_START 0x80000000
Let the runtime code can set the mmcdev and mmcroot based on the devno using mmc_get_env_dev instead of defining separately in build-time configs using mmc_late_init func.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6/icorem6.c | 22 ++++++++++++++++++++++ include/configs/imx6qdl_icore.h | 2 -- 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index f78f8c9..55fc77f 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <mmc.h>
#include <asm/io.h> #include <asm/gpio.h> @@ -205,12 +206,33 @@ int board_early_init_f(void) return 0; }
+#ifdef CONFIG_ENV_IS_IN_MMC +static void mmc_late_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + setenv_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); + setenv("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} +#endif + int board_late_init(void) { switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { case IMX6_BMODE_SD: case IMX6_BMODE_ESD: +#ifdef CONFIG_ENV_IS_IN_MMC + mmc_late_init(); +#endif setenv("modeboot", "mmcboot"); break; case IMX6_BMODE_NAND: diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index b517e87..4bdba57 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -45,9 +45,7 @@ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ - "mmcdev=0\0" \ "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ "nandroot=ubi0:rootfs rootfstype=ubifs\0" \ "mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console},${baudrate} " \
Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + board/engicam/geam6ul/geam6ul.c | 19 +++++++++++++++++++ include/configs/imx6ul_geam.h | 35 ++++++++++++++++------------------- 3 files changed, 36 insertions(+), 19 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 8066aaa..7350488 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -257,6 +257,7 @@ config TARGET_MX6UL_14X14_EVK
config TARGET_MX6UL_GEAM bool "Support Engicam GEAM6UL" + select BOARD_LATE_INIT select MX6UL select OF_CONTROL select DM diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index 40f20a9..29a4830 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -103,6 +103,25 @@ static void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
+int board_late_init(void) +{ + switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> + IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + setenv("modeboot", "mmcboot"); + break; + case IMX6_BMODE_NAND: + setenv("modeboot", "nandboot"); + break; + default: + setenv("modeboot", ""); + break; + } + + return 0; +} + int board_init(void) { /* Address of boot parameters */ diff --git a/include/configs/imx6ul_geam.h b/include/configs/imx6ul_geam.h index 8bffacd..e9a1a06 100644 --- a/include/configs/imx6ul_geam.h +++ b/include/configs/imx6ul_geam.h @@ -63,7 +63,7 @@ "fitboot=echo Booting FIT image from mmc ...; " \ "run mmcargs; " \ "bootm ${loadaddr}\0" \ - "mmcboot=echo Booting from mmc ...; " \ + "_mmcboot=run mmcargs; " \ "run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ "if run loadfdt; then " \ @@ -78,6 +78,20 @@ "else " \ "bootm; " \ "fi\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadfit; then " \ + "run fitboot; " \ + "else " \ + "if run loadimage; then " \ + "run _mmcboot; " \ + "fi; " \ + "fi; " \ + "fi; " \ + "fi\0" \ "nandboot=echo Booting from nand ...; " \ "if mtdparts; then " \ "echo Starting nand boot ...; " \ @@ -89,24 +103,7 @@ "nand read ${fdt_addr} dtb 0x100000; " \ "bootm ${loadaddr} - ${fdt_addr}\0"
-#ifdef CONFIG_NAND_MXS -# define CONFIG_BOOTCOMMAND "run nandboot" -#else -# define CONFIG_BOOTCOMMAND \ - "if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadfit; then " \ - "run fitboot; " \ - "else " \ - "if run loadimage; then " \ - "run mmcboot; " \ - "fi; " \ - "fi; " \ - "fi; " \ - "fi" -#endif +#define CONFIG_BOOTCOMMAND "run $modeboot"
Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/geam6ul/geam6ul.c | 22 ++++++++++++++++++++++ include/configs/imx6ul_geam.h | 2 -- 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index 29a4830..3593719 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -7,6 +7,7 @@ */
#include <asm/io.h> #include <asm/gpio.h> @@ -103,12 +104,33 @@ static void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
+#ifdef CONFIG_ENV_IS_IN_MMC +static void mmc_late_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + setenv_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); + setenv("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} +#endif + int board_late_init(void) { switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { case IMX6_BMODE_SD: case IMX6_BMODE_ESD: +#ifdef CONFIG_ENV_IS_IN_MMC + mmc_late_init(); +#endif setenv("modeboot", "mmcboot"); break; case IMX6_BMODE_NAND: diff --git a/include/configs/imx6ul_geam.h b/include/configs/imx6ul_geam.h index e9a1a06..d331744 100644 --- a/include/configs/imx6ul_geam.h +++ b/include/configs/imx6ul_geam.h @@ -44,9 +44,7 @@ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x87800000\0" \ "boot_fdt=try\0" \ - "mmcdev=0\0" \ "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ "nandroot=ubi0:rootfs rootfstype=ubifs\0" \ "mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console},${baudrate} " \
Set fdt_file env variable during board_late_init
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/geam6ul/geam6ul.c | 3 +++ board/engicam/icorem6/icorem6.c | 5 +++++ board/engicam/icorem6_rqs/icorem6_rqs.c | 5 +++++ board/engicam/isiotmx6ul/isiotmx6ul.c | 8 ++++++++ configs/imx6dl_icore_mmc_defconfig | 1 - configs/imx6dl_icore_nand_defconfig | 1 - configs/imx6dl_icore_rqs_mmc_defconfig | 1 - configs/imx6q_icore_mmc_defconfig | 1 - configs/imx6q_icore_nand_defconfig | 1 - configs/imx6q_icore_rqs_mmc_defconfig | 1 - configs/imx6ul_geam_mmc_defconfig | 1 - configs/imx6ul_geam_nand_defconfig | 1 - configs/imx6ul_isiot_emmc_defconfig | 1 - configs/imx6ul_isiot_mmc_defconfig | 1 - configs/imx6ul_isiot_nand_defconfig | 1 - include/configs/imx6qdl_icore.h | 1 - include/configs/imx6qdl_icore_rqs.h | 1 - include/configs/imx6ul_geam.h | 1 - include/configs/imx6ul_isiot.h | 1 - 19 files changed, 21 insertions(+), 15 deletions(-)
diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index 3593719..eb0e533 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -141,6 +141,9 @@ int board_late_init(void) break; }
+ if (is_mx6ul()) + setenv("fdt_file", "imx6ul-geam-kit.dtb"); + return 0; }
diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index 55fc77f..0687329 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -243,6 +243,11 @@ int board_late_init(void) break; }
+ if (is_mx6dq()) + setenv("fdt_file", "imx6q-icore.dtb"); + else if(is_mx6dl() || is_mx6solo()) + setenv("fdt_file", "imx6dl-icore.dtb"); + return 0; }
diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 01380f1..e95c165 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -88,6 +88,11 @@ int board_late_init(void) break; }
+ if (is_mx6dq()) + setenv("fdt_file", "imx6q-icore-rqs.dtb"); + else if(is_mx6dl() || is_mx6solo()) + setenv("fdt_file", "imx6dl-icore-rqs.dtb"); + return 0; }
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 29a137d..5d1c693 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -149,6 +149,14 @@ int board_late_init(void) break; }
+ if (is_mx6ul()) { +#ifdef CONFIG_ENV_IS_IN_MMC + setenv("fdt_file", "imx6ul-isiot-emmc.dtb"); +#else + setenv("fdt_file", "imx6ul-isiot-nand.dtb"); +#endif + } + return 0; }
diff --git a/configs/imx6dl_icore_mmc_defconfig b/configs/imx6dl_icore_mmc_defconfig index 6b67156..c0644d7 100644 --- a/configs/imx6dl_icore_mmc_defconfig +++ b/configs/imx6dl_icore_mmc_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6dl-icore.dtb" CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index 2099370..20d183f 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6dl-icore.dtb" CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6dl_icore_rqs_mmc_defconfig b/configs/imx6dl_icore_rqs_mmc_defconfig index 1a7d8ef..18e1b9e 100644 --- a/configs/imx6dl_icore_rqs_mmc_defconfig +++ b/configs/imx6dl_icore_rqs_mmc_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6dl-icore-rqs.dtb" CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6q_icore_mmc_defconfig b/configs/imx6q_icore_mmc_defconfig index adb0472..48de950 100644 --- a/configs/imx6q_icore_mmc_defconfig +++ b/configs/imx6q_icore_mmc_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6q-icore.dtb" CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 45d5fce..0ebb2dd 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6q-icore.dtb" CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6q_icore_rqs_mmc_defconfig b/configs/imx6q_icore_rqs_mmc_defconfig index aef6d36..ecccd75 100644 --- a/configs/imx6q_icore_rqs_mmc_defconfig +++ b/configs/imx6q_icore_rqs_mmc_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6q-icore-rqs.dtb" CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 35610c6..8751a36 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6ul-geam-kit.dtb" CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 7010d3d..704c0c0 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6ul-geam-kit.dtb" CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 58c56f5..1f501cb 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6ul-isiot-emmc.dtb" CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_isiot_mmc_defconfig b/configs/imx6ul_isiot_mmc_defconfig index 89bd8a0..5214479 100644 --- a/configs/imx6ul_isiot_mmc_defconfig +++ b/configs/imx6ul_isiot_mmc_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6ul-isiot-emmc.dtb" CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index f7240cc..1b28336 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 -CONFIG_DEFAULT_FDT_FILE="imx6ul-isiot-nand.dtb" CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index 4bdba57..f783eac 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -42,7 +42,6 @@ "fit_image=fit.itb\0" \ "console=ttymxc3\0" \ "fdt_high=0xffffffff\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ "mmcpart=1\0" \ diff --git a/include/configs/imx6qdl_icore_rqs.h b/include/configs/imx6qdl_icore_rqs.h index 3358320..a639468 100644 --- a/include/configs/imx6qdl_icore_rqs.h +++ b/include/configs/imx6qdl_icore_rqs.h @@ -37,7 +37,6 @@ "fit_image=fit.itb\0" \ "console=ttymxc3\0" \ "fdt_high=0xffffffff\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ "mmcpart=1\0" \ diff --git a/include/configs/imx6ul_geam.h b/include/configs/imx6ul_geam.h index d331744..9f66dd3 100644 --- a/include/configs/imx6ul_geam.h +++ b/include/configs/imx6ul_geam.h @@ -41,7 +41,6 @@ "fit_image=fit.itb\0" \ "console=ttymxc0\0" \ "fdt_high=0xffffffff\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x87800000\0" \ "boot_fdt=try\0" \ "mmcpart=1\0" \ diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h index 4009648..5ce70ae 100644 --- a/include/configs/imx6ul_isiot.h +++ b/include/configs/imx6ul_isiot.h @@ -42,7 +42,6 @@ "splashpos=m,m\0" \ "console=ttymxc0\0" \ "fdt_high=0xffffffff\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x87800000\0" \ "boot_fdt=try\0" \ "mmcpart=1\0" \
