[U-Boot-Users] [PATCH 0/7 v6] SMDK6400 support
Version 6: this time, based on the updated nand-testing branch with the latest patch from Scott Wood - thanks again, run-tested. Updates since version 5: restored original bad-block detection in nand_spl/nand_boot.c with only necessary changes to support non block-aligned images, use the chipselect and compile on ARM. Patch 1/7 is gone, as Stefan accepted version 5 (he's had enough of these cc's probably:-))
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Supporting page-aligned reads doesn't incure any sinificant overhead, just a small change in the algorithm. Also replace in_8 with readb, since there is no in_8 on ARM.
Signed-off-by: Guennadi Liakhovetski lg@denx.de --- nand_spl/nand_boot.c | 22 +++++++++++++++++----- 1 files changed, 17 insertions(+), 5 deletions(-)
diff --git a/nand_spl/nand_boot.c b/nand_spl/nand_boot.c index 81b4dfc..02ccfa8 100644 --- a/nand_spl/nand_boot.c +++ b/nand_spl/nand_boot.c @@ -131,7 +131,7 @@ static int nand_is_bad_block(struct mtd_info *mtd, int block) /* * Read one byte */ - if (in_8(this->IO_ADDR_R) != 0xff) + if (readb(this->IO_ADDR_R) != 0xff) return 1;
return 0; @@ -186,24 +186,30 @@ static int nand_read_page(struct mtd_info *mtd, int block, int page, uchar *dst)
static int nand_load(struct mtd_info *mtd, int offs, int uboot_size, uchar *dst) { - int block; + int block, blocks; int blockcopy_count; int page; + unsigned int read = 0;
/* - * offs has to be aligned to a block address! + * offs has to be aligned to a page address! */ block = offs / CFG_NAND_BLOCK_SIZE; + blocks = (uboot_size + offs - ((block - 1) * CFG_NAND_BLOCK_SIZE) - 1) / + CFG_NAND_BLOCK_SIZE; blockcopy_count = 0;
- while (blockcopy_count < (uboot_size / CFG_NAND_BLOCK_SIZE)) { + while (blockcopy_count < blocks) { if (!nand_is_bad_block(mtd, block)) { /* * Skip bad blocks */ for (page = 0; page < CFG_NAND_PAGE_COUNT; page++) { nand_read_page(mtd, block, page, dst); - dst += CFG_NAND_PAGE_SIZE; + /* Overwrite skipped pages */ + if (read >= offs) + dst += CFG_NAND_PAGE_SIZE; + read += CFG_NAND_PAGE_SIZE; }
blockcopy_count++; @@ -235,12 +241,18 @@ void nand_boot(void) nand_chip.dev_ready = NULL; /* preset to NULL */ board_nand_init(&nand_chip);
+ if (nand_chip.select_chip) + nand_chip.select_chip(&nand_info, 0); + /* * Load U-Boot image from NAND into RAM */ ret = nand_load(&nand_info, CFG_NAND_U_BOOT_OFFS, CFG_NAND_U_BOOT_SIZE, (uchar *)CFG_NAND_U_BOOT_DST);
+ if (nand_chip.select_chip) + nand_chip.select_chip(&nand_info, -1); + /* * Jump to U-Boot image */
- blocks = (uboot_size + offs - ((block - 1) * CFG_NAND_BLOCK_SIZE) - 1) /
blockcopy_count = 0;CFG_NAND_BLOCK_SIZE;
- while (blockcopy_count < blocks) { if (!nand_is_bad_block(mtd, block)) { /* * Skip bad blocks */ for (page = 0; page < CFG_NAND_PAGE_COUNT; page++) { nand_read_page(mtd, block, page, dst);
if (read >= offs)
This looks wrong if offs isn't within the first block.
I've pushed a fixed and simplified version to nand-flash/testing -- can you test it?
-Scott
if (read >= offs)
Arrrgh, during the merge the following two lines went missing from the patch:
+ /* Recalculate offs as an offset inside a block */ + offs -= CFG_NAND_BLOCK_SIZE * block;
which were there, for example, in v5.
Yes, it works. Your version is also better, since it skips unneeded pages instead of reading them in and overwriting, as mine did.
Based on the original S3C64XX port by Samsung for U-Boot 1.1.6.
Signed-off-by: Guennadi Liakhovetski lg@denx.de --- cpu/arm1176/Makefile | 50 ++ cpu/arm1176/config.mk | 35 ++ cpu/arm1176/cpu.c | 189 +++++++ cpu/arm1176/s3c64xx/Makefile | 48 ++ cpu/arm1176/s3c64xx/config.mk | 34 ++ cpu/arm1176/s3c64xx/cpu_init.S | 142 +++++ cpu/arm1176/s3c64xx/interrupts.c | 280 ++++++++++ cpu/arm1176/s3c64xx/speed.c | 140 +++++ cpu/arm1176/start.S | 469 ++++++++++++++++ include/asm-arm/arch-s3c64xx/hardware.h | 63 +++ include/common.h | 3 +- include/s3c6400.h | 884 +++++++++++++++++++++++++++++++ include/s3c64x0.h | 92 ++++ 13 files changed, 2428 insertions(+), 1 deletions(-) create mode 100644 cpu/arm1176/Makefile create mode 100644 cpu/arm1176/config.mk create mode 100644 cpu/arm1176/cpu.c create mode 100644 cpu/arm1176/s3c64xx/Makefile create mode 100644 cpu/arm1176/s3c64xx/config.mk create mode 100644 cpu/arm1176/s3c64xx/cpu_init.S create mode 100644 cpu/arm1176/s3c64xx/interrupts.c create mode 100644 cpu/arm1176/s3c64xx/speed.c create mode 100644 cpu/arm1176/start.S create mode 100644 include/asm-arm/arch-s3c64xx/hardware.h create mode 100644 include/s3c6400.h create mode 100644 include/s3c64x0.h
diff --git a/cpu/arm1176/Makefile b/cpu/arm1176/Makefile new file mode 100644 index 0000000..1ca9199 --- /dev/null +++ b/cpu/arm1176/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(CPU).a + +START = start.o +COBJS = cpu.o + +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(START) $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm1176/config.mk b/cpu/arm1176/config.mk new file mode 100644 index 0000000..5083594 --- /dev/null +++ b/cpu/arm1176/config.mk @@ -0,0 +1,35 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +PLATFORM_RELFLAGS += -fno-strict-aliasing -fno-common -ffixed-r8 \ + -msoft-float + +# Make ARMv5 to allow more compilers to work, even though its v6. +PLATFORM_CPPFLAGS += -march=armv5t +# ========================================================================= +# +# Supply options according to compiler version +# +# ========================================================================= +PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32,-mabi=apcs-gnu) +PLATFORM_CPPFLAGS +=$(call cc-option,-mno-thumb-interwork,) +PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,)) diff --git a/cpu/arm1176/cpu.c b/cpu/arm1176/cpu.c new file mode 100644 index 0000000..a0a9268 --- /dev/null +++ b/cpu/arm1176/cpu.c @@ -0,0 +1,189 @@ +/* + * (C) Copyright 2004 Texas Insturments + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * CPU specific code + */ + +#include <common.h> +#include <command.h> +#include <s3c6400.h> + +static void cache_flush (void); + +/* read co-processor 15, register #1 (control register) */ +static unsigned long read_p15_c1 (void) +{ + unsigned long value; + + __asm__ __volatile__( + "mrc p15, 0, %0, c1, c0, 0 @ read control reg\n" + : "=r" (value) + : + : "memory"); + return value; +} + +/* write to co-processor 15, register #1 (control register) */ +static void write_p15_c1 (unsigned long value) +{ + __asm__ __volatile__( + "mcr p15, 0, %0, c1, c0, 0 @ write it back\n" + : + : "r" (value) + : "memory"); + + read_p15_c1(); +} + +static void cp_delay (void) +{ + volatile int i; + + /* Many OMAP regs need at least 2 nops */ + for (i = 0; i < 100; i++) + __asm__ __volatile__("nop\n"); +} + +/* See also ARM Ref. Man. */ +#define C1_MMU (1 << 0) /* mmu off/on */ +#define C1_ALIGN (1 << 1) /* alignment faults off/on */ +#define C1_DC (1 << 2) /* dcache off/on */ +#define C1_WB (1 << 3) /* merging write buffer on/off */ +#define C1_BIG_ENDIAN (1 << 7) /* big endian off/on */ +#define C1_SYS_PROT (1 << 8) /* system protection */ +#define C1_ROM_PROT (1 << 9) /* ROM protection */ +#define C1_IC (1 << 12) /* icache off/on */ +#define C1_HIGH_VECTORS (1 << 13) /* location of vectors: low/high */ +#define RESERVED_1 (0xf << 3) /* must be 111b for R/W */ + +int cpu_init (void) +{ + return 0; +} + +int cleanup_before_linux (void) +{ + /* + * this function is called just before we call linux + * it prepares the processor for linux + * + * we turn off caches etc ... + */ + + disable_interrupts (); + + /* turn off I/D-cache */ + icache_disable(); + dcache_disable(); + cache_flush(); + + return 0; +} + + +/* * reset the cpu by setting up the watchdog timer and let him time out */ +void reset_cpu (ulong ignored) +{ + printf("reset... \n\n\n"); + SW_RST_REG = 0x6400; + /* loop forever and wait for reset to happen */ + while (1) { + if (serial_tstc()) { + serial_getc(); + break; + } + } + /*NOTREACHED*/ +} + +int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + disable_interrupts (); + reset_cpu (0); + /*NOTREACHED*/ + return 0; +} + +void icache_enable (void) +{ + ulong reg; + + reg = read_p15_c1 (); /* get control reg. */ + cp_delay (); + write_p15_c1 (reg | C1_IC); +} + +void icache_disable (void) +{ + ulong reg; + + reg = read_p15_c1 (); + cp_delay (); + write_p15_c1 (reg & ~C1_IC); +} + +int icache_status (void) +{ + return (read_p15_c1 () & C1_IC) != 0; +} + +/* It makes no sense to use the dcache if the MMU is not enabled */ +void dcache_enable (void) +{ + ulong reg; + + reg = read_p15_c1 (); + cp_delay (); + write_p15_c1 (reg | C1_DC); +} + +void dcache_disable (void) +{ + ulong reg; + + reg = read_p15_c1 (); + cp_delay (); + reg &= ~C1_DC; + write_p15_c1 (reg); +} + +int dcache_status (void) +{ + return (read_p15_c1 () & C1_DC) != 0; +} + +/* flush I/D-cache */ +static void cache_flush (void) +{ + /* invalidate both caches and flush btb */ + asm ("mcr p15, 0, %0, c7, c7, 0": :"r" (0)); + /* mem barrier to sync things */ + asm ("mcr p15, 0, %0, c7, c10, 4": :"r" (0)); +} diff --git a/cpu/arm1176/s3c64xx/Makefile b/cpu/arm1176/s3c64xx/Makefile new file mode 100644 index 0000000..fa4ee3f --- /dev/null +++ b/cpu/arm1176/s3c64xx/Makefile @@ -0,0 +1,48 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS-y = interrupts.o +COBJS-$(CONFIG_S3C6400) += cpu_init.o speed.o + +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) + +all: $(obj).depend $(START) $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm1176/s3c64xx/config.mk b/cpu/arm1176/s3c64xx/config.mk new file mode 100644 index 0000000..204e880 --- /dev/null +++ b/cpu/arm1176/s3c64xx/config.mk @@ -0,0 +1,34 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +PLATFORM_RELFLAGS += -fno-strict-aliasing -fno-common -ffixed-r8 \ + -msoft-float + +# Make ARMv5 to allow more compilers to work, even though its v6. +PLATFORM_CPPFLAGS += -march=armv5t +# ========================================================================= +# +# Supply options according to compiler version +# +# ========================================================================= +#PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32,-mabi=apcs-gnu) +PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,)) diff --git a/cpu/arm1176/s3c64xx/cpu_init.S b/cpu/arm1176/s3c64xx/cpu_init.S new file mode 100644 index 0000000..08bda99 --- /dev/null +++ b/cpu/arm1176/s3c64xx/cpu_init.S @@ -0,0 +1,142 @@ +/* + * Originates from Samsung's u-boot 1.1.6 port to S3C6400 / SMDK6400 + * + * Copyright (C) 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <s3c6400.h> + + .globl mem_ctrl_asm_init +mem_ctrl_asm_init: + /* Memory subsystem address 0x7e00f120 */ + ldr r0, =ELFIN_MEM_SYS_CFG + + /* Xm0CSn2 = NFCON CS0, Xm0CSn3 = NFCON CS1 */ + mov r1, #0xd + str r1, [r0] + + /* DMC1 base address 0x7e001000 */ + ldr r0, =ELFIN_DMC1_BASE + + ldr r1, =0x4 + str r1, [r0, #INDEX_DMC_MEMC_CMD] + + ldr r1, =DMC_DDR_REFRESH_PRD + str r1, [r0, #INDEX_DMC_REFRESH_PRD] + + ldr r1, =DMC_DDR_CAS_LATENCY + str r1, [r0, #INDEX_DMC_CAS_LATENCY] + + ldr r1, =DMC_DDR_t_DQSS + str r1, [r0, #INDEX_DMC_T_DQSS] + + ldr r1, =DMC_DDR_t_MRD + str r1, [r0, #INDEX_DMC_T_MRD] + + ldr r1, =DMC_DDR_t_RAS + str r1, [r0, #INDEX_DMC_T_RAS] + + ldr r1, =DMC_DDR_t_RC + str r1, [r0, #INDEX_DMC_T_RC] + + ldr r1, =DMC_DDR_t_RCD + ldr r2, =DMC_DDR_schedule_RCD + orr r1, r1, r2 + str r1, [r0, #INDEX_DMC_T_RCD] + + ldr r1, =DMC_DDR_t_RFC + ldr r2, =DMC_DDR_schedule_RFC + orr r1, r1, r2 + str r1, [r0, #INDEX_DMC_T_RFC] + + ldr r1, =DMC_DDR_t_RP + ldr r2, =DMC_DDR_schedule_RP + orr r1, r1, r2 + str r1, [r0, #INDEX_DMC_T_RP] + + ldr r1, =DMC_DDR_t_RRD + str r1, [r0, #INDEX_DMC_T_RRD] + + ldr r1, =DMC_DDR_t_WR + str r1, [r0, #INDEX_DMC_T_WR] + + ldr r1, =DMC_DDR_t_WTR + str r1, [r0, #INDEX_DMC_T_WTR] + + ldr r1, =DMC_DDR_t_XP + str r1, [r0, #INDEX_DMC_T_XP] + + ldr r1, =DMC_DDR_t_XSR + str r1, [r0, #INDEX_DMC_T_XSR] + + ldr r1, =DMC_DDR_t_ESR + str r1, [r0, #INDEX_DMC_T_ESR] + + ldr r1, =DMC1_MEM_CFG + str r1, [r0, #INDEX_DMC_MEMORY_CFG] + + ldr r1, =DMC1_MEM_CFG2 + str r1, [r0, #INDEX_DMC_MEMORY_CFG2] + + ldr r1, =DMC1_CHIP0_CFG + str r1, [r0, #INDEX_DMC_CHIP_0_CFG] + + ldr r1, =DMC_DDR_32_CFG + str r1, [r0, #INDEX_DMC_USER_CONFIG] + + /* DMC0 DDR Chip 0 configuration direct command reg */ + ldr r1, =DMC_NOP0 + str r1, [r0, #INDEX_DMC_DIRECT_CMD] + + /* Precharge All */ + ldr r1, =DMC_PA0 + str r1, [r0, #INDEX_DMC_DIRECT_CMD] + + /* Auto Refresh 2 time */ + ldr r1, =DMC_AR0 + str r1, [r0, #INDEX_DMC_DIRECT_CMD] + str r1, [r0, #INDEX_DMC_DIRECT_CMD] + + /* MRS */ + ldr r1, =DMC_mDDR_EMR0 + str r1, [r0, #INDEX_DMC_DIRECT_CMD] + + /* Mode Reg */ + ldr r1, =DMC_mDDR_MR0 + str r1, [r0, #INDEX_DMC_DIRECT_CMD] + + /* Enable DMC1 */ + mov r1, #0x0 + str r1, [r0, #INDEX_DMC_MEMC_CMD] + +check_dmc1_ready: + ldr r1, [r0, #INDEX_DMC_MEMC_STATUS] + mov r2, #0x3 + and r1, r1, r2 + cmp r1, #0x1 + bne check_dmc1_ready + nop + + mov pc, lr + + .ltorg diff --git a/cpu/arm1176/s3c64xx/interrupts.c b/cpu/arm1176/s3c64xx/interrupts.c new file mode 100644 index 0000000..4233e8c --- /dev/null +++ b/cpu/arm1176/s3c64xx/interrupts.c @@ -0,0 +1,280 @@ +/* + * (C) Copyright 2003 + * Texas Instruments <www.ti.com> + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002-2004 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2004 + * Philippe Robin, ARM Ltd. philippe.robin@arm.com + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/proc-armv/ptrace.h> +#include <s3c6400.h> + +static ulong timer_load_val; + +#define PRESCALER 167 + +static s3c64xx_timers *s3c64xx_get_base_timers(void) +{ + return (s3c64xx_timers *)ELFIN_TIMER_BASE; +} + +/* macro to read the 16 bit timer */ +static inline ulong read_timer(void) +{ + s3c64xx_timers *const timers = s3c64xx_get_base_timers(); + + return timers->TCNTO4; +} + +/* Internal tick units */ +/* Last decremneter snapshot */ +static unsigned long lastdec; +/* Monotonic incrementing timer */ +static unsigned long long timestamp; + +void enable_interrupts(void) +{ + return; +} +int disable_interrupts(void) +{ + return 0; +} + +void bad_mode(void) +{ + panic("Resetting CPU ...