[PATCH v5] bosch: Add initial board support for ACC
The Bosch ACC (Air Center Control) Board is based on the i.MX6D.
Signed-off-by: Philip Oberfichtner pro@denx.de
Changes in v5: - Rebase on v2022.07-rc1 - Sync device tree with Linux
Changes in v4: - Remove obsolete CONFIG_FEC #defines - Sync device tree with Linux
Changes in v3: - Rename acc to bosch-acc - Sync device tree with Linux
Changes in v2: - Adapt defconfig and device tree to new bootcount driver - Clean up CONFIG_ENV_FLAGS_LIST_STATIC - Fix style issues in device trees - Migrate CONFIG options to Kconfig
This board supports depends on: - "crypto/fsl: Fallback to SW sha1/256 is misaligned buffers", patchwork id 270524 - Linux Device Tree patch, see below
The Device Tree is currently being mainlined into Linux. The DT in this board support patch will be kept in sync as the DT patch for Linux evolves. The Linux patch is tracked under https://lore.kernel.org/linux-devicetree/20220427135229.2339865-4-pro@denx.d...
The only difference compared to the Linux DT is the removal of usbphynop properties. They are defined in the Linux version of imx6qdl.dtsi, but not in the u-boot version.
--- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6q-bosch-acc-u-boot.dtsi | 80 +++ arch/arm/dts/imx6q-bosch-acc.dts | 773 +++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 15 + board/bosch/acc/Kconfig | 19 + board/bosch/acc/MAINTAINERS | 9 + board/bosch/acc/Makefile | 6 + board/bosch/acc/acc.c | 755 ++++++++++++++++++++++ configs/imx6q_bosch_acc_defconfig | 110 ++++ include/configs/imx6q-bosch-acc.h | 122 ++++ 10 files changed, 1890 insertions(+) create mode 100644 arch/arm/dts/imx6q-bosch-acc-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-bosch-acc.dts create mode 100644 board/bosch/acc/Kconfig create mode 100644 board/bosch/acc/MAINTAINERS create mode 100644 board/bosch/acc/Makefile create mode 100644 board/bosch/acc/acc.c create mode 100644 configs/imx6q_bosch_acc_defconfig create mode 100644 include/configs/imx6q-bosch-acc.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1032ce4c85..a24ac93258 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -777,6 +777,7 @@ endif ifneq ($(CONFIG_MX6Q)$(CONFIG_MX6QDL),) dtb-y += \ imx6-apalis.dtb \ + imx6q-bosch-acc.dtb \ imx6q-cm-fx6.dtb \ imx6q-cubox-i.dtb \ imx6q-cubox-i-emmc-som-v15.dtb \ diff --git a/arch/arm/dts/imx6q-bosch-acc-u-boot.dtsi b/arch/arm/dts/imx6q-bosch-acc-u-boot.dtsi new file mode 100644 index 0000000000..37c182d318 --- /dev/null +++ b/arch/arm/dts/imx6q-bosch-acc-u-boot.dtsi @@ -0,0 +1,80 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/* Copyright (C) 2022 Denx Software Engineering GmbH + * Philip Oberfichtner pro@denx.de + */ + +/ { + chosen { + stdout-path = &uart2; + }; + + soc { + u-boot,dm-spl; + + bus@2000000 { + u-boot,dm-spl; + + spba-bus@2000000 { + u-boot,dm-spl; + }; + }; + + bus@2100000 { + u-boot,dm-spl; + }; + }; + + bootcount { + compatible = "u-boot,bootcount-pmic"; + pmic = <&pmic>; + }; +}; + +&uart1 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc4 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&gpio6 { + u-boot,dm-spl; +}; + +&gpio7 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx6q-bosch-acc.dts b/arch/arm/dts/imx6q-bosch-acc.dts new file mode 100644 index 0000000000..103a64f331 --- /dev/null +++ b/arch/arm/dts/imx6q-bosch-acc.dts @@ -0,0 +1,773 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Support for the i.MX6-based Bosch ACC board. + * + * Copyright (C) 2016 Garz & Fricke GmbH + * Copyright (C) 2018 DENX Software Engineering GmbH, Heiko Schocher hs@denx.de + * Copyright (C) 2018 DENX Software Engineering GmbH, Niel Fourie lusus@denx.de + * Copyright (C) 2019-2021 Bosch Thermotechnik GmbH, Matthias Winker matthias.winker@bosch.com + * Copyright (C) 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include "imx6q.dtsi" + +/ { + model = "Bosch ACC"; + compatible = "bosch,imx6q-acc", "fsl,imx6q"; + + aliases { + serial0 = &uart2; + serial1 = &uart1; + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + mmc0 = &usdhc4; + mmc1 = &usdhc2; + }; + + memory@10000000 { + device_type = "memory"; + reg = <0x10000000 0x40000000>; + }; + + backlight_lvds: backlight_lvds { + compatible = "pwm-backlight"; + pwms = <&pwm1 0 200000>; + brightness-levels = <0 61 499 1706 4079 8022 13938 22237 33328 47623 65535>; + num-interpolated-steps = <10>; + default-brightness-level = <60>; + power-supply = <®_lcd>; + }; + + panel { + compatible = "dataimage,fg1001l0dsswmg01"; + backlight = <&backlight_lvds>; + + port { + panel_in: endpoint { + remote-endpoint = <&lvds0_out>; + }; + }; + }; + + refclk: refclk { + compatible = "fixed-factor-clock"; + #clock-cells = <0>; + clocks = <&clks IMX6QDL_CLK_CKO2>; + clock-div = <1>; + clock-mult = <1>; + clock-output-names = "12mhz_refclk"; + assigned-clocks = <&clks IMX6QDL_CLK_CKO>, + <&clks IMX6QDL_CLK_CKO2>, + <&clks IMX6QDL_CLK_CKO2_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_CKO2>, + <&clks IMX6QDL_CLK_CKO2_PODF>, + <&clks IMX6QDL_CLK_OSC>; + assigned-clock-rates = <0>, <12000000>, <0>; + }; + + cpus { + cpu0: cpu@0 { + operating-points = < + /* kHz uV */ + 1200000 1275000 + 996000 1225000 + 852000 1225000 + 792000 1150000 + 396000 950000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 1200000 1225000 + 996000 1175000 + 852000 1175000 + 792000 