[U-Boot] [PATCH v3 2/2] amcore: add support for amcore board
Add support for amcore board.
Signed-off-by: Angelo Dureghello sysamfw@gmail.com Cc: Jason Jin jason.jin@freescale.com --- Changes for v2: - None Changes for v3: - Fix code format issues --- board/sysam/amcore/Makefile | 43 ++++ board/sysam/amcore/amcore.c | 168 ++++++++++++++ board/sysam/amcore/config.mk | 23 ++ board/sysam/amcore/flash.c | 444 ++++++++++++++++++++++++++++++++++++ board/sysam/amcore/u-boot.lds | 101 ++++++++ boards.cfg | 1 + include/configs/amcore.h | 213 +++++++++++++++++ include/flash.h | 1 + 8 files changed, 994 insertions(+), 0 deletions(-)
diff --git a/board/sysam/amcore/Makefile b/board/sysam/amcore/Makefile new file mode 100644 index 0000000..c585b19 --- /dev/null +++ b/board/sysam/amcore/Makefile @@ -0,0 +1,43 @@ +# +# Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS = $(BOARD).o flash.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/sysam/amcore/amcore.c b/board/sysam/amcore/amcore.c new file mode 100644 index 0000000..2a27cad --- /dev/null +++ b/board/sysam/amcore/amcore.c @@ -0,0 +1,168 @@ +/* + * Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <asm/immap.h> + + +int init_lcd (void) +{ + /* + * board can have a K0108 lcd connected on the parallel port, + * wired as below: + * + * fc cpu P0 P1 P2 P3 P4 P5 P6 P7 P10 P11 P12 P13 P14 + * lcd D0 D1 D2 D3 D4 D5 D6 D7 CS1 CS2 RW DI E + * + * Starting up setting lines in high impedance + */ + mbar_writeShort(MCFSIM_PAR, 0x300); + mbar_writeShort(MCFSIM_PADDR, 0xfcff); + mbar_writeShort(MCFSIM_PADAT, 0x0c00); +} + +int checkboard (void) +{ + puts ("Board: "); + puts ("AMCORE v.001(alpha)\n"); + + init_lcd(); + + return 0; +} + +/* aprox delay, to use before any timer init */ +void fudelay (int usec) +{ + int i=0; + + for (;i<10;++i) { + __asm__ __volatile__ ("nop"); + } +} + +phys_size_t initdram (int board_type) +{ + icache_disable(); + + /* + * SDRAM MT48LC4M32B2 details + * Memory block 0: 16 MB of SDRAM at address $00000000 + * Port size: 32-bit port + * + * Memory block 0 wired as follows: + * CPU : A15 A14 A13 A12 A11 A10 A9 A17 A18 A19 A20 A21 A22 A23 + * SDRAM : A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 BA0 BA1 + * + * Ensure that there is a delay of at least 100 microseconds from + * processor reset to the following code so that the SDRAM is ready + * for commands... + * + * write to DACR0 base address:0x0000, CASL:03, command bit 20, + * CBM is OK to 3 ***, 32 bit port, continuos page mode, rest to 0 + */ + + fudelay(1000); + + /* + * DCR + * 0x26 mean Refresh period at 64msec (x4096 rows) + * 0x8000,0x8100,0x8200 are all valid, + * faster is 0x8000 (7G, tRC is >=70ns) + */ + mbar_writeShort(MCFSIM_DCR, 0x8226); + + /* + * DACR0 + * page mode on burst only (to be verified) 0x00 + * CMD on A20 0x0300 + */ + mbar_writeLong(MCFSIM_DACR0, 0x00003304); + mbar_writeLong(MCFSIM_DMR0, 0x00ff0001); + + // issue a PRECHARGE ALL + mbar_writeLong(MCFSIM_DACR0, 0x0000330c); + *((volatile unsigned long *)(0x00000004)) = 0xbeaddeed; + mbar_writeLong(MCFSIM_DACR0, 0x0000b304); + + fudelay(1000); + + *((volatile unsigned long *)(0x00000004)) = 0xbeaddeed; + mbar_writeLong(MCFSIM_DACR0, 0x0000b304); + + fudelay(1000); + + mbar_writeLong(MCFSIM_DACR0, 0x0000b344); + *((volatile unsigned long *)(0x00000c00)) = 