[PATCH] board: gateworks: venice: move README to RST
Move board/gateworks/venice/README to RST documentation.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/MAINTAINERS | 1 + board/gateworks/venice/README | 35 ------------------- doc/board/gateworks/imx8mm_venice.rst | 50 +++++++++++++++++++++++++++ doc/board/gateworks/imx8mn_venice.rst | 50 +++++++++++++++++++++++++++ doc/board/gateworks/imx8mp_venice.rst | 50 +++++++++++++++++++++++++++ doc/board/gateworks/index.rst | 11 ++++++ doc/board/index.rst | 1 + 7 files changed, 163 insertions(+), 35 deletions(-) delete mode 100644 board/gateworks/venice/README create mode 100644 doc/board/gateworks/imx8mm_venice.rst create mode 100644 doc/board/gateworks/imx8mn_venice.rst create mode 100644 doc/board/gateworks/imx8mp_venice.rst create mode 100644 doc/board/gateworks/index.rst
diff --git a/board/gateworks/venice/MAINTAINERS b/board/gateworks/venice/MAINTAINERS index cfdea0cb8adc..01a47a15d6fc 100644 --- a/board/gateworks/venice/MAINTAINERS +++ b/board/gateworks/venice/MAINTAINERS @@ -3,5 +3,6 @@ M: Tim Harvey tharvey@gateworks.com S: Maintained F: arch/arm/dts/imx8m*-venice* F: board/gateworks/venice/ +F: doc/board/gateworks/*venice* F: include/configs/imx8m*_venice.h F: configs/imx8m*_venice_defconfig diff --git a/board/gateworks/venice/README b/board/gateworks/venice/README deleted file mode 100644 index ea9b8348a7df..000000000000 --- a/board/gateworks/venice/README +++ /dev/null @@ -1,35 +0,0 @@ -U-Boot for the Gateworks i.MX8M Mini Venice Development Kit boards - -Quick Start -=========== -- Build the ARM Trusted firmware binary -- Get ddr firmware -- Build U-Boot -- Flash to eMMC -- Boot - -Get and Build the ARM Trusted firmware -====================================== -$ git clone https://github.com/nxp-imx/imx-atf -$ git checkout imx_5.4.47_2.2.0 -$ make PLAT=imx8mm CROSS_COMPILE=aarch64-linux-gnu- bl31 -$ cp build/imx8mm/release/bl31.bin . - -Get the DDR Firmware -==================== -$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin -$ chmod +x firmware-imx-8.9.bin -$ ./firmware-imx-8.9.bin -$ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin . - -Build U-Boot -============ -$ make imx8mm_venice_defconfig -$ make CROSS_COMPILE=aarch64-linux-gnu- - -Update eMMC -=========== -=> tftpboot $loadaddr flash.bin -=> setexpr blkcnt $filesize + 0x1ff && setexpr blkcnt $blkcnt / 0x200 -=> mmc dev 2 && mmc write $loadaddr 0x42 $blkcnt # for IMX8MM -=> mmc dev 2 && mmc write $loadaddr 0x40 $blkcnt # for IMX8MN diff --git a/doc/board/gateworks/imx8mm_venice.rst b/doc/board/gateworks/imx8mm_venice.rst new file mode 100644 index 000000000000..f1e7e4994458 --- /dev/null +++ b/doc/board/gateworks/imx8mm_venice.rst @@ -0,0 +1,50 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +imx8mm_venice +============= + +U-Boot for the Gateworks i.MX8M Mini Venice Development Kit boards + +Quick Start +----------- +- Build the ARM Trusted firmware binary +- Get DDR firmware +- Build U-Boot +- Flash to eMMC +- Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +.. code-block:: bash + + $ git clone https://github.com/nxp-imx/imx-atf.git -b lf_v2.4 + $ make PLAT=imx8mm bl31 CROSS_COMPILE=aarch64-linux-gnu- + $ cp build/imx8mm/release/bl31.bin . + +Get the DDR Firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9.bin + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin . + +Build