[U-Boot] [PATCH v2 02/29] binman: Rename 'position' to 'offset'
After some thought, I believe there is an unfortunate naming flaw in binman. Entries have a position and size, but now that we support hierarchical sections it is unclear whether a position should be an absolute position within the image, or a relative position within its parent section.
At present 'position' actually means the relative position. This indicates a need for an 'image position' for code that wants to find the location of an entry without having to do calculations back through parents to discover this image position.
A better name for the current 'position' or 'pos' is 'offset'. It is not always an absolute position, but it is always an offset from its parent offset.
It is unfortunate to rename this concept now, 18 months after binman was introduced. However I believe it is the right thing to do. The impact is mostly limited to binman itself and a few changes to in-tree users to binman:
tegra sunxi x86
The change makes old binman definitions (e.g. downstream or out-of-tree) incompatible if they use the 'pos = <...>' property. Later work will adjust binman to generate an error when it is used.
Changes in v2: - Adjust symbols in the U-Boot tree also
arch/arm/dts/sunxi-u-boot.dtsi | 2 +- arch/arm/dts/tegra-u-boot.dtsi | 6 +- arch/x86/dts/u-boot.dtsi | 24 ++--- common/spl/spl.c | 4 +- common/spl/spl_ram.c | 2 +- include/spl.h | 2 +- tools/binman/README | 79 ++++++++-------- tools/binman/bsection.py | 88 +++++++++--------- tools/binman/cmdline.py | 2 +- tools/binman/control.py | 4 +- tools/binman/elf.py | 6 +- tools/binman/entry.py | 73 ++++++++------- tools/binman/etype/_testing.py | 4 +- tools/binman/etype/intel_descriptor.py | 8 +- tools/binman/etype/section.py | 14 +-- tools/binman/etype/u_boot_dtb_with_ucode.py | 4 +- tools/binman/etype/u_boot_ucode.py | 4 +- tools/binman/etype/u_boot_with_ucode_ptr.py | 35 +++---- tools/binman/ftest.py | 85 +++++++++-------- tools/binman/image.py | 12 +-- tools/binman/test/08_pack.dts | 2 +- tools/binman/test/12_pack_inv_align.dts | 2 +- tools/binman/test/14_pack_overlap.dts | 2 +- tools/binman/test/21_image_pad.dts | 2 +- tools/binman/test/24_sorted.dts | 6 +- tools/binman/test/25_pack_zero_size.dts | 2 +- tools/binman/test/27_pack_4gb_no_size.dts | 6 +- tools/binman/test/28_pack_4gb_outside.dts | 6 +- tools/binman/test/29_x86-rom.dts | 6 +- tools/binman/test/30_x86-rom-me-no-desc.dts | 4 +- tools/binman/test/31_x86-rom-me.dts | 4 +- tools/binman/test/34_x86_ucode.dts | 2 +- tools/binman/test/35_x86_single_ucode.dts | 2 +- tools/binman/test/37_x86_no_ucode.dts | 2 +- .../binman/test/38_x86_ucode_missing_node.dts | 2 +- .../test/39_x86_ucode_missing_node2.dts | 2 +- .../binman/test/40_x86_ucode_not_in_image.dts | 2 +- tools/binman/test/44_x86_optional_ucode.dts | 2 +- tools/binman/test/45_prop_test.dts | 4 +- tools/binman/test/49_x86_ucode_spl.dts | 2 +- tools/binman/test/53_symbols.dts | 2 +- .../test/58_x86_ucode_spl_needs_retry.dts | 2 +- tools/binman/test/u_boot_binman_syms | Bin 4921 -> 4916 bytes tools/binman/test/u_boot_binman_syms.c | 6 +- 44 files changed, 267 insertions(+), 263 deletions(-)
diff --git a/arch/arm/dts/sunxi-u-boot.dtsi b/arch/arm/dts/sunxi-u-boot.dtsi index 5adfd9bca2e..8a9f2a6417d 100644 --- a/arch/arm/dts/sunxi-u-boot.dtsi +++ b/arch/arm/dts/sunxi-u-boot.dtsi @@ -8,7 +8,7 @@ filename = "spl/sunxi-spl.bin"; }; u-boot-img { - pos = <CONFIG_SPL_PAD_TO>; + offset = <CONFIG_SPL_PAD_TO>; }; }; }; diff --git a/arch/arm/dts/tegra-u-boot.dtsi b/arch/arm/dts/tegra-u-boot.dtsi index 4f692ee9757..fe19619919e 100644 --- a/arch/arm/dts/tegra-u-boot.dtsi +++ b/arch/arm/dts/tegra-u-boot.dtsi @@ -15,7 +15,7 @@ u-boot-spl { }; u-boot { - pos = <(U_BOOT_OFFSET)>; + offset = <(U_BOOT_OFFSET)>; }; };
@@ -26,7 +26,7 @@ u-boot-spl { }; u-boot { - pos = <(U_BOOT_OFFSET)>; + offset = <(U_BOOT_OFFSET)>; }; };
@@ -36,7 +36,7 @@ u-boot-spl { }; u-boot-nodtb { - pos = <(U_BOOT_OFFSET)>; + offset = <(U_BOOT_OFFSET)>; }; }; }; diff --git a/arch/x86/dts/u-boot.dtsi b/arch/x86/dts/u-boot.dtsi index 1253fa51c22..1050236330a 100644 --- a/arch/x86/dts/u-boot.dtsi +++ b/arch/x86/dts/u-boot.dtsi @@ -11,7 +11,7 @@ binman { filename = "u-boot.rom"; end-at-4gb; - sort-by-pos; + sort-by-offset; pad-byte = <0xff>; size = <CONFIG_ROM_SIZE>; #ifdef CONFIG_HAVE_INTEL_ME @@ -24,18 +24,18 @@ #endif #ifdef CONFIG_SPL u-boot-spl-with-ucode-ptr { - pos = <CONFIG_SPL_TEXT_BASE>; + offset = <CONFIG_SPL_TEXT_BASE>; };
u-boot-dtb-with-ucode2 { type = "u-boot-dtb-with-ucode"; }; u-boot { - pos = <0xfff00000>; + offset = <0xfff00000>; }; #else u-boot-with-ucode-ptr { - pos = <CONFIG_SYS_TEXT_BASE>; + offset = <CONFIG_SYS_TEXT_BASE>; }; #endif u-boot-dtb-with-ucode { @@ -45,45 +45,45 @@ }; #ifdef CONFIG_HAVE_MRC intel-mrc { - pos = <CONFIG_X86_MRC_ADDR>; + offset = <CONFIG_X86_MRC_ADDR>; }; #endif #ifdef CONFIG_HAVE_FSP intel-fsp { filename = CONFIG_FSP_FILE; - pos = <CONFIG_FSP_ADDR>; + offset = <CONFIG_FSP_ADDR>; }; #endif #ifdef CONFIG_HAVE_CMC intel-cmc { filename = CONFIG_CMC_FILE; - pos = <CONFIG_CMC_ADDR>; + offset = <CONFIG_CMC_ADDR>; }; #endif #ifdef CONFIG_HAVE_VGA_BIOS intel-vga { filename = CONFIG_VGA_BIOS_FILE; - pos = <CONFIG_VGA_BIOS_ADDR>; + offset = <CONFIG_VGA_BIOS_ADDR>; }; #endif #ifdef CONFIG_HAVE_VBT intel-vbt { filename = CONFIG_VBT_FILE; - pos = <CONFIG_VBT_ADDR>; + offset = <CONFIG_VBT_ADDR>; }; #endif #ifdef CONFIG_HAVE_REFCODE intel-refcode { - pos = <CONFIG_X86_REFCODE_ADDR>; + offset = <CONFIG_X86_REFCODE_ADDR>; }; #endif #ifdef CONFIG_SPL x86-start16-spl { - pos = <CONFIG_SYS_X86_START16>; + offset = <CONFIG_SYS_X86_START16>; }; #else x86-start16 { - pos = <CONFIG_SYS_X86_START16>; + offset = <CONFIG_SYS_X86_START16>; }; #endif }; diff --git a/common/spl/spl.c b/common/spl/spl.c index a1e7b9fa914..b959aa02549 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -34,7 +34,7 @@ DECLARE_GLOBAL_DATA_PTR; u32 *boot_params_ptr = NULL;
/* See spl.h for information about this */ -binman_sym_declare(ulong, u_boot_any, pos); +binman_sym_declare(ulong, u_boot_any, offset);
/* Define board data structure */ static bd_t bdata __attribute__ ((section(".data"))); @@ -129,7 +129,7 @@ __weak void spl_board_prepare_for_boot(void)
void spl_set_header_raw_uboot(struct spl_image_info *spl_image) { - ulong u_boot_pos = binman_sym(ulong, u_boot_any, pos); + ulong u_boot_pos = binman_sym(ulong, u_boot_any, offset);
spl_image->size = CONFIG_SYS_MONITOR_LEN;
diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index e8701934b87..6000f495ccd 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -49,7 +49,7 @@ static int spl_ram_load_image(struct spl_image_info *spl_image, load.read = spl_ram_load_read; spl_load_simple_fit(spl_image, &load, 0, header); } else { - ulong u_boot_pos = binman_sym(ulong, u_boot_any, pos); + ulong u_boot_pos = binman_sym(ulong, u_boot_any, offset);
debug("Legacy image\n"); /* diff --git a/include/spl.h b/include/spl.h index 86287874e1b..8c5523083b2 100644 --- a/include/spl.h +++ b/include/spl.h @@ -60,7 +60,7 @@ struct spl_load_info { * image is found. For * example if u-boot.img is used we don't check that * spl_parse_image_header() can parse a valid header. */ -binman_sym_extern(ulong, u_boot_any, pos); +binman_sym_extern(ulong, u_boot_any, offset);
/** * spl_load_simple_fit() - Loads a fit image from a device. diff --git a/tools/binman/README b/tools/binman/README index 207928aa955..5ff20f15c67 100644 --- a/tools/binman/README +++ b/tools/binman/README @@ -238,7 +238,7 @@ below: filename = "spl/sunxi-spl.bin"; }; u-boot { - pos = <CONFIG_SPL_PAD_TO>; + offset = <CONFIG_SPL_PAD_TO>; }; };
@@ -257,7 +257,7 @@ provide a filename. For 'u-boot', binman knows that this means 'u-boot.bin'.
