[U-Boot] [PATCH] net: phy: micrel: add an option to disable gigabit for the KSZ9031
The environment variable "disable_giga" can now be used to disable 1000baseTx on the Micrel's KSZ9031.
Signed-off-by: Sebastien Bourdelin sebastien.bourdelin@savoirfairelinux.com --- drivers/net/phy/micrel.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/drivers/net/phy/micrel.c b/drivers/net/phy/micrel.c index 0e4a4ebcc6..eeeba3c232 100644 --- a/drivers/net/phy/micrel.c +++ b/drivers/net/phy/micrel.c @@ -491,12 +491,39 @@ static int ksz9031_phy_extwrite(struct phy_device *phydev, int addr, static int ksz9031_config(struct phy_device *phydev) { int ret; + unsigned features; + unsigned bmcr = 0; + ret = ksz9031_of_config(phydev); if (ret) return ret; ret = ksz9031_center_flp_timing(phydev); if (ret) return ret; + + /* add an option to disable the gigabit feature of this PHY */ + if (getenv("disable_giga")) { + /* disable speed 1000 in features supported by the PHY */ + features = phydev->drv->features; + features &= ~(SUPPORTED_1000baseT_Half | + SUPPORTED_1000baseT_Full); + phydev->advertising = phydev->supported = features; + + /* disable speed 1000 in Basic Control Register */ + bmcr = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMCR); + bmcr &= ~(1 << 6); + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, bmcr); + + /* disable speed 1000 in 1000Base-T Control Register */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_CTRL1000, 0); + + /* start autoneg */ + genphy_config_aneg(phydev); + genphy_restart_aneg(phydev); + + return 0; + } + return genphy_config(phydev); }
On Fri, Jul 28, 2017 at 2:59 PM, Sebastien Bourdelin sebastien.bourdelin@savoirfairelinux.com wrote:
Other than one nit below... Acked-by: Joe Hershberger joe.hershberger@ni.com
unsigned features;
unsigned bmcr = 0;
Seems better to define these in the block where they are used and inconsistent initialization is odd. Neither need init since they are assigned as first use.
bmcr &= ~(1 << 6);
/* start autoneg */
-- 2.13.3
Joe Hershberger
Sebastien Bourdelin
