[PATCH v3] usb: dwc3: Add support to reset usb ULPI phy
When usb PHY initialization is done, the PHY need to be reset.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@amd.com ---
Changes in v3: - Fix compilation issues reported by CI and Marek - Use CONFIG_IS_ENABLED(DM_GPIO) and remove Kconfig dependency
Changes in v2: - Remove EBUSY checking which is not needed. Reported by Bin
The patch depends on https://lore.kernel.org/all/152354d05f56c57a21a6306745051a0961ea3c66.1657271...
--- drivers/usb/dwc3/dwc3-generic.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index c5310e465cbf..466b25a0c38e 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -26,6 +26,7 @@ #include <reset.h> #include <clk.h> #include <usb/xhci.h> +#include <asm/gpio.h>
struct dwc3_glue_data { struct clk_bulk clks; @@ -43,6 +44,7 @@ struct dwc3_generic_priv { void *base; struct dwc3 dwc3; struct phy_bulk phys; + struct gpio_desc ulpi_reset; };
struct dwc3_generic_host_priv { @@ -78,6 +80,27 @@ static int dwc3_generic_probe(struct udevice *dev, if (rc && rc != -ENOTSUPP) return rc;
+ if (CONFIG_IS_ENABLED(DM_GPIO) && + device_is_compatible(dev->parent, "xlnx,zynqmp-dwc3")) { + rc = gpio_request_by_name(dev->parent, "reset-gpios", 0, + &priv->ulpi_reset, GPIOD_ACTIVE_LOW); + if (rc) + return rc; + + /* Toggle ulpi to reset the phy. */ + rc = dm_gpio_set_value(&priv->ulpi_reset, 1); + if (rc) + return rc; + + mdelay(5); + + rc = dm_gpio_set_value(&priv->ulpi_reset, 0); + if (rc) + return rc; + + mdelay(5); + } + if (device_is_compatible(dev->parent, "rockchip,rk3399-dwc3")) reset_deassert_bulk(&glue->resets);
@@ -99,6 +122,13 @@ static int dwc3_generic_remove(struct udevice *dev, { struct dwc3 *dwc3 = &priv->dwc3;
+ if (CONFIG_IS_ENABLED(DM_GPIO) && + device_is_compatible(dev->parent, "xlnx,zynqmp-dwc3")) { + struct gpio_desc *ulpi_reset = &priv->ulpi_reset; + + dm_gpio_free(ulpi_reset->dev, ulpi_reset); + } + dwc3_remove(dwc3); dwc3_shutdown_phy(dev, &priv->phys); unmap_physmem(dwc3->regs, MAP_NOCACHE);
Michal, please verify this compiles in CI.
I did it yesterday. https://source.denx.de/u-boot/custodians/u-boot-microblaze/-/pipelines/12650
And my full queue is running just now. https://source.denx.de/u-boot/custodians/u-boot-microblaze/-/pipelines/12652
M
Michal Simek