Entries are normally placed into the image sequentially, one after the other. The image size is the total size of all entries. As you can see, you can -specify the start position of an entry using the 'pos' property. +specify the start offset of an entry using the 'offset' property.
Note that due to a device tree requirement, all entries must have a unique name. If you want to put the same binary in the image multiple times, you can @@ -265,14 +265,15 @@ use any unique name, with the 'type' property providing the type.
The attributes supported for entries are described below.
-pos: - This sets the position of an entry within the image. The first byte - of the image is normally at position 0. If 'pos' is not provided, - binman sets it to the end of the previous region, or the start of - the image's entry area (normally 0) if there is no previous region. +offset: + This sets the offset of an entry within the image or section containing + it. The first byte of the image is normally at offset 0. If 'offset' is + not provided, binman sets it to the end of the previous region, or the + start of the image's entry area (normally 0) if there is no previous + region.
align: - This sets the alignment of the entry. The entry position is adjusted + This sets the alignment of the entry. The entry offset is adjusted so that the entry starts on an aligned boundary within the image. For example 'align = <16>' means that the entry will start on a 16-byte boundary. Alignment shold be a power of 2. If 'align' is not @@ -316,12 +317,12 @@ type: possible to use any name, and then add (for example) 'type = "u-boot"' to specify the type.
-pos-unset: - Indicates that the position of this entry should not be set by placing +offset-unset: + Indicates that the offset of this entry should not be set by placing it immediately after the entry before. Instead, is set by another entry which knows where this entry should go. When this boolean property is present, binman will give an error if another entry does - not set the position (with the GetPositions() method). + not set the offset (with the GetOffsets() method).
The attributes supported for images are described below. Several are similar @@ -338,7 +339,7 @@ align-size:
pad-before: This sets the padding before the image entries. The first entry will - be positionad after the padding. This defaults to 0. + be positioned after the padding. This defaults to 0.
pad-after: This sets the padding after the image entries. The padding will be @@ -351,15 +352,15 @@ pad-byte: filename: This specifies the image filename. It defaults to 'image.bin'.
-sort-by-pos: +sort-by-offset: This causes binman to reorder the entries as needed to make sure they are in increasing positional order. This can be used when your entry order may not match the positional order. A common situation is where - the 'pos' properties are set by CONFIG options, so their ordering is + the 'offset' properties are set by CONFIG options, so their ordering is not known a priori.
This is a boolean property so needs no value. To enable it, add a - line 'sort-by-pos;' to your description. + line 'sort-by-offset;' to your description.
multiple-images: Normally only a single image is generated. To create more than one @@ -383,11 +384,11 @@ multiple-images: };
end-at-4gb: - For x86 machines the ROM positions start just before 4GB and extend + For x86 machines the ROM offsets start just before 4GB and extend up so that the image finished at the 4GB boundary. This boolean option can be enabled to support this. The image size must be provided so that binman knows when the image should start. For an - 8MB ROM, the position of the first entry would be 0xfff80000 with + 8MB ROM, the offset of the first entry would be 0xfff80000 with this option, instead of 0 without this option.
@@ -463,7 +464,7 @@ Order of image creation Image creation proceeds in the following order, for each entry in the image.
1. AddMissingProperties() - binman can add calculated values to the device -tree as part of its processing, for example the position and size of each +tree as part of its processing, for example the offset and size of each entry. This method adds any properties associated with this, expanding the device tree as needed. These properties can have placeholder values which are set later by SetCalculatedProperties(). By that stage the size of sections @@ -486,15 +487,15 @@ functions must return True when they have read the contents. Binman will retry calling the functions a few times if False is returned, allowing dependencies between the contents of different entries.
-4. GetEntryPositions() - calls Entry.GetPositions() for each entry. This can +4. GetEntryOffsets() - calls Entry.GetOffsets() for each entry. This can return a dict containing entries that need updating. The key should be the -entry name and the value is a tuple (pos, size). This allows an entry to -provide the position and size for other entries. The default implementation -of GetEntryPositions() returns {}. +entry name and the value is a tuple (offset, size). This allows an entry to +provide the offset and size for other entries. The default implementation +of GetEntryOffsets() returns {}.
-5. PackEntries() - calls Entry.Pack() which figures out the position and -size of an entry. The 'current' image position is passed in, and the function -returns the position immediately after the entry being packed. The default +5. PackEntries() - calls Entry.Pack() which figures out the offset and +size of an entry. The 'current' image offset is passed in, and the function +returns the offset immediately after the entry being packed. The default implementation of Pack() is usually sufficient.
6. CheckSize() - checks that the contents of all the entries fits within @@ -505,16 +506,16 @@ large enough to hold all the entries. outside the image.
8. SetCalculatedProperties() - update any calculated properties in the device -tree. This sets the correct 'pos' and 'size' vaues, for example. +tree. This sets the correct 'offset' and 'size' vaues, for example.
9. ProcessEntryContents() - this calls Entry.ProcessContents() on each entry. The default implementatoin does nothing. This can be overriden to adjust the contents of an entry in some way. For example, it would be possible to create an entry containing a hash of the contents of some other entries. At this -stage the position and size of entries should not be adjusted. +stage the offset and size of entries should not be adjusted.
10. WriteSymbols() - write the value of symbols into the U-Boot SPL binary. -See 'Access to binman entry positions at run time' below for a description of +See 'Access to binman entry offsets at run time' below for a description of what happens in this stage.
11. BuildImage() - builds the image and writes it to a file. This is the final @@ -549,8 +550,8 @@ the 'warning' line in scripts/Makefile.lib to see what it has found: # u_boot_dtsi_options_debug = $(u_boot_dtsi_options_raw)
-Access to binman entry positions at run time --------------------------------------------- +Access to binman entry offsets at run time +------------------------------------------
Binman assembles images and determines where each entry is placed in the image. This information may be useful to U-Boot at run time. For example, in SPL it @@ -560,15 +561,15 @@ when SPL is finished. Binman allows you to declare symbols in the SPL image which are filled in with their correct values during the build. For example:
- binman_sym_declare(ulong, u_boot_any, pos); + binman_sym_declare(ulong, u_boot_any, offset);
-declares a ulong value which will be assigned to the position of any U-Boot +declares a ulong value which will be assigned to the offset of any U-Boot image (u-boot.bin, u-boot.img, u-boot-nodtb.bin) that is present in the image. You can access this value with something like:
- ulong u_boot_pos = binman_sym(ulong, u_boot_any, pos); + ulong u_boot_offset = binman_sym(ulong, u_boot_any, offset);
-Thus u_boot_pos will be set to the position of U-Boot in memory, assuming that +Thus u_boot_offset will be set to the offset of U-Boot in memory, assuming that the whole image has been loaded, or is available in flash. You can then jump to that address to start U-Boot.
@@ -580,17 +581,17 @@ Map files ---------
The -m option causes binman to output a .map file for each image that it -generates. This shows the position and size of each entry. For example: +generates. This shows the offset and size of each entry. For example:
- Position Size Name + Offset Size Name 00000000 00000010 section@0 00000000 00000004 u-boot 00000010 00000010 section@1 00000000 00000004 u-boot
This shows a hierarchical image with two sections, each with a single entry. The -positions of the sections are absolute hex byte offsets within the image. The -positions of the entries are relative to their respective sections. The size of +offsets of the sections are absolute hex byte offsets within the image. The +offsets of the entries are relative to their respective sections. The size of each entry is also shown, in bytes (hex). The indentation shows the entries nested inside their sections.
@@ -623,7 +624,7 @@ Entry properties are documented in entry.py. The entry subclasses are free to change the values of properties to support special behaviour. For example, when Entry_blob loads a file, it sets content_size to the size of the file. Entry classes can adjust other entries. For example, an entry that knows -where other entries should be positioned can set up those entries' positions +where other entries should be positioned can set up those entries' offsets so they don't need to be set in the binman decription. It can also adjust entry contents.