\n"); + reset_cpu(0); +} + +void show_regs(struct pt_regs *regs) +{ + unsigned long flags; + const char *processor_modes[] = { + "USER_26", "FIQ_26", "IRQ_26", "SVC_26", + "UK4_26", "UK5_26", "UK6_26", "UK7_26", + "UK8_26", "UK9_26", "UK10_26", "UK11_26", + "UK12_26", "UK13_26", "UK14_26", "UK15_26", + "USER_32", "FIQ_32", "IRQ_32", "SVC_32", + "UK4_32", "UK5_32", "UK6_32", "ABT_32", + "UK8_32", "UK9_32", "UK10_32", "UND_32", + "UK12_32", "UK13_32", "UK14_32", "SYS_32", + }; + + flags = condition_codes(regs); + + printf("pc : [<%08lx>] lr : [<%08lx>]\n" + "sp : %08lx ip : %08lx fp : %08lx\n", + instruction_pointer(regs), regs->ARM_lr, regs->ARM_sp, + regs->ARM_ip, regs->ARM_fp); + printf("r10: %08lx r9 : %08lx r8 : %08lx\n", regs->ARM_r10, + regs->ARM_r9, regs->ARM_r8); + printf("r7 : %08lx r6 : %08lx r5 : %08lx r4 : %08lx\n", + regs->ARM_r7, regs->ARM_r6, regs->ARM_r5, regs->ARM_r4); + printf("r3 : %08lx r2 : %08lx r1 : %08lx r0 : %08lx\n", + regs->ARM_r3, regs->ARM_r2, regs->ARM_r1, regs->ARM_r0); + printf("Flags: %c%c%c%c", + flags & CC_N_BIT ? 'N' : 'n', + flags & CC_Z_BIT ? 'Z' : 'z', + flags & CC_C_BIT ? 'C' : 'c', flags & CC_V_BIT ? 'V' : 'v'); + printf(" IRQs %s FIQs %s Mode %s%s\n", + interrupts_enabled(regs) ? "on" : "off", + fast_interrupts_enabled(regs) ? "on" : "off", + processor_modes[processor_mode(regs)], thumb_mode(regs) ? + " (T)" : ""); +} + +void do_undefined_instruction(struct pt_regs *pt_regs) +{ + printf("undefined instruction\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_software_interrupt(struct pt_regs *pt_regs) +{ + printf("software interrupt\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_prefetch_abort(struct pt_regs *pt_regs) +{ + printf("prefetch abort\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_data_abort(struct pt_regs *pt_regs) +{ + printf("data abort\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_not_used(struct pt_regs *pt_regs) +{ + printf("not used\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_fiq(struct pt_regs *pt_regs) +{ + printf("fast interrupt request\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_irq(struct pt_regs *pt_regs) +{ + printf("interrupt request\n"); + show_regs(pt_regs); + bad_mode(); +} + +int interrupt_init(void) +{ + s3c64xx_timers *const timers = s3c64xx_get_base_timers(); + + /* use PWM Timer 4 because it has no output */ + /* + * We use the following scheme for the timer: + * Prescaler is hard fixed at 167, divider at 1/4. + * This gives at PCLK frequency 66MHz approx. 10us ticks + * The timer is set to wrap after 100s, at 66MHz this obviously + * happens after 10,000,000 ticks. A long variable can thus + * keep values up to 40,000s, i.e., 11 hours. This should be + * enough for most uses:-) Possible optimizations: select a + * binary-friendly frequency, e.g., 1ms / 128. Also calculate + * the prescaler automatically for other PCLK frequencies. + */ + /* Set timer frequency to 500KHz, at 66MHz we get prescaler=132 < 255 */ + timers->TCFG0 = PRESCALER << 8; + if (timer_load_val == 0) { + /* + * for 10 ms clock period @ PCLK with 4 bit divider = 1/2 and + * prescaler = 16. Should be 10390 @33.25MHz and 15625 @ 50 MHz + */ + timer_load_val = get_PCLK() / PRESCALER * (100 / 4); /* 100s */ + /*printf("Calculated %lu timer_load_val\n", timer_load_val);*/ + timers->TCFG1 = (timers->TCFG1 & ~0xf0000) | 0x20000; + } + + /* load value for 10 ms timeout */ + lastdec = timers->TCNTB4 = timer_load_val; + /* auto load, manual update of Timer 4 */ + timers->TCON = (timers->TCON & ~0x00700000) | TCON_4_AUTO | + TCON_4_UPDATE; + /* auto load, start Timer 4 */ + timers->TCON = (timers->TCON & ~0x00700000) | TCON_4_AUTO | COUNT_4_ON; + timestamp = 0; + + return 0; +} + +/* + * timer without interrupts + */ + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + ulong now = read_timer(); + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + timer_load_val - now; + } + lastdec = now; + + return timestamp; +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + /* We overrun in 100s */ + return (ulong)(timer_load_val / 100); +} + +void reset_timer_masked(void) +{ + /* reset time */ + lastdec = read_timer(); + timestamp = 0; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer_masked(void) +{ + return get_ticks() / (timer_load_val / (100 * CFG_HZ)); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + timestamp = t * (timer_load_val / (100 * CFG_HZ)); +} + +void udelay(unsigned long usec) +{ + unsigned long long tmp; + ulong tmo; + + tmo = (usec + 9) / 10; + tmp = get_ticks() + tmo; /* get current timestamp */ + + while (get_ticks() < tmp)/* loop till event */ + /*NOP*/; +} diff --git a/cpu/arm1176/s3c64xx/speed.c b/cpu/arm1176/s3c64xx/speed.c new file mode 100644 index 0000000..bb54cb3 --- /dev/null +++ b/cpu/arm1176/s3c64xx/speed.c @@ -0,0 +1,140 @@ +/* + * (C) Copyright 2001-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * This code should work for both the S3C2400 and the S3C2410 + * as they seem to have the same PLL and clock machinery inside. + * The different address mapping is handled by the s3c24xx.h files below. + */ + +#include <common.h> +#include <s3c6400.h> + +#define APLL 0 +#define MPLL 1 +#define EPLL 2 + +/* ------------------------------------------------------------------------- */ +/* + * NOTE: This describes the proper use of this file. + * + * CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL. + * + * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of + * the specified bus in HZ. + */ +/* ------------------------------------------------------------------------- */ + +static ulong get_PLLCLK(int pllreg) +{ + ulong r, m, p, s; + + if (pllreg == APLL) + r = APLL_CON_REG; + else if (pllreg == MPLL) + r = MPLL_CON_REG; + else if (pllreg == EPLL) + r = EPLL_CON0_REG; + else + hang(); + + m = (r >> 16) & 0x3ff; + p = (r >> 8) & 0x3f; + s = r & 0x7; + + return m * (CONFIG_SYS_CLK_FREQ / (p * (1 << s))); +} + +/* return ARMCORE frequency */ +ulong get_ARMCLK(void) +{ + ulong div; + + div = CLK_DIV0_REG; + + return get_PLLCLK(APLL) / ((div & 0x7) + 1); +} + +/* return FCLK frequency */ +ulong get_FCLK(void) +{ + return get_PLLCLK(APLL); +} + +/* return HCLK frequency */ +ulong get_HCLK(void) +{ + ulong fclk; + + uint hclkx2_div = ((CLK_DIV0_REG >> 9) & 0x7) + 1; + uint hclk_div = ((CLK_DIV0_REG >> 8) & 0x1) + 1; + + /* + * Bit 7 exists on s3c6410, and not on s3c6400, it is reserved on + * s3c6400 and is always 0, and it is indeed running in ASYNC mode + */ + if (OTHERS_REG & 0x80) + fclk = get_FCLK(); /* SYNC Mode */ + else + fclk = get_PLLCLK(MPLL); /* ASYNC Mode */ + + return fclk / (hclk_div * hclkx2_div); +} + +/* return PCLK frequency */ +ulong get_PCLK(void) +{ + ulong fclk; + uint hclkx2_div = ((CLK_DIV0_REG >> 9) & 0x7) + 1; + uint pre_div = ((CLK_DIV0_REG >> 12) & 0xf) + 1; + + if (OTHERS_REG & 0x80) + fclk = get_FCLK(); /* SYNC Mode */ + else + fclk = get_PLLCLK(MPLL); /* ASYNC Mode */ + + return fclk / (hclkx2_div * pre_div); +} + +/* return UCLK frequency */ +ulong get_UCLK(void) +{ + return get_PLLCLK(EPLL); +} + +int print_cpuinfo(void) +{ + printf("\nCPU: S3C6400@%luMHz\n", get_ARMCLK() / 1000000); + printf(" Fclk = %luMHz, Hclk = %luMHz, Pclk = %luMHz ", + get_FCLK() / 1000000, get_HCLK() / 1000000, + get_PCLK() / 1000000); + + if (OTHERS_REG & 0x80) + printf("(SYNC Mode) \n"); + else + printf("(ASYNC Mode) \n"); + return 0; +} diff --git a/cpu/arm1176/start.S b/cpu/arm1176/start.S new file mode 100644 index 0000000..00cc186 --- /dev/null +++ b/cpu/arm1176/start.S @@ -0,0 +1,469 @@ +/* + * armboot - Startup Code for S3C6400/ARM1176 CPU-core + * + * Copyright (c) 2007 Samsung Electronics + * + * Copyright (C) 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * 2007-09-21 - Restructured codes by jsgood (jsgood.yang@samsung.com) + * 2007-09-21 - Added MoviNAND and OneNAND boot codes by + * jsgood (jsgood.yang@samsung.com) + * Base codes by scsuh (sc.suh) + */ + +#include <config.h> +#include <version.h> +#ifdef CONFIG_ENABLE_MMU +#include <asm/proc/domain.h> +#endif +#include <s3c6400.h> + +#if !defined(CONFIG_ENABLE_MMU) && !defined(CFG_PHY_UBOOT_BASE) +#define CFG_PHY_UBOOT_BASE CFG_UBOOT_BASE +#endif + +/* + ************************************************************************* + * + * Jump vector table as in table 3.1 in [1] + * + ************************************************************************* + */ + +.globl _start +_start: b reset +#ifndef CONFIG_NAND_SPL + ldr pc, _undefined_instruction + ldr pc, _software_interrupt + ldr pc, _prefetch_abort + ldr pc, _data_abort + ldr pc, _not_used + ldr pc, _irq + ldr pc, _fiq + +_undefined_instruction: + .word undefined_instruction +_software_interrupt: + .word software_interrupt +_prefetch_abort: + .word prefetch_abort +_data_abort: + .word data_abort +_not_used: + .word not_used +_irq: + .word irq +_fiq: + .word fiq +_pad: + .word 0x12345678 /* now 16*4=64 */ +#else + . = _start + 64 +#endif + +.global _end_vect +_end_vect: + .balignl 16,0xdeadbeef +/* + ************************************************************************* + * + * Startup Code (reset vector) + * + * do important init only if we don't start from memory! + * setup Memory and board specific bits prior to relocation. + * relocate armboot to ram + * setup stack + * + ************************************************************************* + */ + +_TEXT_BASE: + .word TEXT_BASE + +/* + * Below variable is very important because we use MMU in U-Boot. + * Without it, we cannot run code correctly before MMU is ON. + * by scsuh. + */ +_TEXT_PHY_BASE: + .word CFG_PHY_UBOOT_BASE + +.globl _armboot_start +_armboot_start: + .word _start + +/* + * These are defined in the board-specific linker script. + */ +.globl _bss_start +_bss_start: + .word __bss_start + +.globl _bss_end +_bss_end: + .word _end + +/* + * the actual reset code + */ + +reset: + /* + * set the cpu to SVC32 mode + */ + mrs r0,cpsr + bic r0,r0,#0x3f + orr r0,r0,#0xd3 + msr cpsr,r0 + +/* + ************************************************************************* + * + * CPU_init_critical registers + * + * setup important registers + * setup memory timing + * + ************************************************************************* + */ + /* + * we do sys-critical inits only at reboot, + * not when booting from ram! + */ +cpu_init_crit: + /* + * When booting from NAND - it has definitely been a reset, so, no need + * to flush caches and disable the MMU + */ +#ifndef CONFIG_NAND_SPL + /* + * flush v4 I/D caches + */ + mov r0, #0 + mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */ + mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ + + /* + * disable MMU stuff and caches + */ + mrc p15, 0, r0, c1, c0, 0 + bic r0, r0, #0x00002300 @ clear bits 13, 9:8 (--V- --RS) + bic r0, r0, #0x00000087 @ clear bits 7, 2:0 (B--- -CAM) + orr r0, r0, #0x00000002 @ set bit 2 (A) Align + orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache + /* Prepare to disable the MMU */ + adr r1, mmu_disable_phys + /* We presume we're within the first 1024 bytes */ + and r1, r1, #0x3fc + ldr r2, _TEXT_PHY_BASE + ldr r3, =0xfff00000 + and r2, r2, r3 + orr r2, r2, r1 + b mmu_disable + + .align 5 + /* Run in a single cache-line */ +mmu_disable: + mcr p15, 0, r0, c1, c0, 0 + nop + nop + mov pc, r2 +#endif + +mmu_disable_phys: + /* Peri port setup */ + ldr r0, =0x70000000 + orr r0, r0, #0x13 + mcr p15,0,r0,c15,c2,4 @ 256M (0x70000000 - 0x7fffffff) + + /* + * Go setup Memory and board specific bits prior to relocation. + */ + bl lowlevel_init /* go setup pll,mux,memory */ + +after_copy: +#ifdef CONFIG_ENABLE_MMU +enable_mmu: + /* enable domain access */ + ldr r5, =0x0000ffff + mcr p15, 0, r5, c3, c0, 0 /* load domain access register */ + + /* Set the TTB register */ + ldr r0, _mmu_table_base + ldr r1, =CFG_PHY_UBOOT_BASE + ldr r2, =0xfff00000 + bic r0, r0, r2 + orr r1, r0, r1 + mcr p15, 0, r1, c2, c0, 0 + + /* Enable the MMU */ + mrc p15, 0, r0, c1, c0, 0 + orr r0, r0, #1 /* Set CR_M to enable MMU */ + + /* Prepare to enable the MMU */ + adr r1, skip_hw_init + and r1, r1, #0x3fc + ldr r2, _TEXT_BASE + ldr r3, =0xfff00000 + and r2, r2, r3 + orr r2, r2, r1 + b mmu_enable + + .align 5 + /* Run in a single cache-line */ +mmu_enable: + + mcr p15, 0, r0, c1, c0, 0 + nop + nop + mov pc, r2 +#endif + +skip_hw_init: + /* Set up the stack */ +stack_setup: +#ifdef CONFIG_MEMORY_UPPER_CODE + ldr sp, =(CFG_UBOOT_BASE + CFG_UBOOT_SIZE - 0xc) +#else + ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ + sub r0, r0, #CFG_MALLOC_LEN /* malloc area */ + sub r0, r0, #CFG_GBL_DATA_SIZE /* bdinfo */ + sub sp, r0, #12 /* leave 3 words for abort-stack */ + +#endif + +clear_bss: + ldr r0, _bss_start /* find start of bss segment */ + ldr r1, _bss_end /* stop here */ + mov r2, #0 /* clear */ + +clbss_l: + str r2, [r0] /* clear loop... */ + add r0, r0, #4 + cmp r0, r1 + ble clbss_l + +#ifndef CONFIG_NAND_SPL + ldr pc, _start_armboot + +_start_armboot: + .word start_armboot +#else + b nand_boot +/* .word nand_boot*/ +#endif + +#ifdef CONFIG_ENABLE_MMU +_mmu_table_base: + .word mmu_table +#endif + +#ifndef CONFIG_NAND_SPL +/* + * we assume that cache operation is done before. (eg. cleanup_before_linux()) + * actually, we don't need to do anything about cache if not use d-cache in + * U-Boot. So, in this function we clean only MMU. by scsuh + * + * void theLastJump(void *kernel, int arch_num, uint boot_params); + */ +#ifdef CONFIG_ENABLE_MMU + .globl theLastJump +theLastJump: + mov r9, r0 + ldr r3, =0xfff00000 + ldr r4, _TEXT_PHY_BASE + adr r5, phy_last_jump + bic r5, r5, r3 + orr r5, r5, r4 + mov pc, r5 +phy_last_jump: + /* + * disable MMU stuff + */ + mrc p15, 0, r0, c1, c0, 0 + bic r0, r0, #0x00002300 /* clear bits 13, 9:8 (--V- --RS) */ + bic r0, r0, #0x00000087 /* clear bits 7, 2:0 (B--- -CAM) */ + orr r0, r0, #0x00000002 /* set bit 2 (A) Align */ + orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */ + mcr p15, 0, r0, c1, c0, 0 + + mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ + + mov r0, #0 + mov pc, r9 +#endif +/* + ************************************************************************* + * + * Interrupt handling + * + ************************************************************************* + */ +@ +@ IRQ stack frame. +@ +#define S_FRAME_SIZE 72 + +#define S_OLD_R0 68 +#define S_PSR 64 +#define S_PC 60 +#define S_LR 56 +#define S_SP 52 + +#define S_IP 48 +#define S_FP 44 +#define S_R10 