SPL FIT is able to pick the suitable fdt file for u-boot, so add that function through board_fit_config_name_match.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 4 ++ board/engicam/icorem6/MAINTAINERS | 6 +-- board/engicam/icorem6/icorem6.c | 12 ++++++ board/engicam/icorem6_rqs/MAINTAINERS | 3 +- board/engicam/icorem6_rqs/icorem6_rqs.c | 12 ++++++ configs/imx6dl_icore_mmc_defconfig | 43 --------------------- configs/imx6dl_icore_nand_defconfig | 44 ---------------------- configs/imx6dl_icore_rqs_mmc_defconfig | 40 -------------------- configs/imx6q_icore_nand_defconfig | 44 ---------------------- ...e_mmc_defconfig => imx6qdl_icore_mmc_defconfig} | 1 + ...c_defconfig => imx6qdl_icore_rqs_mmc_defconfig} | 1 + 11 files changed, 33 insertions(+), 177 deletions(-) delete mode 100644 configs/imx6dl_icore_mmc_defconfig delete mode 100644 configs/imx6dl_icore_nand_defconfig delete mode 100644 configs/imx6dl_icore_rqs_mmc_defconfig delete mode 100644 configs/imx6q_icore_nand_defconfig rename configs/{imx6q_icore_mmc_defconfig => imx6qdl_icore_mmc_defconfig} (96%) rename configs/{imx6q_icore_rqs_mmc_defconfig => imx6qdl_icore_rqs_mmc_defconfig} (95%)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 7350488..0ff9045 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -176,6 +176,7 @@ config TARGET_MX6Q_ICORE select BOARD_LATE_INIT select MX6QDL select OF_CONTROL + select SPL_OF_LIBFDT select DM select DM_ETH select DM_GPIO @@ -183,12 +184,14 @@ config TARGET_MX6Q_ICORE select DM_MMC select DM_THERMAL select SUPPORT_SPL + select SPL_LOAD_FIT
config TARGET_MX6Q_ICORE_RQS bool "Support Engicam i.Core RQS" select BOARD_LATE_INIT select MX6QDL select OF_CONTROL + select SPL_OF_LIBFDT select DM select DM_ETH select DM_GPIO @@ -196,6 +199,7 @@ config TARGET_MX6Q_ICORE_RQS select DM_MMC select DM_THERMAL select SUPPORT_SPL + select SPL_LOAD_FIT
config TARGET_MX6QSABREAUTO bool "mx6qsabreauto" diff --git a/board/engicam/icorem6/MAINTAINERS b/board/engicam/icorem6/MAINTAINERS index 6116648..26b4b56 100644 --- a/board/engicam/icorem6/MAINTAINERS +++ b/board/engicam/icorem6/MAINTAINERS @@ -3,10 +3,8 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: board/engicam/icorem6 F: include/configs/imx6qdl_icore.h -F: configs/imx6q_icore_mmc_defconfig -F: configs/imx6q_icore_nand_defconfig -F: configs/imx6dl_icore_mmc_defconfig -F: configs/imx6dl_icore_nand_defconfig +F: configs/imx6qdl_icore_mmc_defconfig +F: configs/imx6qdl_icore_nand_defconfig F: arch/arm/dts/imx6qdl-icore.dtsi F: arch/arm/dts/imx6q-icore.dts F: arch/arm/dts/imx6dl-icore.dts diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index 0687329..c8aaad1 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -353,6 +353,18 @@ int board_mmc_init(bd_t *bis) } #endif
+#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + if (is_mx6dq() && !strcmp(name, "imx6q-icore")) + return 0; + else if ((is_mx6dl() || is_mx6solo()) && !strcmp(name, "imx6dl-icore")) + return 0; + else + return -1; +} +#endif + /* * Driving strength: * 0x30 == 40 Ohm diff --git a/board/engicam/icorem6_rqs/MAINTAINERS b/board/engicam/icorem6_rqs/MAINTAINERS index 2d2295c..74470ba 100644 --- a/board/engicam/icorem6_rqs/MAINTAINERS +++ b/board/engicam/icorem6_rqs/MAINTAINERS @@ -3,8 +3,7 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: board/engicam/icorem6_rqs F: include/configs/imx6qdl_icore_rqs.h -F: configs/imx6q_icore_rqs_mmc_defconfig -F: configs/imx6dl_icore_rqs_mmc_defconfig +F: configs/imx6qdl_icore_rqs_mmc_defconfig F: arch/arm/dts/imx6qdl-icore-rqs.dtsi F: arch/arm/dts/imx6q-icore-rqs.dts F: arch/arm/dts/imx6dl-icore-rqs.dts diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index e95c165..2027b28 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -224,6 +224,18 @@ void board_boot_order(u32 *spl_boot_list) #endif #endif
+#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + if (is_mx6dq() && !strcmp(name, "imx6q-icore-rqs")) + return 0; + else if ((is_mx6dl() || is_mx6solo()) && !strcmp(name, "imx6dl-icore-rqs")) + return 0; + else + return -1; +} +#endif + /* * Driving strength: * 0x30 == 40 Ohm diff --git a/configs/imx6dl_icore_mmc_defconfig b/configs/imx6dl_icore_mmc_defconfig deleted file mode 100644 index c0644d7..0000000 --- a/configs/imx6dl_icore_mmc_defconfig +++ /dev/null @@ -1,43 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_TARGET_MX6Q_ICORE=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_WATCHDOG_SUPPORT=y -# CONFIG_CMD_BMODE is not set -CONFIG_VIDEO=y -CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" -CONFIG_BOOTDELAY=3 -CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="icorem6qdl> " -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_MMC=y -CONFIG_CMD_I2C=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -# CONFIG_BLK is not set -CONFIG_SYS_I2C_MXC=y -# CONFIG_DM_MMC_OPS is not set -CONFIG_FEC_MXC=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX6=y -CONFIG_MXC_UART=y -CONFIG_IMX_THERMAL=y -CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig deleted file mode 100644 index 20d183f..0000000 --- a/configs/imx6dl_icore_nand_defconfig +++ /dev/null @@ -1,44 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_TARGET_MX6Q_ICORE=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_WATCHDOG_SUPPORT=y -# CONFIG_CMD_BMODE is not set -CONFIG_VIDEO=y -CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" -CONFIG_BOOTDELAY=3 -CONFIG_SPL=y -CONFIG_SPL_DMA_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="icorem6qdl> " -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND=y -CONFIG_CMD_I2C=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_UBI=y -# CONFIG_BLK is not set -CONFIG_SYS_I2C_MXC=y -# CONFIG_DM_MMC_OPS is not set -CONFIG_NAND_MXS=y -CONFIG_FEC_MXC=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX6=y -CONFIG_MXC_UART=y -CONFIG_IMX_THERMAL=y -CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6dl_icore_rqs_mmc_defconfig b/configs/imx6dl_icore_rqs_mmc_defconfig deleted file mode 100644 index 18e1b9e..0000000 --- a/configs/imx6dl_icore_rqs_mmc_defconfig +++ /dev/null @@ -1,40 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_TARGET_MX6Q_ICORE_RQS=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_WATCHDOG_SUPPORT=y -# CONFIG_CMD_BMODE is not set -CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore-rqs" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" -CONFIG_BOOTDELAY=3 -CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="icorem6qdl-rqs> " -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_MMC=y -CONFIG_CMD_I2C=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -# CONFIG_BLK is not set -CONFIG_SYS_I2C_MXC=y -# CONFIG_DM_MMC_OPS is not set -CONFIG_FEC_MXC=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX6=y -CONFIG_MXC_UART=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig deleted file mode 100644 index 0ebb2dd..0000000 --- a/configs/imx6q_icore_nand_defconfig +++ /dev/null @@ -1,44 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_TARGET_MX6Q_ICORE=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_WATCHDOG_SUPPORT=y -# CONFIG_CMD_BMODE is not set -CONFIG_VIDEO=y -CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" -CONFIG_BOOTDELAY=3 -CONFIG_SPL=y -CONFIG_SPL_DMA_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="icorem6qdl> " -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND=y -CONFIG_CMD_I2C=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_UBI=y -# CONFIG_BLK is not set -CONFIG_SYS_I2C_MXC=y -# CONFIG_DM_MMC_OPS is not set -CONFIG_NAND_MXS=y -CONFIG_FEC_MXC=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX6=y -CONFIG_MXC_UART=y -CONFIG_IMX_THERMAL=y -CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6q_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig similarity index 96% rename from configs/imx6q_icore_mmc_defconfig rename to configs/imx6qdl_icore_mmc_defconfig index 48de950..b6b1b4b 100644 --- a/configs/imx6q_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" +CONFIG_OF_LIST="imx6q-icore imx6dl-icore" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y diff --git a/configs/imx6q_icore_rqs_mmc_defconfig b/configs/imx6qdl_icore_rqs_mmc_defconfig similarity index 95% rename from configs/imx6q_icore_rqs_mmc_defconfig rename to configs/imx6qdl_icore_rqs_mmc_defconfig index ecccd75..08e6784 100644 --- a/configs/imx6q_icore_rqs_mmc_defconfig +++ b/configs/imx6qdl_icore_rqs_mmc_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-rqs" +CONFIG_OF_LIST="imx6q-icore-rqs imx6dl-icore-rqs" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y
Since, u-boot handle fdt through uart so move the UART code to SPL instead make it to global area.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/geam6ul/geam6ul.c | 27 ++++++++++----------------- board/engicam/icorem6/icorem6.c | 27 ++++++++++----------------- board/engicam/icorem6_rqs/icorem6_rqs.c | 27 ++++++++++----------------- board/engicam/isiotmx6ul/isiotmx6ul.c | 27 ++++++++++----------------- 4 files changed, 40 insertions(+), 68 deletions(-)
diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index eb0e533..c3d92ac 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -22,22 +22,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); - - return 0; -} - #ifdef CONFIG_NAND_MXS
#define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_100K_UP) @@ -173,6 +157,15 @@ int dram_init(void) #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-ddr.h>
+#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -341,7 +334,7 @@ void board_init_f(ulong dummy) ccgr_init();
/* iomux and setup of i2c */ - board_early_init_f(); + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
/* setup GP timer */ timer_init(); diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index c8aaad1..8c62f0e 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -23,15 +23,6 @@
-#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const uart4_pads[] = { - IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), -}; - #ifdef CONFIG_NAND_MXS
#define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_100K_UP) @@ -199,13 +190,6 @@ static void setup_display(void) } #endif /* CONFIG_VIDEO_IPUV3 */
-int board_early_init_f(void) -{ - SETUP_IOMUX_PADS(uart4_pads); - - return 0; -} - #ifdef CONFIG_ENV_IS_IN_MMC static void mmc_late_init(void) { @@ -281,6 +265,15 @@ int dram_init(void) #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-ddr.h>
+#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart4_pads[] = { + IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -617,7 +610,7 @@ void board_init_f(ulong dummy) gpr_init();
/* iomux */ - board_early_init_f(); + SETUP_IOMUX_PADS(uart4_pads);
/* setup GP timer */ timer_init(); diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 2027b28..d6ca62d 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -22,22 +22,6 @@
-#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const uart4_pads[] = { - IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), -}; - -int board_early_init_f(void) -{ - SETUP_IOMUX_PADS(uart4_pads); - - return 0; -} - int board_init(void) { /* Address of boot parameters */ @@ -110,6 +94,15 @@ int dram_init(void) #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-ddr.h>
+#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart4_pads[] = { + IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -488,7 +481,7 @@ void board_init_f(ulong dummy) gpr_init();
/* setup GP timer */ timer_init(); diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 5d1c693..008a7ae 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -22,22 +22,6 @@
#define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_100K_UP) @@ -185,6 +169,15 @@ int dram_init(void) #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-ddr.h>
+#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -402,7 +395,7 @@ void board_init_f(ulong dummy) ccgr_init();
Usually the drive strength values for DQ and SDL are 0x30 and 0x28 respectively, update them accordingly.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6/icorem6.c | 58 ++++++++++++++++----------------- board/engicam/icorem6_rqs/icorem6_rqs.c | 58 ++++++++++++++++----------------- 2 files changed, 58 insertions(+), 58 deletions(-)
diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index 8c62f0e..8aaac40 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -369,29 +369,29 @@ int board_fit_config_name_match(const char *name)