diff --git a/tools/binman/bsection.py b/tools/binman/bsection.py index de439ef625f..d78a25e83d0 100644 --- a/tools/binman/bsection.py +++ b/tools/binman/bsection.py @@ -25,22 +25,21 @@ class Section(object): _size: Section size in bytes, or None if not known yet _align_size: Section size alignment, or None _pad_before: Number of bytes before the first entry starts. This - effectively changes the place where entry position 0 starts + effectively changes the place where entry offset 0 starts _pad_after: Number of bytes after the last entry ends. The last entry will finish on or before this boundary _pad_byte: Byte to use to pad the section where there is no entry - _sort: True if entries should be sorted by position, False if they + _sort: True if entries should be sorted by offset, False if they must be in-order in the device tree description _skip_at_start: Number of bytes before the first entry starts. These - effectively adjust the starting position of entries. For example, + effectively adjust the starting offset of entries. For example, if _pad_before is 16, then the first entry would start at 16. - An entry with pos = 20 would in fact be written at position 4 + An entry with offset = 20 would in fact be written at offset 4 in the image file. _end_4gb: Indicates that the section ends at the 4GB boundary. This is - used for x86 images, which want to use positions such that a - memory address (like 0xff800000) is the first entry position. - This causes _skip_at_start to be set to the starting memory - address. + used for x86 images, which want to use offsets such that a memory + address (like 0xff800000) is the first entry offset. This causes + _skip_at_start to be set to the starting memory address. _name_prefix: Prefix to add to the name of all entries within this section _entries: OrderedDict() of entries @@ -52,6 +51,7 @@ class Section(object): from entry import Entry
self._node = node + self._offset = 0 self._size = None self._align_size = None self._pad_before = 0 @@ -76,7 +76,7 @@ class Section(object): self._pad_before = fdt_util.GetInt(self._node, 'pad-before', 0) self._pad_after = fdt_util.GetInt(self._node, 'pad-after', 0) self._pad_byte = fdt_util.GetInt(self._node, 'pad-byte', 0) - self._sort = fdt_util.GetBool(self._node, 'sort-by-pos') + self._sort = fdt_util.GetBool(self._node, 'sort-by-offset') self._end_4gb = fdt_util.GetBool(self._node, 'end-at-4gb') if self._end_4gb and not self._size: self._Raise("Section size must be provided when using end-at-4gb") @@ -117,7 +117,7 @@ class Section(object): """Check that the section contents does not exceed its size, etc.""" contents_size = 0 for entry in self._entries.values(): - contents_size = max(contents_size, entry.pos + entry.size) + contents_size = max(contents_size, entry.offset + entry.size)
contents_size -= self._skip_at_start
@@ -190,39 +190,41 @@ class Section(object): 'contents: remaining %s' % todo) return True
- def _SetEntryPosSize(self, name, pos, size): - """Set the position and size of an entry + def _SetEntryOffsetSize(self, name, offset, size): + """Set the offset and size of an entry
Args: name: Entry name to update - pos: New position + offset: New offset size: New size """ entry = self._entries.get(name) if not entry: - self._Raise("Unable to set pos/size for unknown entry '%s'" % name) - entry.SetPositionSize(self._skip_at_start + pos, size) + self._Raise("Unable to set offset/size for unknown entry '%s'" % + name) + entry.SetOffsetSize(self._skip_at_start + offset, size)
- def GetEntryPositions(self): - """Handle entries that want to set the position/size of other entries + def GetEntryOffsets(self): + """Handle entries that want to set the offset/size of other entries
- This calls each entry's GetPositions() method. If it returns a list + This calls each entry's GetOffsets() method. If it returns a list of entries to update, it updates them. """ for entry in self._entries.values(): - pos_dict = entry.GetPositions() - for name, info in pos_dict.iteritems(): - self._SetEntryPosSize(name, *info) + offset_dict = entry.GetOffsets() + for name, info in offset_dict.iteritems(): + self._SetEntryOffsetSize(name, *info)
def PackEntries(self): """Pack all entries into the section""" - pos = self._skip_at_start + offset = self._skip_at_start for entry in self._entries.values(): - pos = entry.Pack(pos) + offset = entry.Pack(offset) + self._size = self.CheckSize()
def _SortEntries(self): - """Sort entries by position""" - entries = sorted(self._entries.values(), key=lambda entry: entry.pos) + """Sort entries by offset""" + entries = sorted(self._entries.values(), key=lambda entry: entry.offset) self._entries.clear() for entry in entries: self._entries[entry._node.name] = entry @@ -231,21 +233,21 @@ class Section(object): """Check that entries do not overlap or extend outside the section""" if self._sort: self._SortEntries() - pos = 0 + offset = 0 prev_name = 'None' for entry in self._entries.values(): - entry.CheckPosition() - if (entry.pos < self._skip_at_start or - entry.pos >= self._skip_at_start + self._size): - entry.Raise("Position %#x (%d) is outside the section starting " + entry.CheckOffset() + if (entry.offset < self._skip_at_start or + entry.offset >= self._skip_at_start + self._size): + entry.Raise("Offset %#x (%d) is outside the section starting " "at %#x (%d)" % - (entry.pos, entry.pos, self._skip_at_start, + (entry.offset, entry.offset, self._skip_at_start, self._skip_at_start)) - if entry.pos < pos: - entry.Raise("Position %#x (%d) overlaps with previous entry '%s' " + if entry.offset < offset: + entry.Raise("Offset %#x (%d) overlaps with previous entry '%s' " "ending at %#x (%d)" % - (entry.pos, entry.pos, prev_name, pos, pos)) - pos = entry.pos + entry.size + (entry.offset, entry.offset, prev_name, offset, offset)) + offset = entry.offset + entry.size prev_name = entry.GetPath()
def ProcessEntryContents(self): @@ -261,9 +263,9 @@ class Section(object): for entry in self._entries.values(): entry.WriteSymbols(self)
- def BuildSection(self, fd, base_pos): + def BuildSection(self, fd, base_offset): """Write the section to a file""" - fd.seek(base_pos) + fd.seek(base_offset) fd.write(self.GetData())
def GetData(self): @@ -272,7 +274,7 @@ class Section(object):
for entry in self._entries.values(): data = entry.GetData() - base = self._pad_before + entry.pos - self._skip_at_start + base = self._pad_before + entry.offset - self._skip_at_start section_data = (section_data[:base] + data + section_data[base + len(data):]) return section_data @@ -283,15 +285,15 @@ class Section(object): Looks up a symbol in an ELF file. Only entry types which come from an ELF image can be used by this function.
- At present the only entry property supported is pos. + At present the only entry property supported is offset.
Args: sym_name: Symbol name in the ELF file to look up in the format _binman_<entry>_prop_<property> where <entry> is the name of the entry and <property> is the property to find (e.g. - _binman_u_boot_prop_pos). As a special case, you can append + _binman_u_boot_prop_offset). As a special case, you can append _any to <entry> to have it search for any matching entry. E.g. - _binman_u_boot_any_prop_pos will match entries called u-boot, + _binman_u_boot_any_prop_offset will match entries called u-boot, u-boot-img and u-boot-nodtb) optional: True if the symbol is optional. If False this function will raise if the symbol is not found @@ -327,8 +329,8 @@ class Section(object): print('Warning: %s' % err, file=sys.stderr) return None raise ValueError(err) - if prop_name == 'pos': - return entry.pos + if prop_name == 'offset': + return entry.offset else: raise ValueError("%s: No such property '%s'" % (msg, prop_name))
diff --git a/tools/binman/cmdline.py b/tools/binman/cmdline.py index ae2d1670f9a..5c9b4dfeadc 100644 --- a/tools/binman/cmdline.py +++ b/tools/binman/cmdline.py @@ -43,7 +43,7 @@ def ParseArgs(argv): parser.add_option('-T', '--test-coverage', action='store_true', default=False, help='run tests and check for 100% coverage') parser.add_option('-u', '--update-fdt', action='store_true', - default=False, help='Update the binman node with position/size info') + default=False, help='Update the binman node with offset/size info') parser.add_option('-v', '--verbosity', default=1, type='int', help='Control verbosity: 0=silent, 1=progress, 3=full, ' '4=debug') diff --git a/tools/binman/control.py b/tools/binman/control.py index a40b300fdac..17c6d7a2d20 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -142,7 +142,7 @@ def Binman(options, args): # size of the device tree is correct. Later, in # SetCalculatedProperties() we will insert the correct values # without changing the device-tree size, thus ensuring that our - # entry positions remain the same. + # entry offsets remain the same. for image in images.values(): if options.update_fdt: image.AddMissingProperties() @@ -157,7 +157,7 @@ def Binman(options, args): # image will be reported after earlier images are already # completed and written, but that does not seem important. image.GetEntryContents() - image.GetEntryPositions() + image.GetEntryOffsets() image.PackEntries() image.CheckSize() image.CheckEntries() diff --git a/tools/binman/elf.py b/tools/binman/elf.py index 8c23040d8c5..97df8e32c5d 100644 --- a/tools/binman/elf.py +++ b/tools/binman/elf.py @@ -81,9 +81,9 @@ def LookupAndWriteSymbols(elf_fname, entry, section): """Replace all symbols in an entry with their correct values
The entry contents is updated so that values for referenced symbols will be - visible at run time. This is done by finding out the symbols positions in - the entry (using the ELF file) and replacing them with values from binman's - data structures. + visible at run time. This is done by finding out the symbols offsets in the + entry (using the ELF file) and replacing them with values from binman's data + structures.
Args: elf_fname: Filename of ELF image containing the symbol information for diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 6a173e663d0..c9529d83223 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -38,12 +38,13 @@ class Entry(object): Attributes: section: The section containing this entry node: The node that created this entry - pos: Absolute position of entry within the section, None if not known + offset: Offset of entry within the section, None if not known yet (in + which case it will be calculated by Pack()) size: Entry size in bytes, None if not known contents_size: Size of contents in bytes, 0 by default - align: Entry start position alignment, or None + align: Entry start offset alignment, or None align_size: Entry size alignment, or None - align_end: Entry end position alignment, or None + align_end: Entry end offset alignment, or None pad_before: Number of pad bytes before the contents, 0 if none pad_after: Number of pad bytes after the contents, 0 if none data: Contents of entry (string of bytes) @@ -53,7 +54,7 @@ class Entry(object): self.etype = etype self._node = node self.name = node and (name_prefix + node.name) or 'none' - self.pos = None + self.offset = None self.size = None self.data = '' self.contents_size = 0 @@ -62,7 +63,7 @@ class Entry(object): self.align_end = None self.pad_before = 0 self.pad_after = 0 - self.pos_unset = False + self.offset_unset = False if read_node: self.ReadNode()
@@ -115,7 +116,7 @@ class Entry(object):
This reads all the fields we recognise from the node, ready for use. """ - self.pos = fdt_util.GetInt(self._node, 'pos') + self.offset = fdt_util.GetInt(self._node, 'offset') self.size = fdt_util.GetInt(self._node, 'size') self.align = fdt_util.GetInt(self._node, 'align') if tools.NotPowerOfTwo(self.align): @@ -128,17 +129,17 @@ class Entry(object): raise ValueError("Node '%s': Alignment size %s must be a power " "of two" % (self._node.path, self.align_size)) self.align_end = fdt_util.GetInt(self._node, 'align-end') - self.pos_unset = fdt_util.GetBool(self._node, 'pos-unset') + self.offset_unset = fdt_util.GetBool(self._node, 'offset-unset')
def AddMissingProperties(self): """Add new properties to the device tree as needed for this entry""" - for prop in ['pos', 'size']: + for prop in ['offset', 'size', 'global-pos']: if not prop in self._node.props: self._node.AddZeroProp(prop)
def SetCalculatedProperties(self): """Set the value of device-tree properties calculated by binman""" - self._node.SetInt('pos', self.pos) + self._node.SetInt('offset', self.offset) self._node.SetInt('size', self.size)
def ProcessFdt(self, fdt): @@ -190,39 +191,39 @@ class Entry(object): # No contents by default: subclasses can implement this return True
- def Pack(self, pos): + def Pack(self, offset): """Figure out how to pack the entry into the section
Most of the time the entries are not fully specified. There may be an alignment but no size. In that case we take the size from the contents of the entry.
