[U-Boot] [PATCH 0/4] efi_loader: fix disk objects + device-paths
Currently u-boot completely gets block-io objects (and their associated device-paths) wrong, which prevents grub2 from figuring out the boot device+partition, which prevents it from automatically finding it's grub.cfg.
Currently efi_loader creates a block-io object per disk, for example on a board with 3 partitions on an sd-card and 4 partitions on a usb disk:
/File(sdhci@07864000.blk)/EndEntire /File(usb_mass_storage.lun0)/EndEntire
at least grub manages to match up the loaded_image device-path, but it cannot figure out which partition it was on. So you end up with prefix=(hd1)/EFI/fedora instead of prefix=(hd1,msdos1)/EFI/fedora. With this patchset, you end up with:
/ACPI(133741d0,0)/UnknownMessaging(1d)/EndEntire /ACPI(133741d0,0)/UnknownMessaging(1d)/HD(0,800,64000,0000000000000000,1,0)/EndEntire /ACPI(133741d0,0)/UnknownMessaging(1d)/HD(1,64800,200000,0000000000000000,1,0)/EndEntire /ACPI(133741d0,0)/UnknownMessaging(1d)/HD(2,264800,19a000,0000000000000000,1,0)/EndEntire /ACPI(133741d0,0)/USB(0,0)/USB(0,0)/USB(0,0)/EndEntire /ACPI(133741d0,0)/USB(0,0)/USB(0,0)/USB(0,0)/HD(0,800,60000,0000000000000000,1,0)/EndEntire /ACPI(133741d0,0)/USB(0,0)/USB(0,0)/USB(0,0)/HD(1,61000,155000,0000000000000000,1,0)/EndEntire /ACPI(133741d0,0)/USB(0,0)/USB(0,0)/USB(0,0)/HD(2,20fa800,1bbf8800,0000000000000000,1,0)/EndEntire /ACPI(133741d0,0)/USB(0,0)/USB(0,0)/USB(0,0)/HD(3,1b6800,1f44000,0000000000000000,1,0)/EndEntire
(Note that "UnknownMessaging(1d)" is actually the MMC node in the device- path, but grub wasn't updated to print out some of the newer device-path sub-types.)
Since we use DM to generate the device-paths from u-boot's device hierarchy, legacy devices will still be broken. I kept them working as they did previously and tried to minimize the ifdeffery, but things will get much cleaner when legacy support is removed.
Peter Jones (1): efi: add some more device path structures
Rob Clark (3): efi_loader: add udevice to EFI device-path mapping efi_loader: make disk objects for partitions efi_loader: use efi_devpath to get correct boot device-path
cmd/bootefi.c | 31 ++++++-- include/efi_api.h | 49 +++++++++++- include/efi_loader.h | 9 +++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_devpath.c | 175 +++++++++++++++++++++++++++++++++++++++++++ lib/efi_loader/efi_disk.c | 73 +++++++++++++----- 6 files changed, 311 insertions(+), 27 deletions(-) create mode 100644 lib/efi_loader/efi_devpath.c
Signed-off-by: Peter Jones pjones@redhat.com --- include/efi_api.h | 49 +++++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 47 insertions(+), 2 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index f071b36b53..e1b3f11c6d 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -275,22 +275,67 @@ struct efi_mac_addr { u8 addr[32]; };
+#define DEVICE_PATH_TYPE_ACPI_DEVICE 0x02 +#define DEVICE_PATH_SUB_TYPE_ACPI_DEVICE 0x01 + +#define EFI_PNP_ID(ID) (u32)(((ID) << 16) | 0x41D0) +#define EISA_PNP_ID(ID) EFI_PNP_ID(ID) + +struct efi_device_path_acpi_path { + struct efi_device_path dp; + u32 hid; + u32 uid; +} __packed; + #define DEVICE_PATH_TYPE_MESSAGING_DEVICE 0x03 +# define DEVICE_PATH_SUB_TYPE_MSG_USB 0x05 # define DEVICE_PATH_SUB_TYPE_MSG_MAC_ADDR 0x0b +# define DEVICE_PATH_SUB_TYPE_MSG_SD 0x1a +# define DEVICE_PATH_SUB_TYPE_MSG_MMC 0x1d + +struct efi_device_path_usb { + struct efi_device_path dp; + u8 parent_port_number; + u8 usb_interface; +} __packed;
struct efi_device_path_mac_addr { struct efi_device_path dp; struct efi_mac_addr mac; u8 if_type; -}; +} __packed; + +struct efi_device_path_sd_mmc_path { + struct efi_device_path dp; + u8 slot_number; +} __packed;
#define DEVICE_PATH_TYPE_MEDIA_DEVICE 0x04 +# define DEVICE_PATH_SUB_TYPE_HARD_DRIVE_PATH 0x01 +# define DEVICE_PATH_SUB_TYPE_CDROM_PATH 0x02 # define DEVICE_PATH_SUB_TYPE_FILE_PATH 0x04
+struct efi_device_path_hard_drive_path { + struct efi_device_path dp; + u32 partition_number; + u64 partition_start; + u64 partition_end; + u8 partition_signature[16]; + u8 partmap_type; + u8 signature_type; +} __packed; + +struct efi_device_path_cdrom_path { + struct efi_device_path dp; + u32 boot_entry; + u64 partition_start; + u64 partition_end; +} __packed; + struct efi_device_path_file_path { struct efi_device_path dp; u16 str[32]; -}; +} __packed;
#define BLOCK_IO_GUID \ EFI_GUID(0x964e5b21, 0x6459, 0x11d2, \
Initially just supports "disk" type devices, but a real UEFI implementation would expose input/output/display/etc with device-paths as well, so we may eventually want to expand this for other uses.
