[PATCH v1 0/3] arm: NPCM: fix npcm bmc error
1. fix incorrect ram size with ecc enabld
2. add name for gpio function
3. add baud rate table
Jim Liu (3): pinctrl: npcm8xx: add name for gpio function arm: NPCM: modify baud rate table and dram setting arm: npcm8xx: support dcache off
arch/arm/mach-npcm/npcm8xx/Kconfig | 4 ++++ arch/arm/mach-npcm/npcm8xx/cpu.c | 12 +++++++++++- board/nuvoton/arbel_evb/arbel_evb.c | 16 ++++++++-------- configs/arbel_evb_defconfig | 1 + drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c | 1 + include/configs/arbel.h | 4 +++- include/configs/poleg.h | 1 + 7 files changed, 29 insertions(+), 10 deletions(-)
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c b/drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c index 7976e3b3ed..ff49819b58 100644 --- a/drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c +++ b/drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c @@ -329,6 +329,7 @@ struct group_info {
static const struct group_info npcm8xx_groups[] = { FUNC_LIST + {FN_gpio, "GPIO", NULL, 0, 0, 0} };
/* Pin flags */
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- board/nuvoton/arbel_evb/arbel_evb.c | 16 ++++++++-------- configs/arbel_evb_defconfig | 1 + include/configs/arbel.h | 4 +++- include/configs/poleg.h | 1 + 4 files changed, 13 insertions(+), 9 deletions(-)
diff --git a/board/nuvoton/arbel_evb/arbel_evb.c b/board/nuvoton/arbel_evb/arbel_evb.c index e52e0a59ab..3fb49a9549 100644 --- a/board/nuvoton/arbel_evb/arbel_evb.c +++ b/board/nuvoton/arbel_evb/arbel_evb.c @@ -16,7 +16,7 @@ #define DRAM_1GB_SIZE 0x40000000ULL #define DRAM_2GB_ECC_SIZE 0x70000000ULL #define DRAM_2GB_SIZE 0x80000000ULL -#define DRAM_4GB_ECC_SIZE 0xE00000000ULL +#define DRAM_4GB_ECC_SIZE 0xE0000000ULL #define DRAM_4GB_SIZE 0x100000000ULL
DECLARE_GLOBAL_DATA_PTR; @@ -29,7 +29,6 @@ int board_init(void) int dram_init(void) { struct npcm_gcr *gcr = (struct npcm_gcr *)NPCM_GCR_BA; - uint64_t delta = 0ULL;
/* * get dram active size value from bootblock. @@ -62,26 +61,27 @@ int dram_init(void) gd->bd->bi_dram[1].size = 0; break; case DRAM_4GB_ECC_SIZE: - gd->bd->bi_dram[0].size = DRAM_2GB_ECC_SIZE; + gd->bd->bi_dram[0].size = DRAM_2GB_SIZE; gd->bd->bi_dram[1].start = DRAM_4GB_SIZE; - gd->bd->bi_dram[1].size = DRAM_2GB_SIZE; - delta = DRAM_4GB_SIZE - DRAM_2GB_ECC_SIZE; + gd->bd->bi_dram[1].size = DRAM_2GB_SIZE - (DRAM_4GB_SIZE - DRAM_4GB_ECC_SIZE); + /* use bank0 only */ + gd->ram_size = DRAM_2GB_SIZE; break; case DRAM_4GB_SIZE: gd->bd->bi_dram[0].size = DRAM_2GB_SIZE; gd->bd->bi_dram[1].start = DRAM_4GB_SIZE; gd->bd->bi_dram[1].size = DRAM_2GB_SIZE; - delta = DRAM_4GB_SIZE - DRAM_2GB_SIZE; + /* use bank0 only */ + gd->ram_size = DRAM_2GB_SIZE; break; default: gd->bd->bi_dram[0].size = DRAM_1GB_SIZE; gd->bd->bi_dram[1].start = 0; gd->bd->bi_dram[1].size = 0; + gd->ram_size = DRAM_1GB_SIZE; break; }
- gd->ram_size -= delta; - return 0; }
diff --git a/configs/arbel_evb_defconfig b/configs/arbel_evb_defconfig index ce7f2355e1..eb6b0c05c4 100644 --- a/configs/arbel_evb_defconfig +++ b/configs/arbel_evb_defconfig @@ -58,6 +58,7 @@ CONFIG_MMC_SDHCI_NPCM=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHY_BROADCOM=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/include/configs/arbel.h b/include/configs/arbel.h index 891257bc93..f103f7e452 100644 --- a/include/configs/arbel.h +++ b/include/configs/arbel.h @@ -7,10 +7,12 @@ #define __CONFIG_ARBEL_H