40 +#define S_R9 36 +#define S_R8 32 +#define S_R7 28 +#define S_R6 24 +#define S_R5 20 +#define S_R4 16 +#define S_R3 12 +#define S_R2 8 +#define S_R1 4 +#define S_R0 0 + +#define MODE_SVC 0x13 +#define I_BIT 0x80 + +/* + * use bad_save_user_regs for abort/prefetch/undef/swi ... + */ + + .macro bad_save_user_regs + /* carve out a frame on current user stack */ + sub sp, sp, #S_FRAME_SIZE + /* Save user registers (now in svc mode) r0-r12 */ + stmia sp, {r0 - r12} + + ldr r2, _armboot_start + sub r2, r2, #(CFG_MALLOC_LEN) + /* set base 2 words into abort stack */ + sub r2, r2, #(CFG_GBL_DATA_SIZE+8) + /* get values for "aborted" pc and cpsr (into parm regs) */ + ldmia r2, {r2 - r3} + /* grab pointer to old stack */ + add r0, sp, #S_FRAME_SIZE + + add r5, sp, #S_SP + mov r1, lr + /* save sp_SVC, lr_SVC, pc, cpsr */ + stmia r5, {r0 - r3} + /* save current stack into r0 (param register) */ + mov r0, sp + .endm + + .macro get_bad_stack + /* setup our mode stack (enter in banked mode) */ + ldr r13, _armboot_start + /* move past malloc pool */ + sub r13, r13, #(CFG_MALLOC_LEN) + /* move to reserved a couple spots for abort stack */ + sub r13, r13, #(CFG_GBL_DATA_SIZE + 8) + + /* save caller lr in position 0 of saved stack */ + str lr, [r13] + /* get the spsr */ + mrs lr, spsr + /* save spsr in position 1 of saved stack */ + str lr, [r13, #4] + + /* prepare SVC-Mode */ + mov r13, #MODE_SVC + @ msr spsr_c, r13 + /* switch modes, make sure moves will execute */ + msr spsr, r13 + /* capture return pc */ + mov lr, pc + /* jump to next instruction & switch modes. */ + movs pc, lr + .endm + + .macro get_bad_stack_swi + /* space on current stack for scratch reg. */ + sub r13, r13, #4 + /* save R0's value. */ + str r0, [r13] + /* get data regions start */ + ldr r0, _armboot_start + /* move past malloc pool */ + sub r0, r0, #(CFG_MALLOC_LEN) + /* move past gbl and a couple spots for abort stack */ + sub r0, r0, #(CFG_GBL_DATA_SIZE + 8) + /* save caller lr in position 0 of saved stack */ + str lr, [r0] + /* get the spsr */ + mrs r0, spsr + /* save spsr in position 1 of saved stack */ + str lr, [r0, #4] + /* restore r0 */ + ldr r0, [r13] + /* pop stack entry */ + add r13, r13, #4 + .endm + +/* + * exception handlers + */ + .align 5 +undefined_instruction: + get_bad_stack + bad_save_user_regs + bl do_undefined_instruction + + .align 5 +software_interrupt: + get_bad_stack_swi + bad_save_user_regs + bl do_software_interrupt + + .align 5 +prefetch_abort: + get_bad_stack + bad_save_user_regs + bl do_prefetch_abort + + .align 5 +data_abort: + get_bad_stack + bad_save_user_regs + bl do_data_abort + + .align 5 +not_used: + get_bad_stack + bad_save_user_regs + bl do_not_used + + .align 5 +irq: + get_bad_stack + bad_save_user_regs + bl do_irq + + .align 5 +fiq: + get_bad_stack + bad_save_user_regs + bl do_fiq +#endif /* CONFIG_NAND_SPL */ diff --git a/include/asm-arm/arch-s3c64xx/hardware.h b/include/asm-arm/arch-s3c64xx/hardware.h new file mode 100644 index 0000000..84d24c9 --- /dev/null +++ b/include/asm-arm/arch-s3c64xx/hardware.h @@ -0,0 +1,63 @@ +/* + * Originates from Samsung's u-boot 1.1.6 port to S3C6400 / SMDK6400 + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ARCH_HARDWARE_H_ +#define _ARCH_HARDWARE_H_ + +#include <asm/sizes.h> + +#ifndef __ASSEMBLY__ +#define UData(Data) ((unsigned long) (Data)) + +#define __REG(x) (*(vu_long *)(x)) +#define __REGl(x) (*(vu_long *)(x)) +#define __REGw(x) (*(vu_short *)(x)) +#define __REGb(x) (*(vu_char *)(x)) +#define __REG2(x, y) (*(vu_long *)((x) + (y))) +#else +#define UData(Data) (Data) + +#define __REG(x) (x) +#define __REGl(x) (x) +#define __REGw(x) (x) +#define __REGb(x) (x) +#define __REG2(x, y) ((x) + (y)) +#endif + +#define Fld(Size, Shft) (((Size) << 16) + (Shft)) + +#define FSize(Field) ((Field) >> 16) +#define FShft(Field) ((Field) & 0x0000FFFF) +#define FMsk(Field) (((UData (1) << FSize (Field)) - 1) << FShft (Field)) +#define FAlnMsk(Field) ((UData (1) << FSize (Field)) - 1) +#define F1stBit(Field) (UData (1) << FShft (Field)) + +#define FClrBit(Data, Bit) (Data = (Data & ~(Bit))) +#define FClrFld(Data, Field) (Data = (Data & ~FMsk(Field))) + +#define FInsrt(Value, Field) \ + (UData (Value) << FShft (Field)) + +#define FExtr(Data, Field) \ + ((UData (Data) >> FShft (Field)) & FAlnMsk (Field)) + +#endif /* _ARCH_HARDWARE_H_ */ diff --git a/include/common.h b/include/common.h index 06ed278..ba87322 100644 --- a/include/common.h +++ b/include/common.h @@ -491,7 +491,8 @@ int prt_mpc8220_clks (void); ulong get_OPB_freq (void); ulong get_PCI_freq (void); #endif -#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || defined(CONFIG_LH7A40X) +#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || \ + defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400) void s3c2410_irq(void); #define ARM920_IRQ_CALLBACK s3c2410_irq ulong get_FCLK (void); diff --git a/include/s3c6400.h b/include/s3c6400.h new file mode 100644 index 0000000..8814747 --- /dev/null +++ b/include/s3c6400.h @@ -0,0 +1,884 @@ +/* + * (C) Copyright 2007 + * Byungjae Lee, Samsung Erectronics, bjlee@samsung.com. + * - only support for S3C6400 + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************ + * NAME : s3c6400.h + * + * Based on S3C6400 User's manual Rev 0.0 + ************************************************/ + +#ifndef __S3C6400_H__ +#define __S3C6400_H__ + +#ifndef CONFIG_S3C6400 +#define CONFIG_S3C6400 1 +#endif + +#define S3C64XX_UART_CHANNELS 3 +#define S3C64XX_SPI_CHANNELS 2 + +#include <asm/hardware.h> + +#define ELFIN_CLOCK_POWER_BASE 0x7e00f000 + +/* Clock & Power Controller for mDirac3*/ +#define APLL_LOCK_OFFSET 0x00 +#define MPLL_LOCK_OFFSET 0x04 +#define EPLL_LOCK_OFFSET 0x08 +#define APLL_CON_OFFSET 0x0C +#define MPLL_CON_OFFSET 0x10 +#define EPLL_CON0_OFFSET 0x14 +#define EPLL_CON1_OFFSET 0x18 +#define CLK_SRC_OFFSET 0x1C +#define CLK_DIV0_OFFSET 0x20 +#define CLK_DIV1_OFFSET 0x24 +#define CLK_DIV2_OFFSET 0x28 +#define CLK_OUT_OFFSET 0x2C +#define HCLK_GATE_OFFSET 0x30 +#define PCLK_GATE_OFFSET 0x34 +#define SCLK_GATE_OFFSET 0x38 +#define AHB_CON0_OFFSET 0x100 +#define AHB_CON1_OFFSET 0x104 +#define AHB_CON2_OFFSET 0x108 +#define SELECT_DMA_OFFSET 0x110 +#define SW_RST_OFFSET 0x114 +#define SYS_ID_OFFSET 0x118 +#define MEM_SYS_CFG_OFFSET 0x120 +#define QOS_OVERRIDE0_OFFSET 0x124 +#define QOS_OVERRIDE1_OFFSET 0x128 +#define MEM_CFG_STAT_OFFSET 0x12C +#define PWR_CFG_OFFSET 0x804 +#define EINT_MASK_OFFSET 0x808 +#define NOR_CFG_OFFSET 0x810 +#define STOP_CFG_OFFSET 0x814 +#define SLEEP_CFG_OFFSET 0x818 +#define OSC_FREQ_OFFSET 0x820 +#define OSC_STABLE_OFFSET 0x824 +#define PWR_STABLE_OFFSET 0x828 +#define FPC_STABLE_OFFSET 0x82C +#define MTC_STABLE_OFFSET 0x830 +#define OTHERS_OFFSET 0x900 +#define RST_STAT_OFFSET 0x904 +#define WAKEUP_STAT_OFFSET 0x908 +#define BLK_PWR_STAT_OFFSET 0x90C +#define INF_REG0_OFFSET 0xA00 +#define INF_REG1_OFFSET 0xA04 +#define INF_REG2_OFFSET 0xA08 +#define INF_REG3_OFFSET 0xA0C +#define INF_REG4_OFFSET 0xA10 +#define INF_REG5_OFFSET 0xA14 +#define INF_REG6_OFFSET 0xA18 +#define INF_REG7_OFFSET 0xA1C + +#define OSC_CNT_VAL_OFFSET 0x824 +#define PWR_CNT_VAL_OFFSET 0x828 +#define FPC_CNT_VAL_OFFSET 0x82C +#define MTC_CNT_VAL_OFFSET 0x830 + +#define APLL_LOCK_REG __REG(ELFIN_CLOCK_POWER_BASE+APLL_LOCK_OFFSET) +#define MPLL_LOCK_REG __REG(ELFIN_CLOCK_POWER_BASE+MPLL_LOCK_OFFSET) +#define EPLL_LOCK_REG __REG(ELFIN_CLOCK_POWER_BASE+EPLL_LOCK_OFFSET) +#define APLL_CON_REG __REG(ELFIN_CLOCK_POWER_BASE+APLL_CON_OFFSET) +#define MPLL_CON_REG __REG(ELFIN_CLOCK_POWER_BASE+MPLL_CON_OFFSET) +#define EPLL_CON0_REG __REG(ELFIN_CLOCK_POWER_BASE+EPLL_CON0_OFFSET) +#define EPLL_CON1_REG __REG(ELFIN_CLOCK_POWER_BASE+EPLL_CON1_OFFSET) +#define CLK_SRC_REG __REG(ELFIN_CLOCK_POWER_BASE+CLK_SRC_OFFSET) +#define CLK_DIV0_REG __REG(ELFIN_CLOCK_POWER_BASE+CLK_DIV0_OFFSET) +#define CLK_DIV1_REG __REG(ELFIN_CLOCK_POWER_BASE+CLK_DIV1_OFFSET) +#define CLK_DIV2_REG __REG(ELFIN_CLOCK_POWER_BASE+CLK_DIV2_OFFSET) +#define CLK_OUT_REG __REG(ELFIN_CLOCK_POWER_BASE+CLK_OUT_OFFSET) +#define HCLK_GATE_REG __REG(ELFIN_CLOCK_POWER_BASE+HCLK_GATE_OFFSET) +#define PCLK_GATE_REG __REG(ELFIN_CLOCK_POWER_BASE+PCLK_GATE_OFFSET) +#define SCLK_GATE_REG __REG(ELFIN_CLOCK_POWER_BASE+SCLK_GATE_OFFSET) +#define AHB_CON0_REG __REG(ELFIN_CLOCK_POWER_BASE+AHB_CON0_OFFSET) +#define AHB_CON1_REG __REG(ELFIN_CLOCK_POWER_BASE+AHB_CON1_OFFSET) +#define AHB_CON2_REG __REG(ELFIN_CLOCK_POWER_BASE+AHB_CON2_OFFSET) +#define SELECT_DMA_REG __REG(ELFIN_CLOCK_POWER_BASE+SELECT_DMA_OFFSET) +#define SW_RST_REG __REG(ELFIN_CLOCK_POWER_BASE+SW_RST_OFFSET) +#define SYS_ID_REG __REG(ELFIN_CLOCK_POWER_BASE+SYS_ID_OFFSET) +#define MEM_SYS_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE+MEM_SYS_CFG_OFFSET) +#define QOS_OVERRIDE0_REG __REG(ELFIN_CLOCK_POWER_BASE+ \ + QOS_OVERRIDE0_OFFSET) +#define QOS_OVERRIDE1_REG __REG(ELFIN_CLOCK_POWER_BASE+ \ + QOS_OVERRIDE1_OFFSET) +#define MEM_CFG_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE+ \ + MEM_CFG_STAT_OFFSET) +#define PWR_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE+PWR_CFG_OFFSET) +#define EINT_MASK_REG __REG(ELFIN_CLOCK_POWER_BASE+EINT_MASK_OFFSET) +#define NOR_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE+NOR_CFG_OFFSET) +#define STOP_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE+STOP_CFG_OFFSET) +#define SLEEP_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE+SLEEP_CFG_OFFSET) +#define OSC_FREQ_REG __REG(ELFIN_CLOCK_POWER_BASE+OSC_FREQ_OFFSET) +#define OSC_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE+OSC_CNT_VAL_OFFSET) +#define PWR_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE+PWR_CNT_VAL_OFFSET) +#define FPC_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE+FPC_CNT_VAL_OFFSET) +#define MTC_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE+MTC_CNT_VAL_OFFSET) +#define OTHERS_REG __REG(ELFIN_CLOCK_POWER_BASE+OTHERS_OFFSET) +#define RST_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE+RST_STAT_OFFSET) +#define WAKEUP_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE+WAKEUP_STAT_OFFSET) +#define BLK_PWR_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE+ \ + BLK_PWR_STAT_OFFSET) +#define INF_REG0_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG0_OFFSET) +#define INF_REG1_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG1_OFFSET) +#define INF_REG2_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG2_OFFSET) +#define INF_REG3_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG3_OFFSET) +#define INF_REG4_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG4_OFFSET) +#define INF_REG5_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG5_OFFSET) +#define INF_REG6_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG6_OFFSET) +#define INF_REG7_REG __REG(ELFIN_CLOCK_POWER_BASE+INF_REG7_OFFSET) + +#define APLL_LOCK (ELFIN_CLOCK_POWER_BASE+APLL_LOCK_OFFSET) +#define MPLL_LOCK (ELFIN_CLOCK_POWER_BASE+MPLL_LOCK_OFFSET) +#define EPLL_LOCK (ELFIN_CLOCK_POWER_BASE+EPLL_LOCK_OFFSET) +#define APLL_CON (ELFIN_CLOCK_POWER_BASE+APLL_CON_OFFSET) +#define MPLL_CON (ELFIN_CLOCK_POWER_BASE+MPLL_CON_OFFSET) +#define EPLL_CON0 (ELFIN_CLOCK_POWER_BASE+EPLL_CON0_OFFSET) +#define EPLL_CON1 (ELFIN_CLOCK_POWER_BASE+EPLL_CON1_OFFSET) +#define CLK_SRC (ELFIN_CLOCK_POWER_BASE+CLK_SRC_OFFSET) +#define CLK_DIV0 (ELFIN_CLOCK_POWER_BASE+CLK_DIV0_OFFSET) +#define CLK_DIV1 (ELFIN_CLOCK_POWER_BASE+CLK_DIV1_OFFSET) +#define CLK_DIV2 (ELFIN_CLOCK_POWER_BASE+CLK_DIV2_OFFSET) +#define CLK_OUT (ELFIN_CLOCK_POWER_BASE+CLK_OUT_OFFSET) +#define HCLK_GATE (ELFIN_CLOCK_POWER_BASE+HCLK_GATE_OFFSET) +#define PCLK_GATE (ELFIN_CLOCK_POWER_BASE+PCLK_GATE_OFFSET) +#define SCLK_GATE (ELFIN_CLOCK_POWER_BASE+SCLK_GATE_OFFSET) +#define AHB_CON0 (ELFIN_CLOCK_POWER_BASE+AHB_CON0_OFFSET) +#define AHB_CON1 (ELFIN_CLOCK_POWER_BASE+AHB_CON1_OFFSET) +#define AHB_CON2 (ELFIN_CLOCK_POWER_BASE+AHB_CON2_OFFSET) +#define SELECT_DMA (ELFIN_CLOCK_POWER_BASE+SELECT_DMA_OFFSET) +#define SW_RST (ELFIN_CLOCK_POWER_BASE+SW_RST_OFFSET) +#define SYS_ID (ELFIN_CLOCK_POWER_BASE+SYS_ID_OFFSET) +#define MEM_SYS_CFG (ELFIN_CLOCK_POWER_BASE+MEM_SYS_CFG_OFFSET) +#define QOS_OVERRIDE0 (ELFIN_CLOCK_POWER_BASE+QOS_OVERRIDE0_OFFSET) +#define QOS_OVERRIDE1 (ELFIN_CLOCK_POWER_BASE+QOS_OVERRIDE1_OFFSET) +#define MEM_CFG_STAT (ELFIN_CLOCK_POWER_BASE+MEM_CFG_STAT_OFFSET) +#define PWR_CFG (ELFIN_CLOCK_POWER_BASE+PWR_CFG_OFFSET) +#define EINT_MASK (ELFIN_CLOCK_POWER_BASE+EINT_MASK_OFFSET) +#define NOR_CFG (ELFIN_CLOCK_POWER_BASE+NOR_CFG_OFFSET) +#define STOP_CFG (ELFIN_CLOCK_POWER_BASE+STOP_CFG_OFFSET) +#define SLEEP_CFG (ELFIN_CLOCK_POWER_BASE+SLEEP_CFG_OFFSET) +#define OSC_FREQ (ELFIN_CLOCK_POWER_BASE+OSC_FREQ_OFFSET) +#define OSC_CNT_VAL (ELFIN_CLOCK_POWER_BASE+OSC_CNT_VAL_OFFSET) +#define PWR_CNT_VAL (ELFIN_CLOCK_POWER_BASE+PWR_CNT_VAL_OFFSET) +#define FPC_CNT_VAL (ELFIN_CLOCK_POWER_BASE+FPC_CNT_VAL_OFFSET) +#define MTC_CNT_VAL (ELFIN_CLOCK_POWER_BASE+MTC_CNT_VAL_OFFSET) +#define OTHERS (ELFIN_CLOCK_POWER_BASE+OTHERS_OFFSET) +#define RST_STAT (ELFIN_CLOCK_POWER_BASE+RST_STAT_OFFSET) +#define WAKEUP_STAT (ELFIN_CLOCK_POWER_BASE+WAKEUP_STAT_OFFSET) +#define BLK_PWR_STAT (ELFIN_CLOCK_POWER_BASE+BLK_PWR_STAT_OFFSET) +#define INF_REG0 (ELFIN_CLOCK_POWER_BASE+INF_REG0_OFFSET) +#define INF_REG1 (ELFIN_CLOCK_POWER_BASE+INF_REG1_OFFSET) +#define INF_REG2 (ELFIN_CLOCK_POWER_BASE+INF_REG2_OFFSET) +#define INF_REG3 (ELFIN_CLOCK_POWER_BASE+INF_REG3_OFFSET) +#define INF_REG4 (ELFIN_CLOCK_POWER_BASE+INF_REG4_OFFSET) +#define INF_REG5 (ELFIN_CLOCK_POWER_BASE+INF_REG5_OFFSET) +#define INF_REG6 (ELFIN_CLOCK_POWER_BASE+INF_REG6_OFFSET) +#define INF_REG7 (ELFIN_CLOCK_POWER_BASE+INF_REG7_OFFSET) + + +/* + * GPIO + */ +#define ELFIN_GPIO_BASE 0x7f008000 + +#define GPACON_OFFSET 0x00 +#define GPADAT_OFFSET 0x04 +#define GPAPUD_OFFSET 0x08 +#define GPACONSLP_OFFSET 0x0C +#define GPAPUDSLP_OFFSET 0x10 +#define GPBCON_OFFSET 0x20 +#define GPBDAT_OFFSET 0x04 +#define GPBPUD_OFFSET 0x08 +#define GPBCONSLP_OFFSET 0x0C +#define GPBPUDSLP_OFFSET 0x30 +#define GPCCON_OFFSET 0x40 +#define GPCDAT_OFFSET 0x44 +#define GPCPUD_OFFSET 0x48 +#define GPCCONSLP_OFFSET 0x4C +#define GPCPUDSLP_OFFSET 0x50 +#define GPDCON_OFFSET 0x60 +#define GPDDAT_OFFSET 0x64 +#define GPDPUD_OFFSET 0x68 +#define GPDCONSLP_OFFSET 0x6C +#define