[PATCH v2] efi_selftest: add hii database protocol test cases
Add a couple of tests for the cases when the HII database protocol get_package_list_handle() function is called with invalid parameters.
Signed-off-by: Vincent Stehlé vincent.stehle@arm.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Ilias Apalodimas ilias.apalodimas@linaro.org ---
Thanks Heinrich for your review and feedbacks; here is v2 of this patch.
Best regards, Vincent.
Changes in v2: - Change initialization of driver_handle to a non-NULL value, which will never get allocated. - Add a second test for the case when driver handle is invalid.
v1 reference(s): - https://lists.denx.de/pipermail/u-boot/2022-December/502213.html - https://lists.denx.de/pipermail/u-boot/2023-January/503718.html
lib/efi_selftest/efi_selftest_hii.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/lib/efi_selftest/efi_selftest_hii.c b/lib/efi_selftest/efi_selftest_hii.c index eaf3b0995d4..608e3982399 100644 --- a/lib/efi_selftest/efi_selftest_hii.c +++ b/lib/efi_selftest/efi_selftest_hii.c @@ -605,6 +605,25 @@ static int test_hii_database_get_package_list_handle(void) goto out; }
+ /* Invalid package list handle. */ + driver_handle = (efi_handle_t)~1UL; + ret = hii_database_protocol->get_package_list_handle( + hii_database_protocol, NULL, &driver_handle); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("get_package_list_handle returned %u not invalid\n", + (unsigned int)ret); + goto out; + } + + /* Invalid driver handle. */ + ret = hii_database_protocol->get_package_list_handle( + hii_database_protocol, handle, NULL); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("get_package_list_handle returned %u not invalid\n", + (unsigned int)ret); + goto out; + } + result = EFI_ST_SUCCESS;
out:
Vincent Stehlé
