[U-Boot] [PATCH] serial_mxc: Fix setup of UARTx_UFCR register
This patch writes the default values for TXTL and RXTL to UARTx_UFCR. Without this patch some older kernel versions crash as UARTx_UFCR was not always correctly initialized.
Signed-off-by: Maximilian Schwerin maximilian.schwerin@tigris.de --- drivers/serial/serial_mxc.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index d6cf1d8..51485c0 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -75,6 +75,7 @@ #define UCR4_DREN (1<<0) /* Recv data ready interrupt enable */ #define UFCR_RXTL_SHF 0 /* Receiver trigger level shift */ #define UFCR_RFDIV (7<<7) /* Reference freq divider mask */ +#define UFCR_RFDIV_SHF 7 /* Reference freq divider shift */ #define UFCR_TXTL_SHF 10 /* Transmitter trigger level shift */ #define USR1_PARITYERR (1<<15) /* Parity error interrupt flag */ #define USR1_RTSS (1<<14) /* RTS pin status */ @@ -135,6 +136,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#define TXTL 2 /* reset default */ +#define RXTL 1 /* reset default */ +#define RFDIV 4 /* divide input clock by 2 */ + static void mxc_serial_setbrg(void) { u32 clk = imx_get_uartclk(); @@ -142,7 +147,9 @@ static void mxc_serial_setbrg(void) if (!gd->baudrate) gd->baudrate = CONFIG_BAUDRATE;
- __REG(UART_PHYS + UFCR) = 4 << 7; /* divide input clock by 2 */ + __REG(UART_PHYS + UFCR) = (RFDIV << UFCR_RFDIV_SHF) + | (TXTL << UFCR_TXTL_SHF) + | (RXTL << UFCR_RXTL_SHF); __REG(UART_PHYS + UBIR) = 0xf; __REG(UART_PHYS + UBMR) = clk / (2 * gd->baudrate);
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
Maximilian Schwerin
Stefano Babic
