[U-Boot] [PATCH v6 1/5] dma: lpc32xx: add DMA driver
Incorporate DMA driver from legacy LPCLinux NXP BSP. The files taken from the legacy patch are: - lpc32xx DMA driver - lpc3250 header file DMA registers definition.
The legacy driver was updated and clean-up as part of the integration with the latest u-boot.
Signed-off-by: Sylvain Lemieux slemieux@tycoint.com --- Changes from v5 to v6: * Addressed Marek's comments on LPC32xx DMA driver: - return "-ETIMEDOUT" on timeout. * Addressed Vladimir's comments on LPC32xx DMA driver: - follow alphabetic order when adding "lpc32xx_dma_init()". - use "writel()" when enabling DMA clock. - move DMAC registers definitions from NAND SLC to "dma.h". - remove support to release DMA channel. - update the API to use an unsigned type for the channel. - return an error instead of generating a fatal BUG when doing a transfer on an unallocated channel. - add an explanatory error when returning with a failure.
Changes from v4 to v5: * Addressed Marek's comments on LPC32xx DMA driver: - Move macro use by the DMA client to write the next DMA linked list item address to NAND SLC driver. - updated "lpc32xx_dma_wait_status()" implementation to make if stetement easier to read. - updated multiline comments style.
Changes from v3 to v4: * Addressed Marek's comments on LPC32xx DMA driver: - updated multiline comments style. - use "u32" instead of "uint32_t". - fixed unbounded loop.
Changes from v2 to v3: * Addressed Marek's comments on LPC32xx DMA driver: - use defined in header file instead of local definition. - remove for loop and use "ffz()". * Provide define to assign next DMA linked list item address to removed typecast in DMA client (ex. NAND SLC).
Changes from v1 to v2: * Moved the DMA patch as the first patch of the series. * The NAND SLC patch (link below) is applied before this patch: https://patchwork.ozlabs.org/patch/497308/
Update to the legacy driver to integrate with the latest u-boot: 1) Fixed checkpatch script output in legacy code. 2) Use LPC32xx definition from "cpu.h" and "clk.h". 3) Incorporate DMA specific register definition from "lpc3250.h" header file from legacy BSP patch from LPCLinux. 4) Use u-boot API for register access to remove the volatile in register definition taken from "lpc3250.h" header file. 5) Add DMA interface to "dma.h". 6) Add dma clock control register bits (clk.h). 7) Add functions to initialize the DMA clock.
The legacy BSP patch (u-boot-2009.03_lpc32x0-v1.07.patch.tar.bz2) was downloaded from the LPCLinux Web site.
arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 7 ++ arch/arm/include/asm/arch-lpc32xx/clk.h | 3 + arch/arm/include/asm/arch-lpc32xx/dma.h | 67 ++++++++++++ arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 1 + drivers/dma/Makefile | 1 + drivers/dma/lpc32xx_dma.c | 147 ++++++++++++++++++++++++++ 6 files changed, 226 insertions(+) create mode 100644 arch/arm/include/asm/arch-lpc32xx/dma.h create mode 100644 drivers/dma/lpc32xx_dma.c
diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c index c0c9c6c..f0af851 100644 --- a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c +++ b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c @@ -41,6 +41,13 @@ void lpc32xx_uart_init(unsigned int uart_id) &clk->u3clk + (uart_id - 3)); }
+void lpc32xx_dma_init(void) +{ + /* Enable DMA interface */ + writel(DMA_CLK_ENABLE, &clk->dmaclk_ctrl); + +} + void lpc32xx_mac_init(void) { /* Enable MAC interface */ diff --git a/arch/arm/include/asm/arch-lpc32xx/clk.h b/arch/arm/include/asm/arch-lpc32xx/clk.h index 010211a..663f6bc 100644 --- a/arch/arm/include/asm/arch-lpc32xx/clk.h +++ b/arch/arm/include/asm/arch-lpc32xx/clk.h @@ -158,6 +158,9 @@ struct clk_pm_regs { #define CLK_NAND_SLC_SELECT (1 << 2) #define CLK_NAND_MLC_INT (1 << 5)
+/* DMA Clock Control Register bits */ +#define DMA_CLK_ENABLE (1 << 0) + /* SSP Clock Control Register bits */ #define CLK_SSP0_ENABLE_CLOCK (1 << 0)
