[PATCH] Kconfig: Don't use RSA_FREESCALE_EXP on MX7ULP
The CAAM on IMX7ULP doesn't support public key hardware acceleration (PKHA), as in other NXP parts. Disable RSA_FREESCALE_EXP for IMX7ULP too.
Fixed: f4e9ff7135 ("Kconfig: Don't use RSA_FREESCALE_EXP on IMX") Signed-off-by: Ricardo Salveti ricardo@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
lib/rsa/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/rsa/Kconfig b/lib/rsa/Kconfig index a90d67e5a8..55e17596f0 100644 --- a/lib/rsa/Kconfig +++ b/lib/rsa/Kconfig @@ -1,6 +1,6 @@ config RSA bool "Use RSA Library" - select RSA_FREESCALE_EXP if FSL_CAAM && !ARCH_MX7 && !ARCH_MX6 && !ARCH_MX5 + select RSA_FREESCALE_EXP if FSL_CAAM && !ARCH_MX7 && !ARCH_MX7ULP && !ARCH_MX6 && !ARCH_MX5 select RSA_SOFTWARE_EXP if !RSA_FREESCALE_EXP help RSA support. This enables the RSA algorithm used for FIT image
- select RSA_FREESCALE_EXP if FSL_CAAM && !ARCH_MX7 && !ARCH_MX7ULP && !ARCH_MX6 && !ARCH_MX5 select RSA_SOFTWARE_EXP if !RSA_FREESCALE_EXP help RSA support. This enables the RSA algorithm used for FIT image
What iMX families does this work on? I think we need to look at fixing the logic to be a bit more restrictive to start with, instead of opting families out.
Frankly, I dunno. We fix what doesn't work. Investigating all imx families and reworking everything around would take much more time and can't be done right now. Anyway, thanks for your question, I rechecked the patch and improved it. The v2 is coming.
-- Tom
-- Best regards,
Oleksandr Suvorov Software Engineer W: www.foundries.io
Oleksandr Suvorov