GPDPUDSLP_OFFSET 0x70 +#define GPECON_OFFSET 0x80 +#define GPEDAT_OFFSET 0x84 +#define GPEPUD_OFFSET 0x88 +#define GPECONSLP_OFFSET 0x8C +#define GPEPUDSLP_OFFSET 0x90 +#define GPFCON_OFFSET 0xA0 +#define GPFDAT_OFFSET 0xA4 +#define GPFPUD_OFFSET 0xA8 +#define GPFCONSLP_OFFSET 0xAC +#define GPFPUDSLP_OFFSET 0xB0 +#define GPGCON_OFFSET 0xC0 +#define GPGDAT_OFFSET 0xC4 +#define GPGPUD_OFFSET 0xC8 +#define GPGCONSLP_OFFSET 0xCC +#define GPGPUDSLP_OFFSET 0xD0 +#define GPHCON0_OFFSET 0xE0 +#define GPHCON1_OFFSET 0xE4 +#define GPHDAT_OFFSET 0xE8 +#define GPHPUD_OFFSET 0xEC +#define GPHCONSLP_OFFSET 0xF0 +#define GPHPUDSLP_OFFSET 0xF4 +#define GPICON_OFFSET 0x100 +#define GPIDAT_OFFSET 0x104 +#define GPIPUD_OFFSET 0x108 +#define GPICONSLP_OFFSET 0x10C +#define GPIPUDSLP_OFFSET 0x110 +#define GPJCON_OFFSET 0x120 +#define GPJDAT_OFFSET 0x124 +#define GPJPUD_OFFSET 0x128 +#define GPJCONSLP_OFFSET 0x12C +#define GPJPUDSLP_OFFSET 0x130 +#define MEM0DRVCON_OFFSET 0x1D0 +#define MEM1DRVCON_OFFSET 0x1D4 +#define GPKCON0_OFFSET 0x800 +#define GPKCON1_OFFSET 0x804 +#define GPKDAT_OFFSET 0x808 +#define GPKPUD_OFFSET 0x80C +#define GPLCON0_OFFSET 0x810 +#define GPLCON1_OFFSET 0x814 +#define GPLDAT_OFFSET 0x818 +#define GPLPUD_OFFSET 0x81C +#define GPMCON_OFFSET 0x820 +#define GPMDAT_OFFSET 0x824 +#define GPMPUD_OFFSET 0x828 +#define GPNCON_OFFSET 0x830 +#define GPNDAT_OFFSET 0x834 +#define GPNPUD_OFFSET 0x838 +#define GPOCON_OFFSET 0x140 +#define GPODAT_OFFSET 0x144 +#define GPOPUD_OFFSET 0x148 +#define GPOCONSLP_OFFSET 0x14C +#define GPOPUDSLP_OFFSET 0x150 +#define GPPCON_OFFSET 0x160 +#define GPPDAT_OFFSET 0x164 +#define GPPPUD_OFFSET 0x168 +#define GPPCONSLP_OFFSET 0x16C +#define GPPPUDSLP_OFFSET 0x170 +#define GPQCON_OFFSET 0x180 +#define GPQDAT_OFFSET 0x184 +#define GPQPUD_OFFSET 0x188 +#define GPQCONSLP_OFFSET 0x18C +#define GPQPUDSLP_OFFSET 0x190 + +#define EINTPEND_OFFSET 0x924 + +#define GPACON_REG __REG(ELFIN_GPIO_BASE+GPACON_OFFSET) +#define GPADAT_REG __REG(ELFIN_GPIO_BASE+GPADAT_OFFSET) +#define GPAPUD_REG __REG(ELFIN_GPIO_BASE+GPAPUD_OFFSET) +#define GPACONSLP_REG __REG(ELFIN_GPIO_BASE+GPACONSLP_OFFSET) +#define GPAPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPAPUDSLP_OFFSET) +#define GPBCON_REG __REG(ELFIN_GPIO_BASE+GPBCON_OFFSET) +#define GPBDAT_REG __REG(ELFIN_GPIO_BASE+GPBDAT_OFFSET) +#define GPBPUD_REG __REG(ELFIN_GPIO_BASE+GPBPUD_OFFSET) +#define GPBCONSLP_REG __REG(ELFIN_GPIO_BASE+GPBCONSLP_OFFSET) +#define GPBPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPBPUDSLP_OFFSET) +#define GPCCON_REG __REG(ELFIN_GPIO_BASE+GPCCON_OFFSET) +#define GPCDAT_REG __REG(ELFIN_GPIO_BASE+GPCDAT_OFFSET) +#define GPCPUD_REG __REG(ELFIN_GPIO_BASE+GPCPUD_OFFSET) +#define GPCCONSLP_REG __REG(ELFIN_GPIO_BASE+GPCCONSLP_OFFSET) +#define GPCPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPCPUDSLP_OFFSET) +#define GPDCON_REG __REG(ELFIN_GPIO_BASE+GPDCON_OFFSET) +#define GPDDAT_REG __REG(ELFIN_GPIO_BASE+GPDDAT_OFFSET) +#define GPDPUD_REG __REG(ELFIN_GPIO_BASE+GPDPUD_OFFSET) +#define GPDCONSLP_REG __REG(ELFIN_GPIO_BASE+GPDCONSLP_OFFSET) +#define GPDPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPDPUDSLP_OFFSET) +#define GPECON_REG __REG(ELFIN_GPIO_BASE+GPECON_OFFSET) +#define GPEDAT_REG __REG(ELFIN_GPIO_BASE+GPEDAT_OFFSET) +#define GPEPUD_REG __REG(ELFIN_GPIO_BASE+GPEPUD_OFFSET) +#define GPECONSLP_REG __REG(ELFIN_GPIO_BASE+GPECONSLP_OFFSET) +#define GPEPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPEPUDSLP_OFFSET) +#define GPFCON_REG __REG(ELFIN_GPIO_BASE+GPFCON_OFFSET) +#define GPFDAT_REG __REG(ELFIN_GPIO_BASE+GPFDAT_OFFSET) +#define GPFPUD_REG __REG(ELFIN_GPIO_BASE+GPFPUD_OFFSET) +#define GPFCONSLP_REG __REG(ELFIN_GPIO_BASE+GPFCONSLP_OFFSET) +#define GPFPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPFPUDSLP_OFFSET) +#define GPGCON_REG __REG(ELFIN_GPIO_BASE+GPGCON_OFFSET) +#define GPGDAT_REG __REG(ELFIN_GPIO_BASE+GPGDAT_OFFSET) +#define GPGPUD_REG __REG(ELFIN_GPIO_BASE+GPGPUD_OFFSET) +#define GPGCONSLP_REG __REG(ELFIN_GPIO_BASE+GPGCONSLP_OFFSET) +#define GPGPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPGPUDSLP_OFFSET) +#define GPHCON0_REG __REG(ELFIN_GPIO_BASE+GPHCON0_OFFSET) +#define GPHCON1_REG __REG(ELFIN_GPIO_BASE+GPHCON1_OFFSET) +#define GPHDAT_REG __REG(ELFIN_GPIO_BASE+GPHDAT_OFFSET) +#define GPHPUD_REG __REG(ELFIN_GPIO_BASE+GPHPUD_OFFSET) +#define GPHCONSLP_REG __REG(ELFIN_GPIO_BASE+GPHCONSLP_OFFSET) +#define GPHPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPHPUDSLP_OFFSET) +#define GPICON_REG __REG(ELFIN_GPIO_BASE+GPICON_OFFSET) +#define GPIDAT_REG __REG(ELFIN_GPIO_BASE+GPIDAT_OFFSET) +#define GPIPUD_REG __REG(ELFIN_GPIO_BASE+GPIPUD_OFFSET) +#define GPICONSLP_REG __REG(ELFIN_GPIO_BASE+GPICONSLP_OFFSET) +#define GPIPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPIPUDSLP_OFFSET) +#define GPJCON_REG __REG(ELFIN_GPIO_BASE+GPJCON_OFFSET) +#define GPJDAT_REG __REG(ELFIN_GPIO_BASE+GPJDAT_OFFSET) +#define GPJPUD_REG __REG(ELFIN_GPIO_BASE+GPJPUD_OFFSET) +#define GPJCONSLP_REG __REG(ELFIN_GPIO_BASE+GPJCONSLP_OFFSET) +#define GPJPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPJPUDSLP_OFFSET) +#define GPKCON0_REG __REG(ELFIN_GPIO_BASE+GPKCON0_OFFSET) +#define GPKCON1_REG __REG(ELFIN_GPIO_BASE+GPKCON1_OFFSET) +#define GPKDAT_REG __REG(ELFIN_GPIO_BASE+GPKDAT_OFFSET) +#define GPKPUD_REG __REG(ELFIN_GPIO_BASE+GPKPUD_OFFSET) +#define GPLCON0_REG __REG(ELFIN_GPIO_BASE+GPLCON0_OFFSET) +#define GPLCON1_REG __REG(ELFIN_GPIO_BASE+GPLCON1_OFFSET) +#define GPLDAT_REG __REG(ELFIN_GPIO_BASE+GPLDAT_OFFSET) +#define GPLPUD_REG __REG(ELFIN_GPIO_BASE+GPLPUD_OFFSET) +#define GPMCON_REG __REG(ELFIN_GPIO_BASE+GPMCON_OFFSET) +#define GPMDAT_REG __REG(ELFIN_GPIO_BASE+GPMDAT_OFFSET) +#define GPMPUD_REG __REG(ELFIN_GPIO_BASE+GPMPUD_OFFSET) +#define GPNCON_REG __REG(ELFIN_GPIO_BASE+GPNCON_OFFSET) +#define GPNDAT_REG __REG(ELFIN_GPIO_BASE+GPNDAT_OFFSET) +#define GPNPUD_REG __REG(ELFIN_GPIO_BASE+GPNPUD_OFFSET) +#define GPOCON_REG __REG(ELFIN_GPIO_BASE+GPOCON_OFFSET) +#define GPODAT_REG __REG(ELFIN_GPIO_BASE+GPODAT_OFFSET) +#define GPOPUD_REG __REG(ELFIN_GPIO_BASE+GPOPUD_OFFSET) +#define GPOCONSLP_REG __REG(ELFIN_GPIO_BASE+GPOCONSLP_OFFSET) +#define GPOPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPOPUDSLP_OFFSET) +#define GPPCON_REG __REG(ELFIN_GPIO_BASE+GPPCON_OFFSET) +#define GPPDAT_REG __REG(ELFIN_GPIO_BASE+GPPDAT_OFFSET) +#define GPPPUD_REG __REG(ELFIN_GPIO_BASE+GPPPUD_OFFSET) +#define GPPCONSLP_REG __REG(ELFIN_GPIO_BASE+GPPCONSLP_OFFSET) +#define GPPPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPPPUDSLP_OFFSET) +#define GPQCON_REG __REG(ELFIN_GPIO_BASE+GPQCON_OFFSET) +#define GPQDAT_REG __REG(ELFIN_GPIO_BASE+GPQDAT_OFFSET) +#define GPQPUD_REG __REG(ELFIN_GPIO_BASE+GPQPUD_OFFSET) +#define GPQCONSLP_REG __REG(ELFIN_GPIO_BASE+GPQCONSLP_OFFSET) +#define GPQPUDSLP_REG __REG(ELFIN_GPIO_BASE+GPQPUDSLP_OFFSET) + +/* + * Bus Matrix + */ +#define ELFIN_MEM_SYS_CFG 0x7e00f120 + +#define GPACON (ELFIN_GPIO_BASE+GPACON_OFFSET) +#define GPADAT (ELFIN_GPIO_BASE+GPADAT_OFFSET) +#define GPAPUD (ELFIN_GPIO_BASE+GPAPUD_OFFSET) +#define GPACONSLP (ELFIN_GPIO_BASE+GPACONSLP_OFFSET) +#define GPAPUDSLP (ELFIN_GPIO_BASE+GPAPUDSLP_OFFSET) +#define GPBCON (ELFIN_GPIO_BASE+GPBCON_OFFSET) +#define GPBDAT (ELFIN_GPIO_BASE+GPBDAT_OFFSET) +#define GPBPUD (ELFIN_GPIO_BASE+GPBPUD_OFFSET) +#define GPBCONSLP (ELFIN_GPIO_BASE+GPBCONSLP_OFFSET) +#define GPBPUDSLP (ELFIN_GPIO_BASE+GPBPUDSLP_OFFSET) +#define GPCCON (ELFIN_GPIO_BASE+GPCCON_OFFSET) +#define GPCDAT (ELFIN_GPIO_BASE+GPCDAT_OFFSET) +#define GPCPUD (ELFIN_GPIO_BASE+GPCPUD_OFFSET) +#define GPCCONSLP (ELFIN_GPIO_BASE+GPCCONSLP_OFFSET) +#define GPCPUDSLP (ELFIN_GPIO_BASE+GPCPUDSLP_OFFSET) +#define GPDCON (ELFIN_GPIO_BASE+GPDCON_OFFSET) +#define GPDDAT (ELFIN_GPIO_BASE+GPDDAT_OFFSET) +#define GPDPUD (ELFIN_GPIO_BASE+GPDPUD_OFFSET) +#define GPDCONSLP (ELFIN_GPIO_BASE+GPDCONSLP_OFFSET) +#define GPDPUDSLP (ELFIN_GPIO_BASE+GPDPUDSLP_OFFSET) +#define GPECON (ELFIN_GPIO_BASE+GPECON_OFFSET) +#define GPEDAT (ELFIN_GPIO_BASE+GPEDAT_OFFSET) +#define GPEPUD (ELFIN_GPIO_BASE+GPEPUD_OFFSET) +#define GPECONSLP (ELFIN_GPIO_BASE+GPECONSLP_OFFSET) +#define GPEPUDSLP (ELFIN_GPIO_BASE+GPEPUDSLP_OFFSET) +#define GPFCON (ELFIN_GPIO_BASE+GPFCON_OFFSET) +#define GPFDAT (ELFIN_GPIO_BASE+GPFDAT_OFFSET) +#define GPFPUD (ELFIN_GPIO_BASE+GPFPUD_OFFSET) +#define GPFCONSLP (ELFIN_GPIO_BASE+GPFCONSLP_OFFSET) +#define GPFPUDSLP (ELFIN_GPIO_BASE+GPFPUDSLP_OFFSET) +#define GPGCON (ELFIN_GPIO_BASE+GPGCON_OFFSET) +#define GPGDAT (ELFIN_GPIO_BASE+GPGDAT_OFFSET) +#define GPGPUD (ELFIN_GPIO_BASE+GPGPUD_OFFSET) +#define GPGCONSLP (ELFIN_GPIO_BASE+GPGCONSLP_OFFSET) +#define GPGPUDSLP (ELFIN_GPIO_BASE+GPGPUDSLP_OFFSET) +#define GPHCON0 (ELFIN_GPIO_BASE+GPHCON0_OFFSET) +#define GPHCON1 (ELFIN_GPIO_BASE+GPHCON1_OFFSET) +#define GPHDAT (ELFIN_GPIO_BASE+GPHDAT_OFFSET) +#define GPHPUD (ELFIN_GPIO_BASE+GPHPUD_OFFSET) +#define GPHCONSLP (ELFIN_GPIO_BASE+GPHCONSLP_OFFSET) +#define GPHPUDSLP (ELFIN_GPIO_BASE+GPHPUDSLP_OFFSET) +#define GPICON (ELFIN_GPIO_BASE+GPICON_OFFSET) +#define GPIDAT (ELFIN_GPIO_BASE+GPIDAT_OFFSET) +#define GPIPUD (ELFIN_GPIO_BASE+GPIPUD_OFFSET) +#define GPICONSLP (ELFIN_GPIO_BASE+GPICONSLP_OFFSET) +#define GPIPUDSLP (ELFIN_GPIO_BASE+GPIPUDSLP_OFFSET) +#define GPJCON (ELFIN_GPIO_BASE+GPJCON_OFFSET) +#define GPJDAT (ELFIN_GPIO_BASE+GPJDAT_OFFSET) +#define GPJPUD (ELFIN_GPIO_BASE+GPJPUD_OFFSET) +#define GPJCONSLP (ELFIN_GPIO_BASE+GPJCONSLP_OFFSET) +#define GPJPUDSLP (ELFIN_GPIO_BASE+GPJPUDSLP_OFFSET) +#define GPKCON0 (ELFIN_GPIO_BASE+GPKCON0_OFFSET) +#define GPKCON1 (ELFIN_GPIO_BASE+GPKCON1_OFFSET) +#define GPKDAT (ELFIN_GPIO_BASE+GPKDAT_OFFSET) +#define GPKPUD (ELFIN_GPIO_BASE+GPKPUD_OFFSET) +#define GPLCON0 (ELFIN_GPIO_BASE+GPLCON0_OFFSET) +#define GPLCON1 (ELFIN_GPIO_BASE+GPLCON1_OFFSET) +#define GPLDAT (ELFIN_GPIO_BASE+GPLDAT_OFFSET) +#define GPLPUD (ELFIN_GPIO_BASE+GPLPUD_OFFSET) +#define GPMCON (ELFIN_GPIO_BASE+GPMCON_OFFSET) +#define GPMDAT (ELFIN_GPIO_BASE+GPMDAT_OFFSET) +#define GPMPUD (ELFIN_GPIO_BASE+GPMPUD_OFFSET) +#define GPNCON (ELFIN_GPIO_BASE+GPNCON_OFFSET) +#define GPNDAT (ELFIN_GPIO_BASE+GPNDAT_OFFSET) +#define GPNPUD (ELFIN_GPIO_BASE+GPNPUD_OFFSET) +#define GPOCON (ELFIN_GPIO_BASE+GPOCON_OFFSET) +#define GPODAT (ELFIN_GPIO_BASE+GPODAT_OFFSET) +#define GPOPUD (ELFIN_GPIO_BASE+GPOPUD_OFFSET) +#define GPOCONSLP (ELFIN_GPIO_BASE+GPOCONSLP_OFFSET) +#define GPOPUDSLP (ELFIN_GPIO_BASE+GPOPUDSLP_OFFSET) +#define GPPCON (ELFIN_GPIO_BASE+GPPCON_OFFSET) +#define GPPDAT (ELFIN_GPIO_BASE+GPPDAT_OFFSET) +#define GPPPUD (ELFIN_GPIO_BASE+GPPPUD_OFFSET) +#define GPPCONSLP (ELFIN_GPIO_BASE+GPPCONSLP_OFFSET) +#define GPPPUDSLP (ELFIN_GPIO_BASE+GPPPUDSLP_OFFSET) +#define GPQCON (ELFIN_GPIO_BASE+GPQCON_OFFSET) +#define GPQDAT (ELFIN_GPIO_BASE+GPQDAT_OFFSET) +#define GPQPUD (ELFIN_GPIO_BASE+GPQPUD_OFFSET) +#define GPQCONSLP (ELFIN_GPIO_BASE+GPQCONSLP_OFFSET) +#define GPQPUDSLP (ELFIN_GPIO_BASE+GPQPUDSLP_OFFSET) + +/* + * Memory controller + */ +#define ELFIN_SROM_BASE 0x70000000 + +#define SROM_BW_REG __REG(ELFIN_SROM_BASE+0x0) +#define SROM_BC0_REG __REG(ELFIN_SROM_BASE+0x4) +#define SROM_BC1_REG __REG(ELFIN_SROM_BASE+0x8) +#define SROM_BC2_REG __REG(ELFIN_SROM_BASE+0xC) +#define SROM_BC3_REG __REG(ELFIN_SROM_BASE+0x10) +#define SROM_BC4_REG __REG(ELFIN_SROM_BASE+0x14) +#define SROM_BC5_REG __REG(ELFIN_SROM_BASE+0x18) + +/* + * SDRAM Controller + */ +#define ELFIN_DMC0_BASE 0x7e000000 +#define ELFIN_DMC1_BASE 0x7e001000 + +#define INDEX_DMC_MEMC_STATUS (0x00) +#define INDEX_DMC_MEMC_CMD (0x04) +#define INDEX_DMC_DIRECT_CMD (0x08) +#define INDEX_DMC_MEMORY_CFG (0x0C) +#define INDEX_DMC_REFRESH_PRD (0x10) +#define INDEX_DMC_CAS_LATENCY (0x14) +#define INDEX_DMC_T_DQSS (0x18) +#define INDEX_DMC_T_MRD (0x1C) +#define INDEX_DMC_T_RAS (0x20) +#define INDEX_DMC_T_RC (0x24) +#define INDEX_DMC_T_RCD (0x28) +#define INDEX_DMC_T_RFC (0x2C) +#define INDEX_DMC_T_RP (0x30) +#define INDEX_DMC_T_RRD (0x34) +#define INDEX_DMC_T_WR (0x38) +#define INDEX_DMC_T_WTR (0x3C) +#define INDEX_DMC_T_XP (0x40) +#define INDEX_DMC_T_XSR (0x44) +#define INDEX_DMC_T_ESR (0x48) +#define INDEX_DMC_MEMORY_CFG2 (0x4C) +#define INDEX_DMC_CHIP_0_CFG (0x200) +#define INDEX_DMC_CHIP_1_CFG (0x204) +#define INDEX_DMC_CHIP_2_CFG (0x208) +#define INDEX_DMC_CHIP_3_CFG (0x20C) +#define INDEX_DMC_USER_STATUS (0x300) +#define INDEX_DMC_USER_CONFIG (0x304) + +/* + * Memory Chip direct command + */ +#define DMC_NOP0 0x0c0000 +#define DMC_NOP1 0x1c0000 +#define DMC_PA0 0x000000 /* Precharge all */ +#define DMC_PA1 0x100000 +#define DMC_AR0 0x040000 /* Autorefresh */ +#define DMC_AR1 0x140000 +#define DMC_SDR_MR0 0x080032 /* MRS, CAS 3, Burst Length 4 */ +#define DMC_SDR_MR1 0x180032 +#define DMC_DDR_MR0 0x080162 +#define DMC_DDR_MR1 0x180162 +#define DMC_mDDR_MR0 0x080032 /* CAS 3, Burst Length 4 */ +#define DMC_mDDR_MR1 0x180032 +#define DMC_mSDR_EMR0 0x0a0000 /* EMRS, DS:Full, PASR:Full Array */ +#define DMC_mSDR_EMR1 0x1a0000 +#define DMC_DDR_EMR0 0x090000 +#define DMC_DDR_EMR1 0x190000 +#define DMC_mDDR_EMR0 0x0a0000 /* DS:Full, PASR:Full Array */ +#define DMC_mDDR_EMR1 0x1a0000 + +/**************************************************************** + Definitions for memory configuration + Set memory configuration + active_chips = 1'b0 (1 chip) + qos_master_chip = 3'b000(ARID[3:0]) + memory burst = 3'b010(burst 4) + stop_mem_clock = 1'b0(disable dynamical stop) + auto_power_down = 1'b0(disable auto power-down mode) + power_down_prd = 6'b00_0000(0 cycle for auto power-down) + ap_bit = 1'b0 (bit position of auto-precharge is 10) + row_bits = 3'b010(# row address 13) + column_bits = 3'b010(# column address 10 ) + + Set user configuration + 2'b10=SDRAM/mSDRAM, 2'b11=DDR, 2'b01=mDDR + + Set chip select for chip [n] + row bank control, bank address 0x3000_0000 ~ 0x37ff_ffff + CHIP_[n]_CFG=0x30F8, 30: ADDR[31:24], F8: Mask[31:24] +******************************************************************/ + +/* + * Nand flash controller + */ +#define ELFIN_NAND_BASE 0x70200000 + +#define NFCONF_OFFSET 0x00 +#define NFCONT_OFFSET 0x04 +#define NFCMMD_OFFSET 0x08 +#define NFADDR_OFFSET 0x0c +#define NFDATA_OFFSET 0x10 +#define NFMECCDATA0_OFFSET 0x14 +#define NFMECCDATA1_OFFSET 0x18 +#define NFSECCDATA0_OFFSET 0x1c +#define NFSBLK_OFFSET 0x20 +#define NFEBLK_OFFSET 0x24 +#define