[U-Boot] [PATCH] ARM: configs: Enable DM_ETH for SBx81LIFKW and SBx81LIFXCAT
The mvgbe driver supports DM_ETH so switch these boards to using it.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
configs/SBx81LIFKW_defconfig | 3 +++ configs/SBx81LIFXCAT_defconfig | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index 8cb397c7570b..f9ca3428a2a0 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -10,6 +10,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_SF=y @@ -40,6 +41,8 @@ CONFIG_MV88E61XX_SWITCH=y CONFIG_MV88E61XX_CPU_PORT=10 CONFIG_MV88E61XX_PHY_PORTS=0x003 CONFIG_MV88E61XX_FIXED_PORTS=0x300 +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DM_RTC=y CONFIG_RTC_MV=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 1f7ff812f478..a8dc9f174986 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -10,6 +10,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y @@ -44,6 +45,8 @@ CONFIG_MV88E61XX_SWITCH=y CONFIG_MV88E61XX_CPU_PORT=10 CONFIG_MV88E61XX_PHY_PORTS=0x003 CONFIG_MV88E61XX_FIXED_PORTS=0x300 +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_SPI=y CONFIG_DM_SPI=y
Thanks, Stefan
Viele Grüße, Stefan
Applied to:
u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Stefan Roese