#define CFG_SYS_SDRAM_BASE 0x0 -#define CFG_SYS_BOOTMAPSZ (30 << 20) +#define CFG_SYS_BOOTMAPSZ (128 << 20) #define CFG_SYS_BOOTM_LEN (20 << 20) #define CFG_SYS_INIT_RAM_ADDR CFG_SYS_SDRAM_BASE #define CFG_SYS_INIT_RAM_SIZE 0x8000 +#define CFG_SYS_BAUDRATE_TABLE { 9600, 14400, 19200, 38400, 57600, 115200, 230400, \ + 380400, 460800, 921600 }
/* Default environemnt variables */ #define CFG_EXTRA_ENV_SETTINGS "uimage_flash_addr=80400000\0" \ diff --git a/include/configs/poleg.h b/include/configs/poleg.h index 1e96e838be..5bea70b8b4 100644 --- a/include/configs/poleg.h +++ b/include/configs/poleg.h @@ -12,6 +12,7 @@
#define CFG_SYS_BOOTMAPSZ (0x30 << 20) #define CFG_SYS_SDRAM_BASE 0x0 +#define CFG_SYS_BAUDRATE_TABLE { 57600, 115200, 230400, 460800 }
/* Default environemnt variables */ #define CFG_EXTRA_ENV_SETTINGS "uimage_flash_addr=80200000\0" \
do not enable dcache by setting CONFIG_SYS_NPCM_DCACHE_OFF=y
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- arch/arm/mach-npcm/npcm8xx/Kconfig | 4 ++++ arch/arm/mach-npcm/npcm8xx/cpu.c | 12 +++++++++++- 2 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-npcm/npcm8xx/Kconfig b/arch/arm/mach-npcm/npcm8xx/Kconfig index 5f4a0506dc..163e7e7d48 100644 --- a/arch/arm/mach-npcm/npcm8xx/Kconfig +++ b/arch/arm/mach-npcm/npcm8xx/Kconfig @@ -6,6 +6,10 @@ config SYS_CPU config SYS_SOC default "npcm8xx"
+config SYS_NPCM_DCACHE_OFF + bool "Do not enable dcache" + default n + config TARGET_ARBEL_EVB bool "Arbel Evaluation Board" help diff --git a/arch/arm/mach-npcm/npcm8xx/cpu.c b/arch/arm/mach-npcm/npcm8xx/cpu.c index af59452609..fc691de950 100644 --- a/arch/arm/mach-npcm/npcm8xx/cpu.c +++ b/arch/arm/mach-npcm/npcm8xx/cpu.c @@ -81,7 +81,8 @@ int print_cpuinfo(void)
int arch_cpu_init(void) { - if (!IS_ENABLED(CONFIG_SYS_DCACHE_OFF)) { + if (!IS_ENABLED(CONFIG_SYS_DCACHE_OFF) && + !IS_ENABLED(CONFIG_SYS_NPCM_DCACHE_OFF)) { /* Enable cache to speed up system running */ if (get_sctlr() & CR_M) return 0; @@ -143,3 +144,12 @@ int timer_init(void)
return 0; } + +void enable_caches(void) +{ + icache_enable(); + + if (!IS_ENABLED(CONFIG_SYS_NPCM_DCACHE_OFF)) + dcache_enable(); + +}
- bool "Do not enable dcache"
- default n
Why do we need a new Kconfig option here on top of the existing generic ones to control cache?
Hi Tom
Thanks for the quick review.
if we set the CONFIG_SYS_DCACHE_OFF the armv8 will build error. So we added a workaround for our bmc uboot.
the error message as below:
CONFIG_SYS_DCACHE_OFF can't be enabled on armv8, or the following build error would happen.
arch/arm/cpu/armv8/cpu.o: in function `cleanup_before_linux': arch/arm/cpu/armv8/cpu.c:60: undefined reference to `icache_disable' arch/arm/cpu/armv8/cpu.c:68: undefined reference to `dcache_disable' arch/arm/cpu/armv8/cpu.c:69: undefined reference to `invalidate_dcache_all'
Best regards, Jim
default n
-- Tom
On Thu, Sep 28, 2023 at 08:49:23AM +0800, Jim Liu wrote:
Hi Tom
OK, so you need https://patchwork.ozlabs.org/project/uboot/patch/20230811054228.3721455-1-bh... to be applied, as-is, yes? Thanks!