NFSTAT_OFFSET 0x28 +#define NFESTAT0_OFFSET 0x2c +#define NFESTAT1_OFFSET 0x30 +#define NFMECC0_OFFSET 0x34 +#define NFMECC1_OFFSET 0x38 +#define NFSECC_OFFSET 0x3c +#define NFMLCBITPT_OFFSET 0x40 + +#define NFCONF (ELFIN_NAND_BASE+NFCONF_OFFSET) +#define NFCONT (ELFIN_NAND_BASE+NFCONT_OFFSET) +#define NFCMMD (ELFIN_NAND_BASE+NFCMMD_OFFSET) +#define NFADDR (ELFIN_NAND_BASE+NFADDR_OFFSET) +#define NFDATA (ELFIN_NAND_BASE+NFDATA_OFFSET) +#define NFMECCDATA0 (ELFIN_NAND_BASE+NFMECCDATA0_OFFSET) +#define NFMECCDATA1 (ELFIN_NAND_BASE+NFMECCDATA1_OFFSET) +#define NFSECCDATA0 (ELFIN_NAND_BASE+NFSECCDATA0_OFFSET) +#define NFSBLK (ELFIN_NAND_BASE+NFSBLK_OFFSET) +#define NFEBLK (ELFIN_NAND_BASE+NFEBLK_OFFSET) +#define NFSTAT (ELFIN_NAND_BASE+NFSTAT_OFFSET) +#define NFESTAT0 (ELFIN_NAND_BASE+NFESTAT0_OFFSET) +#define NFESTAT1 (ELFIN_NAND_BASE+NFESTAT1_OFFSET) +#define NFMECC0 (ELFIN_NAND_BASE+NFMECC0_OFFSET) +#define NFMECC1 (ELFIN_NAND_BASE+NFMECC1_OFFSET) +#define NFSECC (ELFIN_NAND_BASE+NFSECC_OFFSET) +#define NFMLCBITPT (ELFIN_NAND_BASE+NFMLCBITPT_OFFSET) + +#define NFCONF_REG __REG(ELFIN_NAND_BASE+NFCONF_OFFSET) +#define NFCONT_REG __REG(ELFIN_NAND_BASE+NFCONT_OFFSET) +#define NFCMD_REG __REG(ELFIN_NAND_BASE+NFCMMD_OFFSET) +#define NFADDR_REG __REG(ELFIN_NAND_BASE+NFADDR_OFFSET) +#define NFDATA_REG __REG(ELFIN_NAND_BASE+NFDATA_OFFSET) +#define NFDATA8_REG __REGb(ELFIN_NAND_BASE+NFDATA_OFFSET) +#define NFMECCDATA0_REG __REG(ELFIN_NAND_BASE+NFMECCDATA0_OFFSET) +#define NFMECCDATA1_REG __REG(ELFIN_NAND_BASE+NFMECCDATA1_OFFSET) +#define NFSECCDATA0_REG __REG(ELFIN_NAND_BASE+NFSECCDATA0_OFFSET) +#define NFSBLK_REG __REG(ELFIN_NAND_BASE+NFSBLK_OFFSET) +#define NFEBLK_REG __REG(ELFIN_NAND_BASE+NFEBLK_OFFSET) +#define NFSTAT_REG __REG(ELFIN_NAND_BASE+NFSTAT_OFFSET) +#define NFESTAT0_REG __REG(ELFIN_NAND_BASE+NFESTAT0_OFFSET) +#define NFESTAT1_REG __REG(ELFIN_NAND_BASE+NFESTAT1_OFFSET) +#define NFMECC0_REG __REG(ELFIN_NAND_BASE+NFMECC0_OFFSET) +#define NFMECC1_REG __REG(ELFIN_NAND_BASE+NFMECC1_OFFSET) +#define NFSECC_REG __REG(ELFIN_NAND_BASE+NFSECC_OFFSET) +#define NFMLCBITPT_REG __REG(ELFIN_NAND_BASE+NFMLCBITPT_OFFSET) + +#define NFCONF_ECC_4BIT (1<<24) + +#define NFCONT_ECC_ENC (1<<18) +#define NFCONT_WP (1<<16) +#define NFCONT_MECCLOCK (1<<7) +#define NFCONT_SECCLOCK (1<<6) +#define NFCONT_INITMECC (1<<5) +#define NFCONT_INITSECC (1<<4) +#define NFCONT_INITECC (NFCONT_INITMECC | NFCONT_INITSECC) +#define NFCONT_CS_ALT (1<<2) +#define NFCONT_CS (1<<1) +#define NFCONT_ENABLE (1<<0) + +#define NFSTAT_ECCENCDONE (1<<7) +#define NFSTAT_ECCDECDONE (1<<6) +#define NFSTAT_RnB (1<<0) + +#define NFESTAT0_ECCBUSY (1<<31) + +/* + * Interrupt + */ +#define ELFIN_VIC0_BASE_ADDR 0x71200000 +#define ELFIN_VIC1_BASE_ADDR 0x71300000 +#define oINTMOD 0x0C /* VIC INT SELECT (IRQ or FIQ) */ +#define oINTUNMSK 0x10 /* VIC INT EN (Unmask by writing 1) */ +#define oINTMSK 0x14 /* VIC INT EN CLEAR (Mask by writing 1) */ +#define oINTSUBMSK 0x1C /* VIC SOFT INT CLEAR */ +#define oVECTADDR 0xF00 /* VIC ADDRESS */ + +/* + * Watchdog timer + */ +#define ELFIN_WATCHDOG_BASE 0x7E004000 + +#define WTCON_REG __REG(0x7E004004) +#define WTDAT_REG __REG(0x7E004008) +#define WTCNT_REG __REG(0x7E00400C) + + +/* + * UART + */ +#define ELFIN_UART_BASE 0x7F005000 + +#define ELFIN_UART0_OFFSET 0x0000 +#define ELFIN_UART1_OFFSET 0x0400 +#define ELFIN_UART2_OFFSET 0x0800 + +#define ULCON_OFFSET 0x00 +#define UCON_OFFSET 0x04 +#define UFCON_OFFSET 0x08 +#define UMCON_OFFSET 0x0C +#define UTRSTAT_OFFSET 0x10 +#define UERSTAT_OFFSET 0x14 +#define UFSTAT_OFFSET 0x18 +#define UMSTAT_OFFSET 0x1C +#define UTXH_OFFSET 0x20 +#define URXH_OFFSET 0x24 +#define UBRDIV_OFFSET 0x28 +#define UDIVSLOT_OFFSET 0x2C +#define UINTP_OFFSET 0x30 +#define UINTSP_OFFSET 0x34 +#define UINTM_OFFSET 0x38 + +#define ULCON0_REG __REG(0x7F005000) +#define UCON0_REG __REG(0x7F005004) +#define UFCON0_REG __REG(0x7F005008) +#define UMCON0_REG __REG(0x7F00500C) +#define UTRSTAT0_REG __REG(0x7F005010) +#define UERSTAT0_REG __REG(0x7F005014) +#define UFSTAT0_REG __REG(0x7F005018) +#define UMSTAT0_REG __REG(0x7F00501c) +#define UTXH0_REG __REG(0x7F005020) +#define URXH0_REG __REG(0x7F005024) +#define UBRDIV0_REG __REG(0x7F005028) +#define UDIVSLOT0_REG __REG(0x7F00502c) +#define UINTP0_REG __REG(0x7F005030) +#define UINTSP0_REG __REG(0x7F005034) +#define UINTM0_REG __REG(0x7F005038) + +#define ULCON1_REG __REG(0x7F005400) +#define UCON1_REG __REG(0x7F005404) +#define UFCON1_REG __REG(0x7F005408) +#define UMCON1_REG __REG(0x7F00540C) +#define UTRSTAT1_REG __REG(0x7F005410) +#define UERSTAT1_REG __REG(0x7F005414) +#define UFSTAT1_REG __REG(0x7F005418) +#define UMSTAT1_REG __REG(0x7F00541c) +#define UTXH1_REG __REG(0x7F005420) +#define URXH1_REG __REG(0x7F005424) +#define UBRDIV1_REG __REG(0x7F005428) +#define UDIVSLOT1_REG __REG(0x7F00542c) +#define UINTP1_REG __REG(0x7F005430) +#define UINTSP1_REG __REG(0x7F005434) +#define UINTM1_REG __REG(0x7F005438) + +#define UTRSTAT_TX_EMPTY (1 << 2) +#define UTRSTAT_RX_READY (1 << 0) +#define UART_ERR_MASK 0xF + +/* + * PWM timer + */ +#define ELFIN_TIMER_BASE 0x7F006000 + +#define TCFG0_REG __REG(0x7F006000) +#define TCFG1_REG __REG(0x7F006004) +#define TCON_REG __REG(0x7F006008) +#define TCNTB0_REG __REG(0x7F00600c) +#define TCMPB0_REG __REG(0x7F006010) +#define TCNTO0_REG __REG(0x7F006014) +#define TCNTB1_REG __REG(0x7F006018) +#define TCMPB1_REG __REG(0x7F00601c) +#define TCNTO1_REG __REG(0x7F006020) +#define TCNTB2_REG __REG(0x7F006024) +#define TCMPB2_REG __REG(0x7F006028) +#define TCNTO2_REG __REG(0x7F00602c) +#define TCNTB3_REG __REG(0x7F006030) +#define TCMPB3_REG __REG(0x7F006034) +#define TCNTO3_REG __REG(0x7F006038) +#define TCNTB4_REG __REG(0x7F00603c) +#define TCNTO4_REG __REG(0x7F006040) + +/* Fields */ +#define fTCFG0_DZONE Fld(8, 16) /* the dead zone length (= timer 0) */ +#define fTCFG0_PRE1 Fld(8, 8) /* prescaler value for time 2,3,4 */ +#define fTCFG0_PRE0 Fld(8, 0) /* prescaler value for time 0,1 */ +#define fTCFG1_MUX4 Fld(4, 16) +/* bits */ +#define TCFG0_DZONE(x) FInsrt((x), fTCFG0_DZONE) +#define TCFG0_PRE1(x) FInsrt((x), fTCFG0_PRE1) +#define TCFG0_PRE0(x) FInsrt((x), fTCFG0_PRE0) +#define TCON_4_AUTO (1 << 22) /* auto reload on/off for Timer 4 */ +#define TCON_4_UPDATE (1 << 21) /* manual Update TCNTB4 */ +#define TCON_4_ONOFF (1 << 20) /* 0: Stop, 1: start Timer 4 */ +#define COUNT_4_ON (TCON_4_ONOFF * 1) +#define COUNT_4_OFF (TCON_4_ONOFF * 0) +#define TCON_3_AUTO (1 << 19) /* auto reload on/off for Timer 3 */ +#define TIMER3_ATLOAD_ON (TCON_3_AUTO * 1) +#define TIMER3_ATLAOD_OFF FClrBit(TCON, TCON_3_AUTO) +#define TCON_3_INVERT (1 << 18) /* 1: Inverter on for TOUT3 */ +#define TIMER3_IVT_ON (TCON_3_INVERT * 1) +#define TIMER3_IVT_OFF (FClrBit(TCON, TCON_3_INVERT)) +#define TCON_3_MAN (1 << 17) /* manual Update TCNTB3,TCMPB3 */ +#define TIMER3_MANUP (TCON_3_MAN*1) +#define TIMER3_NOP (FClrBit(TCON, TCON_3_MAN)) +#define TCON_3_ONOFF (1 << 16) /* 0: Stop, 1: start Timer 3 */ +#define TIMER3_ON (TCON_3_ONOFF * 1) +#define TIMER3_OFF (FClrBit(TCON, TCON_3_ONOFF)) + +#if defined(CONFIG_CLK_400_100_50) +#define Startup_AMDIV 400 +#define Startup_MDIV 400 +#define Startup_PDIV 6 +#define Startup_SDIV 1 +#elif defined(CONFIG_CLK_400_133_66) +#define Startup_AMDIV 400 +#define Startup_MDIV 533 +#define Startup_PDIV 6 +#define Startup_SDIV 1 +#elif defined(CONFIG_CLK_533_133_66) +#define Startup_AMDIV 533 +#define Startup_MDIV 533 +#define Startup_PDIV 6 +#define Startup_SDIV 1 +#elif defined(CONFIG_CLK_667_133_66) +#define Startup_AMDIV 667 +#define Startup_MDIV 533 +#define Startup_PDIV 6 +#define Startup_SDIV 1 +#endif + +#define Startup_PCLKdiv 3 +#define Startup_HCLKx2div 1 +#define Startup_HCLKdiv 1 +#define Startup_MPLLdiv 1 +#define Startup_APLLdiv 0 + +#define CLK_DIV_VAL ((Startup_PCLKdiv << 12) | (Startup_HCLKx2div << 9)| \ + (Startup_HCLKdiv << 8) | (Startup_MPLLdiv<<4) | Startup_APLLdiv) +#define MPLL_VAL ((1 << 31) | (Startup_MDIV << 16) | \ + (Startup_PDIV << 8) | Startup_SDIV) +#define Startup_MPLL (((CONFIG_SYS_CLK_FREQ >> Startup_SDIV) / \ + Startup_PDIV) * Startup_MDIV) + +#if defined(CONFIG_SYNC_MODE) +#define APLL_VAL ((1 << 31) | (Startup_MDIV << 16) | \ + (Startup_PDIV << 8) | Startup_SDIV) +#define Startup_APLL (((CONFIG_SYS_CLK_FREQ >> Startup_SDIV) / \ + Startup_PDIV) * Startup_MDIV) +#define Startup_HCLK (Startup_MPLL / (Startup_HCLKx2div + 1) / \ + (Startup_HCLKdiv + 1)) +#else +#define APLL_VAL ((1 << 31) | (Startup_AMDIV << 16) | \ + (Startup_PDIV << 8) | Startup_SDIV) +#define Startup_APLL (((CONFIG_SYS_CLK_FREQ >> Startup_SDIV) / \ + Startup_PDIV) * Startup_AMDIV) +#define Startup_HCLK (Startup_MPLL / (Startup_HCLKx2div + 1) / \ + (Startup_HCLKdiv + 1)) +#endif + + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define DMC1_MEM_CFG 0x80010012 /* Chip1, Burst4, Row/Column bit */ +#define DMC1_MEM_CFG2 0xB45 +#define DMC1_CHIP0_CFG 0x150F8 /* 0x4000_0000 ~ 0x43ff_ffff (64MB) */ +#define DMC_DDR_32_CFG 0x0 /* 32bit, DDR */ + +/* Memory Parameters */ +/* DDR Parameters */ +#define DDR_tREFRESH 7800 /* ns */ +#define DDR_tRAS 45 /* ns (min: 45ns)*/ +#define DDR_tRC 68 /* ns (min: 67.5ns)*/ +#define DDR_tRCD 23 /* ns (min: 22.5ns)*/ +#define DDR_tRFC 80 /* ns (min: 80ns)*/ +#define DDR_tRP 23 /* ns (min: 22.5ns)*/ +#define DDR_tRRD 15 /* ns (min: 15ns)*/ +#define DDR_tWR 15 /* ns (min: 15ns)*/ +#define DDR_tXSR 120 /* ns (min: 120ns)*/ +#define DDR_CASL 3 /* CAS Latency 3 */ + +/* + * mDDR memory configuration + */ +#define DMC_DDR_BA_EMRS 2 +#define DMC_DDR_MEM_CASLAT 3 +/* 6 Set Cas Latency to 3 */ +#define DMC_DDR_CAS_LATENCY (DDR_CASL << 1) +/* Min 0.75 ~ 1.25 */ +#define DMC_DDR_t_DQSS 1 +/* Min 2 tck */ +#define DMC_DDR_t_MRD 2 +/* 7, Min 45ns */ +#define DMC_DDR_t_RAS (((Startup_HCLK/1000*DDR_tRAS)-1)/1000000+1) +/* 10, Min 67.5ns */ +#define DMC_DDR_t_RC (((Startup_HCLK/1000*DDR_tRC)-1)/1000000+1) +/* 4,5(TRM), Min 22.5ns */ +#define DMC_DDR_t_RCD (((Startup_HCLK/1000*DDR_tRCD)-1)/1000000+1) +#define DMC_DDR_schedule_RCD ((DMC_DDR_t_RCD - 3) << 3) +/* 11,18(TRM) Min 80ns */ +#define DMC_DDR_t_RFC (((Startup_HCLK/1000*DDR_tRFC)-1)/1000000+1) +#define DMC_DDR_schedule_RFC ((DMC_DDR_t_RFC - 3) << 5) +/* 4, 5(TRM) Min 22.5ns */ +#define DMC_DDR_t_RP (((Startup_HCLK/1000*DDR_tRP)-1)/1000000+1) +#define DMC_DDR_schedule_RP ((DMC_DDR_t_RP - 3) << 3) +/* 3, Min 15ns */ +#define DMC_DDR_t_RRD (((Startup_HCLK/1000*DDR_tRRD)-1)/1000000+1) +/* Min 15ns */ +#define DMC_DDR_t_WR (((Startup_HCLK/1000*DDR_tWR)-1)/1000000+1) +#define DMC_DDR_t_WTR 2 +/* 1tck + tIS(1.5ns) */ +#define DMC_DDR_t_XP 2 +/* 17, Min 120ns */ +#define DMC_DDR_t_XSR (((Startup_HCLK/1000*DDR_tXSR)-1)/1000000+1) +#define DMC_DDR_t_ESR DMC_DDR_t_XSR +/* TRM 2656 */ +#define DMC_DDR_REFRESH_PRD (((Startup_HCLK/1000*DDR_tREFRESH)-1)/1000000) +/* 2b01 : mDDR */ +#define DMC_DDR_USER_CONFIG 1 + +#ifndef __ASSEMBLY__ +enum s3c64xx_uarts_nr { + S3C64XX_UART0, + S3C64XX_UART1, + S3C64XX_UART2, +}; + +#include "s3c64x0.h" + +static inline s3c64xx_uart *s3c64xx_get_base_uart(enum s3c64xx_uarts_nr nr) +{ + return (s3c64xx_uart *)(ELFIN_UART_BASE + (nr * 0x400)); +} +#endif + +#endif /*__S3C6400_H__*/ diff --git a/include/s3c64x0.h b/include/s3c64x0.h new file mode 100644 index 0000000..ba6802a --- /dev/null +++ b/include/s3c64x0.h @@ -0,0 +1,92 @@ +/* + * (C) Copyright 2003 + * David MÃŒller ELSOFT AG Switzerland. d.mueller@elsoft.ch + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************ + * NAME : S3C64XX.h + * Version : 31.3.2003 + * + * common stuff for SAMSUNG S3C64XX SoC + ************************************************/ + +#ifndef __S3C64XX_H__ +#define __S3C64XX_H__ + +#if defined(CONFIG_SYNC_MODE) && defined(CONFIG_S3C6400) +#error CONFIG_SYNC_MODE unavailable on S3C6400, please, fix your configuration! +#endif + +typedef vu_char S3C64XX_REG8; +typedef vu_short S3C64XX_REG16; +typedef vu_long S3C64XX_REG32; + +/* UART (see manual chapter 11) */ +typedef struct { + S3C64XX_REG32 ULCON; + S3C64XX_REG32 UCON; + S3C64XX_REG32 UFCON; + S3C64XX_REG32 UMCON; + S3C64XX_REG32 UTRSTAT; + S3C64XX_REG32 UERSTAT; + S3C64XX_REG32 UFSTAT; + S3C64XX_REG32 UMSTAT; +#ifdef __BIG_ENDIAN + S3C64XX_REG8 res1[3]; + S3C64XX_REG8 UTXH; + S3C64XX_REG8 res2[3]; + S3C64XX_REG8 URXH; +#else /* Little Endian */ + S3C64XX_REG8 UTXH; + S3C64XX_REG8 res1[3]; + S3C64XX_REG8 URXH; + S3C64XX_REG8 res2[3]; +#endif + S3C64XX_REG32 UBRDIV; +#ifdef __BIG_ENDIAN + S3C64XX_REG8 res3[2]; + S3C64XX_REG16 UDIVSLOT; +#else + S3C64XX_REG16 UDIVSLOT; + S3C64XX_REG8 res3[2]; +#endif +} /*__attribute__((__packed__))*/ s3c64xx_uart; + +/* PWM TIMER (see manual chapter 10) */ +typedef struct { + S3C64XX_REG32 TCNTB; + S3C64XX_REG32 TCMPB; + S3C64XX_REG32 TCNTO; +} /*__attribute__((__packed__))*/ s3c64xx_timer; + +typedef struct { + S3C64XX_REG32 TCFG0; + S3C64XX_REG32 TCFG1; + S3C64XX_REG32 TCON; + s3c64xx_timer ch[4]; + S3C64XX_REG32 TCNTB4; + S3C64XX_REG32 TCNTO4; +} /*__attribute__((__packed__))*/ s3c64xx_timers; + +#endif /*__S3C64XX_H__*/
diff --git a/cpu/arm1176/s3c64xx/interrupts.c b/cpu/arm1176/s3c64xx/interrupts.c new file mode 100644 index 0000000..4233e8c --- /dev/null +++ b/cpu/arm1176/s3c64xx/interrupts.c
You can remove anything from enable_interrupts() to do_irq() here. It's already in lib_arm/interrupts.c.
Andreas
It must be the library-linking procedure, that prevented the linker from complaining about duplicate symbols... Yes, will remove them, thanks. Just let's wait a bit if there are more comments.
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Guennadi Liakhovetski schrieb:
Based on the original S3C64XX port by Samsung for U-Boot 1.1.6.
Signed-off-by: Guennadi Liakhovetski lg@denx.de
cpu/arm1176/Makefile | 50 ++ cpu/arm1176/config.mk | 35 ++ cpu/arm1176/cpu.c | 189 +++++++ cpu/arm1176/s3c64xx/Makefile | 48 ++ cpu/arm1176/s3c64xx/config.mk | 34 ++ cpu/arm1176/s3c64xx/cpu_init.S | 142 +++++ cpu/arm1176/s3c64xx/interrupts.c | 280 ++++++++++ cpu/arm1176/s3c64xx/speed.c | 140 +++++ cpu/arm1176/start.S | 469 ++++++++++++++++ include/asm-arm/arch-s3c64xx/hardware.h | 63 +++ include/common.h | 3 +- include/s3c6400.h | 884 +++++++++++++++++++++++++++++++ include/s3c64x0.h | 92 ++++
Is it intended to put the CPU specific header files directly into the include directory (s3c6400.h and s3c64x0.h)?
