[U-Boot] [PATCH v3 2/2] EXYNOS: mmc: support DesignWare Controller for Samsung-SoC
Support DesignWare MMC Controller for Samsung Specific.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Signed-off-by: Rajeshawari Shinde rajeshwari.s@samsung.com --- Changelog V3: - Removed the unnecessary code. Changelog V2: - Nothing --- arch/arm/include/asm/arch-exynos/dwmmc.h | 36 +++++++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/exynos_dw_mmc.c | 57 ++++++++++++++++++++++++++++++ 3 files changed, 94 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/dwmmc.h create mode 100644 drivers/mmc/exynos_dw_mmc.c
diff --git a/arch/arm/include/asm/arch-exynos/dwmmc.h b/arch/arm/include/asm/arch-exynos/dwmmc.h new file mode 100644 index 0000000..8acdf9b --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/dwmmc.h @@ -0,0 +1,36 @@ +/* + * (C) Copyright 2012 SAMSUNG Electronics + * Jaehoon Chung jh80.chung@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#define DWMCI_CLKSEL 0x09C +#define DWMCI_SHIFT_0 0x0 +#define DWMCI_SHIFT_1 0x1 +#define DWMCI_SHIFT_2 0x2 +#define DWMCI_SHIFT_3 0x3 +#define DWMCI_SET_SAMPLE_CLK(x) (x) +#define DWMCI_SET_DRV_CLK(x) ((x) << 16) +#define DWMCI_SET_DIV_RATIO(x) ((x) << 24) + +int exynos_dwmci_init(u32 regbase, int bus_width, int index); + +static inline unsigned int exynos_dwmmc_init(int index, int bus_width) +{ + unsigned int base = samsung_get_base_mmc() + (0x10000 * index); + return exynos_dwmci_init(base, bus_width, index); +} diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 9ef82a6..cb7c7f6 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -48,6 +48,7 @@ COBJS-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o COBJS-$(CONFIG_TEGRA_MMC) += tegra_mmc.o COBJS-$(CONFIG_DWMMC) += dw_mmc.o +COBJS-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c new file mode 100644 index 0000000..72a31b7 --- /dev/null +++ b/drivers/mmc/exynos_dw_mmc.c @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2012 SAMSUNG Electronics + * Jaehoon Chung jh80.chung@samsung.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <malloc.h> +#include <dwmmc.h> +#include <asm/arch/dwmmc.h> +#include <asm/arch/clk.h> + +static char *EXYNOS_NAME = "EXYNOS DWMMC"; + +static void exynos_dwmci_clksel(struct dwmci_host *host) +{ + u32 val; + val = DWMCI_SET_SAMPLE_CLK(DWMCI_SHIFT_0) | + DWMCI_SET_DRV_CLK(DWMCI_SHIFT_0) | DWMCI_SET_DIV_RATIO(0); + + dwmci_writel(host, DWMCI_CLKSEL, val); +} + +int exynos_dwmci_init(u32 regbase, int bus_width, int index) +{ + struct dwmci_host *host = NULL; + host = malloc(sizeof(struct dwmci_host)); + if (!host) { + printf("dwmci_host malloc fail!\n"); + return 1; + } + + host->name = EXYNOS_NAME; + host->ioaddr = (void *)regbase; + host->buswidth = bus_width; + host->clksel = exynos_dwmci_clksel; + host->dev_index = index; + + add_dwmci(host, 52000000, 400000); + + return 0; +} +
Dear, Mr.Kang
Could you merge this patch? This patch is samsung specific file. DesignWare controller has merged at u-boot-mmc repository. If Mr.Kang can't merge this, could Andy merge this?
Changelog V3:
Changelog V2:
- Nothing
- (C) Copyright 2012 SAMSUNG Electronics
- Jaehoon Chung jh80.chung@samsung.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
- unsigned int base = samsung_get_base_mmc() + (0x10000 * index);
- return exynos_dwmci_init(base, bus_width, index);
- u32 val;
- val = DWMCI_SET_SAMPLE_CLK(DWMCI_SHIFT_0) |
- dwmci_writel(host, DWMCI_CLKSEL, val);
- struct dwmci_host *host = NULL;
- host = malloc(sizeof(struct dwmci_host));
- if (!host) {
return 1;
- host->name = EXYNOS_NAME;
- host->ioaddr = (void *)regbase;
- host->buswidth = bus_width;
- host->clksel = exynos_dwmci_clksel;
- host->dev_index = index;
- add_dwmci(host, 52000000, 400000);
Dear Jaehoon and Andy,
On 23 October 2012 19:02, Jaehoon Chung jh80.chung@samsung.com wrote:
Dear, Mr.Kang
This patch have dependency of dw-mmc patch. (because of Makefile) It should be merged to Andy's tree.
Andy, I've delegate this patch to you. http://patchwork.ozlabs.org/patch/191723/ Please check.
Thanks. Minkyu Kang.
Dear Andy,
Do you have any opinion about this patch? If you didn't have any others, could you apply this patch at u-boot-mmc repository?
Dear, Mr.Kang
I got buried in other work. I should get to this by the end of the week
On Nov 21, 2012, at 22:04, "Jaehoon Chung" jh80.chung@samsung.com wrote:
Dear Andy,
Dear, Mr.Kang
Fleming Andy-AFLEMING
Jaehoon Chung
Minkyu Kang
