[U-Boot] [PATCH 2/2] powerpc: mpc85xx: Add dummy gpio.h to enable CONFIG_OF_CONTROL
If CONFIG_OF_CONTROL is enabled, lib/fdtdec.c is compiled. It includes <asm/gpio.h> and then <asm/gpio.h> includes <asm/arch/gpio.h>. As a result, all the SoCs that enable CONFIG_OF_CONTROL must have <asm/arch/gpio.h>.
The right fix would be to split the lib/fdtdec.c to remove dependency on GPIO.
This commit adds a dummy <asm/arch/gpio.h> to support OF_CONTROL for mpc85xx platform. A file mpc85xx_gpio.h exists in arch/powerpc/include/asm. The defintions in that file conflict with the ones in asm-generic/gpio.h. Hence a dummy header file has been added. This will be removed after FDT-GPIO stuff is fixed correctly.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com --- arch/powerpc/include/asm/arch-mpc85xx/gpio.h | 15 +++++++++++++++ 1 file changed, 15 insertions(+) create mode 100644 arch/powerpc/include/asm/arch-mpc85xx/gpio.h
diff --git a/arch/powerpc/include/asm/arch-mpc85xx/gpio.h b/arch/powerpc/include/asm/arch-mpc85xx/gpio.h new file mode 100644 index 0000000..8beed30 --- /dev/null +++ b/arch/powerpc/include/asm/arch-mpc85xx/gpio.h @@ -0,0 +1,15 @@ +/* + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * Dummy header file to enable CONFIG_OF_CONTROL. + * If CONFIG_OF_CONTROL is enabled, lib/fdtdec.c is compiled. + * It includes <asm/arch/gpio.h> via <asm/gpio.h>, so those SoCs that enable + * OF_CONTROL must have arch/gpio.h. + */ + +#ifndef __ASM_ARCH_MX85XX_GPIO_H +#define __ASM_ARCH_MX85XX_GPIO_H + +#endif
Applied to u-boot-mpc85xx master branch, awaiting upstream.
York
Ruchika Gupta
York Sun