/* configure MX6Q/DUAL mmdc DDR io registers */ static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { - .dram_sdqs0 = 0x28, - .dram_sdqs1 = 0x28, - .dram_sdqs2 = 0x28, - .dram_sdqs3 = 0x28, - .dram_sdqs4 = 0x28, - .dram_sdqs5 = 0x28, - .dram_sdqs6 = 0x28, - .dram_sdqs7 = 0x28, - .dram_dqm0 = 0x28, - .dram_dqm1 = 0x28, - .dram_dqm2 = 0x28, - .dram_dqm3 = 0x28, - .dram_dqm4 = 0x28, - .dram_dqm5 = 0x28, - .dram_dqm6 = 0x28, - .dram_dqm7 = 0x28, + .dram_sdqs0 = 0x30, + .dram_sdqs1 = 0x30, + .dram_sdqs2 = 0x30, + .dram_sdqs3 = 0x30, + .dram_sdqs4 = 0x30, + .dram_sdqs5 = 0x30, + .dram_sdqs6 = 0x30, + .dram_sdqs7 = 0x30, + .dram_dqm0 = 0x30, + .dram_dqm1 = 0x30, + .dram_dqm2 = 0x30, + .dram_dqm3 = 0x30, + .dram_dqm4 = 0x30, + .dram_dqm5 = 0x30, + .dram_dqm6 = 0x30, + .dram_dqm7 = 0x30, .dram_cas = 0x30, .dram_ras = 0x30, .dram_sdclk_0 = 0x30, .dram_sdclk_1 = 0x30, .dram_reset = 0x30, - .dram_sdcke0 = 0x3000, - .dram_sdcke1 = 0x3000, + .dram_sdcke0 = 0x30, + .dram_sdcke1 = 0x30, .dram_sdba2 = 0x00000000, .dram_sdodt0 = 0x30, .dram_sdodt1 = 0x30, @@ -417,16 +417,16 @@ static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = {
/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { - .dram_sdclk_0 = 0x30, - .dram_sdclk_1 = 0x30, - .dram_cas = 0x30, - .dram_ras = 0x30, - .dram_reset = 0x30, - .dram_sdcke0 = 0x30, - .dram_sdcke1 = 0x30, + .dram_sdclk_0 = 0x28, + .dram_sdclk_1 = 0x28, + .dram_cas = 0x28, + .dram_ras = 0x28, + .dram_reset = 0x28, + .dram_sdcke0 = 0x28, + .dram_sdcke1 = 0x28, .dram_sdba2 = 0x00000000, - .dram_sdodt0 = 0x30, - .dram_sdodt1 = 0x30, + .dram_sdodt0 = 0x28, + .dram_sdodt1 = 0x28, .dram_sdqs0 = 0x28, .dram_sdqs1 = 0x28, .dram_sdqs2 = 0x28, @@ -450,8 +450,8 @@ struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { .grp_ddr_type = 0x000c0000, .grp_ddrmode_ctl = 0x00020000, .grp_ddrpke = 0x00000000, - .grp_addds = 0x30, - .grp_ctlds = 0x30, + .grp_addds = 0x28, + .grp_ctlds = 0x28, .grp_ddrmode = 0x00020000, .grp_b0ds = 0x28, .grp_b1ds = 0x28, diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index d6ca62d..24093bb 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -240,29 +240,29 @@ int board_fit_config_name_match(const char *name)
/* configure MX6Q/DUAL mmdc DDR io registers */ static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { - .dram_sdqs0 = 0x28, - .dram_sdqs1 = 0x28, - .dram_sdqs2 = 0x28, - .dram_sdqs3 = 0x28, - .dram_sdqs4 = 0x28, - .dram_sdqs5 = 0x28, - .dram_sdqs6 = 0x28, - .dram_sdqs7 = 0x28, - .dram_dqm0 = 0x28, - .dram_dqm1 = 0x28, - .dram_dqm2 = 0x28, - .dram_dqm3 = 0x28, - .dram_dqm4 = 0x28, - .dram_dqm5 = 0x28, - .dram_dqm6 = 0x28, - .dram_dqm7 = 0x28, + .dram_sdqs0 = 0x30, + .dram_sdqs1 = 0x30, + .dram_sdqs2 = 0x30, + .dram_sdqs3 = 0x30, + .dram_sdqs4 = 0x30, + .dram_sdqs5 = 0x30, + .dram_sdqs6 = 0x30, + .dram_sdqs7 = 0x30, + .dram_dqm0 = 0x30, + .dram_dqm1 = 0x30, + .dram_dqm2 = 0x30, + .dram_dqm3 = 0x30, + .dram_dqm4 = 0x30, + .dram_dqm5 = 0x30, + .dram_dqm6 = 0x30, + .dram_dqm7 = 0x30, .dram_cas = 0x30, .dram_ras = 0x30, .dram_sdclk_0 = 0x30, .dram_sdclk_1 = 0x30, .dram_reset = 0x30, - .dram_sdcke0 = 0x3000, - .dram_sdcke1 = 0x3000, + .dram_sdcke0 = 0x30, + .dram_sdcke1 = 0x30, .dram_sdba2 = 0x00000000, .dram_sdodt0 = 0x30, .dram_sdodt1 = 0x30, @@ -288,16 +288,16 @@ static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = {
/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { - .dram_sdclk_0 = 0x30, - .dram_sdclk_1 = 0x30, - .dram_cas = 0x30, - .dram_ras = 0x30, - .dram_reset = 0x30, - .dram_sdcke0 = 0x30, - .dram_sdcke1 = 0x30, + .dram_sdclk_0 = 0x28, + .dram_sdclk_1 = 0x28, + .dram_cas = 0x28, + .dram_ras = 0x28, + .dram_reset = 0x28, + .dram_sdcke0 = 0x28, + .dram_sdcke1 = 0x28, .dram_sdba2 = 0x00000000, - .dram_sdodt0 = 0x30, - .dram_sdodt1 = 0x30, + .dram_sdodt0 = 0x28, + .dram_sdodt1 = 0x28, .dram_sdqs0 = 0x28, .dram_sdqs1 = 0x28, .dram_sdqs2 = 0x28, @@ -321,8 +321,8 @@ struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { .grp_ddr_type = 0x000c0000, .grp_ddrmode_ctl = 0x00020000, .grp_ddrpke = 0x00000000, - .grp_addds = 0x30, - .grp_ctlds = 0x30, + .grp_addds = 0x28, + .grp_ctlds = 0x28, .grp_ddrmode = 0x00020000, .grp_b0ds = 0x28, .grp_b1ds = 0x28,
Use driver strength macros instead of hex numbers. - IMX6DQ_DRIVE_STRENGTH - 0x30 - IMX6SDL_DRIVE_STRENGTH - 0x28
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6/icorem6.c | 140 ++++++++++++++++---------------- board/engicam/icorem6_rqs/icorem6_rqs.c | 140 ++++++++++++++++---------------- 2 files changed, 140 insertions(+), 140 deletions(-)
diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index 8aaac40..c04dbe7 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -369,80 +369,80 @@ int board_fit_config_name_match(const char *name)
/* configure MX6Q/DUAL mmdc DDR io registers */ static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { - .dram_sdqs0 = 0x30, - .dram_sdqs1 = 0x30, - .dram_sdqs2 = 0x30, - .dram_sdqs3 = 0x30, - .dram_sdqs4 = 0x30, - .dram_sdqs5 = 0x30, - .dram_sdqs6 = 0x30, - .dram_sdqs7 = 0x30, - .dram_dqm0 = 0x30, - .dram_dqm1 = 0x30, - .dram_dqm2 = 0x30, - .dram_dqm3 = 0x30, - .dram_dqm4 = 0x30, - .dram_dqm5 = 0x30, - .dram_dqm6 = 0x30, - .dram_dqm7 = 0x30, - .dram_cas = 0x30, - .dram_ras = 0x30, - .dram_sdclk_0 = 0x30, - .dram_sdclk_1 = 0x30, - .dram_reset = 0x30, - .dram_sdcke0 = 0x30, - .dram_sdcke1 = 0x30, + .dram_sdqs0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs1 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs2 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs3 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs4 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs5 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs6 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs7 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm0 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm1 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm2 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm3 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm4 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm5 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm6 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm7 = IMX6DQ_DRIVE_STRENGTH, + .dram_cas = IMX6DQ_DRIVE_STRENGTH, + .dram_ras = IMX6DQ_DRIVE_STRENGTH, + .dram_sdclk_0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdclk_1 = IMX6DQ_DRIVE_STRENGTH, + .dram_reset = IMX6DQ_DRIVE_STRENGTH, + .dram_sdcke0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdcke1 = IMX6DQ_DRIVE_STRENGTH, .dram_sdba2 = 0x00000000, - .dram_sdodt0 = 0x30, - .dram_sdodt1 = 0x30, + .dram_sdodt0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdodt1 = IMX6DQ_DRIVE_STRENGTH, };
/* configure MX6Q/DUAL mmdc GRP io registers */ static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = { - .grp_b0ds = 0x30, - .grp_b1ds = 0x30, - .grp_b2ds = 0x30, - .grp_b3ds = 0x30, - .grp_b4ds = 0x30, - .grp_b5ds = 0x30, - .grp_b6ds = 0x30, - .grp_b7ds = 0x30, - .grp_addds = 0x30, + .grp_b0ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b1ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b2ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b3ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b4ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b5ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b6ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b7ds = IMX6DQ_DRIVE_STRENGTH, + .grp_addds = IMX6DQ_DRIVE_STRENGTH, .grp_ddrmode_ctl = 0x00020000, .grp_ddrpke = 0x00000000, .grp_ddrmode = 0x00020000, - .grp_ctlds = 0x30, + .grp_ctlds = IMX6DQ_DRIVE_STRENGTH, .grp_ddr_type = 0x000c0000, };
/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { - .dram_sdclk_0 = 0x28, - .dram_sdclk_1 = 0x28, - .dram_cas = 0x28, - .dram_ras = 0x28, - .dram_reset = 0x28, - .dram_sdcke0 = 0x28, - .dram_sdcke1 = 0x28, + .dram_sdclk_0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdclk_1 = IMX6SDL_DRIVE_STRENGTH, + .dram_cas = IMX6SDL_DRIVE_STRENGTH, + .dram_ras = IMX6SDL_DRIVE_STRENGTH, + .dram_reset = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke1 = IMX6SDL_DRIVE_STRENGTH, .dram_sdba2 = 0x00000000, - .dram_sdodt0 = 0x28, - .dram_sdodt1 = 0x28, - .dram_sdqs0 = 0x28, - .dram_sdqs1 = 0x28, - .dram_sdqs2 = 0x28, - .dram_sdqs3 = 0x28, - .dram_sdqs4 = 0x28, - .dram_sdqs5 = 0x28, - .dram_sdqs6 = 0x28, - .dram_sdqs7 = 0x28, - .dram_dqm0 = 0x28, - .dram_dqm1 = 0x28, - .dram_dqm2 = 0x28, - .dram_dqm3 = 0x28, - .dram_dqm4 = 0x28, - .dram_dqm5 = 0x28, - .dram_dqm6 = 0x28, - .dram_dqm7 = 0x28, + .dram_sdodt0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdodt1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs2 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs3 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs4 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs5 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs6 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs7 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm0 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm1 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm2 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm3 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm4 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm5 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm6 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm7 = IMX6SDL_DRIVE_STRENGTH, };
/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ @@ -450,17 +450,17 @@ struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { .grp_ddr_type = 0x000c0000, .grp_ddrmode_ctl = 0x00020000, .grp_ddrpke = 0x00000000, - .grp_addds = 0x28, - .grp_ctlds = 0x28, + .grp_addds = IMX6SDL_DRIVE_STRENGTH, + .grp_ctlds = IMX6SDL_DRIVE_STRENGTH, .grp_ddrmode = 0x00020000, - .grp_b0ds = 0x28, - .grp_b1ds = 0x28, - .grp_b2ds = 0x28, - .grp_b3ds = 0x28, - .grp_b4ds = 0x28, - .grp_b5ds = 0x28, - .grp_b6ds = 0x28, - .grp_b7ds = 0x28, + .grp_b0ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b1ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b2ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b3ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b4ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b5ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b6ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b7ds = IMX6SDL_DRIVE_STRENGTH, };
/* mt41j256 */ diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 24093bb..1d07393 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -240,80 +240,80 @@ int board_fit_config_name_match(const char *name)
/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ @@ -321,17 +321,17 @@ struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { .grp_ddr_type = 0x000c0000, .grp_ddrmode_ctl = 0x00020000, .grp_ddrpke = 0x00000000, - .grp_addds = 0x28, - .grp_ctlds = 0x28, + .grp_addds = IMX6SDL_DRIVE_STRENGTH, + .grp_ctlds = IMX6SDL_DRIVE_STRENGTH, .grp_ddrmode = 0x00020000, - .grp_b0ds = 0x28, - .grp_b1ds = 0x28, - .grp_b2ds = 0x28, - .grp_b3ds = 0x28, - .grp_b4ds = 0x28, - .grp_b5ds = 0x28, - .grp_b6ds = 0x28, - .grp_b7ds = 0x28, + .grp_b0ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b1ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b2ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b3ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b4ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b5ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b6ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b7ds = IMX6SDL_DRIVE_STRENGTH, };
/* mt41j256 */
Add generic SETUP_IOMUX_PADS function, for imx6ul mux pads.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/include/asm/imx-common/iomux-v3.h | 6 +++ board/engicam/geam6ul/geam6ul.c | 59 +++++++++++++++--------------- 2 files changed, 35 insertions(+), 30 deletions(-)
diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index ba0ed43..ad35e01 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -253,6 +253,12 @@ if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) { \ imx_iomux_v3_setup_pad(MX6Q_##def); #define SETUP_IOMUX_PADS(x) \ imx_iomux_v3_setup_multiple_pads(x, ARRAY_SIZE(x)) +#elif defined(CONFIG_MX6UL) +#define IOMUX_PADS(x) MX6_##x +#define SETUP_IOMUX_PAD(def) \ + imx_iomux_v3_setup_pad(MX6_##def); +#define SETUP_IOMUX_PADS(x) \ + imx_iomux_v3_setup_multiple_pads(x, ARRAY_SIZE(x)) #else #define IOMUX_PADS(x) MX6DL_##x #define SETUP_IOMUX_PAD(def) \ diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index c3d92ac..06a286b 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -30,21 +30,21 @@ DECLARE_GLOBAL_DATA_PTR; #define GPMI_PAD_CTRL2 (GPMI_PAD_CTRL0 | GPMI_PAD_CTRL1)
static iomux_v3_cfg_t const nand_pads[] = { - MX6_PAD_NAND_DATA00__RAWNAND_DATA00 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_DATA01__RAWNAND_DATA01 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_DATA02__RAWNAND_DATA02 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_DATA03__RAWNAND_DATA03 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_DATA04__RAWNAND_DATA04 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_DATA05__RAWNAND_DATA05 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_DATA06__RAWNAND_DATA06 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_DATA07__RAWNAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_CLE__RAWNAND_CLE | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_ALE__RAWNAND_ALE | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_RE_B__RAWNAND_RE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_WE_B__RAWNAND_WE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_WP_B__RAWNAND_WP_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NAND_READY_B__RAWNAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), + IOMUX_PADS(PAD_NAND_DATA00__RAWNAND_DATA00 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_DATA01__RAWNAND_DATA01 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_DATA02__RAWNAND_DATA02 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_DATA03__RAWNAND_DATA03 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_DATA04__RAWNAND_DATA04 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_DATA05__RAWNAND_DATA05 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_DATA06__RAWNAND_DATA06 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_DATA07__RAWNAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_CLE__RAWNAND_CLE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_ALE__RAWNAND_ALE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_CE0_B__RAWNAND_CE0_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_RE_B__RAWNAND_RE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_WE_B__RAWNAND_WE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_WP_B__RAWNAND_WP_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NAND_READY_B__RAWNAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), };
static void setup_gpmi_nand(void) @@ -52,7 +52,7 @@ static void setup_gpmi_nand(void) struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
/* config gpmi nand iomux */ - imx_iomux_v3_setup_multiple_pads(nand_pads, ARRAY_SIZE(nand_pads)); + SETUP_IOMUX_PADS(nand_pads);
clrbits_le32(&mxc_ccm->CCGR4, MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | @@ -162,8 +162,8 @@ int dram_init(void) PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
static iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IOMUX_PADS(PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL)), };
/* MMC board initialization is needed till adding DM support in SPL */ @@ -176,19 +176,19 @@ static iomux_v3_cfg_t const uart1_pads[] = { PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
static iomux_v3_cfg_t const usdhc1_pads[] = { - MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IOMUX_PADS(PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
/* VSELECT */ - MX6_PAD_GPIO1_IO05__USDHC1_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IOMUX_PADS(PAD_GPIO1_IO05__USDHC1_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL)), /* CD */ - MX6_PAD_UART1_RTS_B__GPIO1_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_UART1_RTS_B__GPIO1_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* RST_B */ - MX6_PAD_GPIO1_IO09__GPIO1_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_GPIO1_IO09__GPIO1_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 1) @@ -223,8 +223,7 @@ int board_mmc_init(bd_t *bis) for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { switch (i) { case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + SETUP_IOMUX_PADS(usdhc1_pads); gpio_direction_input(USDHC1_CD_GPIO); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); break; @@ -334,7 +333,7 @@ void board_init_f(ulong dummy) ccgr_init();
/* iomux and setup of i2c */ - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + SETUP_IOMUX_PADS(uart1_pads);
mmc2 in Is.IoT using usdhc1_pads instead usdhc2_pads, so update the same.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/isiotmx6ul/isiotmx6ul.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 008a7ae..068e2d9 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -260,7 +260,7 @@ int board_mmc_init(bd_t *bis) break; case 1: imx_iomux_v3_setup_multiple_pads( - usdhc1_pads, ARRAY_SIZE(usdhc2_pads)); + usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); gpio_direction_input(USDHC2_CD_GPIO); usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); break;
Add generic SETUP_IOMUX_PADS function, for imx6ul mux pads and use them in Is.IoT board.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/isiotmx6ul/isiotmx6ul.c | 80 +++++++++++++++++------------------ 1 file changed, 39 insertions(+), 41 deletions(-)
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 068e2d9..d6a63d2 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -30,21 +30,21 @@ DECLARE_GLOBAL_DATA_PTR; #define GPMI_PAD_CTRL2 (GPMI_PAD_CTRL0 | GPMI_PAD_CTRL1)
clrbits_le32(&mxc_ccm->CCGR4, MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | @@ -174,8 +174,8 @@ int dram_init(void) PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
/* MMC board initialization is needed till adding DM support in SPL */ @@ -188,31 +188,31 @@ static iomux_v3_cfg_t const uart1_pads[] = { PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
static iomux_v3_cfg_t const usdhc2_pads[] = { - MX6_PAD_NAND_ALE__USDHC2_RESET_B | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_DATA00__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_DATA04__USDHC2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NAND_DATA05__USDHC2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IOMUX_PADS(PAD_NAND_ALE__USDHC2_RESET_B | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_DATA00__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_DATA04__USDHC2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NAND_DATA05__USDHC2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), };
#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 19) @@ -253,14 +253,12 @@ int board_mmc_init(bd_t *bis) for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { switch (i) { case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + SETUP_IOMUX_PADS(usdhc1_pads); gpio_direction_input(USDHC1_CD_GPIO); usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); break; case 1: - imx_iomux_v3_setup_multiple_pads( - usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + SETUP_IOMUX_PADS(usdhc2_pads); gpio_direction_input(USDHC2_CD_GPIO); usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); break; @@ -395,7 +393,7 @@ void board_init_f(ulong dummy) ccgr_init();
SPL code for icorem6 and icorem6_rqs are same, so move them in common area.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/common/Makefile | 8 + board/engicam/common/spl.c | 304 ++++++++++++++++++++++++++++++++ board/engicam/icorem6/icorem6.c | 287 +----------------------------- board/engicam/icorem6_rqs/icorem6_rqs.c | 285 +----------------------------- 4 files changed, 314 insertions(+), 570 deletions(-) create mode 100644 board/engicam/common/Makefile create mode 100644 board/engicam/common/spl.c
diff --git a/board/engicam/common/Makefile b/board/engicam/common/Makefile new file mode 100644 index 0000000..11e7fee --- /dev/null +++ b/board/engicam/common/Makefile @@ -0,0 +1,8 @@ +# Copyright (C) 2016 Amarula Solutions B.V. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifdef CONFIG_MX6QDL +obj-$(CONFIG_SPL_BUILD) += spl.o +endif diff --git a/board/engicam/common/spl.c b/board/engicam/common/spl.c new file mode 100644 index 0000000..71e85d5 --- /dev/null +++ b/board/engicam/common/spl.c @@ -0,0 +1,304 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * Author: Jagan Teki jagan@amarulasolutions.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <linux/sizes.h> + +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> + +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/video.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart4_pads[] = { + IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + +/* + * Driving strength: + * 0x30 == 40 Ohm + * 0x28 == 48 Ohm + */ +#define IMX6DQ_DRIVE_STRENGTH 0x30 +#define IMX6SDL_DRIVE_STRENGTH 0x28 + +/* configure MX6Q/DUAL mmdc DDR io registers */ +static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { + .dram_sdqs0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs1 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs2 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs3 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs4 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs5 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs6 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs7 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm0 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm1 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm2 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm3 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm4 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm5 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm6 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm7 = IMX6DQ_DRIVE_STRENGTH, + .dram_cas = IMX6DQ_DRIVE_STRENGTH, + .dram_ras = IMX6DQ_DRIVE_STRENGTH, + .dram_sdclk_0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdclk_1 = IMX6DQ_DRIVE_STRENGTH, + .dram_reset = IMX6DQ_DRIVE_STRENGTH, + .dram_sdcke0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdcke1 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdodt1 = IMX6DQ_DRIVE_STRENGTH, +}; + +/* configure MX6Q/DUAL mmdc GRP io registers */ +static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = { + .grp_b0ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b1ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b2ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b3ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b4ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b5ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b6ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b7ds = IMX6DQ_DRIVE_STRENGTH, + .grp_addds = IMX6DQ_DRIVE_STRENGTH, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_ddrmode = 0x00020000, + .grp_ctlds = IMX6DQ_DRIVE_STRENGTH, + .grp_ddr_type = 0x000c0000, +}; + +/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ +struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { + .dram_sdclk_0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdclk_1 = IMX6SDL_DRIVE_STRENGTH, + .dram_cas = IMX6SDL_DRIVE_STRENGTH, + .dram_ras = IMX6SDL_DRIVE_STRENGTH, + .dram_reset = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdodt1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs2 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs3 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs4 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs5 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs6 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs7 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm0 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm1 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm2 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm3 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm4 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm5 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm6 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm7 = IMX6SDL_DRIVE_STRENGTH, +}; + +/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ +struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = IMX6SDL_DRIVE_STRENGTH, + .grp_ctlds = IMX6SDL_DRIVE_STRENGTH, + .grp_ddrmode = 0x00020000, + .grp_b0ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b1ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b2ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b3ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b4ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b5ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b6ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b7ds = IMX6SDL_DRIVE_STRENGTH, +}; + +/* mt41j256 */ +static struct mx6_ddr3_cfg mt41j256 = { + .mem_speed = 1066, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 13, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, + .SRT = 0, +}; + +static struct mx6_mmdc_calibration mx6dq_mmdc_calib = { + .p0_mpwldectrl0 = 0x000E0009, + .p0_mpwldectrl1 = 0x0018000E, + .p1_mpwldectrl0 = 0x00000007, + .p1_mpwldectrl1 = 0x00000000, + .p0_mpdgctrl0 = 0x43280334, + .p0_mpdgctrl1 = 0x031C0314, + .p1_mpdgctrl0 = 0x4318031C, + .p1_mpdgctrl1 = 0x030C0258, + .p0_mprddlctl = 0x3E343A40, + .p1_mprddlctl = 0x383C3844, + .p0_mpwrdlctl = 0x40404440, + .p1_mpwrdlctl = 0x4C3E4446, +}; + +/* DDR 64bit */ +static struct mx6_ddr_sysinfo mem_q = { + .ddr_type = DDR_TYPE_DDR3, + .dsize = 2, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 2, + .rtt_wr = 2, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +static struct mx6_mmdc_calibration mx6dl_mmdc_calib = { + .p0_mpwldectrl0 = 0x001F0024, + .p0_mpwldectrl1 = 0x00110018, + .p1_mpwldectrl0 = 0x001F0024, + .p1_mpwldectrl1 = 0x00110018, + .p0_mpdgctrl0 = 0x4230022C, + .p0_mpdgctrl1 = 0x02180220, + .p1_mpdgctrl0 = 0x42440248, + .p1_mpdgctrl1 = 0x02300238, + .p0_mprddlctl = 0x44444A48, + .p1_mprddlctl = 0x46484A42, + .p0_mpwrdlctl = 0x38383234, + .p1_mpwrdlctl = 0x3C34362E, +}; + +/* DDR 64bit 1GB */ +static struct mx6_ddr_sysinfo mem_dl = { + .dsize = 2, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 1, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +/* DDR 32bit 512MB */ +static struct mx6_ddr_sysinfo mem_s = { + .dsize = 1, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 1, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00003F3F, &ccm->CCGR0); + writel(0x0030FC00, &ccm->CCGR1); + writel(0x000FC000, &ccm->CCGR2); + writel(0x3F300000, &ccm->CCGR3); + writel(0xFF00F300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003CC, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + +static void spl_dram_init(void) +{ + if (is_mx6solo()) { + mx6sdl_dram_iocfg(32, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&mem_s, &mx6dl_mmdc_calib, &mt41j256); + } else if (is_mx6dl()) { + mx6sdl_dram_iocfg(64, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&mem_dl, &mx6dl_mmdc_calib, &mt41j256); + } else if (is_mx6dq()) { + mx6dq_dram_iocfg(64, &mx6dq_ddr_ioregs, &mx6dq_grp_ioregs); + mx6_dram_cfg(&mem_q, &mx6dq_mmdc_calib, &mt41j256); + } + + udelay(100); +} + +void board_init_f(ulong dummy) +{ + ccgr_init(); + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + gpr_init(); + + /* iomux */ + SETUP_IOMUX_PADS(uart4_pads); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index c04dbe7..a881d83 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -259,21 +259,6 @@ int dram_init(void) }
#ifdef CONFIG_SPL_BUILD -#include <libfdt.h> -#include <spl.h> - -#include <asm/arch/crm_regs.h> -#include <asm/arch/mx6-ddr.h> - -#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const uart4_pads[] = { - IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), -}; - /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -357,274 +342,4 @@ int board_fit_config_name_match(const char *name) return -1; } #endif - -/* - * Driving strength: - * 0x30 == 40 Ohm - * 0x28 == 48 Ohm - */ - -#define IMX6DQ_DRIVE_STRENGTH 0x30 -#define IMX6SDL_DRIVE_STRENGTH 0x28 - -/* configure MX6Q/DUAL mmdc DDR io registers */ -static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { - .dram_sdqs0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs1 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs2 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs3 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs4 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs5 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs6 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs7 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm0 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm1 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm2 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm3 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm4 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm5 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm6 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm7 = IMX6DQ_DRIVE_STRENGTH, - .dram_cas = IMX6DQ_DRIVE_STRENGTH, - .dram_ras = IMX6DQ_DRIVE_STRENGTH, - .dram_sdclk_0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdclk_1 = IMX6DQ_DRIVE_STRENGTH, - .dram_reset = IMX6DQ_DRIVE_STRENGTH, - .dram_sdcke0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdcke1 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdba2 = 0x00000000, - .dram_sdodt0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdodt1 = IMX6DQ_DRIVE_STRENGTH, -}; - -/* configure MX6Q/DUAL mmdc GRP io registers */ -static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = { - .grp_b0ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b1ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b2ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b3ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b4ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b5ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b6ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b7ds = IMX6DQ_DRIVE_STRENGTH, - .grp_addds = IMX6DQ_DRIVE_STRENGTH, - .grp_ddrmode_ctl = 0x00020000, - .grp_ddrpke = 0x00000000, - .grp_ddrmode = 0x00020000, - .grp_ctlds = IMX6DQ_DRIVE_STRENGTH, - .grp_ddr_type = 0x000c0000, -}; - -/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ -struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { - .dram_sdclk_0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdclk_1 = IMX6SDL_DRIVE_STRENGTH, - .dram_cas = IMX6SDL_DRIVE_STRENGTH, - .dram_ras = IMX6SDL_DRIVE_STRENGTH, - .dram_reset = IMX6SDL_DRIVE_STRENGTH, - .dram_sdcke0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdcke1 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdba2 = 0x00000000, - .dram_sdodt0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdodt1 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs1 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs2 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs3 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs4 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs5 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs6 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs7 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm0 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm1 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm2 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm3 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm4 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm5 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm6 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm7 = IMX6SDL_DRIVE_STRENGTH, -}; - -/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ -struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { - .grp_ddr_type = 0x000c0000, - .grp_ddrmode_ctl = 0x00020000, - .grp_ddrpke = 0x00000000, - .grp_addds = IMX6SDL_DRIVE_STRENGTH, - .grp_ctlds = IMX6SDL_DRIVE_STRENGTH, - .grp_ddrmode = 0x00020000, - .grp_b0ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b1ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b2ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b3ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b4ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b5ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b6ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b7ds = IMX6SDL_DRIVE_STRENGTH, -}; - -/* mt41j256 */ -static struct mx6_ddr3_cfg mt41j256 = { - .mem_speed = 1066, - .density = 2, - .width = 16, - .banks = 8, - .rowaddr = 13, - .coladdr = 10, - .pagesz = 2, - .trcd = 1375, - .trcmin = 4875, - .trasmin = 3500, - .SRT = 0, -}; - -static struct mx6_mmdc_calibration mx6dq_mmdc_calib = { - .p0_mpwldectrl0 = 0x000E0009, - .p0_mpwldectrl1 = 0x0018000E, - .p1_mpwldectrl0 = 0x00000007, - .p1_mpwldectrl1 = 0x00000000, - .p0_mpdgctrl0 = 0x43280334, - .p0_mpdgctrl1 = 0x031C0314, - .p1_mpdgctrl0 = 0x4318031C, - .p1_mpdgctrl1 = 0x030C0258, - .p0_mprddlctl = 0x3E343A40, - .p1_mprddlctl = 0x383C3844, - .p0_mpwrdlctl = 0x40404440, - .p1_mpwrdlctl = 0x4C3E4446, -}; - -/* DDR 64bit */ -static struct mx6_ddr_sysinfo mem_q = { - .ddr_type = DDR_TYPE_DDR3, - .dsize = 2, - .cs1_mirror = 0, - /* config for full 4GB range so that get_mem_size() works */ - .cs_density = 32, - .ncs = 1, - .bi_on = 1, - .rtt_nom = 2, - .rtt_wr = 2, - .ralat = 5, - .walat = 0, - .mif3_mode = 3, - .rst_to_cke = 0x23, - .sde_to_rst = 0x10, -}; - -static struct mx6_mmdc_calibration mx6dl_mmdc_calib = { - .p0_mpwldectrl0 = 0x001F0024, - .p0_mpwldectrl1 = 0x00110018, - .p1_mpwldectrl0 = 0x001F0024, - .p1_mpwldectrl1 = 0x00110018, - .p0_mpdgctrl0 = 0x4230022C, - .p0_mpdgctrl1 = 0x02180220, - .p1_mpdgctrl0 = 0x42440248, - .p1_mpdgctrl1 = 0x02300238, - .p0_mprddlctl = 0x44444A48, - .p1_mprddlctl = 0x46484A42, - .p0_mpwrdlctl = 0x38383234, - .p1_mpwrdlctl = 0x3C34362E, -}; - -/* DDR 64bit 1GB */ -static struct mx6_ddr_sysinfo mem_dl = { - .dsize = 2, - .cs1_mirror = 0, - /* config for full 4GB range so that get_mem_size() works */ - .cs_density = 32, - .ncs = 1, - .bi_on = 1, - .rtt_nom = 1, - .rtt_wr = 1, - .ralat = 5, - .walat = 0, - .mif3_mode = 3, - .rst_to_cke = 0x23, - .sde_to_rst = 0x10, -}; - -/* DDR 32bit 512MB */ -static struct mx6_ddr_sysinfo mem_s = { - .dsize = 1, - .cs1_mirror = 0, - /* config for full 4GB range so that get_mem_size() works */ - .cs_density = 32, - .ncs = 1, - .bi_on = 1, - .rtt_nom = 1, - .rtt_wr = 1, - .ralat = 5, - .walat = 0, - .mif3_mode = 3, - .rst_to_cke = 0x23, - .sde_to_rst = 0x10, -}; - -static void ccgr_init(void) -{ - struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - - writel(0x00003F3F, &ccm->CCGR0); - writel(0x0030FC00, &ccm->CCGR1); - writel(0x000FC000, &ccm->CCGR2); - writel(0x3F300000, &ccm->CCGR3); - writel(0xFF00F300, &ccm->CCGR4); - writel(0x0F0000C3, &ccm->CCGR5); - writel(0x000003CC, &ccm->CCGR6); -} - -static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - -static void spl_dram_init(void) -{ - if (is_mx6solo()) { - mx6sdl_dram_iocfg(32, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); - mx6_dram_cfg(&mem_s, &mx6dl_mmdc_calib, &mt41j256); - } else if (is_mx6dl()) { - mx6sdl_dram_iocfg(64, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); - mx6_dram_cfg(&mem_dl, &mx6dl_mmdc_calib, &mt41j256); - } else if (is_mx6dq()) { - mx6dq_dram_iocfg(64, &mx6dq_ddr_ioregs, &mx6dq_grp_ioregs); - mx6_dram_cfg(&mem_q, &mx6dq_mmdc_calib, &mt41j256); - } - - udelay(100); -} - -void board_init_f(ulong dummy) -{ - ccgr_init(); - - /* setup AIPS and disable watchdog */ - arch_cpu_init(); - - gpr_init(); - - /* iomux */ - SETUP_IOMUX_PADS(uart4_pads); - - /* setup GP timer */ - timer_init(); - - /* UART clocks enabled and gd valid - init serial console */ - preloader_console_init(); - - /* DDR initialization */ - spl_dram_init(); - - /* Clear the BSS. */ - memset(__bss_start, 0, __bss_end - __bss_start); - - /* load/boot image from boot device */ - board_init_r(NULL, 0); -} -#endif +#endif /* CONFIG_SPL_BUILD */ diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 1d07393..854a34e 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -88,21 +88,8 @@ int dram_init(void) }