1150000 + 396000 1150000 + >; + }; + + cpu1: cpu@1 { + operating-points = < + /* kHz uV */ + 1200000 1275000 + 996000 1225000 + 852000 1225000 + 792000 1150000 + 396000 950000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 1200000 1225000 + 996000 1175000 + 852000 1175000 + 792000 1150000 + 396000 1150000 + >; + }; + }; + + pwm-leds { + compatible = "pwm-leds"; + + led_red: led-0 { + color = <LED_COLOR_ID_RED>; + max-brightness = <248>; + default-state = "off"; + pwms = <&pwm2 0 500000>; + }; + + led_white: led-1 { + color = <LED_COLOR_ID_WHITE>; + max-brightness = <248>; + default-state = "off"; + pwms = <&pwm3 0 500000>; + linux,default-trigger = "heartbeat"; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reset_gpio_led>; + + led-2 { + color = <LED_COLOR_ID_RED>; + gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + }; + + reg_5P0: regulator-5P0 { + compatible = "regulator-fixed"; + regulator-name = "5P0"; + }; + + reg_vin: regulator-vin { + compatible = "regulator-fixed"; + regulator-name = "VIN"; + regulator-min-microvolt = <4500000>; + regulator-max-microvolt = <4500000>; + regulator-always-on; + vin-supply = <®_5P0>; + }; + + reg_usb_otg_vbus: regulator-usb-otg-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_usb_h1_vbus: regulator-usb-h1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb_h1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <®_5P0>; + }; + + reg_usb_h2_vbus: regulator-usb-h2-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb_h2_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <®_5P0> ; + regulator-always-on; + }; + + reg_vsnvs: regulator-vsnvs { + compatible = "regulator-fixed"; + regulator-name = "VSNVS_3V0"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + vin-supply = <®_5P0>; + }; + + reg_lcd: regulator-lcd { + compatible = "regulator-fixed"; + regulator-name = "LCD0 POWER"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd_enable>; + gpio = <&gpio3 23 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-boot-on; + }; + + reg_dac: regulator-dac { + compatible = "regulator-fixed"; + regulator-name = "vref_dac"; + regulator-min-microvolt = <20000>; + regulator-max-microvolt = <20000>; + vin-supply = <®_5P0> ; + regulator-boot-on; + }; + + reg_sw4: regulator-sw4 { + compatible = "regulator-fixed"; + regulator-name = "SW4_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <®_5P0>; + }; + + reg_sys: regulator-sys { + compatible = "regulator-fixed"; + regulator-name = "SYS_4V2"; + regulator-min-microvolt = <4200000>; + regulator-max-microvolt = <4200000>; + regulator-always-on; + vin-supply = <®_5P0>; + }; +}; + +®_arm { + vin-supply = <&sw2_reg>; +}; + +®_soc { + vin-supply = <&sw1c_reg>; +}; + +®_vdd1p1 { + vin-supply = <®_vsnvs>; +}; + +®_vdd2p5 { + vin-supply = <®_vsnvs>; +}; + +®_vdd3p0 { + vin-supply = <®_vsnvs>; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + clocks = <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET_REF>; + clock-names = "ipg", "ahb", "ptp", "enet_out"; + phy-mode = "rmii"; + phy-supply = <®_sw4>; + phy-handle = <ðphy>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + ethphy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + interrupt-parent = <&gpio1>; + interrupts = <23 IRQ_TYPE_EDGE_FALLING>; + smsc,disable-energy-detect; + }; + }; +}; + +&gpu_vg { + status = "disabled"; +}; + +&gpu_2d { + status = "disabled"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clock-frequency = <400000>; + status = "okay"; + + eeprom: eeprom@50 { + compatible = "atmel,24c32"; + reg = <0x50>; + pagesize = <32>; + }; + + lm75: sensor@49 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lm75>; + compatible = "national,lm75b"; + reg = <0x49>; + }; + + pmic: pmic@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1c_reg: sw1c { + regulator-name = "VDD_SOC (sw1abc)"; + regulator-min-microvolt = <1275000>; + regulator-max-microvolt = <1500000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-name = "VDD_ARM (sw2)"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1500000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw3a_reg: sw3a { + compatible = "regulator-fixed"; + regulator-name = "DDR_1V5a"; + regulator-boot-on; + regulator-always-on; + + }; + + sw3b_reg: sw3b { + compatible = "regulator-fixed"; + regulator-name = "DDR_1V5b"; + regulator-boot-on; + regulator-always-on; + + }; + + sw4_reg: sw4 { + regulator-name = "AUX 3V15 (sw4)"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + }; + + swbst_reg: swbst { + status = "disabled"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + regulator-boot-on; + regulator-always-on; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-always-on; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-always-on; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + rtc: rtc@51 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rtc>; + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clock-frequency = <100000>; + status = "okay"; + + eeprom_ext: eeprom@50 { + compatible = "atmel,24c32"; + reg = <0x50>; + pagesize = <32>; + }; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clock-frequency = <400000>; + status = "okay"; + + exc3000: touchscreen@2a { + compatible = "eeti,exc3000"; + reg = <0x2a>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ctouch>; + interrupt-parent = <&gpio4>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + touchscreen-size-x = <4096>; + touchscreen-size-y = <4096>; + }; + + usb3503: usb@8 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb3503>; + compatible = "smsc,usb3503"; + reg = <0x08>; + connect-gpios = <&gpio1 16 GPIO_ACTIVE_HIGH>; /* Old: 0, SS: HIGH */ + intn-gpios = <&gpio7 12 GPIO_ACTIVE_LOW>; /* Old: 1, SS: HIGH */ + reset-gpios = <&gpio5 5 GPIO_ACTIVE_LOW>; /* Old: 0, SS: HIGH */ + initial-mode = <1>; + clocks = <&refclk>; + clock-names = "refclk"; + refclk-frequency = <12000000>; + }; + + vcnl4035: light-sensor@60 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_proximity>; + compatible = "vishay,vcnl4035"; + reg = <0x60>; + }; +}; + +&ldb { + status = "okay"; + + lvds0: lvds-channel@0 { + fsl,data-mapping = "spwg"; + fsl,data-width = <24>; + + port@4 { + reg = <4>; + + lvds0_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + }; +}; + +&pmu { + interrupt-affinity = <&{/cpus/cpu@0}>, + <&{/cpus/cpu@1}>; +}; + +&pwm1 { + #pwm-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm1>; + status = "okay"; +}; + +&pwm2 { + #pwm-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm2>; + status = "okay"; +}; + +&pwm3 { + #pwm-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "okay"; +}; + +&pwm4 { + #pwm-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm4>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; + rts-gpios = <&gpio7 8 GPIO_ACTIVE_HIGH>; + linux,rs485-enabled-at-boot-time; + rs485-rx-during-tx; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + uart-has-rtscts; + status = "okay"; +}; + +&usbh1 { + vbus-supply = <®_usb_h1_vbus>; + status = "okay"; +}; + +&usbh2 { + pinctrl-names = "idle", "active"; + pinctrl-0 = <&pinctrl_usbh2_idle>; + pinctrl-1 = <&pinctrl_usbh2_active>; + status = "okay"; + vbus-supply = <®_usb_h2_vbus>; +}; + +&usbotg { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + status = "okay"; + vbus-supply = <®_usb_otg_vbus>; + disable-over-current; + dr_mode = "otg"; + srp-disable; + hnp-disable; + adp-disable; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + status = "okay"; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + no-1-8-v; + keep-power-in-suspend; + enable-sdio-wakeup; + voltage-ranges = <3300 3300>; + vmmc-supply = <®_sw4>; + fsl,wp-controller; +}; + +&usdhc4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc4>; + status = "okay"; + bus-width = <8>; + non-removable; + no-1-8-v; + keep-power-in-suspend; + voltage-ranges = <3300 3300>; + vmmc-supply = <®_sw4>; + fsl,wp-controller; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog1>; + fsl,ext-reset-output; + status = "okay"; + timeout-sec=<10>; +}; + +&iomuxc { + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1b0b0 + MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1b0b0 /* FEC INT */ + MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1b0b0 + MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x0001b098 + MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x0001b098 + MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x0001b098 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + >; + }; + + pinctrl_reset_gpio_led: pinctrl-reset-gpio-led-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x1b0b0 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1 + MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b810 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b810 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_5__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_lcd_enable: lcdenablerp { + fsl,pins = < + MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x1b0b0 /* lcd enable */ + MX6QDL_PAD_EIM_D16__GPIO3_IO16 0x1b0b0 /* sel6_8 */ + >; + }; + + pinctrl_lm75: lm75grp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x1b0b0 + >; + }; + + pinctrl_proximity: proximitygrp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__GPIO4_IO11 0x1b0b0 + >; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x0001b0b0 + >; + }; + + pinctrl_pwm2: pwm2grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT2__PWM2_OUT 0x0001b0b0 + >; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT1__PWM3_OUT 0x0001b0b0 + >; + }; + + pinctrl_pwm4: pwm4grp { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__PWM4_OUT 0x0001b0b0 + >; + }; + + pinctrl_rtc: rtc-grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x1b0b0 /* RTC INT */ + >; + }; + + pinctrl_ctouch: ctouch-grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x1b0b0 /* CTOUCH_INT */ + MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x0001b0b0 /* CTOUCH_RESET */ + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x0001b0b0 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX6QDL_PAD_SD3_DAT4__UART2_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_DAT5__UART2_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D28__UART2_CTS_B 0x1b0b1 + MX6QDL_PAD_EIM_D29__UART2_RTS_B 0x1b0b1 + >; + }; + + pinctrl_usbh2_idle: usbh2-idle-grp { + fsl,pins = < + MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x00013018 + MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x00013018 + >; + }; + + pinctrl_usbh2_active: usbh2-active-grp { + fsl,pins = < + MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x00013018 + MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x00017018 + >; + }; + + pinctrl_usb3503: pinctrl_usb3503-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x00000018 + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x1b0b0 /* USB INT */ + MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x0001b0b0 /* USB Reset */ + MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x1b0b0 /* USB Connect */ + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x00017069 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x00010038 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x00017069 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x00017069 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x00017069 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x00017069 + MX6QDL_PAD_GPIO_4__SD2_CD_B 0x0001b0b0 + >; + }; + + pinctrl_usdhc4: usdhc4grp { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x00017059 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x00010059 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x00017059 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x00017059 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x00017059 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x00017059 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x00017059 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x00017059 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x00017059 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x00017059 + >; + }; + + pinctrl_wdog1: wdoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_9__WDOG1_B 0x1b0b0 + >; + }; +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 947b73fab2..eceb730856 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -347,6 +347,20 @@ config TARGET_MX6Q_ENGICAM select SUPPORT_SPL imply CMD_DM
+config TARGET_MX6Q_ACC + bool "Support for Bosch ACC board" + depends on MX6QDL + select BOARD_LATE_INIT + select OF_CONTROL + select SPL_OF_LIBFDT + select DM + select DM_ETH + select DM_GPIO + select DM_I2C + select DM_MMC + select DM_THERMAL + select SUPPORT_SPL + config TARGET_MX6SABREAUTO bool "mx6sabreauto" depends on MX6QDL @@ -686,6 +700,7 @@ source "board/freescale/mx6sxsabresd/Kconfig" source "board/freescale/mx6sxsabreauto/Kconfig" source "board/freescale/mx6ul_14x14_evk/Kconfig" source "board/freescale/mx6ullevk/Kconfig" +source "board/bosch/acc/Kconfig" source "board/grinn/liteboard/Kconfig" source "board/phytec/pcm058/Kconfig" source "board/phytec/pcl063/Kconfig" diff --git a/board/bosch/acc/Kconfig b/board/bosch/acc/Kconfig new file mode 100644 index 0000000000..da54d96e40 --- /dev/null +++ b/board/bosch/acc/Kconfig @@ -0,0 +1,19 @@ +if TARGET_MX6Q_ACC + +config SYS_VENDOR + default "bosch" + +config SYS_BOARD + default "acc" + +config SYS_CONFIG_NAME + default "imx6q-bosch-acc" + +config SYS_BOOT_EMMC + bool "Boot from EMMC" + default y + help + Say N here if you want to boot from SD card or microUSB. + Say Y to boot from eMMC. + +endif diff --git a/board/bosch/acc/MAINTAINERS b/board/bosch/acc/MAINTAINERS new file mode 100644 index 0000000000..1b88003712 --- /dev/null +++ b/board/bosch/acc/MAINTAINERS @@ -0,0 +1,9 @@ +MX6Q_ACC +M: Matthias Winker matthias.winker@de.bosch.com +M: Philip Oberfichtner pro@denx.de +S: Maintained +F: board/bosch/acc +F: include/configs/imx6q-bosch-acc.h +F: configs/imx6q_bosch_acc_defconfig +F: arch/arm/dts/imx6q-bosch-acc.dts +F: arch/arm/dts/imx6q-bosch-acc-u-boot.dts diff --git a/board/bosch/acc/Makefile b/board/bosch/acc/Makefile new file mode 100644 index 0000000000..d425a677bc --- /dev/null +++ b/board/bosch/acc/Makefile @@ -0,0 +1,6 @@ +# Copyright (C) 2017 +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := acc.o diff --git a/board/bosch/acc/acc.c b/board/bosch/acc/acc.c new file mode 100644 index 0000000000..dbc03c9371 --- /dev/null +++ b/board/bosch/acc/acc.c @@ -0,0 +1,755 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2017 DENX Software Engineering GmbH, Heiko Schocher hs@denx.de + * Copyright (c) 2019 Bosch Thermotechnik GmbH + * Copyright (c) 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de + */ + +#include <common.h> +#include <bootstage.h> +#include <dm.h> +#include <dm/platform_data/serial_mxc.h> +#include <dm/device-internal.h> +#include <env.h> +#include <env_internal.h> +#include <hang.h> +#include <init.h> +#include <linux/delay.h> +#include <mmc.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <linux/sizes.h> + +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/iomux-v3.h> +#include <usb.h> +#include <usb/ehci-ci.h> +#include <fuse.h> + +#include <watchdog.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIO_ACC_PLAT_DETECT IMX_GPIO_NR(5, 9) +#define GPIO_ACC_RAM_VOLT_DETECT IMX_GPIO_NR(5, 0) +#define GPIO_BUZZER IMX_GPIO_NR(1, 18) +#define GPIO_LAN1_RESET IMX_GPIO_NR(4, 27) +#define GPIO_LAN2_RESET IMX_GPIO_NR(4, 19) +#define GPIO_LAN3_RESET IMX_GPIO_NR(4, 18) +#define GPIO_USB_HUB_RESET IMX_GPIO_NR(5, 5) +#define GPIO_EXP_RS485_RESET IMX_GPIO_NR(4, 16) +#define GPIO_TOUCH_RESET IMX_GPIO_NR(1, 20) + +#define BOARD_INFO_MAGIC 0x19730517 + +struct board_info { + int magic; + int board; + int rev; +}; + +static struct board_info *detect_board(void); + +#define PFID_BOARD_ACC 0xe + +static const char * const name_board[] = { + [PFID_BOARD_ACC] = "ACC", +}; + +#define PFID_REV_22 0x8 +#define PFID_REV_21 0x9 +#define PFID_REV_20 0xa +#define PFID_REV_14 0xb +#define