- If an entry has no hard-coded position, it will be placed at @pos. + If an entry has no hard-coded offset, it will be placed at @offset.
- Once this function is complete, both the position and size of the + Once this function is complete, both the offset and size of the entry will be know.
Args: - Current section position pointer + Current section offset pointer
Returns: - New section position pointer (after this entry) + New section offset pointer (after this entry) """ - if self.pos is None: - if self.pos_unset: - self.Raise('No position set with pos-unset: should another ' - 'entry provide this correct position?') - self.pos = tools.Align(pos, self.align) + if self.offset is None: + if self.offset_unset: + self.Raise('No offset set with offset-unset: should another ' + 'entry provide this correct offset?') + self.offset = tools.Align(offset, self.align) needed = self.pad_before + self.contents_size + self.pad_after needed = tools.Align(needed, self.align_size) size = self.size if not size: size = needed - new_pos = self.pos + size - aligned_pos = tools.Align(new_pos, self.align_end) - if aligned_pos != new_pos: - size = aligned_pos - self.pos - new_pos = aligned_pos + new_offset = self.offset + size + aligned_offset = tools.Align(new_offset, self.align_end) + if aligned_offset != new_offset: + size = aligned_offset - self.offset + new_offset = aligned_offset
if not self.size: self.size = size @@ -231,16 +232,16 @@ class Entry(object): self.Raise("Entry contents size is %#x (%d) but entry size is " "%#x (%d)" % (needed, needed, self.size, self.size)) # Check that the alignment is correct. It could be wrong if the - # and pos or size values were provided (i.e. not calculated), but + # and offset or size values were provided (i.e. not calculated), but # conflict with the provided alignment values if self.size != tools.Align(self.size, self.align_size): self.Raise("Size %#x (%d) does not match align-size %#x (%d)" % (self.size, self.size, self.align_size, self.align_size)) - if self.pos != tools.Align(self.pos, self.align): - self.Raise("Position %#x (%d) does not match align %#x (%d)" % - (self.pos, self.pos, self.align, self.align)) + if self.offset != tools.Align(self.offset, self.align): + self.Raise("Offset %#x (%d) does not match align %#x (%d)" % + (self.offset, self.offset, self.align, self.align))
- return new_pos + return new_offset
def Raise(self, msg): """Convenience function to raise an error referencing a node""" @@ -257,11 +258,11 @@ class Entry(object): def GetData(self): return self.data
- def GetPositions(self): + def GetOffsets(self): return {}
- def SetPositionSize(self, pos, size): - self.pos = pos + def SetOffsetSize(self, pos, size): + self.offset = pos self.size = size
def ProcessContents(self): @@ -275,10 +276,10 @@ class Entry(object): """ pass
- def CheckPosition(self): - """Check that the entry positions are correct + def CheckOffset(self): + """Check that the entry offsets are correct
- This is used for entries which have extra position requirements (other + This is used for entries which have extra offset requirements (other than having to be fully inside their section). Sub-classes can implement this function and raise if there is a problem. """ @@ -291,5 +292,5 @@ class Entry(object): fd: File to write the map to indent: Curent indent level of map (0=none, 1=one level, etc.) """ - print('%s%08x %08x %s' % (' ' * indent, self.pos, self.size, + print('%s%08x %08x %s' % (' ' * indent, self.offset, self.size, self.name), file=fd) diff --git a/tools/binman/etype/_testing.py b/tools/binman/etype/_testing.py index 6a1af577988..31f625c026c 100644 --- a/tools/binman/etype/_testing.py +++ b/tools/binman/etype/_testing.py @@ -14,7 +14,7 @@ class Entry__testing(Entry): """A fake entry used for testing
Properties: - return_invalid_entry: Return an invalid entry from GetPositions() + return_invalid_entry: Return an invalid entry from GetOffsets() """ def __init__(self, section, etype, node): Entry.__init__(self, section, etype, node) @@ -35,7 +35,7 @@ class Entry__testing(Entry): self.contents_size = len(self.data) return True
- def GetPositions(self): + def GetOffsets(self): if self.return_invalid_entry : return {'invalid-entry': [1, 2]} return {} diff --git a/tools/binman/etype/intel_descriptor.py b/tools/binman/etype/intel_descriptor.py index 0e7865521e1..0a5151d466c 100644 --- a/tools/binman/etype/intel_descriptor.py +++ b/tools/binman/etype/intel_descriptor.py @@ -36,12 +36,12 @@ class Entry_intel_descriptor(Entry_blob): Entry_blob.__init__(self, section, etype, node) self._regions = []
- def GetPositions(self): - pos = self.data.find(FD_SIGNATURE) - if pos == -1: + def GetOffsets(self): + offset = self.data.find(FD_SIGNATURE) + if offset == -1: self.Raise('Cannot find FD signature') flvalsig, flmap0, flmap1, flmap2 = struct.unpack('<LLLL', - self.data[pos:pos + 16]) + self.data[offset:offset + 16]) frba = ((flmap0 >> 16) & 0xff) << 4 for i in range(MAX_REGIONS): self._regions.append(Region(self.data, frba, i)) diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 787257d3ec1..5a0b0b8c703 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -30,20 +30,20 @@ class Entry_section(Entry): def GetData(self): return self._section.GetData()
- def GetPositions(self): - """Handle entries that want to set the position/size of other entries + def GetOffsets(self): + """Handle entries that want to set the offset/size of other entries
- This calls each entry's GetPositions() method. If it returns a list + This calls each entry's GetOffsets() method. If it returns a list of entries to update, it updates them. """ - self._section.GetEntryPositions() + self._section.GetEntryOffsets() return {}
- def Pack(self, pos): + def Pack(self, offset): """Pack all entries into the section""" self._section.PackEntries() self.size = self._section.CheckSize() - return super(Entry_section, self).Pack(pos) + return super(Entry_section, self).Pack(offset)
def WriteSymbols(self, section): """Write symbol values into binary files for access at run time""" @@ -57,7 +57,7 @@ class Entry_section(Entry): self._section.ProcessEntryContents() super(Entry_section, self).ProcessContents()
- def CheckPosition(self): + def CheckOffset(self): self._section.CheckEntries()
def WriteMap(self, fd, indent): diff --git a/tools/binman/etype/u_boot_dtb_with_ucode.py b/tools/binman/etype/u_boot_dtb_with_ucode.py index 3808d6d2780..55d3a38a64f 100644 --- a/tools/binman/etype/u_boot_dtb_with_ucode.py +++ b/tools/binman/etype/u_boot_dtb_with_ucode.py @@ -33,10 +33,10 @@ class Entry_u_boot_dtb_with_ucode(Entry_blob): # If the section does not need microcode, there is nothing to do ucode_dest_entry = self.section.FindEntryType( 'u-boot-spl-with-ucode-ptr') - if not ucode_dest_entry or not ucode_dest_entry.target_pos: + if not ucode_dest_entry or not ucode_dest_entry.target_offset: ucode_dest_entry = self.section.FindEntryType( 'u-boot-with-ucode-ptr') - if not ucode_dest_entry or not ucode_dest_entry.target_pos: + if not ucode_dest_entry or not ucode_dest_entry.target_offset: return True
# Remove the microcode diff --git a/tools/binman/etype/u_boot_ucode.py b/tools/binman/etype/u_boot_ucode.py index ea0c85cc5c7..922a607cfe6 100644 --- a/tools/binman/etype/u_boot_ucode.py +++ b/tools/binman/etype/u_boot_ucode.py @@ -59,8 +59,8 @@ class Entry_u_boot_ucode(Entry_blob): ucode_dest_entry = self.section.FindEntryType('u-boot-with-ucode-ptr') ucode_dest_entry_spl = self.section.FindEntryType( 'u-boot-spl-with-ucode-ptr') - if ((not ucode_dest_entry or not ucode_dest_entry.target_pos) and - (not ucode_dest_entry_spl or not ucode_dest_entry_spl.target_pos)): + if ((not ucode_dest_entry or not ucode_dest_entry.target_offset) and + (not ucode_dest_entry_spl or not ucode_dest_entry_spl.target_offset)): self.data = '' return True
diff --git a/tools/binman/etype/u_boot_with_ucode_ptr.py b/tools/binman/etype/u_boot_with_ucode_ptr.py index 8b1e41152e3..97e58a0bfcf 100644 --- a/tools/binman/etype/u_boot_with_ucode_ptr.py +++ b/tools/binman/etype/u_boot_with_ucode_ptr.py @@ -23,7 +23,7 @@ class Entry_u_boot_with_ucode_ptr(Entry_blob): def __init__(self, section, etype, node): Entry_blob.__init__(self, section, etype, node) self.elf_fname = 'u-boot' - self.target_pos = None + self.target_offset = None