#ifdef CONFIG_SPL_BUILD -#include <libfdt.h> #include <spl.h>
-#include <asm/arch/crm_regs.h> -#include <asm/arch/mx6-ddr.h> - -#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const uart4_pads[] = { - IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), -}; - /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -228,274 +215,4 @@ int board_fit_config_name_match(const char *name) return -1; } #endif - -/* - * Driving strength: - * 0x30 == 40 Ohm - * 0x28 == 48 Ohm - */ - -#define IMX6DQ_DRIVE_STRENGTH 0x30 -#define IMX6SDL_DRIVE_STRENGTH 0x28 - -/* configure MX6Q/DUAL mmdc DDR io registers */ -static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { - .dram_sdqs0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs1 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs2 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs3 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs4 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs5 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs6 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdqs7 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm0 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm1 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm2 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm3 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm4 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm5 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm6 = IMX6DQ_DRIVE_STRENGTH, - .dram_dqm7 = IMX6DQ_DRIVE_STRENGTH, - .dram_cas = IMX6DQ_DRIVE_STRENGTH, - .dram_ras = IMX6DQ_DRIVE_STRENGTH, - .dram_sdclk_0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdclk_1 = IMX6DQ_DRIVE_STRENGTH, - .dram_reset = IMX6DQ_DRIVE_STRENGTH, - .dram_sdcke0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdcke1 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdba2 = 0x00000000, - .dram_sdodt0 = IMX6DQ_DRIVE_STRENGTH, - .dram_sdodt1 = IMX6DQ_DRIVE_STRENGTH, -}; - -/* configure MX6Q/DUAL mmdc GRP io registers */ -static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = { - .grp_b0ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b1ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b2ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b3ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b4ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b5ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b6ds = IMX6DQ_DRIVE_STRENGTH, - .grp_b7ds = IMX6DQ_DRIVE_STRENGTH, - .grp_addds = IMX6DQ_DRIVE_STRENGTH, - .grp_ddrmode_ctl = 0x00020000, - .grp_ddrpke = 0x00000000, - .grp_ddrmode = 0x00020000, - .grp_ctlds = IMX6DQ_DRIVE_STRENGTH, - .grp_ddr_type = 0x000c0000, -}; - -/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ -struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { - .dram_sdclk_0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdclk_1 = IMX6SDL_DRIVE_STRENGTH, - .dram_cas = IMX6SDL_DRIVE_STRENGTH, - .dram_ras = IMX6SDL_DRIVE_STRENGTH, - .dram_reset = IMX6SDL_DRIVE_STRENGTH, - .dram_sdcke0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdcke1 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdba2 = 0x00000000, - .dram_sdodt0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdodt1 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs0 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs1 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs2 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs3 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs4 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs5 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs6 = IMX6SDL_DRIVE_STRENGTH, - .dram_sdqs7 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm0 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm1 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm2 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm3 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm4 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm5 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm6 = IMX6SDL_DRIVE_STRENGTH, - .dram_dqm7 = IMX6SDL_DRIVE_STRENGTH, -}; - -/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ -struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { - .grp_ddr_type = 0x000c0000, - .grp_ddrmode_ctl = 0x00020000, - .grp_ddrpke = 0x00000000, - .grp_addds = IMX6SDL_DRIVE_STRENGTH, - .grp_ctlds = IMX6SDL_DRIVE_STRENGTH, - .grp_ddrmode = 0x00020000, - .grp_b0ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b1ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b2ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b3ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b4ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b5ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b6ds = IMX6SDL_DRIVE_STRENGTH, - .grp_b7ds = IMX6SDL_DRIVE_STRENGTH, -}; - -/* mt41j256 */ -static struct mx6_ddr3_cfg mt41j256 = { - .mem_speed = 1066, - .density = 2, - .width = 16, - .banks = 8, - .rowaddr = 13, - .coladdr = 10, - .pagesz = 2, - .trcd = 1375, - .trcmin = 4875, - .trasmin = 3500, - .SRT = 0, -}; - -static struct mx6_mmdc_calibration mx6dq_mmdc_calib = { - .p0_mpwldectrl0 = 0x000E0009, - .p0_mpwldectrl1 = 0x0018000E, - .p1_mpwldectrl0 = 0x00000007, - .p1_mpwldectrl1 = 0x00000000, - .p0_mpdgctrl0 = 0x43280334, - .p0_mpdgctrl1 = 0x031C0314, - .p1_mpdgctrl0 = 0x4318031C, - .p1_mpdgctrl1 = 0x030C0258, - .p0_mprddlctl = 0x3E343A40, - .p1_mprddlctl = 0x383C3844, - .p0_mpwrdlctl = 0x40404440, - .p1_mpwrdlctl = 0x4C3E4446, -}; - -/* DDR 64bit */ -static struct mx6_ddr_sysinfo mem_q = { - .ddr_type = DDR_TYPE_DDR3, - .dsize = 2, - .cs1_mirror = 0, - /* config for full 4GB range so that get_mem_size() works */ - .cs_density = 32, - .ncs = 1, - .bi_on = 1, - .rtt_nom = 2, - .rtt_wr = 2, - .ralat = 5, - .walat = 0, - .mif3_mode = 3, - .rst_to_cke = 0x23, - .sde_to_rst = 0x10, -}; - -static struct mx6_mmdc_calibration mx6dl_mmdc_calib = { - .p0_mpwldectrl0 = 0x001F0024, - .p0_mpwldectrl1 = 0x00110018, - .p1_mpwldectrl0 = 0x001F0024, - .p1_mpwldectrl1 = 0x00110018, - .p0_mpdgctrl0 = 0x4230022C, - .p0_mpdgctrl1 = 0x02180220, - .p1_mpdgctrl0 = 0x42440248, - .p1_mpdgctrl1 = 0x02300238, - .p0_mprddlctl = 0x44444A48, - .p1_mprddlctl = 0x46484A42, - .p0_mpwrdlctl = 0x38383234, - .p1_mpwrdlctl = 0x3C34362E, -}; - -/* DDR 64bit 1GB */ -static struct mx6_ddr_sysinfo mem_dl = { - .dsize = 2, - .cs1_mirror = 0, - /* config for full 4GB range so that get_mem_size() works */ - .cs_density = 32, - .ncs = 1, - .bi_on = 1, - .rtt_nom = 1, - .rtt_wr = 1, - .ralat = 5, - .walat = 0, - .mif3_mode = 3, - .rst_to_cke = 0x23, - .sde_to_rst = 0x10, -}; - -/* DDR 32bit 512MB */ -static struct mx6_ddr_sysinfo mem_s = { - .dsize = 1, - .cs1_mirror = 0, - /* config for full 4GB range so that get_mem_size() works */ - .cs_density = 32, - .ncs = 1, - .bi_on = 1, - .rtt_nom = 1, - .rtt_wr = 1, - .ralat = 5, - .walat = 0, - .mif3_mode = 3, - .rst_to_cke = 0x23, - .sde_to_rst = 0x10, -}; - -static void ccgr_init(void) -{ - struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - - writel(0x00003F3F, &ccm->CCGR0); - writel(0x0030FC00, &ccm->CCGR1); - writel(0x000FC000, &ccm->CCGR2); - writel(0x3F300000, &ccm->CCGR3); - writel(0xFF00F300, &ccm->CCGR4); - writel(0x0F0000C3, &ccm->CCGR5); - writel(0x000003CC, &ccm->CCGR6); -} - -static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - -static void spl_dram_init(void) -{ - if (is_mx6solo()) { - mx6sdl_dram_iocfg(32, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); - mx6_dram_cfg(&mem_s, &mx6dl_mmdc_calib, &mt41j256); - } else if (is_mx6dl()) { - mx6sdl_dram_iocfg(64, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); - mx6_dram_cfg(&mem_dl, &mx6dl_mmdc_calib, &mt41j256); - } else if (is_mx6dq()) { - mx6dq_dram_iocfg(64, &mx6dq_ddr_ioregs, &mx6dq_grp_ioregs); - mx6_dram_cfg(&mem_q, &mx6dq_mmdc_calib, &mt41j256); - } - - udelay(100); -} - -void board_init_f(ulong dummy) -{ - ccgr_init(); - - /* setup AIPS and disable watchdog */ - arch_cpu_init(); - - gpr_init(); - - /* iomux */ - SETUP_IOMUX_PADS(uart4_pads); - - /* setup GP timer */ - timer_init(); - - /* UART clocks enabled and gd valid - init serial console */ - preloader_console_init(); - - /* DDR initialization */ - spl_dram_init(); - - /* Clear the BSS. */ - memset(__bss_start, 0, __bss_end - __bss_start); - - /* load/boot image from boot device */ - board_init_r(NULL, 0); -} -#endif +#endif /* CONFIG_SPL_BUILD */
SPL code for geam6 and isiot are same, so move them in common area.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/common/Makefile | 2 - board/engicam/common/spl.c | 93 +++++++++++++++++++++++++- board/engicam/geam6ul/geam6ul.c | 122 ---------------------------------- board/engicam/isiotmx6ul/isiotmx6ul.c | 119 --------------------------------- 4 files changed, 91 insertions(+), 245 deletions(-)
diff --git a/board/engicam/common/Makefile b/board/engicam/common/Makefile index 11e7fee..6fd039c 100644 --- a/board/engicam/common/Makefile +++ b/board/engicam/common/Makefile @@ -3,6 +3,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_MX6QDL obj-$(CONFIG_SPL_BUILD) += spl.o -endif diff --git a/board/engicam/common/spl.c b/board/engicam/common/spl.c index 71e85d5..ab0ab98 100644 --- a/board/engicam/common/spl.c +++ b/board/engicam/common/spl.c @@ -29,11 +29,17 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-static iomux_v3_cfg_t const uart4_pads[] = { +static iomux_v3_cfg_t const uart_pads[] = { +#ifdef CONFIG_MX6QDL IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +#elif CONFIG_MX6UL + IOMUX_PADS(PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL)), +#endif };
+#ifdef CONFIG_MX6QDL /* * Driving strength: * 0x30 == 40 Ohm @@ -234,11 +240,80 @@ static struct mx6_ddr_sysinfo mem_s = { .rst_to_cke = 0x23, .sde_to_rst = 0x10, }; +#endif /* CONFIG_MX6QDL */ + +#ifdef CONFIG_MX6UL +static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = { + .grp_addds = 0x00000030, + .grp_ddrmode_ctl = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_ctlds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_ddrpke = 0x00000000, + .grp_ddrmode = 0x00020000, + .grp_ddr_type = 0x000c0000, +}; + +static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { + .dram_dqm0 = 0x00000030, + .dram_dqm1 = 0x00000030, + .dram_ras = 0x00000030, + .dram_cas = 0x00000030, + .dram_odt0 = 0x00000030, + .dram_odt1 = 0x00000030, + .dram_sdba2 = 0x00000000, + .dram_sdclk_0 = 0x00000008, + .dram_sdqs0 = 0x00000038, + .dram_sdqs1 = 0x00000030, + .dram_reset = 0x00000030, +}; + +static struct mx6_mmdc_calibration mx6_mmcd_calib = { + .p0_mpwldectrl0 = 0x00070007, + .p0_mpdgctrl0 = 0x41490145, + .p0_mprddlctl = 0x40404546, + .p0_mpwrdlctl = 0x4040524D, +}; + +struct mx6_ddr_sysinfo ddr_sysinfo = { + .dsize = 0, + .cs_density = 20, + .ncs = 1, + .cs1_mirror = 0, + .rtt_wr = 2, + .rtt_nom = 1, /* RTT_Nom = RZQ/2 */ + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .ddr_type = DDR_TYPE_DDR3, +}; + +static struct mx6_ddr3_cfg mem_ddr = { + .mem_speed = 800, + .density = 4, + .width = 16, + .banks = 8, +#ifdef TARGET_MX6UL_ISIOT + .rowaddr = 15, +#else + .rowaddr = 13, +#endif + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; +#endif /* CONFIG_MX6UL */