Kind regards, Jens
That's what we've been doing so far:
-> ls -l include/s3c* -rw-rw-r-- 1 wd wd 21763 Dec 9 2007 include/s3c2400.h -rw-rw-r-- 1 wd wd 7629 Dec 9 2007 include/s3c2410.h -rw-rw-r-- 1 wd wd 38129 Oct 13 2007 include/s3c24x0.h
Sorry, don't understand. So is it okay, that these files reside in the include directory or not?
Unless you want to submit a clenaup patch for many existing processors, yes.
What is your suggestion instead?
It was just a question to read your opinion. Personally, I can live with it. I thought, CPU specific header files had to go to the include/asm-<arch>/arch-<cpu> directory.
Sorry for the noise.
Kind regards, Jens
Currently the kernel start move to move it to include/arch/asm
I'll prefer to use this
Best Regards, J.
Hi Guennadi,
[snip]
- unsigned long long tmp;
- ulong tmo;
- tmo = (usec + 9) / 10;
- tmp = get_ticks() + tmo; /* get current timestamp */
- while (get_ticks() < tmp)/* loop till event */
/*NOP*/;
I tried to follow the interrupt init function, but it's difficult. What is the least possible delay with the udelay function? I remember that i.mx31 udelay cannot currently be below 30 microsseconds due to the low input clock. If someone uses udelay(1) in polling loops with timeout, the actual duration is much more longer than assumed.
Kind regards, Jens
On Thu, 7 Aug 2008, Jens Gehrlein wrote:
Hi Guennadi,
[snip]
- ulong tmo;
/*NOP*/;
Actually, the "/ 10" and this comment
/* * We use the following scheme for the timer: * Prescaler is hard fixed at 167, divider at 1/4. * This gives at PCLK frequency 66MHz approx. 10us ticks * The timer is set to wrap after 100s, at 66MHz this obviously * happens after 10,000,000 ticks. A long variable can thus * keep values up to 40,000s, i.e., 11 hours. This should be * enough for most uses:-) Possible optimizations: select a * binary-friendly frequency, e.g., 1ms / 128. Also calculate * the prescaler automatically for other PCLK frequencies. */
shall make it clear, that the timer resolution is configured to 10us, which is also the minimum udelay. The timer could also do better, but then we get other disadvantages, e.g., shorter wrap-around time.
Hi Guennadi,
Hi Guennadi,
[snip]
- ulong tmo;
/*NOP*/;
Okay. Thank you. I think, it's very useful for a developer to know the limits of high resolution timers and to see it immediately, so he can consider it in his code.
Kind regards, Jens
+void dcache_disable (void) +{
- ulong reg;
- reg = read_p15_c1 ();
- cp_delay ();
- reg &= ~C1_DC;
- write_p15_c1 (reg);
why not as the other implementation?
- write_p15_c1 (reg & ~C1_DC);
+int dcache_status (void) +{
- return (read_p15_c1 () & C1_DC) != 0;
+/* flush I/D-cache */ +static void cache_flush (void) +{
- /* invalidate both caches and flush btb */
- asm ("mcr p15, 0, %0, c7, c7, 0": :"r" (0));
- /* mem barrier to sync things */
- asm ("mcr p15, 0, %0, c7, c10, 4": :"r" (0));
- /* Set timer frequency to 500KHz, at 66MHz we get prescaler=132 < 255 */
- timers->TCFG0 = PRESCALER << 8;
- if (timer_load_val == 0) {
* for 10 ms clock period @ PCLK with 4 bit divider = 1/2 and
* prescaler = 16. Should be 10390 @33.25MHz and 15625 @ 50 MHz
timer_load_val = get_PCLK() / PRESCALER * (100 / 4); /* 100s */
/*printf("Calculated %lu timer_load_val\n", timer_load_val);*/
please remove if not need
timers->TCFG1 = (timers->TCFG1 & ~0xf0000) | 0x20000;
please add some empty line to be more readable
- /* load value for 10 ms timeout */
- lastdec = timers->TCNTB4 = timer_load_val;
- /* auto load, manual update of Timer 4 */
- timers->TCON = (timers->TCON & ~0x00700000) | TCON_4_AUTO |
TCON_4_UPDATE;
- /* auto load, start Timer 4 */
- timers->TCON = (timers->TCON & ~0x00700000) | TCON_4_AUTO | COUNT_4_ON;
- timestamp = 0;
- timer without interrupts
- This function is derived from PowerPC code (read timebase as long long).
- On ARM it just returns the timer value.
+unsigned long long get_ticks(void) +{
- ulong now = read_timer();
- if (lastdec >= now) {
/* normal mode */
- NOTE: This describes the proper use of this file.
- CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL.
- get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of
- the specified bus in HZ.
please not uppercase
- ulong r, m, p, s;
- if (pllreg == APLL)
r = APLL_CON_REG;
- else if (pllreg == MPLL)
r = MPLL_CON_REG;
- else if (pllreg == EPLL)
r = EPLL_CON0_REG;
- else
hang();
please move to switch implementation
- m = (r >> 16) & 0x3ff;
- p = (r >> 8) & 0x3f;
- s = r & 0x7;
- return m * (CONFIG_SYS_CLK_FREQ / (p * (1 << s)));
- ulong div;
- div = CLK_DIV0_REG;
- return get_PLLCLK(APLL) / ((div & 0x7) + 1);
- return get_PLLCLK(APLL);
- ulong fclk;
- uint hclkx2_div = ((CLK_DIV0_REG >> 9) & 0x7) + 1;
- uint hclk_div = ((CLK_DIV0_REG >> 8) & 0x1) + 1;
- if (OTHERS_REG & 0x80)
- else
- return fclk / (hclk_div * hclkx2_div);
- ulong fclk;
- uint pre_div = ((CLK_DIV0_REG >> 12) & 0xf) + 1;
- else
- return fclk / (hclkx2_div * pre_div);
- return get_PLLCLK(EPLL);
- printf("\nCPU: S3C6400@%luMHz\n", get_ARMCLK() / 1000000);
- printf(" Fclk = %luMHz, Hclk = %luMHz, Pclk = %luMHz ",
maybe a macro like HZ_TO_MHZ(x) could be helpfull to avoid typo
- else
- armboot - Startup Code for S3C6400/ARM1176 CPU-core
- Copyright (c) 2007 Samsung Electronics
- Copyright (C) 2008
- Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de
- project.
- MA 02111-1307 USA
- 2007-09-21 - Restructured codes by jsgood (jsgood.yang@samsung.com)
- 2007-09-21 - Added MoviNAND and OneNAND boot codes by
- jsgood (jsgood.yang@samsung.com)
- Base codes by scsuh (sc.suh)
- .word _start
- These are defined in the board-specific linker script.
- .word __bss_start
- .word _end
- the actual reset code
+reset:
please add space between parameter
- mrs r0,cpsr
- bic r0,r0,#0x3f
- orr r0,r0,#0xd3
- msr cpsr,r0
- CPU_init_critical registers
- setup important registers
- setup memory timing
- defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400)
Is it possible to have a better and simpler ifdef?
^^^^^^^^^^^ please remove whitesapce
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
Ditto
btw on all macro please add space beetwen operator like
to #define NFCONF_REG __REG(ELFIN_NAND_BASE + NFCONF_OFFSET)
for macro I'll prefer upercase
- Physical Memory Map
^ whitespace please remove
- mDDR memory configuration
+#define DMC_DDR_MEM_CASLAT 3 +/* 6 Set Cas Latency to 3 */ +#define DMC_DDR_CAS_LATENCY (DDR_CASL << 1) +/* Min 0.75 ~ 1.25 */ --- /dev/null +++ b/include/s3c64x0.h @@ -0,0 +1,92 @@ +/*
- (C) Copyright 2003
- David MÃŒller ELSOFT AG Switzerland. d.mueller@elsoft.ch
- (C) Copyright 2008
- project.
- MA 02111-1307 USA
- NAME : S3C64XX.h
- Version : 31.3.2003
- common stuff for SAMSUNG S3C64XX SoC
I'll prefer you use the type directly
- S3C64XX_REG32 ULCON;
- S3C64XX_REG32 UCON;
- S3C64XX_REG32 UFCON;
- S3C64XX_REG32 UMCON;
- S3C64XX_REG32 UTRSTAT;
- S3C64XX_REG32 UERSTAT;
- S3C64XX_REG32 UFSTAT;
- S3C64XX_REG32 UMSTAT;
- S3C64XX_REG8 res1[3];
- S3C64XX_REG8 UTXH;
- S3C64XX_REG8 res2[3];
- S3C64XX_REG8 URXH;
- S3C64XX_REG32 UBRDIV;
- S3C64XX_REG8 res3[2];
- S3C64XX_REG16 UDIVSLOT;
+#else
why do you remove the packed attribute?
- S3C64XX_REG32 TCNTB;
- S3C64XX_REG32 TCMPB;
- S3C64XX_REG32 TCNTO;
Ditto
+typedef struct {
- S3C64XX_REG32 TCFG0;
- S3C64XX_REG32 TCFG1;
- S3C64XX_REG32 TCON;
- s3c64xx_timer ch[4];
- S3C64XX_REG32 TCNTB4;
- S3C64XX_REG32 TCNTO4;
Ditto
Best Regards, J.
Or even better convert it into a debug() call so it can be enabled again for debugging purposes.
No. One empty line os enough here.
Not remove, but use TABs vor vertical alignment.
please add some empty line to be more readable for the following blocks
TCON_4_UPDATE;
timestamp = 0;
[snip]
That's my idea
Best Regards, J.
- ulong reg;
- cp_delay ();
- reg &= ~C1_DC;
ok
ok
TCON_4_UPDATE;
- timestamp = 0;
ok
+static ulong get_PLLCLK(int pllreg)
These are s3c* common functions declared in include/common.h, chenging their declarations is outside of the scope of this patchset (see below)
r = APLL_CON_REG;
r = MPLL_CON_REG;
r = EPLL_CON0_REG;
- else
hang();
ok
get_FCLK() / 1000000, get_HCLK() / 1000000,
get_PCLK() / 1000000);
Don't think such metric conversions deserve a macro.
- mrs r0,cpsr
- bic r0,r0,#0x3f
- orr r0,r0,#0xd3
- msr cpsr,r0
ok
It is possible and desirable to remove these declarations
from this header completely. Don't understand what they are doing in include/common.h. However, this is outside of the scope of this patchset. Please, if you will be fixing this, do this after this patchset.
ok
ok
ok
ok
put it back. Makes no _practical_ difference in this case.
Notice: USB on S3C6400 currently works _only_ with switched off MMU. One could try to enable the MMU, but map addresses 1-to-1, and disable data cache, then it should work too and we could still profit from instruction cache.
Signed-off-by: Guennadi Liakhovetski lg@denx.de --- cpu/arm1176/s3c64xx/Makefile | 1 + cpu/arm1176/s3c64xx/usb.c | 45 ++++++++++++++++++++++++++++++++++++++++++ drivers/usb/usb_ohci.c | 1 + 3 files changed, 47 insertions(+), 0 deletions(-) create mode 100644 cpu/arm1176/s3c64xx/usb.c
diff --git a/cpu/arm1176/s3c64xx/Makefile b/cpu/arm1176/s3c64xx/Makefile index fa4ee3f..4ab1811 100644 --- a/cpu/arm1176/s3c64xx/Makefile +++ b/cpu/arm1176/s3c64xx/Makefile @@ -30,6 +30,7 @@ LIB = $(obj)lib$(SOC).a
COBJS-y = interrupts.o COBJS-$(CONFIG_S3C6400) += cpu_init.o speed.o +COBJS-$(CONFIG_USB_OHCI_NEW) += usb.o
OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y))
diff --git a/cpu/arm1176/s3c64xx/usb.c b/cpu/arm1176/s3c64xx/usb.c new file mode 100644 index 0000000..274a4ed --- /dev/null +++ b/cpu/arm1176/s3c64xx/usb.c @@ -0,0 +1,45 @@ +/* + * URB OHCI HCD (Host Controller Driver) initialization for USB on the S3C64XX. + * + * Copyright (C) 2008, + * Guennadi Liakhovetski, DENX Software Engineering lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <s3c6400.h> + +int usb_cpu_init(void) +{ + OTHERS_REG |= 0x10000; + return 0; +} + +int usb_cpu_stop(void) +{ + OTHERS_REG &= ~0x10000; + return 0; +} + +void usb_cpu_init_fail(void) +{ + OTHERS_REG &= ~0x10000; +} diff --git a/drivers/usb/usb_ohci.c b/drivers/usb/usb_ohci.c index fd60edb..0bfa4d7 100644 --- a/drivers/usb/usb_ohci.c +++ b/drivers/usb/usb_ohci.c @@ -69,6 +69,7 @@ #if defined(CONFIG_ARM920T) || \ defined(CONFIG_S3C2400) || \ defined(CONFIG_S3C2410) || \ + defined(CONFIG_S3C6400) || \ defined(CONFIG_440EP) || \ defined(CONFIG_PCI_OHCI) || \ defined(CONFIG_MPC5200) || \
Guennadi Liakhovetski lg@denx.de writes:
Acked-by: Markus Klotzbuecher mk@denx.de
I can't apply this to the USB custodian repository without the rest of the patchset being applied. I'm also fine if the ARM custodian picks this one up.
Best regards
Markus
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
I'll do.
Thanks for the Ack
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com writes:
I'll do.
Thanks!
Best regards
Markus Klotzbücher
Based on the original S3C64XX UART driver by Samsung for U-Boot 1.1.6.
Signed-off-by: Guennadi Liakhovetski lg@denx.de --- drivers/serial/Makefile | 1 + drivers/serial/s3c64xx.c | 197 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 198 insertions(+), 0 deletions(-) create mode 100644 drivers/serial/s3c64xx.c
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index de6fbab..b1458f2 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -30,6 +30,7 @@ COBJS-$(CONFIG_MCFUART) += mcfuart.o COBJS-y += ns9750_serial.o COBJS-y += ns16550.o COBJS-$(CONFIG_DRIVER_S3C4510_UART) += s3c4510b_uart.o +COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-y += serial.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o COBJS-y += serial_pl010.o diff --git a/drivers/serial/s3c64xx.c b/drivers/serial/s3c64xx.c new file mode 100644 index 0000000..ce0fb91 --- /dev/null +++ b/drivers/serial/s3c64xx.c @@ -0,0 +1,197 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> + +#include <s3c6400.h> + +#ifdef CONFIG_SERIAL1 +#define UART_NR S3C64XX_UART0 + +#elif defined(CONFIG_SERIAL2) +#define UART_NR S3C64XX_UART1 + +#elif defined(CONFIG_SERIAL3) +#define UART_NR S3C64XX_UART2 + +#else +#error "Bad: you didn't configure serial ..." +#endif + +#define barrier() asm volatile("" ::: "memory") + +/* + * The coefficient, used to calculate the baudrate on S3C6400 UARTs is + * calculated as + * C = UBRDIV * 16 + number_of_set_bits_in_UDIVSLOT + * however, section 31.6.11 of the datasheet doesn't recomment using 1 for 1, + * 3 for 2, ... (2^n - 1) for n, instead, they suggest using these constants: + */ +static const int udivslot[] = { + 0, + 0x0080, + 0x0808, + 0x0888, + 0x2222, + 0x4924, + 0x4a52, + 0x54aa, + 0x5555, + 0xd555, + 0xd5d5, + 0xddd5, + 0xdddd, + 0xdfdd, + 0xdfdf, + 0xffdf, +}; + +void serial_setbrg(void) +{ + DECLARE_GLOBAL_DATA_PTR; + s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); + u32 reg; + u32 pclk_ratio = get_PCLK() / gd->baudrate; + int i; + + /* PCLK / (16 * baudrate) - 1 */ + reg = pclk_ratio / 16 - 1; + /* i = pclk_ratio % 16 */ + i = pclk_ratio - (reg + 1) * 16; + + uart->UBRDIV = reg; + uart->UDIVSLOT = udivslot[i]; + + for (i = 0; i < 100; i++) + barrier(); +} + +/* + * Initialise the serial port with the given baudrate. The settings + * are always 8 data bits, no parity, 1 stop bit, no start bits. + * + */ +int serial_init(void) +{ + s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); + + /* reset and enable FIFOs, set triggers to the maximum */ + uart->UFCON = 0xff; + uart->UMCON = 0; + /* 8N1 */ + uart->ULCON = 3; + /* No interrupts, no DMA, pure polling */ + uart->UCON = 5; + + serial_setbrg(); + + return 0; +} + +/* + * Read a single byte from the serial port. Returns 1 on success, 0 + * otherwise. When the function is succesfull, the character read is + * written into its argument c. + */ +int serial_getc(void) +{ + s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); + + /* wait for character to arrive */ + while (!(uart->UTRSTAT & 0x1)); + + return uart->URXH & 0xff; +} + +#ifdef CONFIG_HWFLOW +static int hwflow; /* turned off by default */ +int hwflow_onoff(int on) +{ + switch (on) { + case 1: + hwflow = 1; /* turn on */ + break; + case -1: + hwflow = 0; /* turn off */ + break; + } + return hwflow; +} +#endif + +#ifdef CONFIG_MODEM_SUPPORT +static int be_quiet; +void disable_putc(void) +{ + be_quiet = 1; +} + +void enable_putc(void) +{ + be_quiet = 0; +} +#endif + + +/* + * Output a single byte to the serial port. + */ +void serial_putc(const char c) +{ + s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); + +#ifdef CONFIG_MODEM_SUPPORT + if (be_quiet) + return; +#endif + + /* wait for room in the tx FIFO */ + while (!(uart->UTRSTAT & 0x2)); + +#ifdef CONFIG_HWFLOW + /* Wait for CTS up */ + while (hwflow && !(uart->UMSTAT & 0x1)); +#endif + + uart->UTXH = c; + + /* If \n, also do \r */ + if (c == '\n') + serial_putc('\r'); +} + +/* + * Test whether a character is in the RX buffer + */ +int serial_tstc(void) +{ + s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); + + return uart->UTRSTAT & 0x1; +} + +void serial_puts(const char *s) +{ + while (*s) + serial_putc(*s++); +}
- u32 reg;
- u32 pclk_ratio = get_PCLK() / gd->baudrate;
- int i;
IMHO it's still obscur
- /* PCLK / (16 * baudrate) - 1 */
- reg = pclk_ratio / 16 - 1;
- /* i = pclk_ratio % 16 */
- i = pclk_ratio - (reg + 1) * 16;
- uart->UBRDIV = reg;
- uart->UDIVSLOT = udivslot[i];
- for (i = 0; i < 100; i++)
barrier();
Best Regards, J.
- u32 reg;
- int i;
Sorry, I don't understand how this can be made clearer yet. If you have any specific ideas, please let me know now, before v7 appears, because I would really like to make it final.
Dear Guennadi Liakhovetski,
In message Pine.LNX.4.64.0808111042400.30591@axis700.grange you wrote:
- u32 reg;
- int i;
I don't see any baudrate in this calculation. From the comment I would expect to see
reg = pclk_ratio / (16 * gd->baudrate) - 1;
or similar. For the reader the comment is misleading as it is difficult to figure out that "PCLK" and "pclk_ratio" are not the same thing.
I don't see any % operation in this calculation. From the comment I would expect to see
i = pclk_ratio % 16;
or similar. Either the comment or the code or both are wrong.
Well, maybe the code and the comments should be in sync. Actually, if the comment just says the same as the code, it is redundant and should be omitted. If the comment tries to describe what the code implements in a different way that should be made clear, too.
Probably it doesn't make much sense to try to factor out common expressions when it makes thew code more difficult to read - the compiler is pretty clever about such things, too.
- u32 reg;
- int i;
Ok, pclk_ratio is, probably, not the best name for this.
I think, they are both correct by the way pclk_ration is calculated.
Ok, would this be better
u32 reg; u32 pclk = get_PCLK(); u32 baudrate = gd->baudrate; int i;
reg = pclk / baudrate / 16 - 1; i = (pclk / baudrate) % 16;
This way the compiler does optimize it to only one division, and the operations say what they do, and there doesn't seem to be any need for comment left. Still, the code produced by this is 1 asm instruction longer than my original code:-)
Dear Guennadi,
Is "reg" still used anywhere else?
Is the generated code equivalent? This smells like a subtle bug...
No, I'll remove it.
Don't see a bug there, both look correct. The C-code is different too - one uses "%", another one multiplication and subtraction, don't think it should be alarming that the resulting asm-code is different too.
Based on the original S3C64XX NAND driver by Samsung for U-Boot 1.1.6.
