[PATCH] test: bdinfo: Handle systems without getopt
Systems without getopt support fall back to plain full bdinfo print, handle such a case, which occurs e.g. with sandbox_flattree_defconfig .
Fixes: 8827a3871452 ("test: bdinfo: Test bdinfo -h") Fixes: 2696f3ab8101 ("test: bdinfo: Test bdinfo -m") Fixes: 3ff2d796a6f2 ("test: bdinfo: Test bdinfo -e") Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- test/cmd/bdinfo.c | 26 ++++++++++++++++++-------- 1 file changed, 18 insertions(+), 8 deletions(-)
diff --git a/test/cmd/bdinfo.c b/test/cmd/bdinfo.c index 9744bd16df9..053f2224919 100644 --- a/test/cmd/bdinfo.c +++ b/test/cmd/bdinfo.c @@ -237,12 +237,17 @@ static int bdinfo_test_help(struct unit_test_state *uts) { /* Test BDINFO unknown option help text print */ ut_assertok(console_record_reset_enable()); - ut_asserteq(1, run_commandf("bdinfo -h")); - ut_assert_nextlinen("bdinfo: invalid option -- h"); - ut_assert_nextlinen("bdinfo - print Board Info structure"); - ut_assert_nextline_empty(); - ut_assert_nextlinen("Usage:"); - ut_assert_nextlinen("bdinfo"); + if (!CONFIG_IS_ENABLED(GETOPT)) { + ut_asserteq(0, run_commandf("bdinfo -h")); + ut_assertok(bdinfo_test_all(uts)); + } else { + ut_asserteq(1, run_commandf("bdinfo -h")); + ut_assert_nextlinen("bdinfo: invalid option -- h"); + ut_assert_nextlinen("bdinfo - print Board Info structure"); + ut_assert_nextline_empty(); + ut_assert_nextlinen("Usage:"); + ut_assert_nextlinen("bdinfo"); + } ut_assertok(ut_check_console_end(uts));
return 0; @@ -255,7 +260,10 @@ static int bdinfo_test_memory(struct unit_test_state *uts) /* Test BDINFO memory layout only print */ ut_assertok(console_record_reset_enable()); ut_assertok(run_commandf("bdinfo -m")); - ut_assertok(bdinfo_check_mem(uts)); + if (!CONFIG_IS_ENABLED(GETOPT)) + ut_assertok(bdinfo_test_all(uts)); + else + ut_assertok(bdinfo_check_mem(uts)); ut_assertok(ut_check_console_end(uts));
return 0; @@ -268,7 +276,9 @@ static int bdinfo_test_eth(struct unit_test_state *uts) /* Test BDINFO ethernet settings only print */ ut_assertok(console_record_reset_enable()); ut_assertok(run_commandf("bdinfo -e")); - if (IS_ENABLED(CONFIG_CMD_NET)) + if (!CONFIG_IS_ENABLED(GETOPT)) + ut_assertok(bdinfo_test_all(uts)); + else if (IS_ENABLED(CONFIG_CMD_NET)) ut_assertok(test_eth(uts)); ut_assertok(ut_check_console_end(uts));