PFID_REV_13 0xc +#define PFID_REV_12 0xd +#define PFID_REV_11 0xe +#define PFID_REV_10 0xf + +static const char * const name_revision[] = { + [0 ... PFID_REV_10] = "Unknown", + [PFID_REV_10] = "1.0", + [PFID_REV_11] = "1.1", + [PFID_REV_12] = "1.2", + [PFID_REV_13] = "1.3", + [PFID_REV_14] = "1.4", + [PFID_REV_20] = "2.0", + [PFID_REV_21] = "2.1", + [PFID_REV_22] = "2.2", +}; + +/* + * NXP Reset Default: 0x0001B0B0 + * - Schmitt trigger input (PAD_CTL_HYS) + * - 100K Ohm Pull Up (PAD_CTL_PUS_100K_UP) + * - Pull Enabled (PAD_CTL_PUE) + * - Pull/Keeper Enabled (PAD_CTL_PKE) + * - CMOS output (No PAD_CTL_ODE) + * - Medium Speed (PAD_CTL_SPEED_MED) + * - 40 Ohm drive strength (PAD_CTL_DSE_40ohm) + * - Slow (PAD_CTL_SRE_SLOW) + */ + +/* Input, no pull up/down: 0x0x000100B0 */ +#define GPIN_PAD_CTRL (PAD_CTL_HYS \ + | PAD_CTL_SPEED_MED \ + | PAD_CTL_DSE_40ohm \ + | PAD_CTL_SRE_SLOW) + +/* Input, pull up: 0x0x0001B0B0 */ +#define GPIN_PU_PAD_CTRL (PAD_CTL_HYS \ + | PAD_CTL_PUS_100K_UP \ + | PAD_CTL_PUE \ + | PAD_CTL_PKE \ + | PAD_CTL_SPEED_MED \ + | PAD_CTL_DSE_40ohm \ + | PAD_CTL_SRE_SLOW) + +/* Input, pull down: 0x0x000130B0 */ +#define GPIN_PD_PAD_CTRL (PAD_CTL_HYS \ + | PAD_CTL_PUS_100K_DOWN \ + | PAD_CTL_PUE \ + | PAD_CTL_PKE \ + | PAD_CTL_SPEED_MED \ + | PAD_CTL_DSE_40ohm \ + | PAD_CTL_SRE_SLOW) + +static const iomux_v3_cfg_t board_detect_pads[] = { + /* Platform detect */ + IOMUX_PADS(PAD_DISP0_DAT15__GPIO5_IO09 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* RAM Volt detect */ + IOMUX_PADS(PAD_EIM_WAIT__GPIO5_IO00 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* PFID 0..9 */ + IOMUX_PADS(PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D1__GPIO2_IO01 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D3__GPIO2_IO03 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D5__GPIO2_IO05 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D6__GPIO2_IO06 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D7__GPIO2_IO07 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_CS3__GPIO6_IO16 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* Manufacturer */ + IOMUX_PADS(PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* Redundant */ + IOMUX_PADS(PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(GPIN_PU_PAD_CTRL)) +}; + +static int gpio_acc_pfid[] = { + IMX_GPIO_NR(2, 0), + IMX_GPIO_NR(2, 1), + IMX_GPIO_NR(2, 2), + IMX_GPIO_NR(2, 3), + IMX_GPIO_NR(2, 4), + IMX_GPIO_NR(6, 14), + IMX_GPIO_NR(6, 15), + IMX_GPIO_NR(2, 5), + IMX_GPIO_NR(2, 6), + IMX_GPIO_NR(2, 7), + IMX_GPIO_NR(6, 16), + IMX_GPIO_NR(5, 4), +}; + +static int init_gpio(int nr) +{ + int ret; + + ret = gpio_request(nr, ""); + if (ret != 0) { + printf("Could not request gpio nr: %d\n", nr); + hang(); + } + ret = gpio_direction_input(nr); + if (ret != 0) { + printf("Could not set gpio nr: %d to input\n", nr); + hang(); + } + return 0; +} + +/* + * We want to detect the board type only once in SPL, + * so we store the board_info struct at beginning in IRAM. + * + * U-Boot itself can read it also, and do not need again + * to detect board type. + * + */ +static struct board_info *detect_board(void) +{ + struct board_info *binfo = (struct board_info *)IRAM_BASE_ADDR; + int i; + + if (binfo->magic == BOARD_INFO_MAGIC) + return binfo; + + puts("Board: "); + SETUP_IOMUX_PADS(board_detect_pads); + init_gpio(GPIO_ACC_PLAT_DETECT); + if (gpio_get_value(GPIO_ACC_PLAT_DETECT)) { + puts("not supported"); + hang(); + } else { + puts("Bosch "); + } + + for (i = 0; i < sizeof(gpio_acc_pfid) / sizeof(int); i++) + init_gpio(gpio_acc_pfid[i]); + + binfo->board = gpio_get_value(gpio_acc_pfid[0]) << 0 | + gpio_get_value(gpio_acc_pfid[1]) << 1 | + gpio_get_value(gpio_acc_pfid[2]) << 2 | + gpio_get_value(gpio_acc_pfid[11]) << 3; + printf("%s ", name_board[binfo->board]); + + binfo->rev = gpio_get_value(gpio_acc_pfid[7]) << 0 | + gpio_get_value(gpio_acc_pfid[8]) << 1 | + gpio_get_value(gpio_acc_pfid[9]) << 2 | + gpio_get_value(gpio_acc_pfid[10]) << 3; + printf("rev: %s\n", name_revision[binfo->rev]); + + binfo->magic = BOARD_INFO_MAGIC; + + return binfo; +} + +static void unset_early_gpio(void) +{ + init_gpio(GPIO_LAN1_RESET); + init_gpio(GPIO_LAN2_RESET); + init_gpio(GPIO_LAN3_RESET); + init_gpio(GPIO_USB_HUB_RESET); + init_gpio(GPIO_EXP_RS485_RESET); + init_gpio(GPIO_TOUCH_RESET); + + gpio_set_value(GPIO_LAN1_RESET, 1); + gpio_set_value(GPIO_LAN2_RESET, 1); + gpio_set_value(GPIO_LAN3_RESET, 1); + gpio_set_value(GPIO_USB_HUB_RESET, 1); + gpio_set_value(GPIO_EXP_RS485_RESET, 1); + gpio_set_value(GPIO_TOUCH_RESET, 1); +} + +enum env_location env_get_location(enum env_operation op, int prio) +{ + if (op == ENVOP_SAVE || op == ENVOP_ERASE) + return ENVL_MMC; + + switch (prio) { + case 0: + return ENVL_NOWHERE; + + case 1: + return ENVL_MMC; + } + + return ENVL_UNKNOWN; +} + +int board_late_init(void) +{ + struct board_info *binfo = detect_board(); + + switch (binfo->board) { + case PFID_BOARD_ACC: + env_set("bootconf", "conf-imx6q-bosch-acc.dtb"); + break; + default: + printf("Unknown board %d\n", binfo->board); + break; + } + + unset_early_gpio(); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +#if IS_ENABLED(CONFIG_SPL_BUILD) +#include <asm/arch/crm_regs.