[PATCH RFC] doc: Document address spaces used by U-Boot
This serves as a reference for developers on how to handle all those address spaces for U-Boot.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- Hi all,
I was trying to clear up long standing myth of virtual address vs physical adddress mapping on MIPS by having a clear division betweem virt and phys adddress everywhere.
In this process I would like to confirm my understanding by writing a document and requesting comments from the community.
Note that there are some sysmem APIs mentioned in the document are not in U-Boot tree, namely ``sysmem_addr_t`` and sysmem_to_phys co. I think they can help with annotating address spaces.
Please kindly comment on the design.
Thanks! --- doc/develop/address_spaces.rst | 73 ++++++++++++++++++++++++++++++++++++++++++ doc/develop/index.rst | 1 + 2 files changed, 74 insertions(+)
diff --git a/doc/develop/address_spaces.rst b/doc/develop/address_spaces.rst new file mode 100644 index 000000000000..05c4a1575f27 --- /dev/null +++ b/doc/develop/address_spaces.rst @@ -0,0 +1,73 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (c) 2024 Jiaxun Yang jiaxun.yang@flygoat.com + +Address Spaces +============== + +Introduction +------------ + +In U-Boot, we have three address spaces that are used to describe a memory +address: + + - ``virt``: virtual address space + - ``phys``: physical address space + - ``sysmem``: system memory address space + +On most architectures, we maintain a 1:1:1 mapping between all three address, +with the exception of MIPS and sandbox. + +There are many API misused in existing code base, this document is to clarify +the usage of these address spaces and APIs. Hopefully it will help to reduce +the confusion and porting effort. + +``virt`` +-------- + +This is the address space that is directly used by U-Boot to access memory. +Every pointer in U-Boot must in ``virt`` address space. to get a valid ``virt`` +address from any other address space, you must use relavant mapping functions +to ensure it's being tracked. It is recomanded to use ``ulong`` or pointer types +to store ``virt`` address. + +``phys`` +-------- + +This is the address space that is used to describe the physical memory address. +It's used to describe the physical memory address of a device, or the physical +memory address of a memory region. Usual places you would see ``phys`` address +are addresses comes from Device Tree and some memory related APIs. It is +recommended to use ``fdt_addr_t`` or ``phys_addr_t`` to store ``phys`` address. + +Following APIs are availble to handle ``phys`` address: + + - ``map_physmem()``: Create mapping from physical address to virtual address + - ``unmap_physmem()``: Remove mapping created by ``map_physmem()`` + - ``virt_to_phys()``: Find physical address mapping for a virtual address + - ``ioremap()``: Create mapping for I/O memory region + - ``iounmap()``: Remove mapping created by ``ioremap()`` + +``sysmem`` +---------- + +This is the address space that is used by U-Boot internally to describe RAM +address. It helps to abstract some architecture differences and provide a +consistent way to managed RAM. Usual places you would see ``sysmem`` address +are addresses comes from ``gd->bd->bi_dram[]``, addresses comes from ``LMB`` +addresses being used as memory related config optinos, and addresses being +used as arguments to load commands. It is recommended to use ``sysmem_addr_t`` +to store ``sysmem`` address. + +It is further used by sandbox to simulate memory, and by MIPS to handle +differences between ``virt`` and ``phys`` address spaces. + +Following APIs are availble to handle ``sysmem`` address: + + - ``map_sysmem()``: Create mapping from system memory address to virtual address + - ``unmap_sysmem()``: Remove mapping created by ``map_sysmem()`` + - ``map_to_sysmem()``: Find system memory address mapping for a virtual address + - ``sysmem_to_phys()``: Find physical address mapping for a system memory address + - ``phys_to_sysmem()``: Find system memory address mapping for a physical address + - ``nomap_sysmem()``: Pass through an address unchanged (For sandbox tracking) + - ``nomap_to_sysmem()``: Pass through an address unchanged + diff --git a/doc/develop/index.rst b/doc/develop/index.rst index f82e148b101c..1b8e11cd2f24 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -27,6 +27,7 @@ Implementation .. toctree:: :maxdepth: 1
+ address_spaces directories bloblist bootstd
--- base-commit: ad7dce5abd49ef3b5c93da5303e15449c8c162b4 change-id: 20240517-address-spaces-1c3b9c379b13
Hi all,
Thanks!
Thanks for looking into this.
+``virt`` +--------
%s/must in/must be in/
%s/to get/To get/
%s/relavant/relevant/
+``phys`` +--------
%s/availble/available/
These functions do not reprogram the MMU. In fact these functions are only used to translate between the sandbox' virtual address space and the host's virtual address space.
Looking at the sandbox code
static inline void *map_sysmem(phys_addr_t paddr, unsigned long len) { return map_physmem(paddr, len, MAP_WRBACK); }
there seems to be no difference between sysmem and physmem on the sandbox.
I would say: It is the address space used in the command line interface and in environment variables.
It should not be used elsewhere. Specifically these sandbox virtual addresses must not be used in structures that are passed to external programs like the kernel or EFI binaries.
The CLI addresses are used for memory mapped devices, too. So 'managed RAM' is a bit confusing here.
%s/optinos/options/
Relating to gd->bd->bi_dram[] or LMB just adds a layer of confusion to the reader. I would not refer to specific internal structures in this document.
In most places long is used.
You have been submitting patches to implement EFI for MIPS.
The EFI specification explicitly requires a 1:1 mapping in the MMU between. virtual and physical addresses.
In what respect does MIPS not comply to this?
In how far do MIPS addresses shown in the CLI differ from the physical addresses (i.e. addresses on the electrical address lines)?
CONFIG_ARCH_MAP_SYSMEM seems only to be set on the sandbox and not on MIPS. We should try to keep it that way.
To summarize. If I have not mistaken anything about MIPS:
All physical devices are identity mapped.
The sandbox uses a virtual address space incorrectly called 'physical' which is mapped to the virtual address space of the host. This sandbox virtual address space is used in
* the command line interface * in the sandbox device-tree * in environment variable
This allows using the same address values in sandbox tests irrespective of what part of the host RAM was mapped via mmap().
Best regards
Heinrich
- address_spaces directories bloblist bootstd
在2024年5月18日五月 上午9:08,Heinrich Schuchardt写道:
Hi Heinrich,
Ah sorry I should really spell check it before sending it off.... It was copied directly from my personal note.
%s/optinos/options/
So it's a developer oriented document and I decided to add some examples.
So for MIPS we need to apply a fixed offset to physical address to get a usable virtual address, i.e. 0x1000 physical is 0x80001000 virtual. That mapping is guaranteed by the hardware, and you can't disable it even after enabling MMU.
All CLIs are currently using virtual address.
For EFI all table address passed are virtual-ish address.
I'm actually trying to introduce ARCH_MAP_SYSMEM abstraction to MIPS because currently it's totally a mess about virtual vs physical everywhere.
I think eventually we should convert most internal data structure (and cmd arguments) to use physical address for consistency, but converting all existing boards to that model cost an arm and a leg. So my plan is to introduce an option telling if sysmem is virtual or physical and let boards opt-in that option.
Thanks
- the command line interface
- in the sandbox device-tree
- in environment variable
Best regards
Heinrich
Jiaxun Yang