static void ccgr_init(void) { struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
+#ifdef CONFIG_MX6QDL writel(0x00003F3F, &ccm->CCGR0); writel(0x0030FC00, &ccm->CCGR1); writel(0x000FC000, &ccm->CCGR2); @@ -246,6 +321,15 @@ static void ccgr_init(void) writel(0xFF00F300, &ccm->CCGR4); writel(0x0F0000C3, &ccm->CCGR5); writel(0x000003CC, &ccm->CCGR6); +#elif CONFIG_MX6UL + writel(0x00c03f3f, &ccm->CCGR0); + writel(0xfcffff00, &ccm->CCGR1); + writel(0x0cffffcc, &ccm->CCGR2); + writel(0x3f3c3030, &ccm->CCGR3); + writel(0xff00fffc, &ccm->CCGR4); + writel(0x033f30ff, &ccm->CCGR5); + writel(0x00c00fff, &ccm->CCGR6); +#endif }
static void gpr_init(void) @@ -261,6 +345,7 @@ static void gpr_init(void)
static void spl_dram_init(void) { +#ifdef CONFIG_MX6QDL if (is_mx6solo()) { mx6sdl_dram_iocfg(32, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); mx6_dram_cfg(&mem_s, &mx6dl_mmdc_calib, &mt41j256); @@ -271,6 +356,10 @@ static void spl_dram_init(void) mx6dq_dram_iocfg(64, &mx6dq_ddr_ioregs, &mx6dq_grp_ioregs); mx6_dram_cfg(&mem_q, &mx6dq_mmdc_calib, &mt41j256); } +#elif CONFIG_MX6UL + mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); +#endif
udelay(100); } @@ -285,7 +374,7 @@ void board_init_f(ulong dummy) gpr_init();
/* iomux */ - SETUP_IOMUX_PADS(uart4_pads); + SETUP_IOMUX_PADS(uart_pads);
/* setup GP timer */ timer_init(); diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index 06a286b..408b476 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -151,21 +151,6 @@ int dram_init(void) }
#ifdef CONFIG_SPL_BUILD -#include <libfdt.h> -#include <spl.h> - -#include <asm/arch/crm_regs.h> -#include <asm/arch/mx6-ddr.h> - -#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const uart1_pads[] = { - IOMUX_PADS(PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL)), -}; - /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -243,111 +228,4 @@ int board_mmc_init(bd_t *bis) return 0; } #endif /* CONFIG_FSL_ESDHC */ - -static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = { - .grp_addds = 0x00000030, - .grp_ddrmode_ctl = 0x00020000, - .grp_b0ds = 0x00000030, - .grp_ctlds = 0x00000030, - .grp_b1ds = 0x00000030, - .grp_ddrpke = 0x00000000, - .grp_ddrmode = 0x00020000, - .grp_ddr_type = 0x000c0000, -}; - -static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { - .dram_dqm0 = 0x00000030, - .dram_dqm1 = 0x00000030, - .dram_ras = 0x00000030, - .dram_cas = 0x00000030, - .dram_odt0 = 0x00000030, - .dram_odt1 = 0x00000030, - .dram_sdba2 = 0x00000000, - .dram_sdclk_0 = 0x00000008, - .dram_sdqs0 = 0x00000038, - .dram_sdqs1 = 0x00000030, - .dram_reset = 0x00000030, -}; - -static struct mx6_mmdc_calibration mx6_mmcd_calib = { - .p0_mpwldectrl0 = 0x00070007, - .p0_mpdgctrl0 = 0x41490145, - .p0_mprddlctl = 0x40404546, - .p0_mpwrdlctl = 0x4040524D, -}; - -struct mx6_ddr_sysinfo ddr_sysinfo = { - .dsize = 0, - .cs_density = 20, - .ncs = 1, - .cs1_mirror = 0, - .rtt_wr = 2, - .rtt_nom = 1, /* RTT_Nom = RZQ/2 */ - .walat = 1, /* Write additional latency */ - .ralat = 5, /* Read additional latency */ - .mif3_mode = 3, /* Command prediction working mode */ - .bi_on = 1, /* Bank interleaving enabled */ - .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ - .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ - .ddr_type = DDR_TYPE_DDR3, -}; - -static struct mx6_ddr3_cfg mem_ddr = { - .mem_speed = 800, - .density = 4, - .width = 16, - .banks = 8, - .rowaddr = 13, - .coladdr = 10, - .pagesz = 2, - .trcd = 1375, - .trcmin = 4875, - .trasmin = 3500, -}; - -static void ccgr_init(void) -{ - struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - - writel(0xFFFFFFFF, &ccm->CCGR0); - writel(0xFFFFFFFF, &ccm->CCGR1); - writel(0xFFFFFFFF, &ccm->CCGR2); - writel(0xFFFFFFFF, &ccm->CCGR3); - writel(0xFFFFFFFF, &ccm->CCGR4); - writel(0xFFFFFFFF, &ccm->CCGR5); - writel(0xFFFFFFFF, &ccm->CCGR6); - writel(0xFFFFFFFF, &ccm->CCGR7); -} - -static void spl_dram_init(void) -{ - mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); - mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); -} - -void board_init_f(ulong dummy) -{ - /* setup AIPS and disable watchdog */ - arch_cpu_init(); - - ccgr_init(); - - /* iomux and setup of i2c */ - SETUP_IOMUX_PADS(uart1_pads); - - /* setup GP timer */ - timer_init(); - - /* UART clocks enabled and gd valid - init serial console */ - preloader_console_init(); - - /* DDR initialization */ - spl_dram_init(); - - /* Clear the BSS. */ - memset(__bss_start, 0, __bss_end - __bss_start); - - /* load/boot image from boot device */ - board_init_r(NULL, 0); -} #endif /* CONFIG_SPL_BUILD */ diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index d6a63d2..fa36519 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -163,21 +163,8 @@ int dram_init(void) }
-#include <asm/arch/crm_regs.h> -#include <asm/arch/mx6-ddr.h> - -#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const uart1_pads[] = { - IOMUX_PADS(PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL)), -}; - /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) #include <mmc.h> @@ -304,110 +291,4 @@ void board_boot_order(u32 *spl_boot_list) } #endif #endif /* CONFIG_FSL_ESDHC */ - -static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = { - .grp_addds = 0x00000030, - .grp_ddrmode_ctl = 0x00020000, - .grp_b0ds = 0x00000030, - .grp_ctlds = 0x00000030, - .grp_b1ds = 0x00000030, - .grp_ddrpke = 0x00000000, - .grp_ddrmode = 0x00020000, - .grp_ddr_type = 0x000c0000, -}; - -static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { - .dram_dqm0 = 0x00000030, - .dram_dqm1 = 0x00000030, - .dram_ras = 0x00000030, - .dram_cas = 0x00000030, - .dram_odt0 = 0x00000030, - .dram_odt1 = 0x00000030, - .dram_sdba2 = 0x00000000, - .dram_sdclk_0 = 0x00000008, - .dram_sdqs0 = 0x00000038, - .dram_sdqs1 = 0x00000030, - .dram_reset = 0x00000030, -}; - -static struct mx6_mmdc_calibration mx6_mmcd_calib = { - .p0_mpwldectrl0 = 0x00070007, - .p0_mpdgctrl0 = 0x41490145, - .p0_mprddlctl = 0x40404546, - .p0_mpwrdlctl = 0x4040524D, -}; - -struct mx6_ddr_sysinfo ddr_sysinfo = { - .dsize = 0, - .cs_density = 20, - .ncs = 1, - .cs1_mirror = 0, - .rtt_wr = 2, - .rtt_nom = 1, /* RTT_Nom = RZQ/2 */ - .walat = 1, /* Write additional latency */ - .ralat = 5, /* Read additional latency */ - .mif3_mode = 3, /* Command prediction working mode */ - .bi_on = 1, /* Bank interleaving enabled */ - .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ - .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ - .ddr_type = DDR_TYPE_DDR3, -}; - -static struct mx6_ddr3_cfg mem_ddr = { - .mem_speed = 800, - .density = 4, - .width = 16, - .banks = 8, - .rowaddr = 15, - .coladdr = 10, - .pagesz = 2, - .trcd = 1375, - .trcmin = 4875, - .trasmin = 3500, -}; - -static void ccgr_init(void) -{ - struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - - writel(0x00c03f3f, &ccm->CCGR0); - writel(0xfcffff00, &ccm->CCGR1); - writel(0x0cffffcc, &ccm->CCGR2); - writel(0x3f3c3030, &ccm->CCGR3); - writel(0xff00fffc, &ccm->CCGR4); - writel(0x033f30ff, &ccm->CCGR5); - writel(0x00c00fff, &ccm->CCGR6); -} - -static void spl_dram_init(void) -{ - mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); - mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); -} - -void board_init_f(ulong dummy) -{ - /* setup AIPS and disable watchdog */ - arch_cpu_init(); - - ccgr_init(); - - /* iomux and setup of i2c */ - SETUP_IOMUX_PADS(uart1_pads); - - /* setup GP timer */ - timer_init(); - - /* UART clocks enabled and gd valid - init serial console */ - preloader_console_init(); - - /* DDR initialization */ - spl_dram_init(); - - /* Clear the BSS. */ - memset(__bss_start, 0, __bss_end - __bss_start); - - /* load/boot image from boot device */ - board_init_r(NULL, 0); -} #endif /* CONFIG_SPL_BUILD */
Move possible common board code into common area from supported boards.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/common/Makefile | 1 + board/engicam/common/board.c | 56 +++++++++++++++++++++++++++++++++ board/engicam/common/board.h | 12 +++++++ board/engicam/geam6ul/geam6ul.c | 41 ++---------------------- board/engicam/icorem6/icorem6.c | 47 +++------------------------ board/engicam/icorem6_rqs/icorem6_rqs.c | 33 ++----------------- board/engicam/isiotmx6ul/isiotmx6ul.c | 38 ++-------------------- 7 files changed, 81 insertions(+), 147 deletions(-) create mode 100644 board/engicam/common/board.c create mode 100644 board/engicam/common/board.h
diff --git a/board/engicam/common/Makefile b/board/engicam/common/Makefile index 6fd039c..6630fea 100644 --- a/board/engicam/common/Makefile +++ b/board/engicam/common/Makefile @@ -3,4 +3,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-y := board.o obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/engicam/common/board.c b/board/engicam/common/board.c new file mode 100644 index 0000000..8a83608 --- /dev/null +++ b/board/engicam/common/board.c @@ -0,0 +1,56 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * Author: Jagan Teki jagan@amarulasolutions.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <mmc.h> +#include <asm/arch/sys_proto.h> + +#include "board.h" + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_ENV_IS_IN_MMC +void mmc_late_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + setenv_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); + setenv("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} +#endif + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_NAND_MXS + setup_gpmi_nand(); +#endif + +#ifdef CONFIG_VIDEO_IPUV3 + setup_display(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} diff --git a/board/engicam/common/board.h b/board/engicam/common/board.h new file mode 100644 index 0000000..9717e40 --- /dev/null +++ b/board/engicam/common/board.h @@ -0,0 +1,12 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _BOARD_H_ +#define _BOARD_H_ +void mmc_late_init(void); +void setup_gpmi_nand(void); +void setup_display(void); +#endif /* _BOARD_H_ */ diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index 408b476..c992035 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -20,6 +20,8 @@ #include <asm/arch/sys_proto.h> #include <asm/imx-common/iomux-v3.h>
+#include "../common/board.h" + DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_NAND_MXS @@ -47,7 +49,7 @@ static iomux_v3_cfg_t const nand_pads[] = { IOMUX_PADS(PAD_NAND_READY_B__RAWNAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), };
-static void setup_gpmi_nand(void) +void setup_gpmi_nand(void) { struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
@@ -88,24 +90,6 @@ static void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
-#ifdef CONFIG_ENV_IS_IN_MMC -static void mmc_late_init(void) -{ - char cmd[32]; - char mmcblk[32]; - u32 dev_no = mmc_get_env_dev(); - - setenv_ulong("mmcdev", dev_no); - - /* Set mmcblk env */ - sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); - setenv("mmcroot", mmcblk); - - sprintf(cmd, "mmc dev %d", dev_no); - run_command(cmd, 0); -} -#endif - int board_late_init(void) { switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> @@ -131,25 +115,6 @@ int board_late_init(void) return 0; }
