[U-Boot-Users] [PATCH] 85xx/86xx: Rename DDR init address and init extended address register
Rename init_addr and init_ext_addr to match the docs between 85xx and 86xx. Both now use 'init_addr' and 'init_ext_addr'.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
Can you guys ack and decide who will actually apply this.
- k
include/asm-ppc/immap_85xx.h | 4 ++-- include/asm-ppc/immap_86xx.h | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index 813be5f..2d07625 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -106,8 +106,8 @@ typedef struct ccsr_ddr { char res6[4]; uint sdram_clk_cntl; /* 0x2130 - DDR SDRAM Clock Control */ char res7[20]; - uint init_address; /* 0x2148 - DDR training initialization address */ - uint init_ext_address; /* 0x214C - DDR training initialization extended address */ + uint init_addr; /* 0x2148 - DDR training initialization address */ + uint init_ext_addr; /* 0x214C - DDR training initialization extended address */ char res8_1[16]; uint timing_cfg_4; /* 0x2160 - DDR SDRAM Timing Configuration Register 4 */ uint timing_cfg_5; /* 0x2164 - DDR SDRAM Timing Configuration Register 5 */ diff --git a/include/asm-ppc/immap_86xx.h b/include/asm-ppc/immap_86xx.h index fd4aa54..0b78c94 100644 --- a/include/asm-ppc/immap_86xx.h +++ b/include/asm-ppc/immap_86xx.h @@ -126,7 +126,7 @@ typedef struct ccsr_ddr { uint sdram_ocd_cntl; /* 0x2140 - DDR SDRAM OCD Control */ uint sdram_ocd_status; /* 0x2144 - DDR SDRAM OCD Status */ uint init_addr; /* 0x2148 - DDR training initialzation address */ - uint init_addr_ext; /* 0x214C - DDR training initialzation extended address */ + uint init_ext_addr; /* 0x214C - DDR training initialzation extended address */ char res10[2728]; uint ip_rev1; /* 0x2BF8 - DDR IP Block Revision 1 */ uint ip_rev2; /* 0x2BFC - DDR IP Block Revision 2 */
- k
Ack.
Andy, you've got me two-to-one on this, so if you would, please pick this up!
Thanks, jdl
Jon Loeliger
Kumar Gala
