[U-Boot] [U-BOOT] nand merge problem
Hi I have try to merge Ingenic U-boot (1.1.6) with upstream. but I have some problem 1. there is no -- NAND_CTL_SETNCE: NAND_CTL_CLRNCE: NAND_CTL_SETCLE: NAND_CTL_CLRCLE: NAND_CTL_SETALE: NAND_CTL_CLRALE: instead of : -- NAND_NCE: NAND_CLE: NAND_ALE: NAND_CTRL_CLE: NAND_CTRL_ALE: NAND_CTRL_CHANGE:
I use the NAND_CTL_SETNCE... in the jz_hwcontrol function. i use "nand->hwcontrol = jz_hwcontrol" in the u-boot 1.1.6 but in the U-boot V2009-06 the nand_chip structure does not have "hwcontrol" function.
what am I gonna do?
thanks for help.
Best Regards Xiangfu Liu
jabber : xiangfu.z@gmail.com skype : xiangfu.z
Please avoid sending me Word or PowerPoint attachments. See http://www.gnu.org/philosophy/no-word-attachments.html
Hi I rewrite the jz_hwcontrol to : -- static void jz_hwcontrol(......) { ...... if (ctrl & NAND_CTRL_CHANGE) { if (ctrl & NAND_NCE) REG_EMC_NFCSR |= EMC_NFCSR_NFCE1; else REG_EMC_NFCSR &= ~EMC_NFCSR_NFCE1;
if (ctrl & NAND_CLE) ...... } } and " nand->cmd_ctrl = jz_hwcontrol; " in board_nand_init
but it's still not work: the error message: -- NAND: nand_get_flash_type: second ID read did not match ff,ff against 00,00 No NAND device found!!!
0 MiB --
what can cause this problem?
thanks
0 MiB
It would be helpful if you were to post the entire hwcontrol, so we can see what's hiding behind those "......"s.
Posting the original legacy NAND defines for this board would be helpful as well.
-Scott
Hi Scott
static void jz_hwcontrol(......) { ...... } and " nand->cmd_ctrl = jz_hwcontrol; " in board_nand_init
0 MiB
here is the entire hwontrol static void jz_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct nand_chip *this = (struct nand_chip *)(mtd->priv);
if (ctrl & NAND_CLE) this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) | 0x00008000); else this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) & ~0x00008000);
if (ctrl & NAND_ALE) this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) | 0x00010000); else this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) & ~0x00010000);
I don't know which code should I post. so I post the git URL: http://github.com/xiangfu/pi-u-boot/tree/xiangfu
-Scott
thanks
if (ctrl & NAND_CLE) this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) | 0x00008000); else this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) & ~0x00008000); if (ctrl & NAND_ALE) this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) | 0x00010000); else this->IO_ADDR_W = (void __iomem *) ((unsigned long)(this->IO_ADDR_W) & ~0x00010000);
Nowhere in this function do you issue the command... See cpu/ppc4xx/ndfc.c for a simple hwcontrol function.
-Scott
Scott Wood
xiangfu_gmail