0xbeaddeed; + + // Memory block 1 not in use (DMR1[V] = 0) + mbar_writeLong(MCFSIM_DMR1, 0x00040000); + mbar_writeLong(MCFSIM_DACR1, 0x00000000); + + icache_enable(); + + return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; +} + +int testdram (void) +{ + int i=0,x,rval=0; + const unsigned long a=0xaaaaaaaa; + const unsigned long b=0x55555555; + const unsigned long c=0xffffffff; + volatile unsigned long *p = (volatile unsigned long *)0; + volatile unsigned long *q; + + icache_disable(); + + puts ("SRAM test:\n"); + + for (;i<16;++i) { + printf ("testing MB %02d ...\n", i+1); + q=p=(volatile unsigned long*)(1024*1024*i); + for (x=0;x<65536;++x) { + *p++=0; + *p++=a; + *p++=b; + *p++=c; + } + for (x=0;x<65536;++x) { + if (*q++!=0) goto error; + if (*q++!=a) goto error; + if (*q++!=b) goto error; + if (*q++!=c) goto error; + } + } + puts ("test passed !\n"); + goto exit; + +error: + puts ("test failed !\n"); + rval=1; + +exit: + icache_enable(); + + return (rval); +} diff --git a/board/sysam/amcore/config.mk b/board/sysam/amcore/config.mk new file mode 100644 index 0000000..cb45c2c --- /dev/null +++ b/board/sysam/amcore/config.mk @@ -0,0 +1,23 @@ +# +# Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +CONFIG_SYS_TEXT_BASE = 0xffc00000 diff --git a/board/sysam/amcore/flash.c b/board/sysam/amcore/flash.c new file mode 100644 index 0000000..971b091 --- /dev/null +++ b/board/sysam/amcore/flash.c @@ -0,0 +1,444 @@ +/* + * Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/immap.h> + +#ifndef CONFIG_SYS_FLASH_CFI +typedef unsigned short FLASH_PORT_WIDTH; +typedef volatile unsigned short FLASH_PORT_WIDTHV; + +#define FPW FLASH_PORT_WIDTH +#define FPWV FLASH_PORT_WIDTHV + +#define FLASH_CYCLE1 0x5555 +#define FLASH_CYCLE2 0x2aaa + +#define SYNC __asm__("nop") + +/*----------------------------------------------------------------------- + * Functions + */ + +ulong flash_get_size(FPWV * addr, flash_info_t * info); +int flash_get_offsets(ulong base, flash_info_t * info); +int write_word(flash_info_t * info, FPWV * dest, u16 data); +void inline spin_wheel(void); + +flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +unsigned short swap (unsigned short value) +{ + return ((value << 8) | (value >> 8)); +} + +ulong flash_init(void) +{ + ulong size = 0; + ulong fbase = 0; + + fbase = (ulong) CONFIG_SYS_FLASH_BASE; + flash_get_size((FPWV *) fbase, &flash_info[0]); + flash_get_offsets((ulong) fbase, &flash_info[0]); + fbase += flash_info[0].size; + size += flash_info[0].size; + + return size; +} + +int flash_get_offsets(ulong base, flash_info_t * info) +{ + int j, k; + + if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_SST) { + info->start[0] = base; + for (k = 0, j = 0; j < CONFIG_SYS_SST_SECT; j++, k++) { + info->start[k + 1] = info->start[k] + + CONFIG_SYS_SST_SECTSZ; + info->protect[k] = 0; + } + } + + return ERR_OK; +} + +void flash_print_info(flash_info_t * info) +{ + int i; + + switch (info->flash_id & FLASH_VENDMASK) { + case FLASH_MAN_SST: + printf("SST "); + break; + default: + printf("Unknown Vendor "); + break; + } + + switch (info->flash_id & FLASH_TYPEMASK) { + case FLASH_SST3201B: + printf("SST39VF3201B\n"); + break; + default: + printf("Unknown Chip Type\n"); + return; + } + + if (info->size > 0x100000) { + int remainder; + + printf(" Size: %ld", info->size >> 20); + remainder = (info->size % 0x100000); + if (remainder) { + remainder >>= 10; + remainder = (int)((float) + (((float)remainder/(float)1024)*10000)); + printf(".