[PATCH] imx8mp_evk: README instruction fixes
Use the full name of firmware self extracting file to make it run.
Also, don't use sudo when not needed.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- This time add the u-boot list to Cc. --- board/freescale/imx8mp_evk/README | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/freescale/imx8mp_evk/README b/board/freescale/imx8mp_evk/README index 7dd3a9352a57..0c65a894bb1a 100644 --- a/board/freescale/imx8mp_evk/README +++ b/board/freescale/imx8mp_evk/README @@ -13,17 +13,17 @@ Note: $(srctree) is the U-Boot source directory Get ATF from: https://source.codeaurora.org/external/imx/imx-atf branch: imx_5.4.3_2.0.0 $ make PLAT=imx8mp bl31 -$ sudo cp build/imx8mp/release/bl31.bin $(srctree) +$ cp build/imx8mp/release/bl31.bin $(srctree)
Get the ddr firmware ==================== $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.7.bin $ chmod +x firmware-imx-8.7.bin -$ ./firmware-imx-8.7 -$ sudo cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin -$ sudo cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_201904.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin -$ sudo cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin -$ sudo cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_201904.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin +$ ./firmware-imx-8.7.bin +$ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin +$ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_201904.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin +$ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin +$ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_201904.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin
Build U-Boot ============
Use the full name of firmware self extracting file to make it run. Also, don't use sudo when not needed. Signed-off-by: Baruch Siach baruch@tkos.co.il
Best regards, Stefano Babic
Baruch Siach
sbabic@denx.de
