[U-Boot] [PATCH v1 0/2] Update STM32 QSPI driver
This series : _ assign operation mode in _stm32_qspi_gen_ccr() _ rework mode management to solve quad read issue with Macronix/Micron spi nor.
Christophe Kerello (2): spi: stm32_qspi: assign functional operation mode in _stm32_qspi_gen_ccr spi: stm32_qspi: rework mode management
drivers/spi/stm32_qspi.c | 45 ++++++++++++++++++++++----------------------- 1 file changed, 22 insertions(+), 23 deletions(-)
This patch assigns the functional operation mode in _stm32_qspi_gen_ccr function.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
drivers/spi/stm32_qspi.c | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index f6cc35336320..81b84625ba5b 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -220,7 +220,7 @@ static void _stm32_qspi_set_cs(struct stm32_qspi_priv *priv, unsigned int cs) cs ? STM32_QSPI_CR_FSEL : 0); }
-static unsigned int _stm32_qspi_gen_ccr(struct stm32_qspi_priv *priv) +static unsigned int _stm32_qspi_gen_ccr(struct stm32_qspi_priv *priv, u8 fmode) { unsigned int ccr_reg = 0; u8 imode, admode, dmode; @@ -258,8 +258,11 @@ static unsigned int _stm32_qspi_gen_ccr(struct stm32_qspi_priv *priv) << STM32_QSPI_CCR_ADSIZE_SHIFT); ccr_reg |= (admode << STM32_QSPI_CCR_ADMODE_SHIFT); } + + ccr_reg |= (fmode << STM32_QSPI_CCR_FMODE_SHIFT); ccr_reg |= (imode << STM32_QSPI_CCR_IMODE_SHIFT); ccr_reg |= cmd; + return ccr_reg; }
@@ -272,8 +275,7 @@ static void _stm32_qspi_enable_mmap(struct stm32_qspi_priv *priv, | CMD_HAS_DUMMY; priv->dummycycles = flash->dummy_byte * 8;
- ccr_reg = _stm32_qspi_gen_ccr(priv); - ccr_reg |= (STM32_QSPI_CCR_MEM_MAP << STM32_QSPI_CCR_FMODE_SHIFT); + ccr_reg = _stm32_qspi_gen_ccr(priv, STM32_QSPI_CCR_MEM_MAP);
_stm32_qspi_wait_for_not_busy(priv);
@@ -359,9 +361,8 @@ static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv, }
if (flags & SPI_XFER_END) { - ccr_reg = _stm32_qspi_gen_ccr(priv); - ccr_reg |= STM32_QSPI_CCR_IND_WRITE - << STM32_QSPI_CCR_FMODE_SHIFT; + ccr_reg = _stm32_qspi_gen_ccr(priv, + STM32_QSPI_CCR_IND_WRITE);
@@ -392,9 +393,7 @@ static int _stm32_qspi_xfer(struct stm32_qspi_priv *priv, } } } else if (din) { - ccr_reg = _stm32_qspi_gen_ccr(priv); - ccr_reg |= STM32_QSPI_CCR_IND_READ - << STM32_QSPI_CCR_FMODE_SHIFT; + ccr_reg = _stm32_qspi_gen_ccr(priv, STM32_QSPI_CCR_IND_READ);
This patch solves quad read issue with Macronix/Micron spi nor.
drivers/spi/stm32_qspi.c | 28 ++++++++++++++-------------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 81b84625ba5b..3b92254a5ce1 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -229,21 +229,21 @@ static unsigned int _stm32_qspi_gen_ccr(struct stm32_qspi_priv *priv, u8 fmode)
imode = STM32_QSPI_CCR_IMODE_ONE_LINE; admode = STM32_QSPI_CCR_ADMODE_ONE_LINE; - - if (mode & SPI_RX_QUAD) { - dmode = STM32_QSPI_CCR_DMODE_FOUR_LINE; - if (mode & SPI_TX_QUAD) { - imode = STM32_QSPI_CCR_IMODE_FOUR_LINE; - admode = STM32_QSPI_CCR_ADMODE_FOUR_LINE; - } - } else if (mode & SPI_RX_DUAL) { - dmode = STM32_QSPI_CCR_DMODE_TWO_LINE; - if (mode & SPI_TX_DUAL) { - imode = STM32_QSPI_CCR_IMODE_TWO_LINE; - admode = STM32_QSPI_CCR_ADMODE_TWO_LINE; + dmode = STM32_QSPI_CCR_DMODE_ONE_LINE; + + if ((priv->command & CMD_HAS_ADR) && (priv->command & CMD_HAS_DATA)) { + if (fmode == STM32_QSPI_CCR_IND_WRITE) { + if (mode & SPI_TX_QUAD) + dmode = STM32_QSPI_CCR_DMODE_FOUR_LINE; + else if (mode & SPI_TX_DUAL) + dmode = STM32_QSPI_CCR_DMODE_TWO_LINE; + } else if ((fmode == STM32_QSPI_CCR_MEM_MAP) || + (fmode == STM32_QSPI_CCR_IND_READ)) { + if (mode & SPI_RX_QUAD) + dmode = STM32_QSPI_CCR_DMODE_FOUR_LINE; + else if (mode & SPI_RX_DUAL) + dmode = STM32_QSPI_CCR_DMODE_TWO_LINE; } - } else { - dmode = STM32_QSPI_CCR_DMODE_ONE_LINE; }
if (priv->command & CMD_HAS_DATA)
Patrice Chotard
