Re: [U-Boot-Users] auto-save environment if using defaul
Sorry, just a re-send because I missed the CC in this message. :-(
Hi Mike,
On 26 Mar 2008 at 0:51, Mike Frysinger wrote:
On Tuesday 25 March 2008, w.wegner@astro-kom.de wrote:
I just had the problem of fw_{print,save}env not being able to access the environment because I was using the default (builtin) environment after flashing U-Boot.
if you're using an embedded env, then the default crc should be correct. i'd address that bug first before trying to hack around it on the board.
note: there are known problems with crc generation on the build system when it isnt the same endian/bitsize as the target.
sorry if this was not clear in my post. Everything is fine within U-Boot. I have the "regular" environment in a dedicated sector of the flash and the default environment is "compiled in" (I have to admit I do not know where it is particularly located...).
When accessing the environment from the (linux) application with fw_{print,set}env, of course I only want to access the regular environment in the dedicated sector, and if there was no "saveenv" in U-Boot before, it is simply not there.
Regards, Wolfgang
when you said "builtin" i wasnt sure if you were talking about it being embedded or being the compiled in string. sounds like the latter and you arent using an embedded environment. in other words, if u-boot takes up flash offset (0 - 0x20000), then the environment is not within that region. -mike
Mike Frysinger
