[PATCH v1] gpio: octeon_gpio: Add GPIO controller driver for Octeon
Add support for GPIO controllers found on Octeon II/III and Octeon TX TX2 SoC platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Suneel Garapati sgarapati@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Aaron Williams awilliams@marvell.com Cc: Chandrakala Chavva cchavva@marvell.com --- RFC -> v1 (Stefan) - Separated this patch from the OcteonTX/TX2 RFC patch series into a single patch. This is useful, as the upcoming MIPS Octeon support will use this GPIO driver. - Added MIPS Octeon II/III support (big endian). Rename driver and its function names from "octeontx" to "octeon" to better match all Octeon platforms. - Moved from union to defines / bitmasks. This makes the driver usage on little- and big-endian platforms much easier. - Used clrbits_64() instead of clrbits_le64() and friends to support usage on little- and big-endian systems - Removed dev->req_seq assignment - Enhanced Kconfig text - Rewrote GPIO_BIT macro - Dropped many macros to calculate the registers offsets and implemented simple functions for this (easier to read) - Used GENMASK_ULL and FIELD_GET helpers - Minor cosmetic changes (dropped brackets etc) - Reword commit text and subject
drivers/gpio/Kconfig | 10 ++ drivers/gpio/Makefile | 1 + drivers/gpio/octeon_gpio.c | 241 +++++++++++++++++++++++++++++++++++++ 3 files changed, 252 insertions(+) create mode 100644 drivers/gpio/octeon_gpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 2081520f42..9c72930268 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -316,6 +316,16 @@ config PIC32_GPIO help Say yes here to support Microchip PIC32 GPIOs.
+config OCTEON_GPIO + bool "Octeon II/III/TX/TX2 GPIO driver" + depends on DM_GPIO && (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2) + default y + help + Add support for the Marvell Octeon GPIO driver. This is used with + various Octeon parts such as Octeon II/III and OcteonTX/TX2. + Octeon II/III has 32 GPIOs (count defined via DT) and OcteonTX/TX2 + has 64 GPIOs (count defined via internal register). + config STM32_GPIO bool "ST STM32 GPIO driver" depends on DM_GPIO && (STM32 || ARCH_STM32MP) diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 7638259007..eb6364adb4 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -58,6 +58,7 @@ obj-$(CONFIG_HIKEY_GPIO) += hi6220_gpio.o obj-$(CONFIG_HSDK_CREG_GPIO) += hsdk-creg-gpio.o obj-$(CONFIG_IMX_RGPIO2P) += imx_rgpio2p.o obj-$(CONFIG_PIC32_GPIO) += pic32_gpio.o +obj-$(CONFIG_OCTEON_GPIO) += octeon_gpio.o obj-$(CONFIG_MVEBU_GPIO) += mvebu_gpio.o obj-$(CONFIG_MSM_GPIO) += msm_gpio.o obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o diff --git a/drivers/gpio/octeon_gpio.c b/drivers/gpio/octeon_gpio.c new file mode 100644 index 0000000000..8079f6c5d9 --- /dev/null +++ b/drivers/gpio/octeon_gpio.c @@ -0,0 +1,241 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <pci_ids.h> +#include <asm/bitops.