-int board_init(void) -{ - /* Address of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; - -#ifdef CONFIG_NAND_MXS - setup_gpmi_nand(); -#endif - - return 0; -} - -int dram_init(void) -{ - gd->ram_size = imx_ddr_size(); - - return 0; -} - #ifdef CONFIG_SPL_BUILD /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index a881d83..cb4613b 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -21,6 +21,8 @@ #include <asm/imx-common/iomux-v3.h> #include <asm/imx-common/video.h>
#ifdef CONFIG_NAND_MXS @@ -48,7 +50,7 @@ iomux_v3_cfg_t gpmi_pads[] = { IOMUX_PADS(PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), };
@@ -141,7 +143,7 @@ struct display_info_t const displays[] = {
size_t display_count = ARRAY_SIZE(displays);
-static void setup_display(void) +void setup_display(void) { struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; @@ -190,24 +192,6 @@ static void setup_display(void) } #endif /* CONFIG_VIDEO_IPUV3 */
-#ifdef CONFIG_ENV_IS_IN_MMC -static void mmc_late_init(void) -{ - char cmd[32]; - char mmcblk[32]; - u32 dev_no = mmc_get_env_dev(); - - setenv_ulong("mmcdev", dev_no); - - /* Set mmcblk env */ - sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); - setenv("mmcroot", mmcblk); - - sprintf(cmd, "mmc dev %d", dev_no); - run_command(cmd, 0); -} -#endif - int board_late_init(void) { switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> @@ -235,29 +219,6 @@ int board_late_init(void) return 0; }
-int board_init(void) -{ - /* Address of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; - -#ifdef CONFIG_NAND_MXS - setup_gpmi_nand(); -#endif - -#ifdef CONFIG_VIDEO_IPUV3 - setup_display(); -#endif - - return 0; -} - -int dram_init(void) -{ - gd->ram_size = imx_ddr_size(); - - return 0; -} - #ifdef CONFIG_SPL_BUILD /* MMC board initialization is needed till adding DM support in SPL */ #if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 854a34e..bdd9e0e 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -20,15 +20,9 @@ #include <asm/arch/sys_proto.h> #include <asm/imx-common/iomux-v3.h>
-DECLARE_GLOBAL_DATA_PTR; - -int board_init(void) -{ - /* Address of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; +#include "../common/board.h"
- return 0; -} +DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_ENV_IS_IN_MMC int board_mmc_get_env_dev(int devno) @@ -36,22 +30,6 @@ int board_mmc_get_env_dev(int devno) /* dev 0 for SD/eSD, dev 1 for MMC/eMMC */ return (devno == 3) ? 1 : 0; } - -static void mmc_late_init(void) -{ - char cmd[32]; - char mmcblk[32]; - u32 dev_no = mmc_get_env_dev(); - - setenv_ulong("mmcdev", dev_no); - - /* Set mmcblk env */ - sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); - setenv("mmcroot", mmcblk); - - sprintf(cmd, "mmc dev %d", dev_no); - run_command(cmd, 0); -} #endif
int board_late_init(void) @@ -80,13 +58,6 @@ int board_late_init(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = imx_ddr_size(); - - return 0; -} - #ifdef CONFIG_SPL_BUILD #include <spl.h>
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index fa36519..6607b04 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -20,6 +20,8 @@ #include <asm/arch/sys_proto.h> #include <asm/imx-common/iomux-v3.h>
@@ -94,22 +96,6 @@ int board_mmc_get_env_dev(int devno) /* dev 0 for SD/eSD, dev 1 for MMC/eMMC */ return (devno == 0) ? 0 : 1; } - -static void mmc_late_init(void) -{ - char cmd[32]; - char mmcblk[32]; - u32 dev_no = mmc_get_env_dev(); - - setenv_ulong("mmcdev", dev_no); - - /* Set mmcblk env */ - sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); - setenv("mmcroot", mmcblk); - - sprintf(cmd, "mmc dev %d", dev_no); - run_command(cmd, 0); -} #endif
int board_late_init(void) @@ -144,24 +130,6 @@ int board_late_init(void) return 0; }
-int board_init(void) -{ - /* Address of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; - -#ifdef CONFIG_NAND_MXS - setup_gpmi_nand(); -#endif - return 0; -} - -int dram_init(void) -{ - gd->ram_size = imx_ddr_size(); - - return 0; -} - #ifdef CONFIG_SPL_BUILD #include <spl.h>
Move board_late_init into common area from supported boards.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/common/board.c | 28 +++++++++++++++++++++++++++- board/engicam/common/board.h | 2 +- board/engicam/geam6ul/geam6ul.c | 21 +-------------------- board/engicam/icorem6/icorem6.c | 21 +-------------------- board/engicam/icorem6_rqs/icorem6_rqs.c | 20 +------------------- board/engicam/isiotmx6ul/isiotmx6ul.c | 23 +---------------------- 6 files changed, 32 insertions(+), 83 deletions(-)
diff --git a/board/engicam/common/board.c b/board/engicam/common/board.c index 8a83608..af4ef28 100644 --- a/board/engicam/common/board.c +++ b/board/engicam/common/board.c @@ -15,7 +15,7 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_ENV_IS_IN_MMC -void mmc_late_init(void) +static void mmc_late_init(void) { char cmd[32]; char mmcblk[32]; @@ -32,6 +32,32 @@ void mmc_late_init(void) } #endif
+int board_late_init(void) +{ + switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> + IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: +#ifdef CONFIG_ENV_IS_IN_MMC + mmc_late_init(); +#endif + setenv("modeboot", "mmcboot"); + break; + case IMX6_BMODE_NAND: + setenv("modeboot", "nandboot"); + break; + default: + setenv("modeboot", ""); + break; + } + + setenv_fdt_file(); + + return 0; +} + int board_init(void) { /* Address of boot parameters */ diff --git a/board/engicam/common/board.h b/board/engicam/common/board.h index 9717e40..f364a23 100644 --- a/board/engicam/common/board.h +++ b/board/engicam/common/board.h @@ -6,7 +6,7 @@
#ifndef _BOARD_H_ #define _BOARD_H_ -void mmc_late_init(void); +void setenv_fdt_file(void); void setup_gpmi_nand(void); void setup_display(void); #endif /* _BOARD_H_ */ diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index c992035..841ade9 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -90,29 +90,10 @@ void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
-int board_late_init(void) +void setenv_fdt_file(void) { - switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> - IMX6_BMODE_SHIFT) { - case IMX6_BMODE_SD: - case IMX6_BMODE_ESD: -#ifdef CONFIG_ENV_IS_IN_MMC - mmc_late_init(); -#endif - setenv("modeboot", "mmcboot"); - break; - case IMX6_BMODE_NAND: - setenv("modeboot", "nandboot"); - break; - default: - setenv("modeboot", ""); - break; - } - if (is_mx6ul()) setenv("fdt_file", "imx6ul-geam-kit.dtb"); - - return 0; }
#ifdef CONFIG_SPL_BUILD diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index cb4613b..74cbbc5 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -192,31 +192,12 @@ void setup_display(void) } #endif /* CONFIG_VIDEO_IPUV3 */
-int board_late_init(void) +void setenv_fdt_file(void) { - switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> - IMX6_BMODE_SHIFT) { - case IMX6_BMODE_SD: - case IMX6_BMODE_ESD: -#ifdef CONFIG_ENV_IS_IN_MMC - mmc_late_init(); -#endif - setenv("modeboot", "mmcboot"); - break; - case IMX6_BMODE_NAND: - setenv("modeboot", "nandboot"); - break; - default: - setenv("modeboot", ""); - break; - } - if (is_mx6dq()) setenv("fdt_file", "imx6q-icore.dtb"); else if(is_mx6dl() || is_mx6solo()) setenv("fdt_file", "imx6dl-icore.dtb"); - - return 0; }
#ifdef CONFIG_SPL_BUILD diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index bdd9e0e..c3c3173 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -32,30 +32,12 @@ int board_mmc_get_env_dev(int devno) } #endif
-int board_late_init(void) +void setenv_fdt_file(void) { - switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> - IMX6_BMODE_SHIFT) { - case IMX6_BMODE_SD: - case IMX6_BMODE_ESD: - case IMX6_BMODE_MMC: - case IMX6_BMODE_EMMC: -#ifdef CONFIG_ENV_IS_IN_MMC - mmc_late_init(); -#endif - setenv("modeboot", "mmcboot"); - break; - default: - setenv("modeboot", ""); - break; - } - if (is_mx6dq()) setenv("fdt_file", "imx6q-icore-rqs.dtb"); else if(is_mx6dl() || is_mx6solo()) setenv("fdt_file", "imx6dl-icore-rqs.dtb"); - - return 0; }
#ifdef CONFIG_SPL_BUILD diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 6607b04..105db73 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -98,27 +98,8 @@ int board_mmc_get_env_dev(int devno) } #endif
-int board_late_init(void) +void setenv_fdt_file(void) { - switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> - IMX6_BMODE_SHIFT) { - case IMX6_BMODE_SD: - case IMX6_BMODE_ESD: - case IMX6_BMODE_MMC: - case IMX6_BMODE_EMMC: -#ifdef CONFIG_ENV_IS_IN_MMC - mmc_late_init(); -#endif - setenv("modeboot", "mmcboot"); - break; - case IMX6_BMODE_NAND: - setenv("modeboot", "nandboot"); - break; - default: - setenv("modeboot", ""); - break; - } - if (is_mx6ul()) { #ifdef CONFIG_ENV_IS_IN_MMC setenv("fdt_file", "imx6ul-isiot-emmc.dtb"); @@ -126,8 +107,6 @@ int board_late_init(void) setenv("fdt_file", "imx6ul-isiot-nand.dtb"); #endif } - - return 0; }
On 06/05/2017 23:12, Jagan Teki wrote:
Engicam boards have some common code, so move them as (1) SPL board_init_f and UART MUX init to common/spl.c (2) board_init, dram_init, board_late_init and mmc_late_init to common/board.c
This series also add board_fit_config_name_match to make SPL to pick suitable fdt, so reduced few defconifg files.
Nice cleanup - no comment from my side.
Best regards, Stefano Babic
thanks! Jagan.
Jagan Teki (16): icorem6: Add modeboot env via board_late_init icorem6: Add mmc_late_init geam6ul: Add modeboot env via board_late_init geam6ul: Add mmc_late_init engicam: Set fdt_file env during run-time icorem6: Make SPL to pick suitable fdt engicam: Move uart mux init to SPL icorem6: Use proper iomux_ddr_regs drive strength values icorem6: Use drive strength macros i.MX6UL: geam6ul: Add SETUP_IOMUX_PADS isiot: Fix to use usdhc2_pads for mmc2 i.MX6UL: isiot: Add SETUP_IOMUX_PADS icorem6[_rqs]: Move the spl code common geam6/isiot: Move the spl code common engicam: common: Move common board code engicam: common: Move board_late_init
arch/arm/cpu/armv7/mx6/Kconfig | 6 + arch/arm/include/asm/imx-common/iomux-v3.h | 6 + board/engicam/common/Makefile | 7 + board/engicam/common/board.c | 82 +++++ board/engicam/common/board.h | 12 + board/engicam/common/spl.c | 393 +++++++++++++++++++++ board/engicam/geam6ul/geam6ul.c | 206 ++--------- board/engicam/icorem6/MAINTAINERS | 6 +- board/engicam/icorem6/icorem6.c | 330 +---------------- board/engicam/icorem6_rqs/MAINTAINERS | 3 +- board/engicam/icorem6_rqs/icorem6_rqs.c | 352 +----------------- board/engicam/isiotmx6ul/isiotmx6ul.c | 261 +++----------- configs/imx6dl_icore_mmc_defconfig | 44 --- configs/imx6dl_icore_nand_defconfig | 45 --- configs/imx6dl_icore_rqs_mmc_defconfig | 41 --- configs/imx6q_icore_nand_defconfig | 45 --- ...e_mmc_defconfig => imx6qdl_icore_mmc_defconfig} | 2 +- ...c_defconfig => imx6qdl_icore_rqs_mmc_defconfig} | 2 +- configs/imx6ul_geam_mmc_defconfig | 1 - configs/imx6ul_geam_nand_defconfig | 1 - configs/imx6ul_isiot_emmc_defconfig | 1 - configs/imx6ul_isiot_mmc_defconfig | 1 - configs/imx6ul_isiot_nand_defconfig | 1 - include/configs/imx6qdl_icore.h | 39 +- include/configs/imx6qdl_icore_rqs.h | 1 - include/configs/imx6ul_geam.h | 38 +- include/configs/imx6ul_isiot.h | 1 - 27 files changed, 655 insertions(+), 1272 deletions(-) create mode 100644 board/engicam/common/Makefile create mode 100644 board/engicam/common/board.c create mode 100644 board/engicam/common/board.h create mode 100644 board/engicam/common/spl.c delete mode 100644 configs/imx6dl_icore_mmc_defconfig delete mode 100644 configs/imx6dl_icore_nand_defconfig delete mode 100644 configs/imx6dl_icore_rqs_mmc_defconfig delete mode 100644 configs/imx6q_icore_nand_defconfig rename configs/{imx6q_icore_mmc_defconfig => imx6qdl_icore_mmc_defconfig} (96%) rename configs/{imx6q_icore_rqs_mmc_defconfig => imx6qdl_icore_rqs_mmc_defconfig} (95%)
Jagan Teki
Stefano Babic