Signed-off-by: Rob Clark robdclark@gmail.com --- include/efi_loader.h | 9 +++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_devpath.c | 175 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 185 insertions(+) create mode 100644 lib/efi_loader/efi_devpath.c
diff --git a/include/efi_loader.h b/include/efi_loader.h index 812ec10e37..97d5e3d13d 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -145,6 +145,15 @@ extern void *efi_bounce_buffer; #define EFI_LOADER_BOUNCE_BUFFER_SIZE (64 * 1024 * 1024) #endif
+/* + * u-boot to EFI device mapping: + * + * TODO extend this for GOP and various other input/output + * devices which should also have an EFI devicepath? + */ +struct efi_device_path *efi_dp_from_dev(struct udevice *dev); +struct efi_device_path *efi_dp_from_part(struct blk_desc *desc, int part); + /* Convert strings from normal C strings to uEFI strings */ static inline void ascii2unicode(u16 *unicode, const char *ascii) { diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 9c67367df4..e191a3280b 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -22,3 +22,4 @@ obj-$(CONFIG_DM_VIDEO) += efi_gop.o obj-$(CONFIG_PARTITIONS) += efi_disk.o obj-$(CONFIG_NET) += efi_net.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += efi_smbios.o +obj-$(CONFIG_DM) += efi_devpath.o diff --git a/lib/efi_loader/efi_devpath.c b/lib/efi_loader/efi_devpath.c new file mode 100644 index 0000000000..16b8edf899 --- /dev/null +++ b/lib/efi_loader/efi_devpath.c @@ -0,0 +1,175 @@ +/* + * EFI device path from u-boot device-model mapping + * + * (C) Copyright 2017 Rob Clark + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <blk.h> +#include <dm.h> +#include <usb.h> +#include <mmc.h> +#include <efi_loader.h> +#include <inttypes.h> +#include <part.h> +#include <malloc.h> + +/* template END node: */ +const static struct efi_device_path END = { + .type = DEVICE_PATH_TYPE_END, + .sub_type = DEVICE_PATH_SUB_TYPE_END, + .length = sizeof(END), +}; + +/* template ROOT node, a fictional ACPI PNP device: */ +const static struct efi_device_path_acpi_path ROOT = { + .dp = { + .type = DEVICE_PATH_TYPE_ACPI_DEVICE, + .sub_type = DEVICE_PATH_SUB_TYPE_ACPI_DEVICE, + .length = sizeof(ROOT), + }, + .hid = EISA_PNP_ID(0x1337), + .uid = 0, +}; + + +/* size of device-path not including END node for device and all parents + * up to the root device. + */ +static unsigned dp_size(struct udevice *dev) +{ + if (!dev || !dev->driver) + return sizeof(ROOT); + + switch (dev->driver->id) { + case UCLASS_ROOT: + case UCLASS_SIMPLE_BUS: + /* stop traversing parents at this point: */ + return sizeof(ROOT); + case UCLASS_MMC: + return dp_size(dev->parent) + sizeof(struct efi_device_path_sd_mmc_path); + case UCLASS_MASS_STORAGE: + case UCLASS_USB_HUB: + return dp_size(dev->parent) + sizeof(struct efi_device_path_usb); + default: + /* just skip over unknown classes: */ + return dp_size(dev->parent); + } +} + +static void *dp_fill(void *buf, struct udevice *dev) +{ + if (!dev || !dev->driver) + return buf; + + switch (dev->driver->id) { + case UCLASS_ROOT: + case UCLASS_SIMPLE_BUS: { + /* stop traversing parents at this point: */ + struct efi_device_path_acpi_path *adp = buf; + *adp = ROOT; + return &adp[1]; + } + case UCLASS_MMC: { + struct efi_device_path_sd_mmc_path *sddp = + dp_fill(buf, dev->parent); + struct mmc *mmc = mmc_get_mmc_dev(dev); + struct blk_desc *desc = mmc_get_blk_desc(mmc); + + sddp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; + sddp->dp.sub_type = (desc->if_type == IF_TYPE_MMC) ? + DEVICE_PATH_SUB_TYPE_MSG_MMC : + DEVICE_PATH_SUB_TYPE_MSG_SD; + sddp->dp.length = sizeof(*sddp); + sddp->slot_number = 0; // XXX ??? + + return &sddp[1]; + } + case UCLASS_MASS_STORAGE: + case UCLASS_USB_HUB: { + struct efi_device_path_usb *udp = + dp_fill(buf, dev->parent); + + udp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; + udp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_USB; + udp->dp.length = sizeof(*udp); + udp->parent_port_number = 0; // XXX ??? + udp->usb_interface = 0; // XXX ??? + + return &udp[1]; + } + default: + debug("unhandled device class: %s (%u)\n", + dev->name, dev->driver->id); + return dp_fill(buf, dev->parent); + } +} + +/* Construct a device-path from a device: */ +struct efi_device_path *efi_dp_from_dev(struct udevice *dev) +{ + void *buf, *start; + + start = buf = calloc(1, dp_size(dev) + sizeof(END)); + buf = dp_fill(buf, dev); + *((struct efi_device_path *)buf) = END; + + return start; +} + +/* Construct a device-path from a partition on a blk device: */ +struct efi_device_path *efi_dp_from_part(struct blk_desc *desc, int part) +{ + disk_partition_t info; + unsigned dpsize; + void *buf, *start; + + dpsize = dp_size(desc->bdev->parent) + sizeof(END); + + if (desc->part_type == PART_TYPE_ISO) { + dpsize += sizeof(struct efi_device_path_cdrom_path); + } else { + dpsize += sizeof(struct efi_device_path_hard_drive_path); + } + + start = buf = calloc(1, dpsize); + + buf = dp_fill(buf, desc->bdev->parent); + + part_get_info(desc, part, &info); + + if (desc->part_type == PART_TYPE_ISO) { + struct efi_device_path_cdrom_path *cddp = buf; + + cddp->boot_entry = part - 1; + cddp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; + cddp->dp.sub_type = DEVICE_PATH_SUB_TYPE_CDROM_PATH; + cddp->dp.length = sizeof (*cddp); + cddp->partition_start = info.start; + cddp->partition_end = info.size; + + buf = &cddp[1]; + } else { + struct efi_device_path_hard_drive_path *hddp = buf; + + hddp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; + hddp->dp.sub_type = DEVICE_PATH_SUB_TYPE_HARD_DRIVE_PATH; + hddp->dp.length = sizeof (*hddp); + hddp->partition_number = part - 1; + hddp->partition_start = info.start; + hddp->partition_end = info.size; + if (desc->part_type == PART_TYPE_EFI) + hddp->partmap_type = 2; + else + hddp->partmap_type = 1; + hddp->signature_type = 0; + + buf = &hddp[1]; + } + + *((struct efi_device_path *)buf) = END; + + return start; +}
So the static bootefi_device_obj is making things slightly awkward for efi_load_image() from a file-path. And really it should just go away, and instead we should plug in the appropriate diskobj (or netobj) to the loaded_image_obj at boot time. Also we should nuke bootefi_device_path. And since we need to construct a new loaded_image_obj in efi_load_image(), probably split out a helper to fill that out properly and plug in the correct boot device-path, etc, etc, so we don't have too many different places constructing the same sort of object and forgetting to install some protocols in one place or another.