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <linux/bitfield.h> +#include <dt-bindings/gpio/gpio.h> + +/* Returns the bit value to write or read based on the offset */ +#define GPIO_BIT(x) BIT_ULL((x) & 0x3f) + +/* Some offsets which are different on Octeon & OcteonTX/TX2 */ +#if defined(CONFIG_ARCH_OCTEON) +#define REG_OFFS 0x80 +#define GPIO_BIT_CFG_OFFS 0x100 +#else +#define REG_OFFS 0x00 +#define GPIO_BIT_CFG_OFFS 0x400 +#endif + +#define GPIO_RX_DAT (REG_OFFS + 0x00) +#define GPIO_TX_SET (REG_OFFS + 0x08) +#define GPIO_TX_CLR (REG_OFFS + 0x10) +#define GPIO_CONST (REG_OFFS + 0x90) /* OcteonTX only */ + +/* Offset to register-set for 2nd GPIOs (> 63), OcteonTX only */ +#define GPIO1_OFFSET 0x1400 + +/* GPIO_CONST register bits */ +#define GPIO_CONST_GPIOS_MASK GENMASK_ULL(7, 0) + +/* GPIO_BIT_CFG register bits */ +#define GPIO_BIT_CFG_TX_OE BIT_ULL(0) +#define GPIO_BIT_CFG_PIN_XOR BIT_ULL(1) +#define GPIO_BIT_CFG_INT_EN BIT_ULL(2) +#define GPIO_BIT_CFG_PIN_SEL_MASK GENMASK_ULL(26, 16) + +struct octeon_gpio { + void __iomem *base; +}; + +/* Returns the offset to the output register based on the offset and value */ +static u32 gpio_tx_reg(int offset, int value) +{ + u32 ret; + + ret = value ? GPIO_TX_SET : GPIO_TX_CLR; + if (offset > 63) + ret += GPIO1_OFFSET; + + return ret; +} + +/* Returns the offset to the input data register based on the offset */ +static u32 gpio_rx_dat_reg(int offset) +{ + u32 ret; + + ret = GPIO_RX_DAT; + if (offset > 63) + ret += GPIO1_OFFSET; + + return ret; +} + +/* Returns the bit configuration register based on the offset */ +static u32 gpio_bit_cfg_reg(int offset) +{ + return GPIO_BIT_CFG_OFFS + 8 * offset; +} + +static int octeon_gpio_dir_input(struct udevice *dev, unsigned int offset) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + + debug("%s(%s, %u)\n", __func__, dev->name, offset); + clrbits_64(gpio->base + gpio_bit_cfg_reg(offset), + GPIO_BIT_CFG_TX_OE | GPIO_BIT_CFG_PIN_XOR | + GPIO_BIT_CFG_INT_EN | GPIO_BIT_CFG_PIN_SEL_MASK); + + return 0; +} + +static int octeon_gpio_dir_output(struct udevice *dev, unsigned int offset, + int value) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + + debug("%s(%s, %u, %d)\n", __func__, dev->name, offset, value); + writeq(GPIO_BIT(offset), gpio->base + gpio_tx_reg(offset, value)); + + clrsetbits_64(gpio->base + gpio_bit_cfg_reg(offset), + GPIO_BIT_CFG_PIN_SEL_MASK | GPIO_BIT_CFG_INT_EN, + GPIO_BIT_CFG_TX_OE); + + return 0; +} + +static int octeon_gpio_get_value(struct udevice *dev, unsigned int offset) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + u64 reg = readq(gpio->base + gpio_rx_dat_reg(offset)); + + debug("%s(%s, %u): value: %d\n", __func__, dev->name, offset, + !!(reg & GPIO_BIT(offset))); + + return !!(reg & GPIO_BIT(offset)); +} + +static int octeon_gpio_set_value(struct udevice *dev, + unsigned int offset, int value) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + + debug("%s(%s, %u, %d)\n", __func__, dev->name, offset, value); + writeq(GPIO_BIT(offset), gpio->base + gpio_tx_reg(offset, value)); + + return 0; +} + +static int octeon_gpio_get_function(struct udevice *dev, unsigned int offset) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + u64 val = readq(gpio->base + gpio_bit_cfg_reg(offset)); + int pin_sel; + + debug("%s(%s, %u): GPIO_BIT_CFG: 0x%llx\n", __func__, dev->name, + offset, val); + pin_sel = FIELD_GET(GPIO_BIT_CFG_PIN_SEL_MASK, val); + if (pin_sel) + return GPIOF_FUNC; + else if (val & GPIO_BIT_CFG_TX_OE) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int octeon_gpio_xlate(struct udevice *dev, struct gpio_desc *desc, + struct ofnode_phandle_args *args) +{ + if (args->args_count < 1) + return -EINVAL; + + desc->offset = args->args[0]; + desc->flags = 0; + if (args->args_count > 1) { + if (args->args[1] & GPIO_ACTIVE_LOW) + desc->flags |= GPIOD_ACTIVE_LOW; + /* In the future add tri-state flag