[PATCH] net: wget: let wget_with_dns work with dns disabled
This was marked as TODO in the code: -Enable use of wget_with_dns even if CMD_DNS is disabled if the given uri has the ip address for the http server. -Check for port in the uri when transforming to legacy wget syntax inside wget_with_dns. -Move the check for CMD_DNS inside wget_with_dns.
Signed-off-by: Adriano Cordova adrianox@gmail.com --- net/wget.c | 38 ++++++++++++++++++++++++-------------- 1 file changed, 24 insertions(+), 14 deletions(-)
diff --git a/net/wget.c b/net/wget.c index 2d931c2bc6..5bb61a2b8d 100644 --- a/net/wget.c +++ b/net/wget.c @@ -528,12 +528,10 @@ void wget_start(void) wget_send(TCP_SYN, 0, 0, 0); }
-#if (IS_ENABLED(CONFIG_CMD_DNS)) int wget_with_dns(ulong dst_addr, char *uri) { int ret; - char *s, *host_name, *file_name, *str_copy; - + char *s, *host_name, *file_name, *str_copy, *port; /* * Download file using wget. * @@ -554,18 +552,31 @@ int wget_with_dns(ulong dst_addr, char *uri) } file_name = s;
- /* TODO: If the given uri has ip address for the http server, skip dns */ - net_dns_resolve = host_name; - net_dns_env_var = "httpserverip"; - if (net_loop(DNS) < 0) { - log_err("Error: dns lookup of %s failed, check setup\n", net_dns_resolve); - ret = -EINVAL; - goto out; - } - s = env_get("httpserverip"); - if (!s) { + port = host_name; + host_name = strsep(&port, ":"); + + if (string_to_ip(host_name).s_addr != 0) { + s = host_name; + } else { +#if (IS_ENABLED(CONFIG_CMD_DNS)) + net_dns_resolve = host_name; + net_dns_env_var = "httpserverip"; + if (net_loop(DNS) < 0) { + log_err("Error: dns lookup of %s failed, check setup\n", net_dns_resolve); + ret = -EINVAL; + goto out; + } + s = env_get("httpserverip"); + if (!s) { + log_err("Error: %s could not be resolved\n", net_dns_resolve); + ret = -EINVAL; + goto out; + } +#else + log_err("Error: dns disabled, %s could not be resolved\n", host_name); ret = -EINVAL; goto out; +#endif }
strlcpy(net_boot_file_name, s, sizeof(net_boot_file_name)); @@ -579,7 +590,6 @@ out:
return ret < 0 ? ret : 0; } -#endif
/** * wget_validate_uri() - validate the uri for wget
Adriano Cordova