U-Boot +------------ + +.. code-block:: bash + + $ make imx8mm_venice_defconfig + $ make CROSS_COMPILE=aarch64-linux-gnu- + +Update eMMC +----------- + +.. code-block:: bash + + => tftpboot $loadaddr flash.bin + => setexpr blkcnt $filesize + 0x1ff && setexpr blkcnt $blkcnt / 0x200 + => mmc dev 2 && mmc write $loadaddr 0x42 $blkcnt diff --git a/doc/board/gateworks/imx8mn_venice.rst b/doc/board/gateworks/imx8mn_venice.rst new file mode 100644 index 000000000000..7ba953a4a85c --- /dev/null +++ b/doc/board/gateworks/imx8mn_venice.rst @@ -0,0 +1,50 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +imx8mn_venice +============= + +U-Boot for the Gateworks i.MX8M Nano Venice Development Kit boards + +Quick Start +----------- +- Build the ARM Trusted firmware binary +- Get DDR firmware +- Build U-Boot +- Flash to eMMC +- Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +.. code-block:: bash + + $ git clone https://github.com/nxp-imx/imx-atf.git -b lf_v2.4 + $ make PLAT=imx8mn bl31 CROSS_COMPILE=aarch64-linux-gnu- + $ cp build/imx8mn/release/bl31.bin . + +Get the DDR Firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9.bin + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin . + +Build U-Boot +------------ + +.. code-block:: bash + + $ make imx8mn_venice_defconfig + $ make CROSS_COMPILE=aarch64-linux-gnu- + +Update eMMC +----------- + +.. code-block:: bash + + => tftpboot $loadaddr flash.bin + => setexpr blkcnt $filesize + 0x1ff && setexpr blkcnt $blkcnt / 0x200 + => mmc dev 2 && mmc write $loadaddr 0x40 $blkcnt diff --git a/doc/board/gateworks/imx8mp_venice.rst b/doc/board/gateworks/imx8mp_venice.rst new file mode 100644 index 000000000000..632cd742d1f8 --- /dev/null +++ b/doc/board/gateworks/imx8mp_venice.rst @@ -0,0 +1,50 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +imx8mp_venice +============= + +U-Boot for the Gateworks i.MX8M Plus Venice Development Kit boards + +Quick Start +----------- +- Build the ARM Trusted firmware binary +- Get DDR firmware +- Build U-Boot +- Flash to eMMC +- Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +.. code-block:: bash + + $ git clone https://github.com/nxp-imx/imx-atf.git -b lf_v2.4 + $ make PLAT=imx8mp bl31 CROSS_COMPILE=aarch64-linux-gnu- + $ cp build/imx8mp/release/bl31.bin . + +Get the DDR Firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9.bin + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin . + +Build U-Boot +------------ + +.. code-block:: bash + + $ make imx8mp_venice_defconfig + $ make CROSS_COMPILE=aarch64-linux-gnu- + +Update eMMC +----------- + +.. code-block:: bash + + => tftpboot $loadaddr flash.bin + => setexpr blkcnt $filesize + 0x1ff && setexpr blkcnt $blkcnt / 0x200 + => mmc dev 2 && mmc write $loadaddr 0x40 $blkcnt diff --git a/doc/board/gateworks/index.rst b/doc/board/gateworks/index.rst new file mode 100644 index 000000000000..6cf0839814df --- /dev/null +++ b/doc/board/gateworks/index.rst @@ -0,0 +1,11 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Gateworks +========= + +.. toctree:: + :maxdepth: 2 + + imx8mm_venice + imx8mn_venice + imx8mp_venice diff --git a/doc/board/index.rst b/doc/board/index.rst index 1e628e99e637..618d22e616b2 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -20,6 +20,7 @@ Board-specific doc congatec/index coreboot/index emulation/index + gateworks/index google/index highbank/index intel/index
Tim Harvey
