[PATCH 0/1] Add flash protection support for Winbond's w25q128
According to datasheets, all 3 types of w25q128 support ST Micro-like flash protection that using BP{0-2}/TB bits in status register.
Su Baocheng (1): mtd: spi-nor-ids: Add support of flash protection to w25q128
drivers/mtd/spi/spi-nor-ids.c | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
The NOR flash w25q128 denoted by JEDEC ID 0xef4018 actually represents various models. From Winbond's website, I could only find 3 types of them:
W25Q128JV-IQ/JQ datasheet:https://www.winbond.com/resource-files/ w25q128jv%20revg%2004082019%20plus.pdf
W25Q128FV (SPI Mode) datasheet: https://www.winbond.com/resource-files/ w25q128fv%20rev.m%2005132016%20kms.pdf
W25Q128BV datesheet: https://www.winbond.com/resource-files/ w25q128bv_revh_100313_wo_automotive.pdf
According to the datasheets, all of these 3 types support BP(0,1,2) and TB bits in the status register (SR), so it could reuse the flash protection logic for ST Micro.
So it should be safe to add the SPI_NOR_HAS_LOCK and SPI_NOR_HAS_TB flags to the w25q128 entry of spi_nor_ids table.
Signed-off-by: Su Baocheng baocheng.su@siemens.com ---
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 5bd5dd3003..dcce25bec2 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -319,7 +319,17 @@ const struct flash_info spi_nor_ids[] = { { INFO("w25q80bl", 0xef4014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25q16cl", 0xef4015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25q64cv", 0xef4017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { INFO("w25q128", 0xef4018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + /* There are 3 types of w25q128 with JEDEC ID 0xef4018: + * W25Q128JV-IQ/JQ + * W25Q128FV (SPI Mode) + * W25Q128BV + * According to the datasheets, All of these 3 types support + * protection through BP{0,1,2}, TB in the status register (SR). + */ + { INFO("w25q128", 0xef4018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, { INFO("w25q256", 0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25m512jw", 0xef6119, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25m512jv", 0xef7119, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
* W25Q128JV-IQ/JQ
* W25Q128BV
Dropped comments, as it clearly mentioned on commit log.
Applied to u-boot-spi/master
Jagan Teki
Su Baocheng
