[U-Boot] [PATCH 1/1] Dockerfile: build GRUB UEFI target for RISC-V 64bit
Build GRUB UEFI target grubriscv64.efi. It is needed for running test_efi_grub_net().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- This patch applies to https://gitlab.denx.de/u-boot/gitlab-ci-runner --- Dockerfile | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/Dockerfile b/Dockerfile index 23d4042..d73fd10 100644 --- a/Dockerfile +++ b/Dockerfile @@ -112,6 +112,20 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot \ search search_fs_file search_fs_uuid search_label serial sleep test \ true && \ + make clean && \ + ./configure --target=riscv64 --with-platform=efi \ + CC=gcc \ + TARGET_CC=/opt/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc \ + TARGET_OBJCOPY=/opt/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy \ + TARGET_STRIP=/opt/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-strip \ + TARGET_NM=/opt/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-nm \ + TARGET_RANLIB=/opt/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && \ + make && \ + ./grub-mkimage -O riscv64-efi -o /opt/grub/grubriscv64.efi --prefix= -d \ + grub-core cat chain configfile echo efinet ext2 fat halt help linux \ + lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot \ + search search_fs_file search_fs_uuid search_label serial sleep test \ + true && \ rm -rf /tmp/grub
RUN git clone git://git.qemu.org/qemu.git /tmp/qemu && \ -- 2.20.1
Reviewed-by: Bin Meng bmeng.cn@gmail.com _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hello Tom,
the patch did not yet make it into
https://gitlab.denx.de/u-boot/gitlab-ci-runner.git
Anything I should do?
Best regards
Heinrich
Hello Tom,
Sorry, I assume this is blocking being able to then enable tests on the platform? If so, I'll go spin things around shortly and in the future feel free to poke me if I don't turn them around in a day or two.
Hello Tom,
Once we build grubriscv64.efi we can use it in the UEFI unit test test_efi_grub_net().
It is not high priority as Linux is still missing an EFI stub for RISC. I just wanted to avoid the patch sinking into oblivion.
Best regards
Heinrich
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Bin Meng bmeng.cn@gmail.com
Applied to u-boot-gitlab-ci-runner/master. Pushed and trini/u-boot-gitlab-ci-runner:xenial-20190720-13Sep2019 built, tagged and uploaded to docker. Thanks!
Bin Meng