diff --git a/arch/arm/include/asm/arch-lpc32xx/dma.h b/arch/arm/include/asm/arch-lpc32xx/dma.h new file mode 100644 index 0000000..b4569af --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/dma.h @@ -0,0 +1,67 @@ +/* + * LPC32xx DMA Controller Interface + * + * Copyright (C) 2008 by NXP Semiconductors + * @Author: Kevin Wells + * @Descr: Definitions for LPC3250 chip + * @References: NXP LPC3250 User's Guide + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _LPC32XX_DMA_H +#define _LPC32XX_DMA_H + +#include <common.h> + +/* + * DMA linked list structure used with a channel's LLI register; + * refer to UM10326, "LPC32x0 and LPC32x0/01 User manual" - Rev. 3 + * tables 84, 85, 86 & 87 for details. + */ +struct lpc32xx_dmac_ll { + u32 dma_src; + u32 dma_dest; + u32 next_lli; + u32 next_ctrl; +}; + +/* control register definitions */ +#define DMAC_CHAN_INT_TC_EN (1 << 31) /* channel terminal count interrupt */ +#define DMAC_CHAN_DEST_AUTOINC (1 << 27) /* automatic destination increment */ +#define DMAC_CHAN_SRC_AUTOINC (1 << 26) /* automatic source increment */ +#define DMAC_CHAN_DEST_AHB1 (1 << 25) /* AHB1 master for dest. transfer */ +#define DMAC_CHAN_DEST_WIDTH_32 (1 << 22) /* Destination data width selection */ +#define DMAC_CHAN_SRC_WIDTH_32 (1 << 19) /* Source data width selection */ +#define DMAC_CHAN_DEST_BURST_1 0 +#define DMAC_CHAN_DEST_BURST_4 (1 << 15) /* Destination data burst size */ +#define DMAC_CHAN_SRC_BURST_1 0 +#define DMAC_CHAN_SRC_BURST_4 (1 << 12) /* Source data burst size */ + +/* + * config_ch register definitions + * DMAC_CHAN_FLOW_D_xxx: flow control with DMA as the controller + * DMAC_DEST_PERIP: Macro for loading destination peripheral + * DMAC_SRC_PERIP: Macro for loading source peripheral + */ +#define DMAC_CHAN_FLOW_D_M2P (0x1 << 11) +#define DMAC_CHAN_FLOW_D_P2M (0x2 << 11) +#define DMAC_DEST_PERIP(n) (((n) & 0x1F) << 6) +#define DMAC_SRC_PERIP(n) (((n) & 0x1F) << 1) + +/* + * config_ch register definitions + * (source and destination peripheral ID numbers). + * These can be used with the DMAC_DEST_PERIP and DMAC_SRC_PERIP macros. + */ +#define DMA_PERID_NAND1 1 + +/* Channel enable bit */ +#define DMAC_CHAN_ENABLE (1 << 0) + +int lpc32xx_dma_get_channel(void); +int lpc32xx_dma_start_xfer(unsigned int channel, + const struct lpc32xx_dmac_ll *desc, u32 config); +int lpc32xx_dma_wait_status(unsigned int channel); + +#endif /* _LPC32XX_DMA_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/sys_proto.h b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h index 0845f83..d6e5e68 100644 --- a/arch/arm/include/asm/arch-lpc32xx/sys_proto.h +++ b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h @@ -10,6 +10,7 @@ #include <asm/arch/emc.h>
void lpc32xx_uart_init(unsigned int uart_id); +void lpc32xx_dma_init(void); void lpc32xx_mac_init(void); void lpc32xx_mlc_nand_init(void); void lpc32xx_slc_nand_init(void); diff --git a/drivers/dma/Makefile b/drivers/dma/Makefile index 4c8fcc2..f95fe70 100644 --- a/drivers/dma/Makefile +++ b/drivers/dma/Makefile @@ -10,3 +10,4 @@ obj-$(CONFIG_APBH_DMA) += apbh_dma.o obj-$(CONFIG_FSL_DMA) += fsl_dma.o obj-$(CONFIG_TI_KSNAV) += keystone_nav.o keystone_nav_cfg.o obj-$(CONFIG_TI_EDMA3) += ti-edma3.o +obj-$(CONFIG_DMA_LPC32XX) += lpc32xx_dma.o diff --git a/drivers/dma/lpc32xx_dma.c b/drivers/dma/lpc32xx_dma.c new file mode 100644 index 0000000..955adfe --- /dev/null +++ b/drivers/dma/lpc32xx_dma.c @@ -0,0 +1,147 @@ +/* + * Copyright (C) 2008 by NXP Semiconductors + * @Author: Kevin Wells + * @Descr: LPC3250 DMA controller interface support functions + * + * Copyright (c) 2015 Tyco Fire Protection Products. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <asm/arch/dma.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> + +/* DMA controller channel register structure */ +struct dmac_chan_reg { + u32 src_addr; + u32 dest_addr; + u32 lli; + u32 control; + u32 config_ch; + u32 reserved[3]; +}; + +/* DMA controller register structures */ +struct dma_reg { + u32 int_stat; + u32 int_tc_stat; + u32 int_tc_clear; + u32 int_err_stat; + u32 int_err_clear; + u32 raw_tc_stat; + u32 raw_err_stat; + u32 chan_enable; + u32 sw_burst_req; + u32 sw_single_req; + u32 sw_last_burst_req; + u32 sw_last_single_req; + u32 config; + u32 sync; + u32 reserved[50]; + struct dmac_chan_reg