And since there are a lot of places we need to map to device-path and back, I'm starting to thing the sane way to do all this without breaking legacy (!CONFIG_DM) is to introduce a efi_device_path.c and efi_device_path_legacy.c. Move all the hacky stuff of current devicepath construction into efi_device_path_legacy.c. Add some device-path parsing/matching stuff to efi_device_path_util.c (which probably just be efi_device_path_to_text.c renamed and then spiffed out with some more device-path helpers), which would be shared in common in legacy and CONFIG_DM cases.
Sound semi-reasonable? I'm not sure if this intersects too badly with other stuff Heinrich is working on?
(Also, small logistical question.. anyone know how to do "obj-$(!CONFIG_DM) += efi_boot_device_legacy.o"?)
BR, -R
- u-boot to EFI device mapping:
- TODO extend this for GOP and various other input/output
- devices which should also have an EFI devicepath?
- EFI device path from u-boot device-model mapping
- (C) Copyright 2017 Rob Clark
.dp = {
.uid = 0,
- up to the root device.
case UCLASS_ROOT:
case UCLASS_MMC:
default:
return buf;
case UCLASS_ROOT:
*adp = ROOT;
return &adp[1];
case UCLASS_MMC: {
return &sddp[1];
return &udp[1];
default:
void *buf, *start;
return start;
unsigned dpsize;
void *buf, *start;
} else {
buf = &cddp[1];
} else {
else
buf = &hddp[1];
return start;
2.13.0
Sounds reasonable to me :).
I don't know - I'll let him comment.
I would do
ifeq ($(CONFIG_DM),y) obj-y += efi_boot_device_dm.o else obj-y += efi_boot_device_nodm.o endif
Alex
OpenProtocol should manage a lock table of type EFI_OPEN_PROTOCOL_INFORMATION_ENTRY[] per protocol. I am trying to implement this table which is also needed by OpenProtocolInformation, CloseProtocol, ConnectController, and DisconnectConntroller.
Best regards
Heinrich
I would do
Alex
Normally a EFI application, like grub2, is going to expect to see block-io devices for both the actual disk and for each partition (with the disk object being parent of the partition objects).
Now instead of seeing devices like:
You see:
This is on a board with single USB disk and single sd-card. The UnknownMessaging(1d) node in the device-path is the MMC device, but grub_efi_print_device_path() hasn't been updated yet for some of the newer device-path sub-types.
This patch is somewhat based on a patch originally from Peter Jones, but re-worked to use efi_devpath, so it doesn't much resemble the original.
This depends on efi_devpath, which depends on CONFIG_DM, so legacy devices will still get the old broken behavior.
There are a couple TODOs: 1) how to find slot # for mmc device 2) how to find parent port # and interface # for usb device
Also I don't seem to manage to get u-boot to recognize my usb-eth dongle (config issue?) so I haven't been able to test the net-boot path.. so it likely needs some work.
Cc: Peter Jones pjones@redhat.com Signed-off-by: Rob Clark robdclark@gmail.com --- lib/efi_loader/efi_disk.c | 73 ++++++++++++++++++++++++++++++++++------------- 1 file changed, 53 insertions(+), 20 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 09697936b5..44f72c93e2 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -28,7 +28,7 @@ struct efi_disk_obj { /* EFI Interface Media descriptor struct, referenced by ops */ struct efi_block_io_media media; /* EFI device path to this block device */ - struct efi_device_path_file_path *dp; + struct efi_device_path *dp; /* Offset into disk for simple partitions */ lbaint_t offset; /* Internal block device */ @@ -193,21 +193,47 @@ static const struct efi_block_io block_io_disk_template = { .flush_blocks = &efi_disk_flush_blocks, };
+static struct efi_device_path *blk2dp(struct blk_desc *desc, + const char *name, unsigned part) +{ +#ifdef CONFIG_DM + /* part==0 is the case for parent block device representing + * entire disk, and part>=1 is for child per-partition + * MEDIA_DEVICE objects: + */ + if (part == 0) + return efi_dp_from_dev(desc->bdev->parent); + return efi_dp_from_part(desc, part); +#else + struct efi_device_path_file_path *dp = calloc(2, sizeof(*dp)); + + dp[0].dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; + dp[0].dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH; + dp[0].dp.length = sizeof(*dp); + ascii2unicode(dp[0].str, name); + + dp[1].dp.type = DEVICE_PATH_TYPE_END; + dp[1].dp.sub_type = DEVICE_PATH_SUB_TYPE_END; + dp[1].dp.length = sizeof(*dp); + + return dp; +#endif +} + static void efi_disk_add_dev(const char *name, const char *if_typename, - const struct blk_desc *desc, + struct blk_desc *desc, int dev_index, - lbaint_t offset) + lbaint_t offset, + unsigned part) { struct efi_disk_obj *diskobj; - struct efi_device_path_file_path *dp; - int objlen = sizeof(*diskobj) + (sizeof(*dp) * 2);