def GetDefaultFilename(self): return 'u-boot-nodtb.bin' @@ -33,52 +33,53 @@ class Entry_u_boot_with_ucode_ptr(Entry_blob): fname = tools.GetInputFilename(self.elf_fname) sym = elf.GetSymbolAddress(fname, '_dt_ucode_base_size') if sym: - self.target_pos = sym + self.target_offset = sym elif not fdt_util.GetBool(self._node, 'optional-ucode'): self.Raise('Cannot locate _dt_ucode_base_size symbol in u-boot') return True
def ProcessContents(self): # If the image does not need microcode, there is nothing to do - if not self.target_pos: + if not self.target_offset: return
- # Get the position of the microcode + # Get the offset of the microcode ucode_entry = self.section.FindEntryType('u-boot-ucode') if not ucode_entry: self.Raise('Cannot find microcode region u-boot-ucode')
# Check the target pos is in the section. If it is not, then U-Boot is - # being linked incorrectly, or is being placed at the wrong position + # being linked incorrectly, or is being placed at the wrong offset # in the section. # # The section must be set up so that U-Boot is placed at the # flash address to which it is linked. For example, if # CONFIG_SYS_TEXT_BASE is 0xfff00000, and the ROM is 8MB, then - # the U-Boot region must start at position 7MB in the section. In this - # case the ROM starts at 0xff800000, so the position of the first + # the U-Boot region must start at offset 7MB in the section. In this + # case the ROM starts at 0xff800000, so the offset of the first # entry in the section corresponds to that. - if (self.target_pos < self.pos or - self.target_pos >= self.pos + self.size): + if (self.target_offset < self.offset or + self.target_offset >= self.offset + self.size): self.Raise('Microcode pointer _dt_ucode_base_size at %08x is ' 'outside the section ranging from %08x to %08x' % - (self.target_pos, self.pos, self.pos + self.size)) + (self.target_offset, self.offset, self.offset + self.size))
# Get the microcode, either from u-boot-ucode or u-boot-dtb-with-ucode. # If we have left the microcode in the device tree, then it will be # in the former. If we extracted the microcode from the device tree # and collated it in one place, it will be in the latter. if ucode_entry.size: - pos, size = ucode_entry.pos, ucode_entry.size + offset, size = ucode_entry.offset, ucode_entry.size else: dtb_entry = self.section.FindEntryType('u-boot-dtb-with-ucode') if not dtb_entry or not dtb_entry.ready: self.Raise('Cannot find microcode region u-boot-dtb-with-ucode') - pos = dtb_entry.pos + dtb_entry.ucode_offset + offset = dtb_entry.offset + dtb_entry.ucode_offset size = dtb_entry.ucode_size
- # Write the microcode position and size into the entry - pos_and_size = struct.pack('<2L', pos, size) - self.target_pos -= self.pos - self.ProcessContentsUpdate(self.data[:self.target_pos] + pos_and_size + - self.data[self.target_pos + 8:]) + # Write the microcode offset and size into the entry + offset_and_size = struct.pack('<2L', offset, size) + self.target_offset -= self.offset + self.ProcessContentsUpdate(self.data[:self.target_offset] + + offset_and_size + + self.data[self.target_offset + 8:]) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 12164a85b4d..1efedc2ec30 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -153,7 +153,7 @@ class TestFunctional(unittest.TestCase): fname: Device-tree source filename to use (e.g. 05_simple.dts) debug: True to enable debugging output map: True to output map files for the images - update_dtb: Update the position and size of each entry in the device + update_dtb: Update the offset and size of each entry in the device tree before packing it into the image """ args = ['-p', '-I', self._indir, '-d', self.TestFile(fname)] @@ -204,7 +204,7 @@ class TestFunctional(unittest.TestCase): test contents (the U_BOOT_DTB_DATA string) can be used. But in some test we need the real contents. map: True to output map files for the images - update_dtb: Update the position and size of each entry in the device + update_dtb: Update the offset and size of each entry in the device tree before packing it into the image
Returns: @@ -257,7 +257,7 @@ class TestFunctional(unittest.TestCase): """Create a new test input file, creating directories as needed
Args: - fname: Filenaem to create + fname: Filename to create contents: File contents to write in to the file Returns: Full pathname of file created @@ -292,10 +292,10 @@ class TestFunctional(unittest.TestCase): Args: entries: List of entries to check """ - pos = 0 + offset = 0 for entry in entries.values(): - self.assertEqual(pos, entry.pos) - pos += entry.size + self.assertEqual(offset, entry.offset) + offset += entry.size
def GetFdtLen(self, dtb): """Get the totalsize field from a device-tree binary @@ -319,7 +319,6 @@ class TestFunctional(unittest.TestCase): prop_path = path + '/' + subnode.name + ':' + prop.name tree[prop_path[len('/binman/'):]] = fdt_util.fdt32_to_cpu( prop.value) - #print ' ', prop.name AddNode(subnode, path)
tree = {} @@ -467,32 +466,32 @@ class TestFunctional(unittest.TestCase): # First u-boot self.assertIn('u-boot', entries) entry = entries['u-boot'] - self.assertEqual(0, entry.pos) + self.assertEqual(0, entry.offset) self.assertEqual(len(U_BOOT_DATA), entry.size)
# Second u-boot, aligned to 16-byte boundary self.assertIn('u-boot-align', entries) entry = entries['u-boot-align'] - self.assertEqual(16, entry.pos) + self.assertEqual(16, entry.offset) self.assertEqual(len(U_BOOT_DATA), entry.size)
# Third u-boot, size 23 bytes self.assertIn('u-boot-size', entries) entry = entries['u-boot-size'] - self.assertEqual(20, entry.pos) + self.assertEqual(20, entry.offset) self.assertEqual(len(U_BOOT_DATA), entry.contents_size) self.assertEqual(23, entry.size)
# Fourth u-boot, placed immediate after the above self.assertIn('u-boot-next', entries) entry = entries['u-boot-next'] - self.assertEqual(43, entry.pos) + self.assertEqual(43, entry.offset) self.assertEqual(len(U_BOOT_DATA), entry.size)
- # Fifth u-boot, placed at a fixed position + # Fifth u-boot, placed at a fixed offset self.assertIn('u-boot-fixed', entries) entry = entries['u-boot-fixed'] - self.assertEqual(61, entry.pos) + self.assertEqual(61, entry.offset) self.assertEqual(len(U_BOOT_DATA), entry.size)
self.assertEqual(65, image._size) @@ -510,32 +509,32 @@ class TestFunctional(unittest.TestCase): # First u-boot with padding before and after self.assertIn('u-boot', entries) entry = entries['u-boot'] - self.assertEqual(0, entry.pos) + self.assertEqual(0, entry.offset) self.assertEqual(3, entry.pad_before) self.assertEqual(3 + 5 + len(U_BOOT_DATA), entry.size)
# Second u-boot has an aligned size, but it has no effect self.assertIn('u-boot-align-size-nop', entries) entry = entries['u-boot-align-size-nop'] - self.assertEqual(12, entry.pos) + self.assertEqual(12, entry.offset) self.assertEqual(4, entry.size)
# Third u-boot has an aligned size too self.assertIn('u-boot-align-size', entries) entry = entries['u-boot-align-size'] - self.assertEqual(16, entry.pos) + self.assertEqual(16, entry.offset) self.assertEqual(32, entry.size)
# Fourth u-boot has an aligned end self.assertIn('u-boot-align-end', entries) entry = entries['u-boot-align-end'] - self.assertEqual(48, entry.pos) + self.assertEqual(48, entry.offset) self.assertEqual(16, entry.size)
# Fifth u-boot immediately afterwards self.assertIn('u-boot-align-both', entries) entry = entries['u-boot-align-both'] - self.assertEqual(64, entry.pos) + self.assertEqual(64, entry.offset) self.assertEqual(64, entry.size)
self.CheckNoGaps(entries) @@ -556,10 +555,10 @@ class TestFunctional(unittest.TestCase): "power of two", str(e.exception))
def testPackInvalidAlign(self): - """Test detection of an position that does not match its alignment""" + """Test detection of an offset that does not match its alignment""" with self.assertRaises(ValueError) as e: self._DoTestFile('12_pack_inv_align.dts') - self.assertIn("Node '/binman/u-boot': Position 0x5 (5) does not match " + self.assertIn("Node '/binman/u-boot': Offset 0x5 (5) does not match " "align 0x4 (4)", str(e.exception))