Changes since v5: now it actually works with nand-testing
drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/s3c64xx.c | 309 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 310 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/nand/s3c64xx.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index ffb3169..268a758 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -34,6 +34,7 @@ COBJS-y += nand_util.o
COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o COBJS-y += fsl_upm.o +COBJS-$(CONFIG_NAND_S3C64XX) += s3c64xx.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mtd/nand/s3c64xx.c b/drivers/mtd/nand/s3c64xx.c new file mode 100644 index 0000000..57a3b18 --- /dev/null +++ b/drivers/mtd/nand/s3c64xx.c @@ -0,0 +1,309 @@ +/* + * (C) Copyright 2006 DENX Software Engineering + * + * Implementation for U-Boot 1.1.6 by Samsung + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#include <nand.h> +#include <s3c6400.h> + +#include <asm/io.h> + +#ifdef CONFIG_NAND_SPL +#define printf(arg...) do {} while (0) +#endif + +/* Nand flash definition values by jsgood */ +#ifdef S3C_NAND_DEBUG +/* + * Function to print out oob buffer for debugging + * Written by jsgood + */ +static void print_oob(const char *header, struct mtd_info *mtd) +{ + int i; + struct nand_chip *chip = mtd->priv; + + printf("%s:\t", header); + + for (i = 0; i < 64; i++) + printf("%02x ", chip->oob_poi[i]); + + printf("\n"); +} +#endif /* S3C_NAND_DEBUG */ + +#ifdef CONFIG_NAND_SPL +static u_char nand_read_byte(struct mtd_info *mtd) +{ + struct nand_chip *this = mtd->priv; + return readb(this->IO_ADDR_R); +} + +static void nand_write_buf(struct mtd_info *mtd, const uint8_t *buf, int len) +{ + int i; + struct nand_chip *this = mtd->priv; + + for (i = 0; i < len; i++) + writeb(buf[i], this->IO_ADDR_W); +} + +static void nand_read_buf(struct mtd_info *mtd, u_char *buf, int len) +{ + int i; + struct nand_chip *this = mtd->priv; + + for (i = 0; i < len; i++) + buf[i] = readb(this->IO_ADDR_R); +} +#endif + +static void s3c_nand_select_chip(struct mtd_info *mtd, int chip) +{ + int ctrl = readl(NFCONT); + + switch (chip) { + case -1: + ctrl |= 6; + break; + case 0: + ctrl &= ~2; + break; + case 1: + ctrl &= ~4; + break; + default: + return; + } + + writel(ctrl, NFCONT); +} + +/* + * Hardware specific access to control-lines function + * Written by jsgood + */ +static void s3c_nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) +{ + struct nand_chip *this = mtd->priv; + + if (ctrl & NAND_CTRL_CHANGE) { + if (ctrl & NAND_CLE) + this->IO_ADDR_W = (void __iomem *)NFCMMD; + else if (ctrl & NAND_ALE) + this->IO_ADDR_W = (void __iomem *)NFADDR; + else + this->IO_ADDR_W = (void __iomem *)NFDATA; + if (ctrl & NAND_NCE) + s3c_nand_select_chip(mtd, 0); + else + s3c_nand_select_chip(mtd, -1); + } + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); +} + +/* + * Function for checking device ready pin + * Written by jsgood + */ +static int s3c_nand_device_ready(struct mtd_info *mtdinfo) +{ + while (!(readl(NFSTAT) & NFSTAT_RnB)) {} + return 1; +} + +#ifdef CFG_S3C_NAND_HWECC +/* + * This function is called before encoding ecc codes to ready ecc engine. + * Written by jsgood + */ +static void s3c_nand_enable_hwecc(struct mtd_info *mtd, int mode) +{ + u_long nfcont, nfconf; + + /* + * The original driver used 4-bit ECC for "new" MLC chips, i.e., for + * those with non-zero ID[3][3:2], which anyway only holds for ST + * (Numonyx) chips + */ + nfconf = readl(NFCONF) & ~NFCONF_ECC_4BIT; + + writel(nfconf, NFCONF); + + /* Initialize & unlock */ + nfcont = readl(NFCONT); + nfcont |= NFCONT_INITECC; + nfcont &= ~NFCONT_MECCLOCK; + + if (mode == NAND_ECC_WRITE) + nfcont |= NFCONT_ECC_ENC; + else if (mode == NAND_ECC_READ) + nfcont &= ~NFCONT_ECC_ENC; + + writel(nfcont, NFCONT); +} + +/* + * This function is called immediately after encoding ecc codes. + * This function returns encoded ecc codes. + * Written by jsgood + */ +static int s3c_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, + u_char *ecc_code) +{ + u_long nfcont, nfmecc0; + + /* Lock */ + nfcont = readl(NFCONT); + nfcont |= NFCONT_MECCLOCK; + writel(nfcont, NFCONT); + + nfmecc0 = readl(NFMECC0); + + ecc_code[0] = nfmecc0 & 0xff; + ecc_code[1] = (nfmecc0 >> 8) & 0xff; + ecc_code[2] = (nfmecc0 >> 16) & 0xff; + ecc_code[3] = (nfmecc0 >> 24) & 0xff; + + return 0; +} + +/* + * This function determines whether read data is good or not. + * If SLC, must write ecc codes to controller before reading status bit. + * If MLC, status bit is already set, so only reading is needed. + * If status bit is good, return 0. + * If correctable errors occured, do that. + * If uncorrectable errors occured, return -1. + * Written by jsgood + */ +static int s3c_nand_correct_data(struct mtd_info *mtd, u_char *dat, + u_char *read_ecc, u_char *calc_ecc) +{ + int ret = -1; + u_long nfestat0, nfmeccdata0, nfmeccdata1, err_byte_addr; + u_char err_type, repared; + + /* SLC: Write ecc to compare */ + nfmeccdata0 = (calc_ecc[1] << 16) | calc_ecc[0]; + nfmeccdata1 = (calc_ecc[3] << 16) | calc_ecc[2]; + writel(nfmeccdata0, NFMECCDATA0); + writel(nfmeccdata1, NFMECCDATA1); + + /* Read ecc status */ + nfestat0 = readl(NFESTAT0); + err_type = nfestat0 & 0x3; + + switch (err_type) { + case 0: /* No error */ + ret = 0; + break; + + case 1: + /* + * 1 bit error (Correctable) + * (nfestat0 >> 7) & 0x7ff :error byte number + * (nfestat0 >> 4) & 0x7 :error bit number + */ + err_byte_addr = (nfestat0 >> 7) & 0x7ff; + repared = dat[err_byte_addr] ^ (1 << ((nfestat0 >> 4) & 0x7)); + + printf("S3C NAND: 1 bit error detected at byte %ld. " + "Correcting from 0x%02x to 0x%02x...OK\n", + err_byte_addr, dat[err_byte_addr], repared); + + dat[err_byte_addr] = repared; + + ret = 1; + break; + + case 2: /* Multiple error */ + case 3: /* ECC area error */ + printf("S3C NAND: ECC uncorrectable error detected. " + "Not correctable.\n"); + ret = -1; + break; + } + + return ret; +} +#endif /* CFG_S3C_NAND_HWECC */ + +/* + * Board-specific NAND initialization. The following members of the + * argument are board-specific (per include/linux/mtd/nand.h): + * - IO_ADDR_R?: address to read the 8 I/O lines of the flash device + * - IO_ADDR_W?: address to write the 8 I/O lines of the flash device + * - hwcontrol: hardwarespecific function for accesing control-lines + * - dev_ready: hardwarespecific function for accesing device ready/busy line + * - enable_hwecc?: function to enable (reset) hardware ecc generator. Must + * only be provided if a hardware ECC is available + * - eccmode: mode of ecc, see defines + * - chip_delay: chip dependent delay for transfering data from array to + * read regs (tR) + * - options: various chip options. They can partly be set to inform + * nand_scan about special functionality. See the defines for further + * explanation + * Members with a "?" were not set in the merged testing-NAND branch, + * so they are not set here either. + */ +int board_nand_init(struct nand_chip *nand) +{ + NFCONT_REG = (NFCONT_REG & ~NFCONT_WP) | NFCONT_ENABLE | 0x6; + + nand->IO_ADDR_R = (void __iomem *)NFDATA; + nand->IO_ADDR_W = (void __iomem *)NFDATA; + nand->cmd_ctrl = s3c_nand_hwcontrol; + nand->dev_ready = s3c_nand_device_ready; + nand->select_chip = s3c_nand_select_chip; + nand->options = 0; +#ifdef CONFIG_NAND_SPL + nand->read_byte = nand_read_byte; + nand->write_buf = nand_write_buf; + nand->read_buf = nand_read_buf; +#endif + +#ifdef CFG_S3C_NAND_HWECC + nand->ecc.hwctl = s3c_nand_enable_hwecc; + nand->ecc.calculate = s3c_nand_calculate_ecc; + nand->ecc.correct = s3c_nand_correct_data; + + /* + * If you get more than 1 NAND-chip with different page-sizes on the + * board one day, it will get more complicated... + */ + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = CFG_NAND_ECCSIZE; + nand->ecc.bytes = CFG_NAND_ECCBYTES; +#else + nand->ecc.mode = NAND_ECC_SOFT; +#endif /* ! CFG_S3C_NAND_HWECC */ + + return 0; +}
On Wed, Aug 06, 2008 at 09:42:27PM +0200, Guennadi Liakhovetski wrote:
- if (ctrl & NAND_CTRL_CHANGE) {
else
else
What if select_chip(mtd, 1) had been called?
- Function for checking device ready pin
- Written by jsgood
- while (!(readl(NFSTAT) & NFSTAT_RnB)) {}
- return 1;
Might want a timeout here.
- u_char err_type, repared;
repaired
-Scott
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl driver for it too. The board can also boot from the NOR flash, but due to hardware limitations it can only address 64KiB on it, which is not enough for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6.
Changes since v5: adjust the configuration to more precisely desribe NAND ECC layout.
MAKEALL | 1 + Makefile | 17 ++ board/samsung/smdk6400/Makefile | 54 +++++ board/samsung/smdk6400/config.mk | 30 +++ board/samsung/smdk6400/lowlevel_init.S | 316 ++++++++++++++++++++++++++++ board/samsung/smdk6400/smdk6400.c | 130 ++++++++++++ board/samsung/smdk6400/u-boot-nand.lds | 62 ++++++ include/configs/smdk6400.h | 306 +++++++++++++++++++++++++++ nand_spl/board/samsung/smdk6400/Makefile | 106 ++++++++++ nand_spl/board/samsung/smdk6400/config.mk | 40 ++++ nand_spl/board/samsung/smdk6400/u-boot.lds | 61 ++++++ 11 files changed, 1123 insertions(+), 0 deletions(-) create mode 100644 board/samsung/smdk6400/Makefile create mode 100644 board/samsung/smdk6400/config.mk create mode 100644 board/samsung/smdk6400/lowlevel_init.S create mode 100644 board/samsung/smdk6400/smdk6400.c create mode 100644 board/samsung/smdk6400/u-boot-nand.lds create mode 100644 include/configs/smdk6400.h create mode 100644 nand_spl/board/samsung/smdk6400/Makefile create mode 100644 nand_spl/board/samsung/smdk6400/config.mk create mode 100644 nand_spl/board/samsung/smdk6400/u-boot.lds
diff --git a/MAKEALL b/MAKEALL index ee83cca..a3ed47d 100755 --- a/MAKEALL +++ b/MAKEALL @@ -515,6 +515,7 @@ LIST_ARM11=" \ imx31_litekit \ imx31_phycore \ mx31ads \ + smdk6400 \ "
######################################################################### diff --git a/Makefile b/Makefile index cb8c0f5..898b3f6 100644 --- a/Makefile +++ b/Makefile @@ -2686,6 +2686,23 @@ mx31ads_config : unconfig omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4 NULL omap24xx
+######################################################################### +## ARM1176 Systems +######################################################################### +smdk6400_noUSB_config \ +smdk6400_config : unconfig + @mkdir -p $(obj)include $(obj)board/samsung/smdk6400 + @mkdir -p $(obj)nand_spl/board/samsung/smdk6400 + @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h + @if [ -z "$(findstring smdk6400_noUSB_config,$@)" ]; then \ + echo "RAM_TEXT = 0x57e00000" >> $(obj)board/samsung/smdk6400/config.tmp;\ + $(MKCONFIG) $(@:_config=) arm arm1176 smdk6400 samsung s3c64xx; \ + else \ + echo "RAM_TEXT = 0xc7e00000" >> $(obj)board/samsung/smdk6400/config.tmp;\ + $(MKCONFIG) $(@:_noUSB_config=) arm arm1176 smdk6400 samsung s3c64xx; \ + fi + @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk + #======================================================================== # i386 #======================================================================== diff --git a/board/samsung/smdk6400/Makefile b/board/samsung/smdk6400/Makefile new file mode 100644 index 0000000..d35dc8b --- /dev/null +++ b/board/samsung/smdk6400/Makefile @@ -0,0 +1,54 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := smdk6400.o +SOBJS := lowlevel_init.o +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) crv $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +#.depend: Makefile $(SOBJS:.o=.S) $(OBJS:.o=.c) +# $(CC) -M $(CPPFLAGS) $(SOBJS:.o=.S) $(OBJS:.o=.c) > $@ + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/samsung/smdk6400/config.mk b/board/samsung/smdk6400/config.mk new file mode 100644 index 0000000..298d387 --- /dev/null +++ b/board/samsung/smdk6400/config.mk @@ -0,0 +1,30 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# SAMSUNG SMDK6400 board with mDirac3 (ARM1176) cpu +# +# see http://www.samsung.com/ for more information on SAMSUNG + +# On SMDK6400 we use the 64 MB SDRAM bank at +# +# 0x50000000 to 0x58000000 +# +# Linux-Kernel is expected to be at 0x50008000, entry 0x50008000 +# +# we load ourselves to 0x57e00000 without MMU +# with MMU, load address is changed to 0xc7e00000 +# +# download area is 0x5000c000 + +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef CONFIG_NAND_SPL +TEXT_BASE = $(RAM_TEXT) +else +TEXT_BASE = 0 +endif diff --git a/board/samsung/smdk6400/lowlevel_init.S b/board/samsung/smdk6400/lowlevel_init.S new file mode 100644 index 0000000..034c810 --- /dev/null +++ b/board/samsung/smdk6400/lowlevel_init.S @@ -0,0 +1,316 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and + * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) + * + * Modified for the Samsung SMDK2410 by + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#include <config.h> +#include <version.h> + +#include <s3c6400.h> + +#ifdef CONFIG_SERIAL1 +#define ELFIN_UART_CONSOLE_BASE (ELFIN_UART_BASE + ELFIN_UART0_OFFSET) +#elif defined(CONFIG_SERIAL2) +#define ELFIN_UART_CONSOLE_BASE (ELFIN_UART_BASE + ELFIN_UART1_OFFSET) +#else +#define ELFIN_UART_CONSOLE_BASE (ELFIN_UART_BASE + ELFIN_UART2_OFFSET) +#endif + +_TEXT_BASE: + .word TEXT_BASE + + .globl lowlevel_init +lowlevel_init: + mov r12, lr + + /* LED on only #8 */ + ldr r0, =ELFIN_GPIO_BASE + ldr r1, =0x55540000 + str r1, [r0, #GPNCON_OFFSET] + + ldr r1, =0x55555555 + str r1, [r0, #GPNPUD_OFFSET] + + ldr r1, =0xf000 + str r1, [r0, #GPNDAT_OFFSET] + + /* Disable Watchdog */ + ldr r0, =0x7e000000 @0x7e004000 + orr r0, r0, #0x4000 + mov r1, #0 + str r1, [r0] + + /* External interrupt pending clear */ + ldr r0, =(ELFIN_GPIO_BASE+EINTPEND_OFFSET) /*EINTPEND*/ + ldr r1, [r0] + str r1, [r0] + + ldr r0, =ELFIN_VIC0_BASE_ADDR @0x71200000 + ldr r1, =ELFIN_VIC1_BASE_ADDR @0x71300000 + + /* Disable all interrupts (VIC0 and VIC1) */ + mvn r3, #0x0 + str r3, [r0, #oINTMSK] + str r3, [r1, #oINTMSK] + + /* Set all interrupts as IRQ */ + mov r3, #0x0 + str r3, [r0, #oINTMOD] + str r3, [r1, #oINTMOD] + + /* Pending Interrupt Clear */ + mov r3, #0x0 + str r3, [r0, #oVECTADDR] + str r3, [r1, #oVECTADDR] + + /* init system clock */ + bl system_clock_init + +#ifndef CONFIG_NAND_SPL + /* for UART */ + bl uart_asm_init +#endif + +#ifdef CONFIG_BOOT_NAND + /* simple init for NAND */ + bl nand_asm_init +#endif + + bl mem_ctrl_asm_init + +/* Wakeup support. Don't know if it's going to be used, untested. */ + ldr r0, =(ELFIN_CLOCK_POWER_BASE + RST_STAT_OFFSET) + ldr r1, [r0] + bic r1, r1, #0xfffffff7 + cmp r1, #0x8 + beq wakeup_reset + +1: + mov lr, r12 + mov pc, lr + +wakeup_reset: + + /* Clear wakeup status register */ + ldr r0, =(ELFIN_CLOCK_POWER_BASE + WAKEUP_STAT_OFFSET) + ldr r1, [r0] + str r1, [r0] + + /* LED test */ + ldr r0, =ELFIN_GPIO_BASE + ldr r1, =0x3000 + str r1, [r0, #GPNDAT_OFFSET] + + /* Load return address and jump to kernel */ + ldr r0, =(ELFIN_CLOCK_POWER_BASE + INF_REG0_OFFSET) + /* r1 = physical address of s3c6400_cpu_resume function */ + ldr r1, [r0] + /* Jump to kernel (sleep-s3c6400.S) */ + mov pc, r1 + nop + nop +/* + * system_clock_init: Initialize core clock and bus clock. + * void system_clock_init(void) + */ +system_clock_init: + ldr r0, =ELFIN_CLOCK_POWER_BASE /* 0x7e00f000 */ + +#ifdef CONFIG_SYNC_MODE + ldr r1, [r0, #OTHERS_OFFSET] + mov r2, #0x40 + orr r1, r1, r2 + str r1, [r0, #OTHERS_OFFSET] + + nop + nop + nop + nop + nop + + ldr r2, =0x80 + orr r1, r1, r2 + str r1, [r0, #OTHERS_OFFSET] + +check_syncack: + ldr r1, [r0, #OTHERS_OFFSET] + ldr r2, =0xf00 + and r1, r1, r2 + cmp r1, #0xf00 + bne check_syncack +#else /* ASYNC Mode */ + nop + nop + nop + nop + nop + + /* + * This was unconditional in original Samsung sources, but it doesn't + * seem to make much sense on S3C6400. + */ +#ifndef CONFIG_S3C6400 + ldr r1, [r0, #OTHERS_OFFSET] + bic r1, r1, #0xC0 + orr r1, r1, #0x40 + str r1, [r0, #OTHERS_OFFSET] + +wait_for_async: + ldr r1, [r0, #OTHERS_OFFSET] + and r1, r1, #0xf00 + cmp r1, #0x0 + bne wait_for_async +#endif + + ldr r1, [r0, #OTHERS_OFFSET] + bic r1, r1, #0x40 + str r1, [r0, #OTHERS_OFFSET] +#endif + + mov r1, #0xff00 + orr r1, r1, #0xff + str r1, [r0, #APLL_LOCK_OFFSET] + str r1, [r0, #MPLL_LOCK_OFFSET] + + /* Set Clock Divider */ + ldr r1, [r0, #CLK_DIV0_OFFSET] + bic r1, r1, #0x30000 + bic r1, r1, #0xff00 + bic r1, r1, #0xff + ldr r2, =CLK_DIV_VAL + orr r1, r1, r2 + str r1, [r0, #CLK_DIV0_OFFSET] + + ldr r1, =APLL_VAL + str r1, [r0, #APLL_CON_OFFSET] + ldr r1, =MPLL_VAL + str r1, [r0, #MPLL_CON_OFFSET] + + /* FOUT of EPLL is 96MHz */ + ldr r1, =0x200203 + str r1, [r0, #EPLL_CON0_OFFSET] + ldr r1, =0x0 + str r1, [r0, #EPLL_CON1_OFFSET] + + /* APLL, MPLL, EPLL select to Fout */ + ldr r1, [r0, #CLK_SRC_OFFSET] + orr r1, r1, #0x7 + str r1, [r0, #CLK_SRC_OFFSET] + + /* wait at least 200us to stablize all clock */ + mov r1, #0x10000 +1: subs r1, r1, #1 + bne 1b + + /* Synchronization for VIC port */ +#if defined(CONFIG_SYNC_MODE) + ldr r1, [r0, #OTHERS_OFFSET] + orr r1, r1, #0x20 + str r1, [r0, #OTHERS_OFFSET] +#elif !defined(CONFIG_S3C6400) + /* According to 661558um_S3C6400X_rev10.pdf 0x20 is reserved */ + ldr r1, [r0, #OTHERS_OFFSET] + bic r1, r1, #0x20 + str r1, [r0, #OTHERS_OFFSET] +#endif + mov pc, lr + + +#ifndef CONFIG_NAND_SPL +/* + * uart_asm_init: Initialize UART's pins + */ +uart_asm_init: + /* set GPIO to enable UART */ + ldr r0, =ELFIN_GPIO_BASE + ldr r1, =0x220022 + str r1, [r0, #GPACON_OFFSET] + mov pc, lr +#endif + +#ifdef CONFIG_BOOT_NAND +/* + * NAND Interface init for SMDK6400 + */ +nand_asm_init: + ldr r0, =ELFIN_NAND_BASE + ldr r1, [r0, #NFCONF_OFFSET] + orr r1, r1, #0x70 + orr r1, r1, #0x7700 + str r1, [r0, #NFCONF_OFFSET] + + ldr r1, [r0, #NFCONT_OFFSET] + orr r1, r1, #0x07 + str r1, [r0, #NFCONT_OFFSET] + + mov pc, lr +#endif + +#ifdef CONFIG_ENABLE_MMU +/* + * MMU Table for SMDK6400 + */ + + /* form a first-level section entry */ +.macro FL_SECTION_ENTRY base,ap,d,c,b + .word (\base << 20) | (\ap << 10) | \ + (\d << 5) | (1<<4) | (\c << 3) | (\b << 2) | (1<<1) +.endm + +.section .mmudata, "a" + .align 14 + /* the following alignment creates the mmu table at address 0x4000. */ + .globl mmu_table +mmu_table: + .set __base, 0 + /* 1:1 mapping for debugging */ + .rept 0xA00 + FL_SECTION_ENTRY __base, 3, 0, 0, 0 + .set __base, __base + 1 + .endr + + /* access is not allowed. */ + .rept 0xC00 - 0xA00 + .word 0x00000000 + .endr + + /* 128MB for SDRAM 0xC0000000 -> 0x50000000 */ + .set __base, 0x500 + .rept 0xC80 - 0xC00 + FL_SECTION_ENTRY __base, 3, 0, 1, 1 + .set __base, __base + 1 + .endr + + /* access is not allowed. */ + .rept 0x1000 - 0xc80 + .word 0x00000000 + .endr +#endif diff --git a/board/samsung/smdk6400/smdk6400.c b/board/samsung/smdk6400/smdk6400.c new file mode 100644 index 0000000..77fd2c8 --- /dev/null +++ b/board/samsung/smdk6400/smdk6400.c @@ -0,0 +1,130 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <s3c6400.h> + +/* ------------------------------------------------------------------------- */ +#define CS8900_Tacs 0x0 /* 0clk address set-up */ +#define CS8900_Tcos 0x4 /* 4clk chip selection set-up */ +#define CS8900_Tacc 0xE /* 14clk access cycle */ +#define CS8900_Tcoh 0x1 /* 1clk chip selection hold */ +#define CS8900_Tah 0x4 /* 4clk address holding time */ +#define CS8900_Tacp 0x6 /* 6clk page mode access cycle */ +#define CS8900_PMC 0x0 /* normal(1data)page mode configuration */ + +static inline void delay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b" + : "=r" (loops) : "0" (loops)); +} + +/* + * Miscellaneous platform dependent initialisations + */ + +static void cs8900_pre_init(void) +{ + SROM_BW_REG &= ~(0xf << 4); + SROM_BW_REG |= (1 << 7) | (1 << 6) | (1 << 4); + SROM_BC1_REG = ((CS8900_Tacs << 28) + (CS8900_Tcos << 24) + + (CS8900_Tacc << 16) + (CS8900_Tcoh << 12) + + (CS8900_Tah << 8) + (CS8900_Tacp << 4) + CS8900_PMC); +} + +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + cs8900_pre_init(); + + /* NOR-flash in SROM0 */ + + /* Enable WAIT */ + SROM_BW_REG |= 4 | 8 | 1; + + gd->bd->bi_arch_number = MACH_TYPE; + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + printf("Board: SMDK6400\n"); + return 0; +} +#endif + +#ifdef CONFIG_ENABLE_MMU +ulong virt_to_phy_smdk6400(ulong addr) +{ + if ((0xc0000000 <= addr) && (addr < 0xc8000000)) + return addr - 0xc0000000 + 0x50000000; + else + printf("do not support this address : %08lx\n", addr); + + return addr; +} +#endif + +#if defined(CONFIG_CMD_NAND) && defined(CFG_NAND_LEGACY) +#include <linux/mtd/nand.h> +extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; +void nand_init(void) +{ + nand_probe(CFG_NAND_BASE); + if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) + print_size(nand_dev_desc[0].totlen, "\n"); +} +#endif + +ulong board_flash_get_legacy (ulong base, int banknum, flash_info_t *info) +{ + if (banknum == 0) { /* non-CFI boot flash */ + info->portwidth = FLASH_CFI_16BIT; + info->chipwidth = FLASH_CFI_BY16; + info->interface = FLASH_CFI_X16; + return 1; + } else + return 0; +} diff --git a/board/samsung/smdk6400/u-boot-nand.lds b/board/samsung/smdk6400/u-boot-nand.lds new file mode 100644 index 0000000..132ab21 --- /dev/null +++ b/board/samsung/smdk6400/u-boot-nand.lds @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm1176/start.o (.text) + cpu/arm1176/s3c64xx/cpu_init.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + .mmudata : { *(.mmudata) } + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h new file mode 100644 index 0000000..1bc8996 --- /dev/null +++ b/include/configs/smdk6400.h @@ -0,0 +1,306 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * Gary Jennejohn gj@denx.de + * David Mueller d.mueller@elsoft.ch + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * Configuation settings for the SAMSUNG SMDK6400(mDirac-III) board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_S3C6400 1 /* in a SAMSUNG S3C6400 SoC */ +#define CONFIG_S3C64XX 1 /* in a SAMSUNG S3C64XX Family */ +#define CONFIG_SMDK6400 1 /* on a SAMSUNG SMDK6400 Board */ + +#define CFG_SDRAM_BASE 0x50000000 + +/* input clock of PLL: SMDK6400 has 12MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 12000000 + +#if !defined(CONFIG_NAND_SPL) && (TEXT_BASE >= 0xc0000000) +#define CONFIG_ENABLE_MMU +#endif + +#define CONFIG_MEMORY_UPPER_CODE + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG + +/* + * Architecture magic and machine type + */ +#define MACH_TYPE 1270 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#undef CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 1024 * 1024) +#define CFG_GBL_DATA_SIZE 128 /* size in bytes for initial data */ + +/* + * Hardware drivers + */ +#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ +#define CS8900_BASE 0x18800300 +#define CS8900_BUS16 1 /* follow the Linux driver */ + +/* + * select serial console configuration + */ +#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SMDK6400 */ + +#define CFG_HUSH_PARSER /* use "hush" command parser */ +#ifdef CFG_HUSH_PARSER +#define CFG_PROMPT_HUSH_PS2 "> " +#endif + +#define CONFIG_CMDLINE_EDITING + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BAUDRATE 115200 + +/*********************************************************** + * Command definition + ***********************************************************/ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_ENV +#define CONFIG_CMD_NAND +#if defined(CONFIG_BOOT_ONENAND) +#define CONFIG_CMD_ONENAND +#endif +#define CONFIG_CMD_PING +#define CONFIG_CMD_ELF + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#if (CONFIG_COMMANDS & CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ +#endif + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "SMDK6400 # " /* Monitor Command Prompt */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE 384 /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START CFG_SDRAM_BASE /* memtest works on */ +#define CFG_MEMTEST_END (CFG_SDRAM_BASE + 0x7e00000) /* 126MB in DRAM */ + +#define CFG_LOAD_ADDR CFG_SDRAM_BASE /* default load address */ + +#define CFG_HZ 1000 + +/* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE 0x40000 /* regular stack 256KB */ + +/********************************** + Support Clock Settings + ********************************** + Setting SYNC ASYNC + ---------------------------------- + 667_133_66 X O + 533_133_66 O O + 400_133_66 X O + 400_100_50 O O + **********************************/ + +/*#define CONFIG_CLK_667_133_66*/ +#define CONFIG_CLK_533_133_66 +/* +#define CONFIG_CLK_400_100_50 +#define CONFIG_CLK_400_133_66 +#define CONFIG_SYNC_MODE +*/ + +/* SMDK6400 has 2 banks of DRAM, but we use only one in U-Boot */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CFG_SDRAM_BASE /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB in Bank #1 */ + +#define CFG_FLASH_BASE 0x10000000 +#define CFG_MONITOR_BASE 0x00000000 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +/* AM29LV160B has 35 sectors, AM29LV800B - 19 */ +#define CFG_MAX_FLASH_SECT 40 + +#define CONFIG_AMD_LV800 +#define CFG_FLASH_CFI 1 /* Use CFI parameters (needed?) */ +/* Use drivers/cfi_flash.c, even though the flash is not CFI-compliant */ +#define CFG_FLASH_CFI_DRIVER 1 +#define CFG_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_FLASH_CFI_LEGACY +#define CFG_FLASH_LEGACY_512Kx16 + +/* timeout values are in ticks */ +#define CFG_FLASH_ERASE_TOUT (5 * CFG_HZ) /* Timeout for Flash Erase */ +#define CFG_FLASH_WRITE_TOUT (5 * CFG_HZ) /* Timeout for Flash Write */ + +#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ + +/* + * SMDK6400 board specific data + */ + +#define CONFIG_IDENT_STRING " for SMDK6400" + +/* base address for uboot */ +#define CFG_PHY_UBOOT_BASE (CFG_SDRAM_BASE + 0x07e00000) +/* total memory available to uboot */ +#define CFG_UBOOT_SIZE (1024 * 1024) + +#ifdef CONFIG_ENABLE_MMU +#define CFG_MAPPED_RAM_BASE 0xc0000000 +#define CONFIG_BOOTCOMMAND "nand read 0xc0018000 0x60000 0x1c0000;" \ + "bootm 0xc0018000" +#else +#define CFG_MAPPED_RAM_BASE CFG_SDRAM_BASE +#define CONFIG_BOOTCOMMAND "nand read 0x50018000 0x60000 0x1c0000;" \ + "bootm 0x50018000" +#endif + +/* NAND U-Boot load and start address */ +#define CFG_UBOOT_BASE (CFG_MAPPED_RAM_BASE + 0x07e00000) + +#define CFG_ENV_OFFSET 0x0040000 + +/* NAND configuration */ +#define CFG_MAX_NAND_DEVICE 1 +#define CFG_NAND_BASE 0x70200010 +#define NAND_MAX_CHIPS 1 +#define CFG_S3C_NAND_HWECC + +#define CFG_NAND_SKIP_BAD_DOT_I 1 /* ".i" read skips bad blocks */ +#define CFG_NAND_WP 1 +#define CFG_NAND_YAFFS_WRITE 1 /* support yaffs write */ +#define CFG_NAND_BBT_2NDPAGE 1 /* bad-block markers in 1st and 2nd pages */ + +#define CFG_NAND_U_BOOT_DST CFG_PHY_UBOOT_BASE /* NUB load-addr */ +#define CFG_NAND_U_BOOT_START CFG_NAND_U_BOOT_DST /* NUB start-addr */ + +#define CFG_NAND_U_BOOT_OFFS (4 * 1024) /* Offset to RAM U-Boot image */ +#define CFG_NAND_U_BOOT_SIZE (252 * 1024) /* Size of RAM U-Boot image */ + +/* NAND chip page size */ +#define CFG_NAND_PAGE_SIZE 2048 +/* NAND chip block size */ +#define CFG_NAND_BLOCK_SIZE (128 * 1024) +/* NAND chip page per block count */ +#define CFG_NAND_PAGE_COUNT 64 +/* Location of the bad-block label */ +#define CFG_NAND_BAD_BLOCK_POS 0 +/* Extra address cycle for > 128MiB */ +#define CFG_NAND_5_ADDR_CYCLE + +/* Size of the block protected by one OOB (Spare Area in Samsung terminology) */ +#define CFG_NAND_ECCSIZE CFG_NAND_PAGE_SIZE +/* Number of ECC bytes per OOB - S3C6400 calculates 4 bytes ECC in 1-bit mode */ +#define CFG_NAND_ECCBYTES 4 +/* Number of ECC-blocks per NAND page */ +#define CFG_NAND_ECCSTEPS (CFG_NAND_PAGE_SIZE / CFG_NAND_ECCSIZE) +/* Size of a single OOB region */ +#define CFG_NAND_OOBSIZE 64 +/* Number of ECC bytes per page */ +#define CFG_NAND_ECCTOTAL (CFG_NAND_ECCBYTES * CFG_NAND_ECCSTEPS) +/* ECC byte positions */ +#define CFG_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47, \ + 48, 49, 50, 51, 52, 53, 54, 55, \ + 56, 57, 58, 59, 60, 61, 62, 63} + +/* Boot configuration (define only one of next 3) */ +#define CONFIG_BOOT_NAND +/* None of these are currently implemented. Left from the original Samsung + * version for reference +#define CONFIG_BOOT_NOR +#define CONFIG_BOOT_MOVINAND +#define CONFIG_BOOT_ONENAND +*/ + +#define CONFIG_NAND +#define CONFIG_NAND_S3C64XX +/* Unimplemented or unsupported. See comment above. +#define CONFIG_ONENAND +#define CONFIG_MOVINAND +*/ + +/* Settings as above boot configuration */ +#define CFG_ENV_IS_IN_NAND +#define CONFIG_BOOTARGS "console=ttySAC,115200" +#define CONFIG_EXTRA_ENV_SETTINGS "bootargs=" CONFIG_BOOTARGS + +#if !defined(CONFIG_ENABLE_MMU) +#define CONFIG_CMD_USB 1 +#define CONFIG_USB_OHCI_NEW 1 +#define CFG_USB_OHCI_REGS_BASE 0x74300000 +#define CFG_USB_OHCI_SLOT_NAME "s3c6400" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 3 +#define CFG_USB_OHCI_CPU_INIT 1 +#define LITTLEENDIAN 1 /* used by usb_ohci.c */ + +#define CONFIG_USB_STORAGE 1 +#endif +#define CONFIG_DOS_PARTITION 1 + +#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_ENABLE_MMU) +# error "usb_ohci.c is currently broken with MMU enabled." +#endif + +#endif /* __CONFIG_H */ diff --git a/nand_spl/board/samsung/smdk6400/Makefile b/nand_spl/board/samsung/smdk6400/Makefile new file mode 100644 index 0000000..ae9eb2a --- /dev/null +++ b/nand_spl/board/samsung/smdk6400/Makefile @@ -0,0 +1,106 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +CONFIG_NAND_SPL = y + +include $(TOPDIR)/config.mk +include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_NAND_SPL + +SOBJS = start.o cpu_init.o lowlevel_init.o +COBJS = nand_boot.o nand_ecc.o s3c64xx.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +# create symbolic links for common files + +# from cpu directory +$(obj)start.S: + @rm -f $@ + @ln -s $(TOPDIR)/cpu/arm1176/start.S $@ + +# from SoC directory +$(obj)cpu_init.S: + @rm -f $@ + @ln -s $(TOPDIR)/cpu/arm1176/s3c64xx/cpu_init.S $@ + +# from board directory +$(obj)lowlevel_init.S: + @rm -f $@ + @ln -s $(TOPDIR)/board/samsung/smdk6400/lowlevel_init.S $@ + +# from nand_spl directory +$(obj)nand_boot.c: + @rm -f $@ + @ln -s $(TOPDIR)/nand_spl/nand_boot.c $@ + +# from drivers/mtd/nand directory +$(obj)nand_ecc.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mtd/nand/nand_ecc.c $@ + +$(obj)s3c64xx.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mtd/nand/s3c64xx.c $@ + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/samsung/smdk6400/config.mk b/nand_spl/board/samsung/smdk6400/config.mk new file mode 100644 index 0000000..4b16230 --- /dev/null +++ b/nand_spl/board/samsung/smdk6400/config.mk @@ -0,0 +1,40 @@ +# +# (C) Copyright 2006 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# +# Samsung S3C64xx Reference Platform (smdk6400) board + +# TEXT_BASE for SPL: +# +# On S3C64xx platforms the SPL is located in SRAM at 0. +# +# TEXT_BASE = 0 + +include $(TOPDIR)/board/$(BOARDDIR)/config.mk + +# PAD_TO used to generate a 4kByte binary needed for the combined image +# -> PAD_TO = TEXT_BASE + 4096 +PAD_TO := $(shell expr $$[$(TEXT_BASE) + 4096]) + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif diff --git a/nand_spl/board/samsung/smdk6400/u-boot.lds b/nand_spl/board/samsung/smdk6400/u-boot.lds new file mode 100644 index 0000000..1bf022c --- /dev/null +++ b/nand_spl/board/samsung/smdk6400/u-boot.lds @@ -0,0 +1,61 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + start.o (.text) + cpu_init.o (.text) + nand_boot.o (.text) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +}
please add your entry in MAINTAINERS
- $(AR) crv $@ $(OBJS)
please keep this Makefile as other new style
ex from atmel board
COBJS-y += at91cap9adk.o COBJS-y += led.o COBJS-y += partition.o COBJS-$(CONFIG_CMD_NAND) += nand.o
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) SOBJS := $(addprefix $(obj),$(SOBJS))
$(LIB): $(obj).depend $(OBJS) $(SOBJS) $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
clean: rm -f $(SOBJS) $(OBJS)
distclean: clean rm -f $(LIB) core *.bak $(obj).depend
# defines $(obj).depend target include $(SRCTREE)/rules.mk
+ifndef CONFIG_NAND_SPL +TEXT_BASE = $(RAM_TEXT) +else +TEXT_BASE = 0 +endif +check_syncack:
- ldr r1, [r0, #OTHERS_OFFSET]
- ldr r2, =0xf00
- and r1, r1, r2
- cmp r1, #0xf00
- bne check_syncack
please use .rept
- nop
- nop
- nop
- nop
- nop
and please be carefull with whitespaces
index 0000000..77fd2c8 --- /dev/null +++ b/board/samsung/smdk6400/smdk6400.c @@ -0,0 +1,130 @@ +/* +static inline void delay(unsigned long loops) +{
- __asm__ volatile ("1:\n" "subs %0, %1, #1\n"
"bne 1b"
- Miscellaneous platform dependent initialisations
- nand_probe(CFG_NAND_BASE);
- if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN)
+} +#endif
- if (banknum == 0) { /* non-CFI boot flash */
return 1;
- } else
please replace with } else { return 0; }
or }
+} diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h new file mode 100644 index 0000000..1bc8996 --- /dev/null +++ b/include/configs/smdk6400.h @@ -0,0 +1,306 @@ +/* +#define CONFIG_SMDK6400 1 /* on a SAMSUNG SMDK6400 Board */
- Architecture magic and machine type
please use mach type from the hearder
- Size of malloc() pool
- Hardware drivers
please remove the whitespace
- select serial console configuration
do you really want the idef?
- Command definition
replace with #ifdef CONFIG_CMD_KGDB
- Miscellaneous configurable options
- Stack sizes
- The stack sizes are set up in start.S using the settings below
- Support Clock Settings
- Setting SYNC ASYNC
- 667_133_66 X O
- 533_133_66 O O
- 400_133_66 X O
- 400_100_50 O O
please remove if not need or use idef
Ditto
+/* SMDK6400 has 2 banks of DRAM, but we use only one in U-Boot */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CFG_SDRAM_BASE /* SDRAM Bank #1 */ +#define CONFIG_BOOT_MOVINAND +#define CONFIG_BOOT_ONENAND +*/
- $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@
- $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@
- cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \
please replace with $(nandobj)u-boot-spl: $(OBJS) cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ -Map $@.map -o $@
Best Regards, J.
participants (7)
Andreas Engel
Jens Gehrlein
Markus Klotzbücher
Scott Wood