/* Don't add empty devices */ if (!desc->lba) return;
- diskobj = calloc(1, objlen); + diskobj = calloc(1, sizeof(*diskobj));
/* Fill in object data */ diskobj->parent.protocols[0].guid = &efi_block_io_guid; @@ -228,18 +254,7 @@ static void efi_disk_add_dev(const char *name, diskobj->media.io_align = desc->blksz; diskobj->media.last_block = desc->lba - offset; diskobj->ops.media = &diskobj->media; - - /* Fill in device path */ - dp = (void*)&diskobj[1]; - diskobj->dp = dp; - dp[0].dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; - dp[0].dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH; - dp[0].dp.length = sizeof(*dp); - ascii2unicode(dp[0].str, name); - - dp[1].dp.type = DEVICE_PATH_TYPE_END; - dp[1].dp.sub_type = DEVICE_PATH_SUB_TYPE_END; - dp[1].dp.length = sizeof(*dp); + diskobj->dp = blk2dp(desc, name, part);
/* Hook up to the device list */ list_add_tail(&diskobj->parent.link, &efi_obj_list); @@ -259,11 +274,16 @@ static int efi_disk_create_eltorito(struct blk_desc *desc, if (desc->part_type != PART_TYPE_ISO) return 0;
+#ifdef CONFIG_DM + /* add block device: */ + efi_disk_add_dev(devname, if_typename, desc, diskid, 0, 0); +#endif + /* ... and devices for each partition: */ while (!part_get_info(desc, part, &info)) { snprintf(devname, sizeof(devname), "%s:%d", pdevname, part); efi_disk_add_dev(devname, if_typename, desc, diskid, - info.start); + info.start, part); part++; disks++; } @@ -290,9 +310,22 @@ int efi_disk_register(void) uclass_next_device(&dev)) { struct blk_desc *desc = dev_get_uclass_platdata(dev); const char *if_typename = dev->driver->name; + disk_partition_t info; + int part = 1;
printf("Scanning disk %s...\n", dev->name); - efi_disk_add_dev(dev->name, if_typename, desc, desc->devnum, 0); + +#ifdef CONFIG_DM + /* add block device: */ + efi_disk_add_dev(dev->name, if_typename, desc, + desc->devnum, 0, 0); +#endif + /* ... and devices for each partition: */ + while (!part_get_info(desc, part, &info)) { + efi_disk_add_dev(dev->name, if_typename, desc, + desc->devnum, 0, part); + part++; + } disks++;
%s/a/an/
You see:
- how to find slot # for mmc device
- how to find parent port # and interface # for usb device
- struct efi_device_path *dp; /* Offset into disk for simple partitions */ lbaint_t offset; /* Internal block device */
- /* part==0 is the case for parent block device representing
- if (part == 0)
- return efi_dp_from_part(desc, part);
+#else
- struct efi_device_path_file_path *dp = calloc(2, sizeof(*dp));
- return dp;
+#endif +}
lbaint_t offset)
lbaint_t offset,
unsigned part)
I am unable to apply this patch to the efi-next branch of git://github.com/agraf/u-boot.git
Applying: efi_loader: make disk objects for partitions error: patch failed: lib/efi_loader/efi_disk.c:193 error: lib/efi_loader/efi_disk.c: patch does not apply Patch failed at 0001 efi_loader: make disk objects for partitions
Could you, please, resubmit your patch series rebased on efi-next.
You somehow forgot to CC the maintainer Alexander Graf in your patch.
Please, always use scripts/get_maintainer.pl to determine whom a patch should be addressed to.
Best regards
- diskobj->dp = dp;
+#ifdef CONFIG_DM
- /* add block device: */
- efi_disk_add_dev(devname, if_typename, desc, diskid, 0, 0);
- /* ... and devices for each partition: */ while (!part_get_info(desc, part, &info)) { snprintf(devname, sizeof(devname), "%s:%d", pdevname, part); efi_disk_add_dev(devname, if_typename, desc, diskid,
info.start);
part++; disks++; }info.start, part);
int part = 1;
+#ifdef CONFIG_DM
part++;
disks++;
On Sun, Jul 23, 2017 at 6:25 AM, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
%s/a/an/
You see:
if (part == 0)
+#else
return dp;
+#endif +}
lbaint_t offset)
lbaint_t offset,
unsigned part)
int objlen = sizeof(*diskobj) + (sizeof(*dp) * 2); /* Don't add empty devices */ if (!desc->lba) return;
diskobj = calloc(1, sizeof(*diskobj)); /* Fill in object data */ diskobj->parent.protocols[0].guid = &efi_block_io_guid;
sorry, wasn't aware of efi-next tree.. I'll rebase soon. I have some more updates[1] (including some parts that I'd like to squash into this patch) to get shim.efi and fallback.efi working, but I'll send a new version of these patches when I have that working.