def testPackInvalidSizeAlign(self): @@ -573,7 +572,7 @@ class TestFunctional(unittest.TestCase): """Test that overlapping regions are detected""" with self.assertRaises(ValueError) as e: self._DoTestFile('14_pack_overlap.dts') - self.assertIn("Node '/binman/u-boot-align': Position 0x3 (3) overlaps " + self.assertIn("Node '/binman/u-boot-align': Offset 0x3 (3) overlaps " "with previous entry '/binman/u-boot' ending at 0x4 (4)", str(e.exception))
@@ -651,11 +650,11 @@ class TestFunctional(unittest.TestCase): self.assertEqual(chr(0) * 1 + U_BOOT_SPL_DATA + chr(0) * 2 + U_BOOT_DATA, data)
- def testPackZeroPosition(self): - """Test that an entry at position 0 is not given a new position""" + def testPackZeroOffset(self): + """Test that an entry at offset 0 is not given a new offset""" with self.assertRaises(ValueError) as e: self._DoTestFile('25_pack_zero_size.dts') - self.assertIn("Node '/binman/u-boot-spl': Position 0x0 (0) overlaps " + self.assertIn("Node '/binman/u-boot-spl': Offset 0x0 (0) overlaps " "with previous entry '/binman/u-boot' ending at 0x4 (4)", str(e.exception))
@@ -672,10 +671,10 @@ class TestFunctional(unittest.TestCase): "using end-at-4gb", str(e.exception))
def testPackX86RomOutside(self): - """Test that the end-at-4gb property checks for position boundaries""" + """Test that the end-at-4gb property checks for offset boundaries""" with self.assertRaises(ValueError) as e: self._DoTestFile('28_pack_4gb_outside.dts') - self.assertIn("Node '/binman/u-boot': Position 0x0 (0) is outside " + self.assertIn("Node '/binman/u-boot': Offset 0x0 (0) is outside " "the section starting at 0xffffffe0 (4294967264)", str(e.exception))
@@ -697,9 +696,9 @@ class TestFunctional(unittest.TestCase): """Test that the Intel requires a descriptor entry""" with self.assertRaises(ValueError) as e: self._DoTestFile('30_x86-rom-me-no-desc.dts') - self.assertIn("Node '/binman/intel-me': No position set with " - "pos-unset: should another entry provide this correct " - "position?", str(e.exception)) + self.assertIn("Node '/binman/intel-me': No offset set with " + "offset-unset: should another entry provide this correct " + "offset?", str(e.exception))
def testPackX86RomMe(self): """Test that an x86 ROM with an ME region can be created""" @@ -728,7 +727,7 @@ class TestFunctional(unittest.TestCase): Returns: Tuple: Contents of first region (U-Boot or SPL) - Position and size components of microcode pointer, as inserted + Offset and size components of microcode pointer, as inserted in the above (two 4-byte words) """ data = self._DoReadFile(dts_fname, True) @@ -761,7 +760,7 @@ class TestFunctional(unittest.TestCase): self.assertEqual(ucode_data, ucode_content[:len(ucode_data)])
# Check that the microcode pointer was inserted. It should match the - # expected position and size + # expected offset and size pos_and_size = struct.pack('<2L', 0xfffffe00 + ucode_pos, len(ucode_data)) u_boot = data[:len(nodtb_data)] @@ -806,7 +805,7 @@ class TestFunctional(unittest.TestCase): ucode_pos = second.find(ucode_data) + len(U_BOOT_NODTB_DATA)
# Check that the microcode pointer was inserted. It should match the - # expected position and size + # expected offset and size pos_and_size = struct.pack('<2L', 0xfffffe00 + ucode_pos, len(ucode_data)) first = data[:len(U_BOOT_NODTB_DATA)] @@ -890,7 +889,7 @@ class TestFunctional(unittest.TestCase): """Test that microcode must be placed within the image""" with self.assertRaises(ValueError) as e: self._DoReadFile('41_unknown_pos_size.dts', True) - self.assertIn("Section '/binman': Unable to set pos/size for unknown " + self.assertIn("Section '/binman': Unable to set offset/size for unknown " "entry 'invalid-entry'", str(e.exception))
def testPackFsp(self): @@ -984,7 +983,7 @@ class TestFunctional(unittest.TestCase): elf_fname = self.TestFile('u_boot_binman_syms') syms = elf.GetSymbols(elf_fname, ['binman', 'image']) addr = elf.GetSymbolAddress(elf_fname, '__image_copy_start') - self.assertEqual(syms['_binman_u_boot_spl_prop_pos'].address, addr) + self.assertEqual(syms['_binman_u_boot_spl_prop_offset'].address, addr)
with open(self.TestFile('u_boot_binman_syms')) as fd: TestFunctional._MakeInputFile('spl/u-boot-spl', fd.read()) @@ -1009,7 +1008,7 @@ class TestFunctional(unittest.TestCase): def testMap(self): """Tests outputting a map of the images""" _, _, map_data, _ = self._DoReadFileDtb('55_sections.dts', map=True) - self.assertEqual('''Position Size Name + self.assertEqual(''' Offset Size Name 00000000 00000010 section@0 00000000 00000004 u-boot 00000010 00000010 section@1 @@ -1019,7 +1018,7 @@ class TestFunctional(unittest.TestCase): def testNamePrefix(self): """Tests that name prefixes are used""" _, _, map_data, _ = self._DoReadFileDtb('56_name_prefix.dts', map=True) - self.assertEqual('''Position Size Name + self.assertEqual(''' Offset Size Name 00000000 00000010 section@0 00000000 00000004 ro-u-boot 00000010 00000010 section@1 @@ -1042,24 +1041,24 @@ class TestFunctional(unittest.TestCase): '2 to 1', str(e.exception))
def testUpdateFdt(self): - """Test that we can update the device tree with pos/size info""" + """Test that we can update the device tree with offset/size info""" _, _, _, out_dtb_fname = self._DoReadFileDtb('60_fdt_update.dts', update_dtb=True) - props = self._GetPropTree(out_dtb_fname, ['pos', 'size']) + props = self._GetPropTree(out_dtb_fname, ['offset', 'size']) with open('/tmp/x.dtb', 'wb') as outf: with open(out_dtb_fname) as inf: outf.write(inf.read()) self.assertEqual({ - '_testing:pos': 32, + '_testing:offset': 32, '_testing:size': 1, - 'section@0/u-boot:pos': 0, + 'section@0/u-boot:offset': 0, 'section@0/u-boot:size': len(U_BOOT_DATA), - 'section@0:pos': 0, + 'section@0:offset': 0, 'section@0:size': 16,
- 'section@1/u-boot:pos': 0, + 'section@1/u-boot:offset': 0, 'section@1/u-boot:size': len(U_BOOT_DATA), - 'section@1:pos': 16, + 'section@1:offset': 16, 'section@1:size': 16, 'size': 40 }, props) diff --git a/tools/binman/image.py b/tools/binman/image.py index 94028f19a51..ed8261a652a 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -57,7 +57,7 @@ class Image: def AddMissingProperties(self): """Add properties that are not present in the device tree
- When binman has completed packing the entries the position and size of + When binman has completed packing the entries the offset and size of each entry are known. But before this the device tree may not specify these. Add any missing properties, with a dummy value, so that the size of the entry is correct. That way we can insert the correct values @@ -73,13 +73,13 @@ class Image: """ self._section.GetEntryContents()
def PackEntries(self): """Pack all entries into the image""" @@ -121,5 +121,5 @@ class Image: filename = '%s.map' % self._name fname = tools.GetOutputFilename(filename) with open(fname, 'w') as fd: - print('%8s %8s %s' % ('Position', 'Size', 'Name'), file=fd) + print('%8s %8s %s' % ('Offset', 'Size', 'Name'), file=fd) self._section.WriteMap(fd, 0) diff --git a/tools/binman/test/08_pack.dts b/tools/binman/test/08_pack.dts index dc63d99dcb0..a88785d8352 100644 --- a/tools/binman/test/08_pack.dts +++ b/tools/binman/test/08_pack.dts @@ -24,7 +24,7 @@
u-boot-fixed { type = "u-boot"; - pos = <61>; + offset = <61>; }; }; }; diff --git a/tools/binman/test/12_pack_inv_align.dts b/tools/binman/test/12_pack_inv_align.dts index 1d9d80a65cc..d8dd600edb8 100644 --- a/tools/binman/test/12_pack_inv_align.dts +++ b/tools/binman/test/12_pack_inv_align.dts @@ -6,7 +6,7 @@
binman { u-boot { - pos = <5>; + offset = <5>; align = <4>; }; }; diff --git a/tools/binman/test/14_pack_overlap.dts b/tools/binman/test/14_pack_overlap.dts index 611cfd97300..3895cba3bdb 100644 --- a/tools/binman/test/14_pack_overlap.dts +++ b/tools/binman/test/14_pack_overlap.dts @@ -10,7 +10,7 @@
u-boot-align { type = "u-boot"; - pos = <3>; + offset = <3>; }; }; }; diff --git a/tools/binman/test/21_image_pad.dts b/tools/binman/test/21_image_pad.dts index bf39dc1b6f7..c6516689d94 100644 --- a/tools/binman/test/21_image_pad.dts +++ b/tools/binman/test/21_image_pad.dts @@ -10,7 +10,7 @@ };
