[U-Boot] [PATCH] ARM: UniPhier: adjust device trees for business transfer
Panasonic's System LSI products, UniPhier SoC family, have been transferred to Socionext Inc.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ph1-ld4-ref.dts | 7 ++++--- arch/arm/dts/uniphier-ph1-ld4.dtsi | 27 ++++++++++++++------------- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 7 ++++--- arch/arm/dts/uniphier-ph1-pro4.dtsi | 33 +++++++++++++++++---------------- arch/arm/dts/uniphier-ph1-sld3-ref.dts | 7 ++++--- arch/arm/dts/uniphier-ph1-sld3.dtsi | 27 ++++++++++++++------------- arch/arm/dts/uniphier-ph1-sld8-ref.dts | 7 ++++--- arch/arm/dts/uniphier-ph1-sld8.dtsi | 27 ++++++++++++++------------- arch/arm/dts/uniphier-ref-daughter.dtsi | 3 ++- drivers/i2c/i2c-uniphier-f.c | 7 ++++--- drivers/i2c/i2c-uniphier.c | 7 ++++--- drivers/serial/serial_uniphier.c | 7 ++++--- drivers/usb/host/ehci-uniphier.c | 5 +++-- lib/fdtdec.c | 2 +- 14 files changed, 93 insertions(+), 80 deletions(-)
diff --git a/arch/arm/dts/uniphier-ph1-ld4-ref.dts b/arch/arm/dts/uniphier-ph1-ld4-ref.dts index d479be1..d972c02 100644 --- a/arch/arm/dts/uniphier-ph1-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld4-ref.dts @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-LD4 Reference Board * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -12,8 +13,8 @@ /include/ "uniphier-ref-daughter.dtsi"
/ { - model = "Panasonic UniPhier PH1-LD4 Reference Board"; - compatible = "panasonic,ph1-ld4-ref", "panasonic,ph1-ld4"; + model = "UniPhier PH1-LD4 Reference Board"; + compatible = "socionext,ph1-ld4-ref", "socionext,ph1-ld4";
memory { device_type = "memory"; diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 8ed7bbf..c200838 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-LD4 SoC * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,7 +11,7 @@ /include/ "skeleton.dtsi"
/ { - compatible = "panasonic,ph1-ld4"; + compatible = "socionext,ph1-ld4";
cpus { #address-cells = <1>; @@ -30,35 +31,35 @@ ranges;
uart0: serial@54006800 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x20>; clock-frequency = <36864000>; };
uart1: serial@54006900 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x20>; clock-frequency = <36864000>; };
uart2: serial@54006a00 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x20>; clock-frequency = <36864000>; };
uart3: serial@54006b00 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x20>; clock-frequency = <36864000>; };
i2c0: i2c@58400000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58400000 0x40>; @@ -67,7 +68,7 @@ };
i2c1: i2c@58480000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58480000 0x40>; @@ -76,7 +77,7 @@ };
i2c2: i2c@58500000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58500000 0x40>; @@ -85,7 +86,7 @@ };
i2c3: i2c@58580000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58580000 0x40>; @@ -94,19 +95,19 @@ };
usb0: usb@5a800100 { - compatible = "panasonic,uniphier-ehci", "generic-ehci"; + compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; };
usb1: usb@5a810100 { - compatible = "panasonic,uniphier-ehci", "generic-ehci"; + compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; };
usb2: usb@5a820100 { - compatible = "panasonic,uniphier-ehci", "generic-ehci"; + compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4-ref.dts b/arch/arm/dts/uniphier-ph1-pro4-ref.dts index 5bec92b..f6d03e3 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-ref.dts @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-Pro4 Reference Board * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -12,8 +13,8 @@ /include/ "uniphier-ref-daughter.dtsi"
/ { - model = "Panasonic UniPhier PH1-Pro4 Reference Board"; - compatible = "panasonic,ph1-pro4-ref", "panasonic,ph1-pro4"; + model = "UniPhier PH1-Pro4 Reference Board"; + compatible = "socionext,ph1-pro4-ref", "socionext,ph1-pro4";
memory { device_type = "memory"; diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index 1247779..8195266 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-Pro4 SoC * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,7 +11,7 @@ /include/ "skeleton.dtsi"
/ { - compatible = "panasonic,ph1-pro4"; + compatible = "socionext,ph1-pro4";
cpus { #address-cells = <1>; @@ -36,35 +37,35 @@ ranges;
uart0: serial@54006800 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x20>; clock-frequency = <73728000>; };