[1] https://github.com/robclark/u-boot/commits/wip-enough-uefi-for-shim <-- very much work-in-progress
BR, -R
Best regards
diskobj->dp = dp;
diskobj->dp = blk2dp(desc, name, part); /* Hook up to the device list */ list_add_tail(&diskobj->parent.link, &efi_obj_list);
+#ifdef CONFIG_DM
info.start);
int part = 1; printf("Scanning disk %s...\n", dev->name);
+#ifdef CONFIG_DM
part++;
} disks++; /*
This way grub can properly match up the loaded_image device-path to a partition device object, so it can locate it's grub.cfg.
Signed-off-by: Rob Clark robdclark@gmail.com --- cmd/bootefi.c | 31 ++++++++++++++++++++++++++----- 1 file changed, 26 insertions(+), 5 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 5030b7bd86..ea0d5dbc79 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -41,6 +41,11 @@ static struct efi_device_path_file_path bootefi_image_path[] = { } };
+/* if we have CONFIG_DM we construct a proper device-path from the + * boot device, otherwise fallback to using bootefi_device_path. + */ +static struct efi_device_path *real_bootefi_device_path; + static struct efi_device_path_file_path bootefi_device_path[] = { { .dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE, @@ -58,13 +63,12 @@ static efi_status_t EFIAPI bootefi_open_dp(void *handle, efi_guid_t *protocol, void **protocol_interface, void *agent_handle, void *controller_handle, uint32_t attributes) { - *protocol_interface = bootefi_device_path; + *protocol_interface = real_bootefi_device_path; return EFI_SUCCESS; }
/* The EFI loaded_image interface for the image executed via "bootefi" */ static struct efi_loaded_image loaded_image_info = { - .device_handle = bootefi_device_path, .file_path = bootefi_image_path, };
@@ -93,7 +97,6 @@ static struct efi_object loaded_image_info_obj = {
/* The EFI object struct for the device the "bootefi" image was loaded from */ static struct efi_object bootefi_device_obj = { - .handle = bootefi_device_path, .protocols = { { /* When asking for the device path interface, return @@ -239,8 +242,6 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt)
if (!memcmp(bootefi_device_path[0].str, "N\0e\0t", 6)) loaded_image_info.device_handle = nethandle; - else - loaded_image_info.device_handle = bootefi_device_path; #endif #ifdef CONFIG_GENERATE_SMBIOS_TABLE efi_smbios_register(); @@ -339,6 +340,18 @@ U_BOOT_CMD( bootefi_help_text );
+#ifdef CONFIG_DM +static int parse_partnum(const char *devnr) +{ + const char *str = strchr(devnr, ':'); + if (str) { + str++; + return simple_strtoul(str, NULL, 16); + } + return 0; +} +#endif + void efi_set_bootdev(const char *dev, const char *devnr, const char *path) { __maybe_unused struct blk_desc *desc; @@ -376,9 +389,14 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path) if (colon) *colon = '\0';
+#ifdef CONFIG_DM + real_bootefi_device_path = efi_dp_from_part(desc, parse_partnum(devnr)); +#else /* Patch bootefi_device_path to the target device */ + real_bootefi_device_path = bootefi_device_path; memset(bootefi_device_path[0].str, 0, sizeof(bootefi_device_path[0].str)); ascii2unicode(bootefi_device_path[0].str, devname); +#endif
/* Patch bootefi_image_path to the target file path */ memset(bootefi_image_path[0].str, 0, sizeof(bootefi_image_path[0].str)); @@ -389,4 +407,7 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path) snprintf(devname, sizeof(devname), "%s", path); } ascii2unicode(bootefi_image_path[0].str, devname); + + loaded_image_info.device_handle = real_bootefi_device_path; + bootefi_device_obj.handle = real_bootefi_device_path; }
Alexander Graf
Rob Clark
