[U-Boot] TQM860L_config: u-boot.lds:76 cannot move location counter backwards
so i got permission to try to update u-boot on one of the TQM860 boards, so i checked out the u-boot git repo, ran:
$ make TQM860L_config $ make
and eventually got:
u-boot.lds:76 cannot move location counter backwards (from 40008604 to 40008000) make: *** [u-boot] Error 1
i can read an explanation of what that allegedly means here:
http://www.denx.de/wiki/view/DULG/PortingProblemCannotMoveLocationCounterBac...
but that explanation is in the context of someone *porting* u-boot to a new board. should i expect this for what should be an already supported board?
in any event, it's late so i'll tackle this again tomorrow.
rday
and eventually got:
http://www.denx.de/wiki/view/DULG/PortingProblemCannotMoveLocationCounterBa ckwards
rday
What version of uboot do you use? What compiler and it's version do you use?
M
and eventually got:
rday
i'm using the latest "git pull" of u-boot, and:
$ powerpc-unknown-linux-gnu-gcc --version powerpc-unknown-linux-gnu-gcc (crosstool-NG-1.10.0) 4.4.5 ...
i get the same result with u-boot 2010.12.
rday
Dear Robert,
Your tool chain is broken / generates inefcient code.
Top of tree: -> git describe v2011.09-1259-g7708d8b -> eldk-switch -r 4.2 ppc_8xx Setup for ppc_8xx (using ELDK 4.2) -> ${CROSS_COMPILE}gcc -v ... gcc version 4.2.2 -> ./MAKEALL TQM860L Configuring for TQM860L board... text data bss dec hex filename 261815 14100 27240 303155 4a033 ./u-boot
--------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- -> eldk-switch -r 5.1 powerpc Setup for powerpc (using ELDK 5.1) -> ${CROSS_COMPILE}gcc -v ... gcc version 4.6.1 20110627 (prerelease) (GCC) -> ./MAKEALL TQM860L Configuring for TQM860L board... text data bss dec hex filename 256410 4444 27212 288066 46542 ./u-boot
So both older tool chains (GCC 4.2.2) and more recent ones (gcc 6.6.1) build top of tree fine. I save the efforts of building v2010.12 because I already did as part of the QA for that release.
Get yourself a working tool chain.
On Sat, 3 Dec 2011, Wolfgang Denk wrote:
Dear Robert,
ok, i'll grab another one, thanks.
rday
Dear Robert,
i'm using the latest "git pull" of u-boot, and: $ powerpc-unknown-linux-gnu-gcc --version powerpc-unknown-linux-gnu-gcc (crosstool-NG-1.10.0) 4.4.5 ...
rday
I think I told you already to try ELDK 5.0 / 5.1.
M
Dear Robert,
rday
downloading as we speak.
rday
Dear Robert,
i'm sure someone will yell at me for this question as well, but where does one find "eldk-switch"? i have a fully updated git clone of uboot and there is no such script (which is what i assume i'm looking for).
rday
Hi Robert,
On Sat, 3 Dec 2011 12:47:47 -0500 (EST) "Robert P. J. Day" rpjday@crashcourse.ca wrote: ...
eldk-switch is internally used script, it is not distributed with U-Boot since its purpose is to configure environment in preparation for building using desired ELDK version.
You don't need this script. You can setup environment i. e. by running
$ export ARCH=powerpc $ export CROSS_COMPILE=ppc_8xx- $ export PATH=<your-eldk-root-dir>/usr/bin:$PATH
To check if the environment is set correctly you can try to run installed cross gcc, i.e. run:
More info is available in ELDK documentation, i. e. [1]
HTH, Anatolij
On Sat, 3 Dec 2011, Anatolij Gustschin wrote:
Hi Robert,
um, my understanding for the need of that script (or its equivalent, which i assume is just to switch to the git 4.2 branch), is to avoid this issue:
http://lists.denx.de/pipermail/eldk/2011-November/002052.html
which is *precisely* what i ran into, so i'm assuming i need to back off to v4.2. unless that issue has been addressed already in the ELDK toolchain development branch but i didn't see any git commit that referred to it.
rday
On Sat, 3 Dec 2011 15:12:44 -0500 (EST) "Robert P. J. Day" rpjday@crashcourse.ca wrote: ...
For mpc860 you have to use pre-build ELDK-4.2, available at [1]. Mount the iso file, install ppc_8xx cpu family version as described in ELDK documentation [2].
Anatolij
[1] ftp://ftp.denx.de/pub/eldk/4.2/ppc-linux-x86/iso/ppc-2008-04-01_freescale.iso [2] http://www.denx.de/wiki/view/DULG/ELDKInitialInstallation
Anatolij
ok, i've gone through that process before, thanks.
rday
Dear Robert,
This is fixed in ELDK 5.1. A beta version is available at ftp://ftp.denx.de/pub/eldk/5.1-beta/targets/powerpc/
Anatolij Gustschin
Robert P. J. Day