uart1: serial@54006900 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x20>; clock-frequency = <73728000>; };
uart2: serial@54006a00 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x20>; clock-frequency = <73728000>; };
uart3: serial@54006b00 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x20>; clock-frequency = <73728000>; };
i2c0: i2c@58780000 { - compatible = "panasonic,uniphier-fi2c"; + compatible = "socionext,uniphier-fi2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58780000 0x80>; @@ -73,7 +74,7 @@ };
i2c1: i2c@58781000 { - compatible = "panasonic,uniphier-fi2c"; + compatible = "socionext,uniphier-fi2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58781000 0x80>; @@ -82,7 +83,7 @@ };
i2c2: i2c@58782000 { - compatible = "panasonic,uniphier-fi2c"; + compatible = "socionext,uniphier-fi2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58782000 0x80>; @@ -91,7 +92,7 @@ };
i2c3: i2c@58783000 { - compatible = "panasonic,uniphier-fi2c"; + compatible = "socionext,uniphier-fi2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58783000 0x80>; @@ -102,7 +103,7 @@ /* i2c4 does not exist */
i2c5: i2c@58785000 { - compatible = "panasonic,uniphier-fi2c"; + compatible = "socionext,uniphier-fi2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58785000 0x80>; @@ -111,7 +112,7 @@ };
i2c6: i2c@58786000 { - compatible = "panasonic,uniphier-fi2c"; + compatible = "socionext,uniphier-fi2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58786000 0x80>; @@ -120,25 +121,25 @@ };
usb2: usb@5a800100 { - compatible = "panasonic,uniphier-ehci", "generic-ehci"; + compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; };
usb3: usb@5a810100 { - compatible = "panasonic,uniphier-ehci", "generic-ehci"; + compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; };
usb0: usb@65a00000 { - compatible = "panasonic,uniphier-xhci", "generic-xhci"; + compatible = "socionext,uniphier-xhci", "generic-xhci"; status = "disabled"; reg = <0x65a00000 0x100>; };
usb1: usb@65c00000 { - compatible = "panasonic,uniphier-xhci", "generic-xhci"; + compatible = "socionext,uniphier-xhci", "generic-xhci"; status = "disabled"; reg = <0x65c00000 0x100>; }; diff --git a/arch/arm/dts/uniphier-ph1-sld3-ref.dts b/arch/arm/dts/uniphier-ph1-sld3-ref.dts index 8a7f90a..d9616f6 100644 --- a/arch/arm/dts/uniphier-ph1-sld3-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld3-ref.dts @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-sLD3 Reference Board * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -12,8 +13,8 @@ /include/ "uniphier-ref-daughter.dtsi"
/ { - model = "Panasonic UniPhier PH1-sLD3 Reference Board"; - compatible = "panasonic,ph1-sld3-ref", "panasonic,ph1-sld3"; + model = "UniPhier PH1-sLD3 Reference Board"; + compatible = "socionext,ph1-sld3-ref", "socionext,ph1-sld3";
memory { device_type = "memory"; diff --git a/arch/arm/dts/uniphier-ph1-sld3.dtsi b/arch/arm/dts/uniphier-ph1-sld3.dtsi index 88322c6..44b1989 100644 --- a/arch/arm/dts/uniphier-ph1-sld3.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld3.dtsi @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-sLD3 SoC * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,7 +11,7 @@ /include/ "skeleton.dtsi"
/ { - compatible = "panasonic,ph1-sld3"; + compatible = "socionext,ph1-sld3";
cpus { #address-cells = <1>; @@ -36,28 +37,28 @@ ranges;
i2c0: i2c@58400000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58400000 0x40>; @@ -66,7 +67,7 @@ };
i2c1: i2c@58480000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58480000 0x40>; @@ -75,7 +76,7 @@ };
i2c2: i2c@58500000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58500000 0x40>; @@ -84,7 +85,7 @@ };
i2c3: i2c@58580000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x58580000 0x40>; @@ -93,25 +94,25 @@ };
usb3: usb@5a830100 { - compatible = "panasonic,uniphier-ehci", "generic-ehci"; + compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a830100 0x100>; }; diff --git a/arch/arm/dts/uniphier-ph1-sld8-ref.dts b/arch/arm/dts/uniphier-ph1-sld8-ref.dts index 0cb9c47..69e9bfa 100644 --- a/arch/arm/dts/uniphier-ph1-sld8-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld8-ref.dts @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-sLD8 Reference Board * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -12,8 +13,8 @@ /include/ "uniphier-ref-daughter.dtsi"
