[U-Boot-Users] Unable to boot linux 2.6.25 with U-Boot 1.1.4
Hello everyone. I have got a modified u-boot source which boots vanilla 2.6.22 kernel, but is unable to boot vanilla 2.6.25.
The message I get is this : Uncompressing Linux.......................................................................................... done, booting the kernel.
Nothing shows up after this. The modified U-Boot version is "U-Boot 1.1.4".
Could somebody help. Thanks in advance Rohit
Activate in the linux kernel CONFIG_LL_DEBUG ( maybe ?! ) and check that the u_boot_board_id == linux_board_id
Regards Michael
I am working on OMAP2420 (ARM 11) based apollon board. The board id in u-boot is ( in file board/apollon.c, board_init() ): gd->bd->bi_arch_number = 919;
The board id in linux-2.6.22, linux-2.6.25 ( as defined in arch/arm/tools/mach-types ) : omap_apollon MACH_OMAP_APOLLON OMAP_APOLLON 919
Thanks, Rohit
Sorry, missed that.. Don't sure about this particular CPU, but with Atmel's AT91 there was some migration to new serial driver interface. I faced similar problem when booting 2.6.25 kernel, but after studying some code - something related to serial was missing in map_io.
Kind regards, Andrejs Cainikovs.
Do you have CONFIG_CLOCKS_IN_MHZ defined? If so, try turning it off.
--- Gary Jennejohn ********************************************************************* DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de *********************************************************************
Nope, it is undefined.
Thanks, Rohit
On Tue, Jun 24, 2008 at 11:04:55AM -0500, Timur Tabi wrote:
1.1.4 is too old to boot such a modern kernel.
No, it's not -- it should be quite capable of booting current kernels using cuImage. Passing a device tree is more questionable, if it's even supported at all.
-Scott
To clarify, the above applies on powerpc. It seems the original poster never specified what sort of hardware was involved.
-Scott
participants (6)
Andrejs Cainikovs
Gary Jennejohn
michael
rohit h
Scott Wood
Timur Tabi