u-boot { - pos = <20>; + offset = <20>; }; }; }; diff --git a/tools/binman/test/24_sorted.dts b/tools/binman/test/24_sorted.dts index 43a7831341c..d35d39f077d 100644 --- a/tools/binman/test/24_sorted.dts +++ b/tools/binman/test/24_sorted.dts @@ -5,13 +5,13 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; u-boot { - pos = <22>; + offset = <22>; };
u-boot-spl { - pos = <1>; + offset = <1>; }; }; }; diff --git a/tools/binman/test/25_pack_zero_size.dts b/tools/binman/test/25_pack_zero_size.dts index 7d2baad3c6d..e863c44e3fd 100644 --- a/tools/binman/test/25_pack_zero_size.dts +++ b/tools/binman/test/25_pack_zero_size.dts @@ -9,7 +9,7 @@ };
u-boot-spl { - pos = <0>; + offset = <0>; }; }; }; diff --git a/tools/binman/test/27_pack_4gb_no_size.dts b/tools/binman/test/27_pack_4gb_no_size.dts index e0b6519e75b..371cca10d58 100644 --- a/tools/binman/test/27_pack_4gb_no_size.dts +++ b/tools/binman/test/27_pack_4gb_no_size.dts @@ -5,14 +5,14 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; u-boot { - pos = <0xfffffff0>; + offset = <0xfffffff0>; };
u-boot-spl { - pos = <0xfffffff7>; + offset = <0xfffffff7>; }; }; }; diff --git a/tools/binman/test/28_pack_4gb_outside.dts b/tools/binman/test/28_pack_4gb_outside.dts index 18d6bb5b8af..2216abfb70c 100644 --- a/tools/binman/test/28_pack_4gb_outside.dts +++ b/tools/binman/test/28_pack_4gb_outside.dts @@ -5,15 +5,15 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <32>; u-boot { - pos = <0>; + offset = <0>; };
u-boot-spl { - pos = <0xffffffeb>; + offset = <0xffffffeb>; }; }; }; diff --git a/tools/binman/test/29_x86-rom.dts b/tools/binman/test/29_x86-rom.dts index d49078e19e2..d5c69f9d4a9 100644 --- a/tools/binman/test/29_x86-rom.dts +++ b/tools/binman/test/29_x86-rom.dts @@ -5,15 +5,15 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <32>; u-boot { - pos = <0xffffffe0>; + offset = <0xffffffe0>; };
u-boot-spl { - pos = <0xffffffeb>; + offset = <0xffffffeb>; }; }; }; diff --git a/tools/binman/test/30_x86-rom-me-no-desc.dts b/tools/binman/test/30_x86-rom-me-no-desc.dts index 68d3ce09ecd..796cb87afc7 100644 --- a/tools/binman/test/30_x86-rom-me-no-desc.dts +++ b/tools/binman/test/30_x86-rom-me-no-desc.dts @@ -5,12 +5,12 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <16>; intel-me { filename = "me.bin"; - pos-unset; + offset-unset; }; }; }; diff --git a/tools/binman/test/31_x86-rom-me.dts b/tools/binman/test/31_x86-rom-me.dts index ee3dac875a6..b8b0a5a74bb 100644 --- a/tools/binman/test/31_x86-rom-me.dts +++ b/tools/binman/test/31_x86-rom-me.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x800000>; intel-descriptor { @@ -14,7 +14,7 @@
intel-me { filename = "me.bin"; - pos-unset; + offset-unset; }; }; }; diff --git a/tools/binman/test/34_x86_ucode.dts b/tools/binman/test/34_x86_ucode.dts index 64a6c2c3d5d..40725731cd3 100644 --- a/tools/binman/test/34_x86_ucode.dts +++ b/tools/binman/test/34_x86_ucode.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-with-ucode-ptr { diff --git a/tools/binman/test/35_x86_single_ucode.dts b/tools/binman/test/35_x86_single_ucode.dts index 973e97f8641..2b1f086a41c 100644 --- a/tools/binman/test/35_x86_single_ucode.dts +++ b/tools/binman/test/35_x86_single_ucode.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-with-ucode-ptr { diff --git a/tools/binman/test/37_x86_no_ucode.dts b/tools/binman/test/37_x86_no_ucode.dts index 9e12156ee2f..6da49c3da6d 100644 --- a/tools/binman/test/37_x86_no_ucode.dts +++ b/tools/binman/test/37_x86_no_ucode.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-with-ucode-ptr { diff --git a/tools/binman/test/38_x86_ucode_missing_node.dts b/tools/binman/test/38_x86_ucode_missing_node.dts index d6cf0d844ed..720677c9c1e 100644 --- a/tools/binman/test/38_x86_ucode_missing_node.dts +++ b/tools/binman/test/38_x86_ucode_missing_node.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-with-ucode-ptr { diff --git a/tools/binman/test/39_x86_ucode_missing_node2.dts b/tools/binman/test/39_x86_ucode_missing_node2.dts index b7e26c5ae41..10ac086d549 100644 --- a/tools/binman/test/39_x86_ucode_missing_node2.dts +++ b/tools/binman/test/39_x86_ucode_missing_node2.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-with-ucode-ptr { diff --git a/tools/binman/test/40_x86_ucode_not_in_image.dts b/tools/binman/test/40_x86_ucode_not_in_image.dts index 67d17d392fd..609725824a5 100644 --- a/tools/binman/test/40_x86_ucode_not_in_image.dts +++ b/tools/binman/test/40_x86_ucode_not_in_image.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; size = <0x200>; u-boot-with-ucode-ptr { }; diff --git a/tools/binman/test/44_x86_optional_ucode.dts b/tools/binman/test/44_x86_optional_ucode.dts index abe1322798e..24a7040d318 100644 --- a/tools/binman/test/44_x86_optional_ucode.dts +++ b/tools/binman/test/44_x86_optional_ucode.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-with-ucode-ptr { diff --git a/tools/binman/test/45_prop_test.dts b/tools/binman/test/45_prop_test.dts index d22e460d299..064de2b3167 100644 --- a/tools/binman/test/45_prop_test.dts +++ b/tools/binman/test/45_prop_test.dts @@ -5,12 +5,12 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <16>; intel-me { filename = "me.bin"; - pos-unset; + offset-unset; intval = <3>; intarray = <5 6>; byteval = [08]; diff --git a/tools/binman/test/49_x86_ucode_spl.dts b/tools/binman/test/49_x86_ucode_spl.dts index 67db93ad502..350d2c4730b 100644 --- a/tools/binman/test/49_x86_ucode_spl.dts +++ b/tools/binman/test/49_x86_ucode_spl.dts @@ -5,7 +5,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-spl-with-ucode-ptr { diff --git a/tools/binman/test/53_symbols.dts b/tools/binman/test/53_symbols.dts index 980b066eb21..9f135676cb0 100644 --- a/tools/binman/test/53_symbols.dts +++ b/tools/binman/test/53_symbols.dts @@ -10,7 +10,7 @@ };
u-boot-spl2 { diff --git a/tools/binman/test/58_x86_ucode_spl_needs_retry.dts b/tools/binman/test/58_x86_ucode_spl_needs_retry.dts index e2cb80cf6e2..a04adaaf7ba 100644 --- a/tools/binman/test/58_x86_ucode_spl_needs_retry.dts +++ b/tools/binman/test/58_x86_ucode_spl_needs_retry.dts @@ -7,7 +7,7 @@ #size-cells = <1>;
binman { - sort-by-pos; + sort-by-offset; end-at-4gb; size = <0x200>; u-boot-spl-with-ucode-ptr { diff --git a/tools/binman/test/u_boot_binman_syms b/tools/binman/test/u_boot_binman_syms index 2e02dc0ca9e2651bc12ac6d61d95dfa5ccee7a68..f2dcb887ed84e4799ae9eca1d2d39585635fb4c6 100755 GIT binary patch delta 350 zcmdm~wnc4%0+Wo;Mx}TB;meYz8))l=?8tMFe6oF=pXpo`4}S(U;O^{frJxa-RGL>( zs$i;TqGzCMRtn}B))|`V8JOr<YC^;nj0_CT49pBHCr*@|d`Hk^vVssxtOn3H4j>j} zU}7)>(gr}x0_BGSX%!^?L?9am1Q-|@N`M>_sDJ=ae=Cp;QV#+k{*1|uLgwB^@dZWs z1@ZZ5X~n4}4Dm^sdAW&s@ul%e`S~UBiFuXyq>Br3kfkRx3R_H$7r4r3GTBs6nd!3N k<S0Qk-V6Z-h66w=*?^dJa<8DYgoYpk!)hQ81{k3X02qTyEC2ui
delta 311 zcmdm@wo`3_0@DhCjY{wM{giSY5Bn9IT;WmHowz;j+V6#vLY6V00e5F-D+P_vq|&^S zQUwz|3q2EEqf#)>u+Gp#&%i{_SQ8>X`I6u@M(xQfg_N1%1ty;pQsX@!$iQ#`XdW8~ zPi7RBW}P6!z_4=iMIqsdGh`;W2$<9(+s4B1@xK^QKm~|dfLM@$iNOd-fdB&|gC&r! z0mK|o`7j`D0K_o$ML@O*5QBgKP=7O!2AKx}ApSHUjo>p*Ru|Nq+%L$+RghoI5MNx9 XSX46ER#1u=$ekQ3C<&%#3t9jG`lCCI
diff --git a/tools/binman/test/u_boot_binman_syms.c b/tools/binman/test/u_boot_binman_syms.c index d8371610a5b..cbb2f3f7b17 100644 --- a/tools/binman/test/u_boot_binman_syms.c +++ b/tools/binman/test/u_boot_binman_syms.c @@ -8,6 +8,6 @@ #define CONFIG_BINMAN #include <binman_sym.h>
-binman_sym_declare(unsigned long, u_boot_spl, pos); -binman_sym_declare(unsigned long long, u_boot_spl2, pos); -binman_sym_declare(unsigned long, u_boot_any, pos); +binman_sym_declare(unsigned long, u_boot_spl, offset); +binman_sym_declare(unsigned long long, u_boot_spl2, offset); +binman_sym_declare(unsigned long, u_boot_any, offset);
At present each entry has an offset within its parent section. This is useful for figuring out how entries relate to one another. However it is sometimes necessary to locate an entry within an image, regardless of which sections it is nested inside.
Add a new 'image-pos' property to provide this information. Also add some documentation for the -u option binman provides, which updates the device tree with final entry information.
Since the image position is a better symbol to use for the position of U-Boot as obtained by SPL, update the SPL symbols to use this instead of offset, which might be incorrect if hierarchical sections are used.