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <spl.h> + +/* Early + * - Buzzer -> GPIO IN, Pull-Down (PWM enabled by Kernel later-on, lacks of an + * external pull-down resistor) + * - Touch clean reset on every boot + * - Ethernet(s), USB Hub, Expansion RS485 -> Clean reset on each u-boot init + */ +static const iomux_v3_cfg_t early_pads[] = { + IOMUX_PADS(PAD_SD1_CMD__GPIO1_IO18 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* Buzzer PWM */ + IOMUX_PADS(PAD_DISP0_DAT6__GPIO4_IO27 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #FEC_RESET_B */ + IOMUX_PADS(PAD_DI0_PIN2__GPIO4_IO18 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #ETH1_RESET */ + IOMUX_PADS(PAD_DI0_PIN3__GPIO4_IO19 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #ETH2_RESET */ + IOMUX_PADS(PAD_DISP0_DAT11__GPIO5_IO05 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #USB Reset */ + IOMUX_PADS(PAD_DI0_DISP_CLK__GPIO4_IO16 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #UART_RESET */ + IOMUX_PADS(PAD_SD1_CLK__GPIO1_IO20 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #CTOUCH_RESET */ +}; + +static void setup_iomux_early(void) +{ + SETUP_IOMUX_PADS(early_pads); +} + +static void set_early_gpio(void) +{ + init_gpio(GPIO_BUZZER); + init_gpio(GPIO_LAN1_RESET); + init_gpio(GPIO_LAN2_RESET); + init_gpio(GPIO_LAN3_RESET); + init_gpio(GPIO_USB_HUB_RESET); + init_gpio(GPIO_EXP_RS485_RESET); + init_gpio(GPIO_TOUCH_RESET); + + /* Reset signals are active low */ + gpio_set_value(GPIO_BUZZER, 0); + gpio_set_value(GPIO_LAN1_RESET, 0); + gpio_set_value(GPIO_LAN2_RESET, 0); + gpio_set_value(GPIO_LAN3_RESET, 0); + gpio_set_value(GPIO_USB_HUB_RESET, 0); + gpio_set_value(GPIO_EXP_RS485_RESET, 0); + gpio_set_value(GPIO_TOUCH_RESET, 0); +} + +/* UART */ +#define UART_PAD_CTRL \ + (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#undef UART_PAD_CTRL +#define UART_PAD_CTRL 0x1b0b1 +static const iomux_v3_cfg_t uart2_pads[] = { + IOMUX_PADS(PAD_SD3_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT5__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CMD__UART2_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CLK__UART2_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + +static void setup_iomux_uart(void) +{ + SETUP_IOMUX_PADS(uart2_pads); +} + +void spl_board_init(void) +{ +} + +static const struct mx6dq_iomux_ddr_regs acc_mx6d_ddr_ioregs = { + .dram_sdclk_0 = 0x00008038, + .dram_sdclk_1 = 0x00008038, + .dram_cas = 0x00008028, + .dram_ras = 0x00008028, + .dram_reset = 0x00000028, + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + .dram_sdba2 = 0x00008000, + .dram_sdodt0 = 0x00000028, + .dram_sdodt1 = 0x00000028, + .dram_sdqs0 = 0x00008038, + .dram_sdqs1 = 0x00008038, + .dram_sdqs2 = 0x00008038, + .dram_sdqs3 = 0x00008038, + .dram_sdqs4 = 0x00008038, + .dram_sdqs5 = 0x00008038, + .dram_sdqs6 = 0x00008038, + .dram_sdqs7 = 0x00008038, + .dram_dqm0 = 0x00008038, + .dram_dqm1 = 0x00008038, + .dram_dqm2 = 0x00008038, + .dram_dqm3 = 0x00008038, + .dram_dqm4 = 0x00008038, + .dram_dqm5 = 0x00008038, + .dram_dqm6 = 0x00008038, + .dram_dqm7 = 0x00008038, +}; + +static const struct mx6dq_iomux_grp_regs acc_mx6d_grp_ioregs = { + .grp_ddr_type = 0x000C0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = 0x00000030, + .grp_ctlds = 0x00000028, + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000038, + .grp_b1ds = 0x00000038, + .grp_b2ds = 0x00000038, + .grp_b3ds = 0x00000038, + .grp_b4ds = 0x00000038, + .grp_b5ds = 0x00000038, + .grp_b6ds = 0x00000038, + .grp_b7ds = 0x00000038, +}; + +static const struct mx6_mmdc_calibration acc_mx6d_mmdc_calib = { + .p0_mpwldectrl0 = 0x0020001F, + .p0_mpwldectrl1 = 0x00280021, + .p1_mpwldectrl0 = 0x00120028, + .p1_mpwldectrl1 = 0x000D001F, + .p0_mpdgctrl0 = 0x43340342, + .p0_mpdgctrl1 = 0x03300325, + .p1_mpdgctrl0 = 0x4334033E, + .p1_mpdgctrl1 = 0x03280270, + .p0_mprddlctl = 0x46373B3E, + .p1_mprddlctl = 0x3B383544, + .p0_mpwrdlctl = 0x36383E40, + .p1_mpwrdlctl = 0x4030433A, +}; + +/* Micron MT41K128M16JT-125 (standard - 1600,CL=11) + * !!! i.MX6 does NOT support data rates higher than DDR3-1066 !!! + * So this setting is actually invalid! + * +static const struct mx6_ddr3_cfg acc_mx6d_mem_ddr3_1600 = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, + .SRT = 0, +}; + */ + +/* Micron MT41K128M16JT-125 is backward-compatible with 1333,CL=9 (-15E) and 1066,CL=7 (-187E) + * Lowering to 1066 saves on ACC ~0.25 Watt at DC In with negligible performance loss + * width set to 64, as four chips are used on acc (4 * 16 = 64) + */ +static const struct mx6_ddr3_cfg acc_mx6d_mem_ddr3_1066 = { + .mem_speed = 1066, + .density = 2, + .width = 64, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1313, // 13.125ns + .trcmin = 5063, // 50.625ns + .trasmin = 3750, // 37.5ns + .SRT = 0, // Set to 1 for temperatures above 85°C +}; + +static const struct mx6_ddr_sysinfo acc_mx6d_ddr_info = { + .ddr_type = DDR_TYPE_DDR3, + /* width of data bus:0=16,1=32,2=64 */ + .dsize = 2, + .cs_density = 32, /* 32Gb per CS */ + .ncs = 1, /* single chip select */ + .cs1_mirror = 0, + .rtt_wr = 1, /* DDR3_RTT_60_OHM, RTT_Wr = RZQ/4 */ + .rtt_nom = 1, /* DDR3_RTT_60_OHM, RTT_Nom = RZQ/4 */ + .walat = 0, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x33, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x33, /* 33 cycles, 500us (JEDEC default) */ +}; + +#define ACC_SPREAD_SPECTRUM_STOP 0x0fa +#define ACC_SPREAD_SPECTRUM_STEP 0x001 +#define ACC_SPREAD_SPECTRUM_DENOM 0x190 + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* Turn clocks on/off */ + writel(0x00C0000F, &ccm->CCGR0); + writel(0x0030FC00, &ccm->CCGR1); + writel(0x03FF0033, &ccm->CCGR2); + writel(0x3FF3300F, &ccm->CCGR3); + writel(0x0003C300, &ccm->CCGR4); + writel(0x0F3000C3, &ccm->CCGR5); + writel(0x00000FFF, &ccm->CCGR6); + + /* Enable spread spectrum */ + writel(BM_ANADIG_PLL_528_SS_ENABLE | + BF_ANADIG_PLL_528_SS_STOP(ACC_SPREAD_SPECTRUM_STOP) | + BF_ANADIG_PLL_528_SS_STEP(ACC_SPREAD_SPECTRUM_STEP), + &ccm->analog_pll_528_ss); + + writel(BF_ANADIG_PLL_528_DENOM_B(ACC_SPREAD_SPECTRUM_DENOM), + &ccm->analog_pll_528_denom); +} + +/* MMC board initialization is needed till adding DM support in SPL */ +#if IS_ENABLED(CONFIG_FSL_ESDHC_IMX) && !IS_ENABLED(CONFIG_DM_MMC) +#include <mmc.h> +#include <fsl_esdhc_imx.h> + +static const iomux_v3_cfg_t usdhc2_pads[] = { + IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(0x00010038)), + IOMUX_PADS(PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(0x0001B0B0)), /* CD */ +}; + +static const iomux_v3_cfg_t usdhc4_pads[] = { + IOMUX_PADS(PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(0x00010059)), + IOMUX_PADS(PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(0x00017059)), +}; + +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC2_BASE_ADDR, 1, 4}, + {USDHC4_BASE_ADDR, 1, 8}, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + detect_board(); + + switch (cfg->esdhc_base) { + case USDHC2_BASE_ADDR: + return !gpio_get_value(USDHC2_CD_GPIO); + case USDHC4_BASE_ADDR: + return 1; /* eMMC always present */ + } + + return ret; +} + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + + gpio_direction_input(USDHC2_CD_GPIO); + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC2 + * mmc1 USDHC4 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + SETUP_IOMUX_PADS(usdhc2_pads); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + break; + case 1: + SETUP_IOMUX_PADS(usdhc4_pads); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + break; + default: + printf("Warning - USDHC%d controller not supporting\n", + i + 1); + return 0; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} +#endif + +void board_boot_order(u32 *spl_boot_list) +{ + u32 bmode = imx6_src_get_boot_mode(); + u8 boot_dev = BOOT_DEVICE_MMC1; + + detect_board(); + + switch ((bmode & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + /* SD/eSD - BOOT_DEVICE_MMC1 */ + if (IS_ENABLED(CONFIG_SYS_BOOT_EMMC)) { + /* + * boot from SD is not allowed, if boot from eMMC is + * configured. + */ + puts("SD boot not allowed\n"); + spl_boot_list[0] = BOOT_DEVICE_NONE; + return; + } + + boot_dev = BOOT_DEVICE_MMC1; + break; + + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: + /* MMC/eMMC */ + boot_dev = BOOT_DEVICE_MMC2; + break; + default: + /* Default - BOOT_DEVICE_MMC1 */ + printf("Wrong board boot order\n"); + break; + } + + spl_boot_list[0] = boot_dev; +} + +static void setup_ddr(void) +{ + struct board_info *binfo = detect_board(); + + switch (binfo->rev) { + case PFID_REV_20: + case PFID_REV_21: + case PFID_REV_22: + default: + /* Rev 2 board has i.MX6 Dual with 64-bit RAM */ + mx6dq_dram_iocfg(acc_mx6d_mem_ddr3_1066.width, + &acc_mx6d_ddr_ioregs, + &acc_mx6d_grp_ioregs); + mx6_dram_cfg(&acc_mx6d_ddr_info, &acc_mx6d_mmdc_calib, + &acc_mx6d_mem_ddr3_1066); + /* Perform DDR DRAM calibration */ + udelay(100); + mmdc_do_write_level_calibration(&acc_mx6d_ddr_info); + mmdc_do_dqs_calibration(&acc_mx6d_ddr_info); + break; + } +} + +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog power-down counter (only enabled after reset) */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* setup GP timer */ + timer_init(); + + /* Enable device tree and early DM support*/ + spl_early_init(); + + /* Setup early required pinmuxes */ + setup_iomux_early(); + set_early_gpio(); + + /* Setup UART pinmux */ + setup_iomux_uart(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + setup_ddr(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif + +#if IS_ENABLED(CONFIG_USB_EHCI_MX6) +#define USB_OTHERREGS_OFFSET 0x800 +#define UCTRL_PWR_POL BIT(9) + +int board_usb_phy_mode(int port) +{ + if (port == 1) + return USB_INIT_HOST; + else + return usb_phy_mode(port); +} + +int board_ehci_hcd_init(int port) +{ + u32 *usbnc_usb_ctrl; + + if (port > 1) + return -EINVAL; + + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET + + port * 4); + + /* Set Power polarity */ + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); + + return 0; +} +#endif + +int board_fit_config_name_match(const char *name) +{ + if (!strcmp(name, "imx6q-bosch-acc")) + return 0; + return -1; +} + +void reset_cpu(ulong addr) +{ + puts("Hanging CPU for watchdog reset!