[U-Boot] [PATCH] Tegra114: Initialize System Counter (TSC) with osc frequency
T114 needs the SYSCTR0 counter initialized so the TSC can be read by the kernel. Do it in the bootloader since it's a write-once deal (secure/non-secure mode dependent).
Signed-off-by: Tom Warren twarren@nvidia.com --- arch/arm/cpu/tegra-common/clock.c | 3 +++ arch/arm/cpu/tegra114-common/clock.c | 22 ++++++++++++++++++ arch/arm/cpu/tegra20-common/clock.c | 4 ++++ arch/arm/cpu/tegra30-common/clock.c | 4 ++++ arch/arm/include/asm/arch-tegra/clock.h | 3 +++ arch/arm/include/asm/arch-tegra114/sysctr.h | 35 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-tegra114/tegra.h | 1 + 7 files changed, 72 insertions(+) create mode 100644 arch/arm/include/asm/arch-tegra114/sysctr.h
diff --git a/arch/arm/cpu/tegra-common/clock.c b/arch/arm/cpu/tegra-common/clock.c index 49a0633..9156d00 100644 --- a/arch/arm/cpu/tegra-common/clock.c +++ b/arch/arm/cpu/tegra-common/clock.c @@ -557,4 +557,7 @@ void clock_init(void) debug("PLLP = %d\n", pll_rate[CLOCK_ID_PERIPH]); debug("PLLC = %d\n", pll_rate[CLOCK_ID_CGENERAL]); debug("PLLX = %d\n", pll_rate[CLOCK_ID_XCPU]); + + /* Do any special system timer/TSC setup */ + arch_timer_init(); } diff --git a/arch/arm/cpu/tegra114-common/clock.c b/arch/arm/cpu/tegra114-common/clock.c index 9b29ce1..5c4305a 100644 --- a/arch/arm/cpu/tegra114-common/clock.c +++ b/arch/arm/cpu/tegra114-common/clock.c @@ -19,6 +19,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> +#include <asm/arch/sysctr.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/clk_rst.h> #include <asm/arch-tegra/timer.h> @@ -653,3 +654,24 @@ void clock_early_init(void) writel(0x40000C10, &clkrst->crc_pll[CLOCK_ID_DISPLAY].pll_misc); udelay(2); } + +void arch_timer_init(void) +{ + struct sysctr_ctlr *sysctr = (struct sysctr_ctlr *)NV_PA_TSC_BASE; + u32 freq, val; + + freq = clock_get_rate(CLOCK_ID_OSC); + debug("%s: osc freq is %dHz [0x%08X]\n", __func__, freq, freq); + + /* ARM CNTFRQ */ + asm("mcr p15, 0, %0, c14, c0, 0\n" : : "r" (freq)); + + /* Only T114 has the System Counter regs */ + debug("%s: setting CNTFID0 to 0x%08X\n", __func__, freq); + writel(freq, &sysctr->cntfid0); + + val = readl(&sysctr->cntcr); + val |= TSC_CNTCR_ENABLE | TSC_CNTCR_HDBG; + writel(val, &sysctr->cntcr); + debug("%s: TSC CNTCR = 0x%08X\n", __func__, val); +} diff --git a/arch/arm/cpu/tegra20-common/clock.c b/arch/arm/cpu/tegra20-common/clock.c index ec93894..4afb205 100644 --- a/arch/arm/cpu/tegra20-common/clock.c +++ b/arch/arm/cpu/tegra20-common/clock.c @@ -559,3 +559,7 @@ void clock_early_init(void) break; } } + +void arch_timer_init(void) +{ +} diff --git a/arch/arm/cpu/tegra30-common/clock.c b/arch/arm/cpu/tegra30-common/clock.c index a93f2c9..74bd22b 100644 --- a/arch/arm/cpu/tegra30-common/clock.c +++ b/arch/arm/cpu/tegra30-common/clock.c @@ -616,3 +616,7 @@ void clock_early_init(void) break; } } + +void arch_timer_init(void) +{ +} diff --git a/arch/arm/include/asm/arch-tegra/clock.h b/arch/arm/include/asm/arch-tegra/clock.h index c8677bd..c7a696c 100644 --- a/arch/arm/include/asm/arch-tegra/clock.h +++ b/arch/arm/include/asm/arch-tegra/clock.h @@ -317,4 +317,7 @@ int clock_set_rate(enum clock_id clkid, u32 n, u32 m, u32 p, u32 cpcon); #define periphc_internal_id_isvalid(id) ((id) >= 0 && \ (id) < PERIPHC_COUNT)
+/* SoC-specific TSC init */ +void arch_timer_init(void); + #endif /* _TEGRA_CLOCK_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/sysctr.h b/arch/arm/include/asm/arch-tegra114/sysctr.h new file mode 100644 index 0000000..c05e2c3 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra114/sysctr.h @@ -0,0 +1,35 @@ +/* + * Copyright (c) 2013, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _TEGRA114_SYSCTR_H_ +#define _TEGRA114_SYSCTR_H_ + +struct sysctr_ctlr { + u32 cntcr; /* 0x00: SYSCTR0_CNTCR Counter Control */ + u32 cntsr; /* 0x04: SYSCTR0_CNTSR Counter Status */ + u32 cntcv0; /* 0x08: SYSCTR0_CNTCV0 Counter Count 31:00 */ + u32 cntcv1; /* 0x0C: SYSCTR0_CNTCV1 Counter Count 63:32 */ + u32 reserved1[4]; /* 0x10 - 0x1C */ + u32 cntfid0; /* 0x20: SYSCTR0_CNTFID0 Freq Table Entry */ + u32 cntfid1; /* 0x24: SYSCTR0_CNTFID1 Freq Table End */ + u32 reserved2[1002]; /* 0x28 - 0xFCC */ + u32 counterid[12]; /* 0xFD0 - 0xFxx CounterID regs, RO */ +}; + +#define TSC_CNTCR_ENABLE (1 << 0) /* Enable */ +#define TSC_CNTCR_HDBG (1 << 1) /* Halt on debug */ + +#endif /* _TEGRA114_SYSCTR_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/tegra.h b/arch/arm/include/asm/arch-tegra114/tegra.h index a3d12d6..5d426b5 100644 --- a/arch/arm/include/asm/arch-tegra114/tegra.h +++ b/arch/arm/include/asm/arch-tegra114/tegra.h @@ -18,6 +18,7 @@ #define _TEGRA114_H_
#define NV_PA_SDRAM_BASE 0x80000000 /* 0x80000000 for real T114 */ +#define NV_PA_TSC_BASE 0x700F0000 /* System Counter TSC regs */
#include <asm/arch-tegra/tegra.h>
- /* Do any special system timer/TSC setup */
- arch_timer_init();
I wonder if we shouldn't ifdef that, so that ...
We don't need those stubs on the chips that don't support this. (I imagine that for future chips, the implementation will be common and will move out of the chip-specific file into some arch-timers file).
Either way though, Reviewed-by: Stephen Warren swarren@nvidia.com
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Wednesday, April 03, 2013 4:26 PM To: Tom Warren Cc: u-boot@lists.denx.de; Stephen Warren; Tom Warren Subject: Re: [U-Boot] [PATCH] Tegra114: Initialize System Counter (TSC) with osc frequency
I had an ifdef in there originally, but I don't like to add #ifdefs if they can be avoided, and I wasn't sure if there might not be some T20/T30-specific TSC/HPT init needed later.
Thanks
-- nvpublic
Stephen Warren
Tom Warren
Tom Warren
