[U-Boot] [PATCH] spi: mxc_spi: Set master mode for all channels
The glitch in the SPI clock line, which commit 3cea335c34 (spi: mxc_spi: Fix spi clock glitch durant reset) solved, is back now and itwas re-introduced by commit d36b39bf0d (spi: mxc_spi: Fix ECSPI reset handling).
Actually the glitch is happening due to always toggling between slave mode and master mode by configuring the CHANNEL_MODE bits in this reset function.
Since the spi driver only supports master mode, set the mode for all channels always to master mode in order to have a stable, "glitch-free" SPI clock line.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/spi/mxc_spi.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 4c19e0b..9eb2bce 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -137,9 +137,14 @@ static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, return -1; }
- /* Reset spi */ - reg_write(®s->ctrl, 0); - reg_write(®s->ctrl, MXC_CSPICTRL_EN); + /* + * Reset SPI and set all CSs to master mode, if toggling + * between slave and master mode we might see a glitch + * on the clock line + */ + reg_write(®s->ctrl, 0x000000F0); + reg_ctrl = reg_read(®s->ctrl); + reg_write(®s->ctrl, reg_ctrl | MXC_CSPICTRL_EN);
Am 06.04.2013 15:15, schrieb Fabio Estevam:
Ok, thanks, I wasn't aware of this.
- /* Reset spi */
I haven't checked the rest of the driver, but do we touch the CSs bits anywhere else, too? Could that parts dropped with this patch, then. I.e. never touch the bits regs->ctrl[7-4] again?
if toggling
* on the clock line
- reg_write(®s->ctrl, 0x000000F0);
Do we have a macro for the 0xF?
- reg_ctrl = reg_read(®s->ctrl);
Do we expect reg_ctrl to be 0x000000F0 then? If yes, do we have to really read it here? If we read it here, should we drop the read below, then?
So, as mentioned by Stefano before, I'd propose to either
a) do the reg_read(®s->ctrl); only _once_. E.g.
/* * Reset SPI and set all CSs to master mode, if toggling * between slave and master mode we might see a glitch * on the clock line */ reg_write(®s->ctrl, 0x000000F0); /* FIXME: use a macro here*/ reg_ctrl = reg_read(®s->ctrl) | MXC_CSPICTRL_EN; /* Reading back the register content is done because we don't get back the value written above */ reg_write(®s->ctrl, reg_ctrl); => no additional read of reg_ctrl needed here as reg_ctrl contains already the recent register content <=
or
b) _never_ read back the register. E.g.
/* * Reset SPI and set all CSs to master mode, if toggling * between slave and master mode we might see a glitch * on the clock line */ reg_ctrl = 0x000000F0; /* FIXME: use a macro here*/ reg_write(®s->ctrl, reg_ctrl); reg_ctrl |= MXC_CSPICTRL_EN; reg_write(®s->ctrl, reg_ctrl); => no additional read of reg_ctrl needed here as reg_ctrl contains already the recent register content <=
Would one of these options work?
Best regards
Dirk
Dirk Behme
Fabio Estevam