%d ", remainder); + } + printf("MB in %d Sectors\n", info->sector_count); + } else + printf(" Size: %ld KB in %d Sectors\n", + info->size >> 10, info->sector_count); + + printf(" Sector Start Addresses:"); + for (i = 0; i < info->sector_count; ++i) { + if ((i % 5) == 0) + printf("\n "); + printf(" %08lX%s", + info->start[i], info->protect[i] ? " (RO)" : " "); + } + printf("\n"); +} + +/* + * The following code cannot be run from FLASH! + */ +ulong flash_get_size(FPWV * addr, flash_info_t * info) +{ + u16 vend, flid; + + /* amcore board has bus bytes swapped */ + addr[FLASH_CYCLE1] = (FPWV) 0xAA00AA00; + addr[FLASH_CYCLE2] = (FPWV) 0x55005500; + /* selects Manufacture */ + addr[FLASH_CYCLE1] = (FPWV) 0x90009000; + + vend=swap(addr[0]); + + switch (vend) { + case (u8) SST_MANUFACT: + info->flash_id = FLASH_MAN_SST; + flid = swap(addr[1]); + break; + default: + printf("Unknown Flash\n"); + info->flash_id = FLASH_UNKNOWN; + info->sector_count = 0; + info->size = 0; + *addr = (FPW) 0xF000F000; + return (0); + } + + //printf ("flash id = %08X\n", flid); + + switch (flid) { + case (u16) SST_ID_xF3201B: + info->flash_id += FLASH_SST3201B; + break; + default: + info->flash_id = FLASH_UNKNOWN; + break; + } + + info->sector_count = 0; + info->size = 0; + info->sector_count = CONFIG_SYS_SST_SECT; + info->size = CONFIG_SYS_SST_SECT * CONFIG_SYS_SST_SECTSZ; + + /* reset ID mode */ + *addr = (FPWV) 0xF000F000; + + if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { + printf("** ERROR: sector count %d > max (%d) **\n", + info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); + info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; + } + + return (info->size); +} + +int flash_erase(flash_info_t * info, int s_first, int s_last) +{ + FPWV *addr; + int flag, prot, sect, count; + ulong type, start, last; + int rcode = 0, flashtype = 0; + + if ((s_first < 0) || (s_first > s_last)) { + if (info->flash_id == FLASH_UNKNOWN) + printf("- missing\n"); + else + printf("- no sectors to erase\n"); + return 1; + } + + type = (info->flash_id & FLASH_VENDMASK); + + switch (type) { + case FLASH_MAN_SST: + flashtype = 1; + break; + default: + type = (info->flash_id & FLASH_VENDMASK); + printf("Can't erase unknown flash type %08lx - aborted\n", + info->flash_id); + return 1; + } + + prot = 0; + for (sect = s_first; sect <= s_last; ++sect) { + if (info->protect[sect]) { + prot++; + } + } + + if (prot) + printf("- Warning: %d protected sectors will not be erased!\n", + prot); + else + printf("\n"); + + flag = disable_interrupts(); + + start = get_timer(0); + last = start; + + if ((s_last - s_first) == (CONFIG_SYS_SST_SECT - 1)) { + if (prot == 0) { + addr = (FPWV *) info->start[0]; + + addr[FLASH_CYCLE1] = 0xAA00; /* unlock */ + addr[FLASH_CYCLE2] = 0x5500; /* unlock */ + addr[FLASH_CYCLE1] = 0x8000; /* erase mode */ + addr[FLASH_CYCLE1] = 0xAA00; /* unlock */ + addr[FLASH_CYCLE2] = 0x5500; /* unlock */ + *addr = 0x3000; /* erase chip */ + + count = 0; + start = get_timer(0); + + while ((*addr & 0x8000) != 0x8000) { + if (count++ > 0x10000) { + spin_wheel(); + count = 0; + } + if (get_timer(start) > + CONFIG_SYS_FLASH_ERASE_TOUT) { + printf("Timeout\n"); + /* reset to read mode */ + *addr = 0xF000; + return 1; + } + } + /* reset to read mode */ + *addr = 0xF000; + + printf("\b. done\n"); + if (flag) + enable_interrupts(); + + return 0; + } else if (prot == CONFIG_SYS_SST_SECT) { + return 1; + } + } + + /* Start erase on unprotected sectors */ + for (sect = s_first; sect <= s_last; sect++) { + if (info->protect[sect] == 0) { /* not protected */ + addr = (FPWV *) (info->start[sect]); + printf("."); + /* arm simple, non interrupt dependent timer */ + start = get_timer(0); + switch (flashtype) { + case 1: + { + /* first address in bank */ + FPWV *base; + flag = disable_interrupts(); + /* First sector */ + base = (FPWV *) (CONFIG_SYS_FLASH_BASE); + base[FLASH_CYCLE1] = 0xAA00; /* unlock */ + base[FLASH_CYCLE2] = 0x5500; /* unlock */ + base[FLASH_CYCLE1] = 0x8000; /* erase mode */ + base[FLASH_CYCLE1] = 0xAA00; /* unlock */ + base[FLASH_CYCLE2] = 0x5500; /* unlock */ + *addr = 0x5000; /* erase sector */ + + if (flag) + enable_interrupts(); + + while ((*addr & 0x8000) != 0x8000) { + if (get_timer(start) > + CONFIG_SYS_FLASH_ERASE_TOUT) { + printf("Timeout\n"); + /* reset to read mode */ + *addr = 0xF000; + rcode = 1; + break; + } + } + /* reset to read mode */ + *addr = 0xF000; + break; + } + } /* switch (flashtype) */ + } + } + printf(" done\n"); + + if (flag) + enable_interrupts(); + + return rcode; +} + +int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) +{ + ulong wp, count; + u16 data; + int rc, port_width; + + if (info->flash_id == FLASH_UNKNOWN) + return 4; + + /* get lower word aligned address */ + wp = addr; + port_width = sizeof(FPW); + + /* handle unaligned start bytes */ + if (wp & 1) { + data = *((FPWV *) wp); + data = (data << 8) | *src; + + if ((rc = write_word(info, (FPWV *) wp, data)) != 0) + return (rc); + + wp++; + cnt -= 1; + src++; + } + + while (cnt >= 2) { + /* + * writing words here + */ + count = 0; + data = *((FPWV *) src); + if ((rc = write_word(info, (FPWV *) wp, data)) != 0) + return (rc); + wp += 2; + src += 2; + cnt -= 2; + if (count++ > 0x800) { + spin_wheel(); + count = 0; + } + } + /* handle last byte, if exist */ + if (cnt) { + count = 0; + data = *((FPWV *) wp); + data = (data & 0x00ff) | (*src << 8); + if ((rc = write_word(info, (FPWV *) wp, data)) != 0) + return (rc); + cnt--; + } + if (cnt == 0) + return ERR_OK; + + return ERR_OK; +} + +/* + * Write a word to Flash + * Function ready for 16 bit PS flash chips + * + * returns: + * 0 - OK + * 1 - write timeout + * 2 - Flash not erased + */ +int write_word(flash_info_t * info, FPWV * dest, u16 data) +{ + ulong start; + int flag; + int res = 0; /* result, assume success */ + FPWV *base; /* first address in flash bank */ + + /* Check if Flash is (sufficiently) erased */ + if ((*dest & data) != data) { + return (2); + } + + base = (FPWV *) (CONFIG_SYS_FLASH_BASE); + + /* Disable interrupts which might cause a timeout here */ + flag = disable_interrupts(); + + base[FLASH_CYCLE1] = 0xAA00; /* unlock */ + base[FLASH_CYCLE2] = 0x5500; /* unlock */ + base[FLASH_CYCLE1] = 0xA000; /* selects program mode */ + + *dest = data; /* start programming the data */ + + /* re-enable interrupts if necessary */ + if (flag) + enable_interrupts(); + + start = get_timer(0); + + /* data