dma_chan[8]; +}; + +#define DMA_NO_OF_CHANNELS 8 + +/* config register definitions */ +#define DMAC_CTRL_ENABLE (1 << 0) /* For enabling the DMA controller */ + +static u32 alloc_ch; + +static struct dma_reg *dma = (struct dma_reg *)DMA_BASE; + +int lpc32xx_dma_get_channel(void) +{ + int i; + + if (!alloc_ch) { /* First time caller */ + /* + * DMA clock are enable by "lpc32xx_dma_init()" and should + * be call by board "board_early_init_f()" function. + */ + + /* + * Make sure DMA controller and all channels are disabled. + * Controller is in little-endian mode. Disable sync signals. + */ + writel(0, &dma->config); + writel(0, &dma->sync); + + /* Clear interrupt and error statuses */ + writel(0xFF, &dma->int_tc_clear); + writel(0xFF, &dma->raw_tc_stat); + writel(0xFF, &dma->int_err_clear); + writel(0xFF, &dma->raw_err_stat); + + /* Enable DMA controller */ + writel(DMAC_CTRL_ENABLE, &dma->config); + } + + i = ffz(alloc_ch); + + /* Check if all the available channels are busy */ + if (unlikely(i == DMA_NO_OF_CHANNELS)) + return -1; + alloc_ch |= BIT_MASK(i); + return i; +} + +int lpc32xx_dma_start_xfer(unsigned int channel, + const struct lpc32xx_dmac_ll *desc, u32 config) +{ + if (unlikely(((BIT_MASK(channel) & alloc_ch) == 0) || + (channel >= DMA_NO_OF_CHANNELS))) { + error("Request for xfer on unallocated channel %d", channel); + return -1; + } + writel(BIT_MASK(channel), &dma->int_tc_clear); + writel(BIT_MASK(channel), &dma->int_err_clear); + writel(desc->dma_src, &dma->dma_chan[channel].src_addr); + writel(desc->dma_dest, &dma->dma_chan[channel].dest_addr); + writel(desc->next_lli, &dma->dma_chan[channel].lli); + writel(desc->next_ctrl, &dma->dma_chan[channel].control); + writel(config, &dma->dma_chan[channel].config_ch); + + return 0; +} + +int lpc32xx_dma_wait_status(unsigned int channel) +{ + unsigned long start; + u32 reg; + + /* Check if given channel is valid */ + if (unlikely(channel >= DMA_NO_OF_CHANNELS)) { + error("Request for status on unallocated channel %d", channel); + return -1; + } + + start = get_timer(0); + while (1) { + reg = readl(&dma->raw_tc_stat); + reg |= readl(dma->raw_err_stat); + if (reg & BIT_MASK(channel)) + break; + + if (get_timer(start) > CONFIG_SYS_HZ) { + error("DMA status timeout channel %d\n", channel); + return -ETIMEDOUT; + } + udelay(1); + } + + if (unlikely(readl(&dma->raw_err_stat) & BIT_MASK(channel))) { + setbits_le32(&dma->int_err_clear, BIT_MASK(channel)); + setbits_le32(&dma->raw_err_stat, BIT_MASK(channel)); + error("DMA error on channel %d\n", channel); + return -1; + } + setbits_le32(&dma->int_tc_clear, BIT_MASK(channel)); + setbits_le32(&dma->raw_tc_stat, BIT_MASK(channel)); + return 0; +}
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Hi Sylvain,
- Addressed Marek's comments on LPC32xx DMA driver:
- Addressed Vladimir's comments on LPC32xx DMA driver:
- Provide define to assign next DMA linked list item address to removed typecast in DMA client (ex. NAND SLC).
- Moved the DMA patch as the first patch of the series.
- The NAND SLC patch (link below) is applied before this patch: https://patchwork.ozlabs.org/patch/497308/
- Fixed checkpatch script output in legacy code.
- Use LPC32xx definition from "cpu.h" and "clk.h".
- Incorporate DMA specific register definition from "lpc3250.h" header file from legacy BSP patch from LPCLinux.
- Use u-boot API for register access to remove the volatile in register definition taken from "lpc3250.h" header file.
- Add DMA interface to "dma.h".
- Add dma clock control register bits (clk.h).
- Add functions to initialize the DMA clock.
- /* Enable DMA interface */
- writel(DMA_CLK_ENABLE, &clk->dmaclk_ctrl);
for sake of consistency with all the rest clock name bits, please rename DMA_CLK_ENABLE to CLK_DMA_ENABLE
Not sure about the ordering policy here, probably appending is good enough.
Tested on non-SPL build with hardware NAND SLC ECC, feel free to add
Tested-by: Vladimir Zapolskiy vz@mleia.com
-- With best wishes, Vladimir
Signed-off-by: Sylvain Lemieux slemieux@tycoint.com Acked-by: Marek Vasut marex@denx.de Tested-by: Vladimir Zapolskiy vz@mleia.com
Vladimir Zapolskiy