/ { - model = "Panasonic UniPhier PH1-sLD8 Reference Board"; - compatible = "panasonic,ph1-sld8-ref", "panasonic,ph1-sld8"; + model = "UniPhier PH1-sLD8 Reference Board"; + compatible = "socionext,ph1-sld8-ref", "socionext,ph1-sld8";
memory { device_type = "memory"; diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index 1b3eb22..d9f61c2 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier PH1-sLD8 SoC * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,7 +11,7 @@ /include/ "skeleton.dtsi"
/ { - compatible = "panasonic,ph1-sld8"; + compatible = "socionext,ph1-sld8";
uart0: serial@54006800 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006800 0x20>; clock-frequency = <80000000>; };
uart1: serial@54006900 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006900 0x20>; clock-frequency = <80000000>; };
uart2: serial@54006a00 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006a00 0x20>; clock-frequency = <80000000>; };
uart3: serial@54006b00 { - compatible = "panasonic,uniphier-uart"; + compatible = "socionext,uniphier-uart"; status = "disabled"; reg = <0x54006b00 0x20>; clock-frequency = <80000000>; };
usb2: usb@5a820100 { - compatible = "panasonic,uniphier-ehci", "generic-ehci"; + compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; }; diff --git a/arch/arm/dts/uniphier-ref-daughter.dtsi b/arch/arm/dts/uniphier-ref-daughter.dtsi index 0145b51..aca9f58 100644 --- a/arch/arm/dts/uniphier-ref-daughter.dtsi +++ b/arch/arm/dts/uniphier-ref-daughter.dtsi @@ -2,7 +2,8 @@ * Device Tree Source for UniPhier Reference Daughter Board * * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ diff --git a/drivers/i2c/i2c-uniphier-f.c b/drivers/i2c/i2c-uniphier-f.c index 6707edd..fd28c17 100644 --- a/drivers/i2c/i2c-uniphier-f.c +++ b/drivers/i2c/i2c-uniphier-f.c @@ -1,6 +1,7 @@ /* * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -352,8 +353,8 @@ static const struct dm_i2c_ops uniphier_fi2c_ops = { };
static const struct udevice_id uniphier_fi2c_of_match[] = { - { .compatible = "panasonic,uniphier-fi2c" }, - {}, + { .compatible = "socionext,uniphier-fi2c" }, + { /* sentinel */ } };
U_BOOT_DRIVER(uniphier_fi2c) = { diff --git a/drivers/i2c/i2c-uniphier.c b/drivers/i2c/i2c-uniphier.c index 64a9ed8..666272d 100644 --- a/drivers/i2c/i2c-uniphier.c +++ b/drivers/i2c/i2c-uniphier.c @@ -1,6 +1,7 @@ /* * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -212,8 +213,8 @@ static const struct dm_i2c_ops uniphier_i2c_ops = { };
static const struct udevice_id uniphier_i2c_of_match[] = { - { .compatible = "panasonic,uniphier-i2c" }, - {}, + { .compatible = "socionext,uniphier-i2c" }, + { /* sentinel */ } };
U_BOOT_DRIVER(uniphier_i2c) = { diff --git a/drivers/serial/serial_uniphier.c b/drivers/serial/serial_uniphier.c index a6bd27f..98e3b81 100644 --- a/drivers/serial/serial_uniphier.c +++ b/drivers/serial/serial_uniphier.c @@ -1,6 +1,7 @@ /* * Copyright (C) 2012-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -115,8 +116,8 @@ static int uniphier_serial_remove(struct udevice *dev)
#ifdef CONFIG_OF_CONTROL static const struct udevice_id uniphier_uart_of_match[] = { - { .compatible = "panasonic,uniphier-uart" }, - {}, + { .compatible = "socionext,uniphier-uart" }, + { /* sentinel */ } };
static int uniphier_serial_ofdata_to_platdata(struct udevice *dev) diff --git a/drivers/usb/host/ehci-uniphier.c b/drivers/usb/host/ehci-uniphier.c index b5ec296..846bf50 100644 --- a/drivers/usb/host/ehci-uniphier.c +++ b/drivers/usb/host/ehci-uniphier.c @@ -1,6 +1,7 @@ /* * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2015 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -16,7 +17,7 @@ DECLARE_GLOBAL_DATA_PTR;
#define FDT gd->fdt_blob -#define COMPAT "panasonic,uniphier-ehci" +#define COMPAT "socionext,uniphier-ehci"
static int get_uniphier_ehci_base(int index, struct ehci_hccr **base) { diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 21933e4..d21040e 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -76,7 +76,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(AMS_AS3722, "ams,as3722"), COMPAT(INTEL_ICH_SPI, "intel,ich-spi"), COMPAT(INTEL_QRK_MRC, "intel,quark-mrc"), - COMPAT(PANASONIC_XHCI, "panasonic,uniphier-xhci"), + COMPAT(PANASONIC_XHCI, "socionext,uniphier-xhci"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
2015-03-11 15:54 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