polling for D7 */ + while (res == 0 + && (*dest & 0x8000) != (data & 0x8000)) { + if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { + /* reset bank */ + *dest = 0xF000; + res = 1; + } + } + /* reset bank */ + *dest++ = 0xF000; + + return (res); +} + +void inline spin_wheel(void) +{ + static int p = 0; + static char w[] = "\/-"; + + printf("\010%c", w[p]); + (++p == 3) ? (p = 0) : 0; +} + +#endif diff --git a/board/sysam/amcore/u-boot.lds b/board/sysam/amcore/u-boot.lds new file mode 100644 index 0000000..ccb770d --- /dev/null +++ b/board/sysam/amcore/u-boot.lds @@ -0,0 +1,101 @@ +/* + * Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(m68k) + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + .text : + { + arch/m68k/cpu/mcf530x/start.o (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/env_embedded.o (.text) + + *(.text) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + + .reloc : + { + __got_start = .; + KEEP(*(.got)) + __got_end = .; + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.sdata) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + + . = ALIGN(4); + .u_boot_list : { + #include <u-boot.lst> + } + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + _sbss = .; + *(.sbss*) + *(.bss*) + *(COMMON) + . = ALIGN(4); + _ebss = .; + } + __bss_end__ = . ; + PROVIDE (end = .); +} diff --git a/boards.cfg b/boards.cfg index 0ecd1b8..536d048 100644 --- a/boards.cfg +++ b/boards.cfg @@ -375,6 +375,7 @@ M5271EVB m68k mcf52x2 m5271evb freesca M5272C3 m68k mcf52x2 m5272c3 freescale M5275EVB m68k mcf52x2 m5275evb freescale M5282EVB m68k mcf52x2 m5282evb freescale +amcore m68k mcf530x amcore sysam astro_mcf5373l m68k mcf532x mcf5373l astro M53017EVB m68k mcf532x m53017evb freescale M5329AFEE m68k mcf532x m5329evb freescale - M5329EVB:NANDFLASH_SIZE=0 diff --git a/include/configs/amcore.h b/include/configs/amcore.h new file mode 100644 index 0000000..92127ea --- /dev/null +++ b/include/configs/amcore.h @@ -0,0 +1,213 @@ +/* + * Configuation settings for the Sysam AMCORE board. + * + * Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * board/config.h - configuration options, board specific + */ + +#ifndef _AMCORE_H +#define _AMCORE_H + +/* + * AMCORE flash memory map + * + * As per CONFIG_SYS_SST_SECTSZ, amcore SST39VF3201B flash + * is organized into 1024 x 4K small secotrs (total 4MB). + * + * 0xffc00000 flash start + * 0xffc00000 u-boot code (128-4kB) + * 0xffc1f000 u-boot env (4kB) + * ----------------------------------------- + * 0xffc20000 to + * 0xffffffff reserved for os usage + */ + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_MCF530x /* define processor family */ +#define CONFIG_M5307 /* define processor type */ + +#define CONFIG_MCFTMR + +#define CONFIG_MCFUART +#define CONFIG_SYS_UART_PORT (0) +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600 , 19200 , 38400 , \ + 57600, 115200 } +#define CONFIG_BOOTDELAY 1 /* autoboot after 5 seconds */ +#define CONFIG_BOOTCOMMAND "bootm ffc20000" /* autoboot command */ + +#undef CONFIG_WATCHDOG +#undef CONFIG_MONITOR_IS_IN_RAM + +/* + * BOOTP options + */ +#undef CONFIG_BOOTP_BOOTFILESIZE +#undef CONFIG_BOOTP_BOOTPATH +#undef CONFIG_BOOTP_GATEWAY +#undef CONFIG_BOOTP_HOSTNAME + +/* + * Command line configuration. + */ + +#include <config_cmd_default.h> +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_CACHE + +#define CONFIG_SYS_PROMPT "amcore$ " +//#define CONFIG_SYS_LONGHELP /* undef to save memory */ + +#if defined(CONFIG_CMD_KGDB) +/* Console I/O buff. size */ +#define CONFIG_SYS_CBSIZE 1024 +#else +#define CONFIG_SYS_CBSIZE 256 +#endif +/* Print buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 +/* Boot argument buffer size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* no console @ startup */ +#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ +#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ + +#define CONFIG_SYS_LOAD_ADDR 0x20000 /* default load address */ + +#undef CONFIG_SYS_DRAM_TEST +#define CONFIG_SYS_MEMTEST_START 0x0 +#define CONFIG_SYS_MEMTEST_END 0x100000 + +#define CONFIG_SYS_HZ 1000 + +/* + * Clock configuration: enable only one of the following options + */ + +/* bypass PLL for test purpose */ +#undef CONFIG_SYS_PLL_BYPASS +/* MCF5307 run at 90MHz */ +#define CONFIG_SYS_CLK 90000000 + +/* + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + */ +#define CONFIG_SYS_MBAR 0x10000000 /* Register Base Addrs */ + +/* + * Definitions for initial stack pointer and data area (in DPRAM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* size of used SRAM */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* + * Start addresses for the final memory configuration + * (Set up by the startup code) + * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 + */ +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_SIZE 16 /* in MB */ +#define CONFIG_SYS_FLASH_BASE 0xffc00000 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 1024 +#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 + +/* reserve 128-4KB */ +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE + 0x400) +#define CONFIG_SYS_MONITOR_LEN ((128-4)*1024) +#define CONFIG_SYS_MALLOC_LEN (1*1024*1024) +#define CONFIG_SYS_BOOTPARAMS_LEN 64*1024 + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SIZE 0x1000 /* Size of env. data */ +#define CONFIG_ENV_SECT_SIZE 0x1000 /* see README */ + +#define FLASH_SST3201B 0x300 + +#define CONFIG_SYS_SST_SECT 1024 +#define CONFIG_SYS_SST_SECTSZ 0x1000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization ?? + */ +#define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + \ + (CONFIG_SYS_SDRAM_SIZE << 20)) + +/* + * Cache Configuration + */ +#define CONFIG_SYS_CACHELINE_SIZE 16 + +#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - 8) +#define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - 4) +#define CONFIG_SYS_ICACHE_INV (CF_CACR_CINVA) +#define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_FLASH_BASE | \ + CF_ADDRMASK(2) | \ + CF_ACR_EN | CF_ACR_SM_ALL) + +/* no ACR1 initialization for SDRAM before SDRAM init */ +#define CONFIG_SYS_CACHE_ICACR (CF_CACR_EC | CF_CACR_CINVA | \ + CF_CACR_DCM_P) + +/* + * Memory bank definitions + */ + +/* CS0 - AMD Flash, address 0xffc00000 */ +#define CONFIG_SYS_CS0_BASE (CONFIG_SYS_FLASH_BASE) +/* WS=10, AA=1, PS=16bit (10) */ +#define CONFIG_SYS_CS0_CTRL 0x00001980 +/* 4MB, AA=0,V=1 C/I BIT !!!!! */ +#define CONFIG_SYS_CS0_MASK 0x003f0001 + +/* CS1 - DM9000 Ethernet Controller, address 0x30000000 */ +#define CONFIG_SYS_CS1_BASE 0x30000000 +#define CONFIG_SYS_CS1_CTRL 0x00000100 +#define CONFIG_SYS_CS1_MASK 0x00070001 + +#endif //_AMCORE_H diff --git a/include/flash.h b/include/flash.h index 7db599e..a04ce90 100644 --- a/include/flash.h +++ b/include/flash.h @@ -282,6 +282,7 @@ extern flash_info_t *flash_get_info(ulong base); #define SST_ID_xF1601 0x234B234B /* 39xF1601 ID (16M = 1M x 16 ) */ #define SST_ID_xF1602 0x234A234A /* 39xF1602 ID (16M = 1M x 16 ) */ #define SST_ID_xF3201 0x235B235B /* 39xF3201 ID (32M = 2M x 16 ) */ +#define SST_ID_xF3201B 0x235D235D /* 39xF3201B ID (32M = 2M x 16 ) */ #define SST_ID_xF3202 0x235A235A /* 39xF3202 ID (32M = 2M x 16 ) */ #define SST_ID_xF6401 0x236B236B /* 39xF6401 ID (64M = 4M x 16 ) */ #define SST_ID_xF6402 0x236A236A /* 39xF6402 ID (64M = 4M x 16 ) */
Dear angelo,
Changes for v2:
- None
Changes for v3:
Entry to MAINTAINERS missing.
Only one blank line in places like that, please. Please fix globally.
* wired as below:
- mbar_writeShort(MCFSIM_PAR, 0x300);
- mbar_writeShort(MCFSIM_PADDR, 0xfcff);
- mbar_writeShort(MCFSIM_PADAT, 0x0c00);
Did you bother to compile your code? This is a function returning "int", but I don't see any return statement. I would expect to see compiler warnings here?
Please make sure to use get_mem_size() !
We have plenty of memory tests already. Chose one, but don't implement yet another one.
This should never be needed. Please move this to board congih file instead.
This looks like a standard CFI flash. Why cannot you use the standard CFI driver, then?
if (remainder) {
remainder >>= 10;
Also please note that we do not use any kind of FP operations in U-Boot. Please get rid of thise - fix globally, please.
We don't use such stuff, either.
Why exactly do you need a board specific linker script?
Please no parens around simple valies - p[lease fix globally.
Comment and code disagree.
PLease do not undefine what is not defiend anyway.
Please do not define values for any macros which are just tested for existence. Please fix globally.
Now macros like this do need parens!!
- For booting Linux, the board info and command line data
- have to be in the first 8 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization ??
Is this really the case?
Note - whenever you have to add anything to include/flash.h you should ask yourself what you are doing wrong.
Hi Wolfgang,
sorry but i have still a note here.
About
#define VALUE (0)
you said to fix it globally, without parens.
Working for the fixes i found several "accepted" files (i.e. m5282.h) full of
#define XYZ1 (1) #define XYZ2 (2)
etc etc.
CodingStyle says parens around expressions must be used, but don't seems to set any rule for this case.
I know this is a detail, but i need to know the reason for the fix.
Best Regards Angelo Dureghello
On Sun, Nov 04, 2012 at 11:02:36PM +0100, Wolfgang Denk wrote:
Dear angelo,
Changes for v2:
- None
Changes for v3:
* wired as below:
if (remainder) {
remainder >>= 10;
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Roses are red Violets are blue Some poems rhyme
Dear Angelo,
In message 20121105211017.GA24778@angel3 you wrote:
#define VALUE (0)
True.
You will find many examples of poor code. If you have time and resources, patches to clean up such are welcome.
In any case, we should not use such bad examples as excuse to add more bad code.
A simple value is not an expression that needs parens.
angelo
Angelo Dureghello