Changes in v2: - Update U-Boot symbols to use image_pos instead of offset - Update tests to include test coverage of image_pos
common/spl/spl.c | 4 ++-- common/spl/spl_ram.c | 2 +- include/spl.h | 2 +- tools/binman/README | 22 ++++++++++++++++++++-- tools/binman/bsection.py | 10 +++++++++- tools/binman/control.py | 1 + tools/binman/entry.py | 12 +++++++++++- tools/binman/etype/section.py | 4 ++++ tools/binman/ftest.py | 9 ++++++++- tools/binman/image.py | 3 +++ tools/binman/test/u_boot_binman_syms | Bin 4916 -> 4924 bytes tools/binman/test/u_boot_binman_syms.c | 2 +- 12 files changed, 61 insertions(+), 10 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index b959aa02549..eda84d0c74c 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -34,7 +34,7 @@ DECLARE_GLOBAL_DATA_PTR; u32 *boot_params_ptr = NULL;
/* See spl.h for information about this */ -binman_sym_declare(ulong, u_boot_any, offset); +binman_sym_declare(ulong, u_boot_any, image_pos);
void spl_set_header_raw_uboot(struct spl_image_info *spl_image) { - ulong u_boot_pos = binman_sym(ulong, u_boot_any, offset); + ulong u_boot_pos = binman_sym(ulong, u_boot_any, image_pos);
diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index 6000f495ccd..e594beaeaa3 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -49,7 +49,7 @@ static int spl_ram_load_image(struct spl_image_info *spl_image, load.read = spl_ram_load_read; spl_load_simple_fit(spl_image, &load, 0, header); } else { - ulong u_boot_pos = binman_sym(ulong, u_boot_any, offset); + ulong u_boot_pos = binman_sym(ulong, u_boot_any, image_pos);
debug("Legacy image\n"); /* diff --git a/include/spl.h b/include/spl.h index 8c5523083b2..7fad62c043e 100644 --- a/include/spl.h +++ b/include/spl.h @@ -60,7 +60,7 @@ struct spl_load_info { * image is found. For * example if u-boot.img is used we don't check that * spl_parse_image_header() can parse a valid header. */ -binman_sym_extern(ulong, u_boot_any, offset); +binman_sym_extern(ulong, u_boot_any, image_pos);
/** * spl_load_simple_fit() - Loads a fit image from a device. diff --git a/tools/binman/README b/tools/binman/README index 4b13776ffad..df88819a1c3 100644 --- a/tools/binman/README +++ b/tools/binman/README @@ -324,6 +324,12 @@ offset-unset: property is present, binman will give an error if another entry does not set the offset (with the GetOffsets() method).
+image-pos: + This cannot be set on entry (or at least it is ignored if it is), but + with the -u option, binman will set it to the absolute image position + for each entry. This makes it easy to find out exactly where the entry + ended up in the image, regardless of parent sections, etc. +
The attributes supported for images are described below. Several are similar to those for entries. @@ -550,8 +556,8 @@ the 'warning' line in scripts/Makefile.lib to see what it has found: # u_boot_dtsi_options_debug = $(u_boot_dtsi_options_raw)
-Access to binman entry offsets at run time ------------------------------------------- +Access to binman entry offsets at run time (symbols) +----------------------------------------------------
Binman assembles images and determines where each entry is placed in the image. This information may be useful to U-Boot at run time. For example, in SPL it @@ -577,6 +583,18 @@ At present this feature is only supported in SPL. In principle it is possible to fill in such symbols in U-Boot proper, as well.
+Access to binman entry offsets at run time (fdt) +------------------------------------------------ + +Binman can update the U-Boot FDT to include the final position and size of +each entry in the images it processes. The option to enable this is -u and it +causes binman to make sure that the 'offset', 'image-pos' and 'size' properties +are set correctly for every entry. Since it is not necessary to specify these in +the image definition, binman calculates the final values and writes these to +the device tree. These can be used by U-Boot at run-time to find the location +of each entry. + + Map files ---------
diff --git a/tools/binman/bsection.py b/tools/binman/bsection.py index 1604b9915ec..08c6f0cda85 100644 --- a/tools/binman/bsection.py +++ b/tools/binman/bsection.py @@ -96,7 +96,7 @@ class Section(object):
def AddMissingProperties(self): """Add new properties to the device tree as needed for this entry""" - for prop in ['offset', 'size']: + for prop in ['offset', 'size', 'image-pos']: if not prop in self._node.props: self._node.AddZeroProp(prop) for entry in self._entries.values(): @@ -105,6 +105,7 @@ class Section(object): def SetCalculatedProperties(self): self._node.SetInt('offset', self._offset) self._node.SetInt('size', self._size) + self._node.SetInt('image-pos', self._image_pos) for entry in self._entries.values(): entry.SetCalculatedProperties()
@@ -260,6 +261,11 @@ class Section(object): offset = entry.offset + entry.size prev_name = entry.GetPath()
+ def SetImagePos(self, image_pos): + self._image_pos = image_pos + for entry in self._entries.values(): + entry.SetImagePos(image_pos) + def ProcessEntryContents(self): """Call the ProcessContents() method for each entry
@@ -341,6 +347,8 @@ class Section(object): raise ValueError(err) if prop_name == 'offset': return entry.offset + elif prop_name == 'image_pos': + return entry.image_pos else: raise ValueError("%s: No such property '%s'" % (msg, prop_name))
diff --git a/tools/binman/control.py b/tools/binman/control.py index 97652334e01..43d192c9a74 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -161,6 +161,7 @@ def Binman(options, args): image.PackEntries() image.CheckSize() image.CheckEntries() + image.SetImagePos() if options.update_fdt: image.SetCalculatedProperties() image.ProcessEntryContents() diff --git a/tools/binman/entry.py b/tools/binman/entry.py index cb693c93820..8004918eb58 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -64,6 +64,7 @@ class Entry(object): self.pad_before = 0 self.pad_after = 0 self.offset_unset = False + self.image_pos = None if read_node: self.ReadNode()
@@ -133,7 +134,7 @@ class Entry(object):
@@ -141,6 +142,7 @@ class Entry(object): """Set the value of device-tree properties calculated by binman""" self._node.SetInt('offset', self.offset) self._node.SetInt('size', self.size) + self._node.SetInt('image-pos', self.image_pos)
def ProcessFdt(self, fdt): return True @@ -265,6 +267,14 @@ class Entry(object): self.offset = pos self.size = size
+ def SetImagePos(self, image_pos): + """Set the position in the image + + Args: + image_pos: Position of this entry in the image + """ + self.image_pos = image_pos + self.offset + def ProcessContents(self): pass
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 1d27301ae92..b90b80e4ce7 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -46,6 +46,10 @@ class Entry_section(Entry): self.size = self._section.GetSize() return super(Entry_section, self).Pack(offset)
+ def SetImagePos(self, image_pos): + Entry.SetImagePos(self, image_pos) + self._section.SetImagePos(image_pos + self.offset) + def WriteSymbols(self, section): """Write symbol values into binary files for access at run time""" self._section.WriteSymbols() diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 94e48f3ab33..94a50aac166 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -1051,23 +1051,30 @@ class TestFunctional(unittest.TestCase): """Test that we can update the device tree with offset/size info""" _, _, _, out_dtb_fname = self._DoReadFileDtb('60_fdt_update.dts', update_dtb=True) - props = self._GetPropTree(out_dtb_fname, ['offset', 'size']) + props = self._GetPropTree(out_dtb_fname, ['offset', 'size', + 'image-pos']) with open('/tmp/x.dtb', 'wb') as outf: with open(out_dtb_fname) as inf: outf.write(inf.read()) self.assertEqual({ + 'image-pos': 0, 'offset': 0, '_testing:offset': 32, '_testing:size': 1, + '_testing:image-pos': 32, 'section@0/u-boot:offset': 0, 'section@0/u-boot:size': len(U_BOOT_DATA), + 'section@0/u-boot:image-pos': 0, 'section@0:offset': 0, 'section@0:size': 16, + 'section@0:image-pos': 0,
'section@1/u-boot:offset': 0, 'section@1/u-boot:size': len(U_BOOT_DATA), + 'section@1/u-boot:image-pos': 16, 'section@1:offset': 16, 'section@1:size': 16, + 'section@1:image-pos': 16, 'size': 40 }, props)
diff --git a/tools/binman/image.py b/tools/binman/image.py index ed8261a652a..4debc734519 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -96,6 +96,9 @@ class Image: def SetCalculatedProperties(self): self._section.SetCalculatedProperties()
+ def SetImagePos(self): + self._section.SetImagePos(0) + def ProcessEntryContents(self): """Call the ProcessContents() method for each entry
diff --git a/tools/binman/test/u_boot_binman_syms b/tools/binman/test/u_boot_binman_syms index f2dcb887ed84e4799ae9eca1d2d39585635fb4c6..126a1a623092cbe25f7a24118d26d4a0e8d0e0fc 100755 GIT binary patch delta 184 zcmdm@wnuG(0;9@C#rOOoD(}AY&Moeq!@T5hu`>ITRenxu^(Lzb7%>?dOb!>&o!ltk z?W@ATz`z2;f(%RyQ-CxK2rw`*gaSDRKn#;F2eM6|3Iu@aJAiDEeh>ihXHS+C44K>` zC^$J@P@FR}H!(dmz97GN@@&DClbwZ98BHgz6jElqHTkTNI%Ce{uR`jqI)V%g>n2|m G5(WUg>nL;p
delta 188 zcmdm^wnc4%0;9}E#rOOo%aW%XXzPXS$a9c<vVEPO>0A{L|H&!>MvRt|BLs9OcL;d+ z8Za<0umG_j0~13ikXAwBPXw}IK!Aafp#;b=feHu!)wcrKAoU;s;?I~YD;P3)f*|MQ vXhHSKO9Yos_7O^9G?~0nNSX2S<f}sJj2V;v3aLwI2r@9NhG+wmj8HZJbRHr-
diff --git a/tools/binman/test/u_boot_binman_syms.c b/tools/binman/test/u_boot_binman_syms.c index cbb2f3f7b17..4898f983e32 100644 --- a/tools/binman/test/u_boot_binman_syms.c +++ b/tools/binman/test/u_boot_binman_syms.c @@ -10,4 +10,4 @@
binman_sym_declare(unsigned long, u_boot_spl, offset); binman_sym_declare(unsigned long long, u_boot_spl2, offset); -binman_sym_declare(unsigned long, u_boot_any, offset); +binman_sym_declare(unsigned long, u_boot_any, image_pos);