support */ + } + return 0; +} + +static const struct dm_gpio_ops octeon_gpio_ops = { + .direction_input = octeon_gpio_dir_input, + .direction_output = octeon_gpio_dir_output, + .get_value = octeon_gpio_get_value, + .set_value = octeon_gpio_set_value, + .get_function = octeon_gpio_get_function, + .xlate = octeon_gpio_xlate, +}; + +static int octeon_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct octeon_gpio *priv = dev_get_priv(dev); + char *end; +#if !defined(CONFIG_ARCH_OCTEON) + pci_dev_t bdf = dm_pci_get_bdf(dev); +#endif + +#if !defined(CONFIG_ARCH_OCTEON) + priv->base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); +#else + priv->base = dev_remap_addr(dev); +#endif + if (!priv->base) { + debug("%s(%s): Could not get base address\n", + __func__, dev->name); + return -1; + } + +#if !defined(CONFIG_ARCH_OCTEON) + uc_priv->gpio_count = readq(priv->base + GPIO_CONST) & + GPIO_CONST_GPIOS_MASK; +#else + uc_priv->gpio_count = ofnode_read_u32_default(dev->node, + "nr-gpios", 32); +#endif + + uc_priv->bank_name = strdup(dev->name); + end = strchr(uc_priv->bank_name, '@'); + end[0] = 'A' + dev->seq; + end[1] = '\0'; + + debug("%s(%s): base address: %p, pin count: %d\n", + __func__, dev->name, priv->base, uc_priv->gpio_count); + + return 0; +} + +static const struct udevice_id octeon_gpio_ids[] = { + { .compatible = "cavium,thunder-8890-gpio" }, + { .compatible = "cavium,octeon-7890-gpio" }, + { } +}; + +U_BOOT_DRIVER(octeon_gpio) = { + .name = "octeon_gpio", + .id = UCLASS_GPIO, + .of_match = of_match_ptr(octeon_gpio_ids), + .probe = octeon_gpio_probe, + .priv_auto_alloc_size = sizeof(struct octeon_gpio), + .ops = &octeon_gpio_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +#if !defined(CONFIG_ARCH_OCTEON) +static struct pci_device_id octeon_gpio_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_GPIO) }, + { }, +}; + +U_BOOT_PCI_DEVICE(octeon_gpio, octeontx_gpio_supported); +#endif
Hi Stefan,
RFC -> v1 (Stefan)
+config OCTEON_GPIO
default y
help
- Copyright (C) 2018 Marvell International Ltd.
- (C) Copyright 2011
- eInfochips Ltd. <www.einfochips.com>
- Written-by: Ajay Bhargav ajay.bhargav@einfochips.com
- (C) Copyright 2010
- Marvell Semiconductor <www.marvell.com>
void __iomem *base;
u32 ret;
if (offset > 63)
return ret;
u32 ret;
ret = GPIO_RX_DAT;
if (offset > 63)
return ret;
int value)
int pin_sel;
offset, val);
if (pin_sel)
return GPIOF_FUNC;
else
return GPIOF_INPUT;
return -EINVAL;
desc->flags = 0;
char *end;
PCI_REGION_MEM);
+#else
if (!priv->base) {
return -1;
Should not have #ifdefs in drivers. Perhaps use the compatible string?
+#else
"nr-gpios", 32);
end[1] = '\0';
.id = UCLASS_GPIO,
Is it bad to always enable this and remove the #ifdef?
2.26.2
Hi Simon,
RFC -> v1 (Stefan)
+config OCTEON_GPIO
default y
help
- config STM32_GPIO bool "ST STM32 GPIO driver" depends on DM_GPIO && (STM32 || ARCH_STM32MP)
void __iomem *base;
u32 ret;
if (offset > 63)
return ret;
u32 ret;
ret = GPIO_RX_DAT;
if (offset > 63)
return ret;
int value)
int pin_sel;
offset, val);
if (pin_sel)
return GPIOF_FUNC;
else
return GPIOF_INPUT;
return -EINVAL;
desc->flags = 0;
char *end;
PCI_REGION_MEM);
+#else
if (!priv->base) {
return -1;
Yes, will try to remove this.
+#else
"nr-gpios", 32);
end[1] = '\0';
.id = UCLASS_GPIO,
It didn't work with the base Octeon port, which didn't enable DM_PCI. But I'll add DM_PCI and then this will work as well.
Thanks, Stefan
Stefan Roese