Best regards, Jim
default n
-- Tom
Hi Tom
Thanks for your understanding. but this patch is an incomplete patch. After I applied this patch I had another error.
arch/arm/cpu/armv8/cache_v8.c:773:2: error: #error Please describe your MMU layout in CONFIG_SYS_MEM_MAP and enable dcache. 773 | #error Please describe your MMU layout in CONFIG_SYS_MEM_MAP and enable dcache.
This error is the same as that link.
Best regards, Jim
Hi Tom
Best regards, Jim
default n
-- Tom
-- Tom
On Thu, Sep 28, 2023 at 10:32:51PM +0800, Jim Liu wrote:
Hi Tom
Please use that patch as a starting point (and also possibly needing to grab https://patchwork.ozlabs.org/project/uboot/patch/20230822075112.717992-2-bhu... as that's how I'd like to proceed with addressing this generic armv8 issue, thanks!
Best regards, Jim
Hi Tom
Best regards, Jim
default n
-- Tom
-- Tom
Hi Tom
I followed your suggestion to modify the code. but still have errors. Should I use my workaround?
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Tom
Best regards, Jim
default n
-- Tom
-- Tom
-- Tom
On Mon, Oct 02, 2023 at 12:40:54AM -0700, Jim Liu wrote:
Hi Tom
No, please figure out the errors, or at least post what you've got, thanks.
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Tom
Best regards, Jim
> do not enable dcache by setting CONFIG_SYS_NPCM_DCACHE_OFF=y > > Signed-off-by: Jim Liu JJLIU0@nuvoton.com > --- > arch/arm/mach-npcm/npcm8xx/Kconfig | 4 ++++ > arch/arm/mach-npcm/npcm8xx/cpu.c | 12 +++++++++++- > 2 files changed, 15 insertions(+), 1 deletion(-) > > diff --git a/arch/arm/mach-npcm/npcm8xx/Kconfig b/arch/arm/mach-npcm/npcm8xx/Kconfig > index 5f4a0506dc..163e7e7d48 100644 > --- a/arch/arm/mach-npcm/npcm8xx/Kconfig > +++ b/arch/arm/mach-npcm/npcm8xx/Kconfig > @@ -6,6 +6,10 @@ config SYS_CPU > config SYS_SOC > default "npcm8xx" > > +config SYS_NPCM_DCACHE_OFF > + bool "Do not enable dcache" > + default n > + > config TARGET_ARBEL_EVB > bool "Arbel Evaluation Board" > help
-- Tom
-- Tom
-- Tom
Hi Tom
Thanks for your reply. I will create another thread for this topic.
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Tom
Best regards, Jim
On Tue, Sep 26, 2023 at 9:48 PM Tom Rini trini@konsulko.com wrote: > > On Tue, Sep 26, 2023 at 04:56:50PM +0800, Jim Liu wrote: > > > do not enable dcache by setting CONFIG_SYS_NPCM_DCACHE_OFF=y > > > > Signed-off-by: Jim Liu JJLIU0@nuvoton.com > > --- > > arch/arm/mach-npcm/npcm8xx/Kconfig | 4 ++++ > > arch/arm/mach-npcm/npcm8xx/cpu.c | 12 +++++++++++- > > 2 files changed, 15 insertions(+), 1 deletion(-) > > > > diff --git a/arch/arm/mach-npcm/npcm8xx/Kconfig b/arch/arm/mach-npcm/npcm8xx/Kconfig > > index 5f4a0506dc..163e7e7d48 100644 > > --- a/arch/arm/mach-npcm/npcm8xx/Kconfig > > +++ b/arch/arm/mach-npcm/npcm8xx/Kconfig > > @@ -6,6 +6,10 @@ config SYS_CPU > > config SYS_SOC > > default "npcm8xx" > > > > +config SYS_NPCM_DCACHE_OFF > > + bool "Do not enable dcache" > > + default n > > + > > config TARGET_ARBEL_EVB > > bool "Arbel Evaluation Board" > > help > > Why do we need a new Kconfig option here on top of the existing generic > ones to control cache? > > -- > Tom
-- Tom
-- Tom
-- Tom
Jim Liu