\n"); + hang(); +} + +#if CONFIG_IS_ENABLED(SHOW_BOOT_PROGRESS) +void show_boot_progress(int val) +{ + u32 fuseval; + int ret; + + if (val < 0) + val *= -1; + + switch (val) { + case BOOTSTAGE_ID_ENTER_CLI_LOOP: + printf("autoboot failed, check fuse\n"); + ret = fuse_read(0, 6, &fuseval); + if (ret == 0 && (fuseval & 0x2) == 0x0) { + printf("Enter cmdline, as device not closed\n"); + return; + } + ret = fuse_read(5, 7, &fuseval); + if (ret == 0 && fuseval == 0x0) { + printf("Enter cmdline, as it is a Development device\n"); + return; + } + panic("do not enter cmdline"); + break; + } +} +#endif diff --git a/configs/imx6q_bosch_acc_defconfig b/configs/imx6q_bosch_acc_defconfig new file mode 100644 index 0000000000..3c02f0f5dd --- /dev/null +++ b/configs/imx6q_bosch_acc_defconfig @@ -0,0 +1,110 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x17780000 +CONFIG_SYS_MALLOC_LEN=0x01000000 +CONFIG_SYS_MALLOC_F_LEN=0x9000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x1fe000 +CONFIG_MX6QDL=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6Q_ACC=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-bosch-acc" +CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_BOOTCOUNT_BOOTLIMIT=8 +CONFIG_SPL_SIZE_LIMIT=69632 +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0x1ff000 +CONFIG_IMX_HAB=y +# CONFIG_CMD_BMODE is not set +# CONFIG_CMD_DEKBLOB is not set +CONFIG_BUILD_TARGET="" +# CONFIG_LOCALVERSION_AUTO is not set +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run mmc_mmc_fit" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xaa +# CONFIG_SPL_CRC32 is not set +# CONFIG_SPL_CRYPTO is not set +CONFIG_SPL_WATCHDOG=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_MEMORY is not set +# CONFIG_CMD_FUSE is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +# CONFIG_CMD_PINMUX is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_BLOCK_CACHE is not set +# CONFIG_CMD_SLEEP is not set +# CONFIG_CMD_MP is not set +# CONFIG_CMD_HASH is not set +CONFIG_CMD_EXT4=y +CONFIG_DOS_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent" +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_ENV_APPEND=y +CONFIG_ENV_WRITEABLE_LIST=y +CONFIG_ENV_ACCESS_IGNORE_FORCE=y +CONFIG_VERSION_VARIABLE=y +CONFIG_TFTP_BLOCKSIZE=512 +CONFIG_SPL_DM=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_DM_BOOTCOUNT_PMIC_PFUZE100=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 +CONFIG_IMX_WATCHDOG=y +CONFIG_WDT=y +CONFIG_EXT4_WRITE=y +CONFIG_FS_FAT=y +CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/imx6q-bosch-acc.h b/include/configs/imx6q-bosch-acc.h new file mode 100644 index 0000000000..6d362557ac --- /dev/null +++ b/include/configs/imx6q-bosch-acc.h @@ -0,0 +1,122 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (c) 2017 DENX Software Engineering GmbH, Heiko Schocher hs@denx.de + * Copyright (c) 2019 Bosch Thermotechnik GmbH + * Copyright (c) 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de + */ + +#ifndef __IMX6Q_ACC_H +#define __IMX6Q_ACC_H + +#include <linux/sizes.h> +#include "mx6_common.h" + +#ifdef CONFIG_SYS_BOOT_EMMC +#define MMC_ROOTFS_DEV 0 +#define MMC_ROOTFS_PART 2 +#endif + +#ifdef CONFIG_SYS_BOOT_EMMC +/* eMMC Boot */ +#define ENV_EXTRA \ + "mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \ + "mmcpart=" __stringify(MMC_ROOTFS_PART) "\0" \ + "fitpart=1\0" \ + "optargs=ro quiet systemd.gpt_auto=false\0" \ + "production=1\0" \ + "mmcautodetect=yes\0" \ + "mmcrootfstype=ext4\0" \ + "finduuid=part uuid mmc ${mmcdev}:${mmcpart} uuid\0" \ + "mmcargs=run finduuid; setenv bootargs " \ + "root=PARTUUID=${uuid} ${optargs} rootfstype=${mmcrootfstype}\0" \ + "mmc_mmc_fit=run env_persist; run setbm; run mmcloadfit; " \ + "run auth_fit_or_reset; run mmcargs addcon; " \ + "bootm ${fit_addr}#${bootconf}\0" \ + "bootset=0\0" \ + "setbm=if test ${bootset} -eq 1; " \ + "then setenv mmcpart 4; setenv fitpart 3; " \ + "else; setenv mmcpart 2; setenv fitpart 1; fi\0" \ + "handle_ustate=if test ${ustate} -eq 2; then setenv ustate 3; fi\0" \ + "switch_bootset=if test ${bootset} -eq 1; then setenv bootset 0; " \ + "else; setenv bootset 1;fi\0" \ + "env_persisted=0\0" \ + "env_persist=if test ${env_persisted} != 1; " \ + "then env set env_persisted 1; run save_env; fi;\0" \ + "save_env=env save; env save\0" \ + "altbootcmd=run handle_ustate; run switch_bootset; run save_env; run bootcmd\0" + +#define CONFIG_ENV_FLAGS_LIST_STATIC \ + "bootset:bw," \ + "clone_pending:bw," \ + "endurance_test:bw," \ + "env_persisted:bw," \ + "factory_reset:bw," \ + "fdtcontroladdr:xw," \ + "fitpart:dw," \ + "mmcpart:dw," \ + "production:bw," \ + "ustate:dw" + +#else +/* SD Card boot */ +#define ENV_EXTRA \ + "mmcdev=1\0" \ + "fitpart=1\0" \ + "rootpart=2\0" \ + "optargs=ro systemd.gpt_auto=false\0" \ + "finduuid=part uuid mmc ${mmcdev}:${rootpart} uuid\0" \ + "mmcargs=run finduuid;setenv bootargs root=PARTUUID=${uuid} ${optargs}\0" \ + "mmc_mmc_fit=run mmcloadfit; run auth_fit_or_reset; run mmcargs addcon; " \ + "bootm ${fit_addr}#${bootconf}\0" + +#endif + +/* Default environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootconf=conf-imx6q-bosch-acc.dtb\0"\ + "mmcfit_name=fitImage\0" \ + "mmcloadfit=ext4load mmc ${mmcdev}:${fitpart} ${fit_addr} ${mmcfit_name}\0" \ + "auth_fit_or_reset=hab_auth_img ${fit_addr} ${filesize} || reset\0" \ + "console=ttymxc0\0" \ + "addcon=setenv bootargs ${bootargs} console=${console},${baudrate}\0" \ + "fit_addr=19000000\0" \ + ENV_EXTRA + +/* Physical Memory Map */ +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* SPL */ +#ifdef CONFIG_SPL +#include "imx6_spl.h" + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#ifdef CONFIG_SYS_BOOT_EMMC + +/* Boot from eMMC */ +#define CONFIG_SYS_FSL_ESDHC_ADDR 1 + +#else + +/* Boot from SD-card */ +# define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#endif + +#endif +#endif + +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Enabled USB controller number */ + +#endif /* __IMX6Q_ACC_H */
Philip Oberfichtner
