[U-Boot] is "CONFIG_OMAP_INNOVATOR" a typo or not?
in my travels through OMAP land, i'm still running across what look like typoes but i'm not sure if they are or if there's something subtle and funky going on underneath with macro concatenation or something.
witness:
$ grep -r CONFIG.*OMAP.*INNOVATOR * include/configs/omap1510.h:#ifdef CONFIG_OMAP_INNOVATOR include/configs/omap1610inn.h:#define CONFIG_MACH_OMAP_INNOVATOR /* Select board mach-type */ include/asm-arm/mach-types.h:#ifdef CONFIG_MACH_OMAP_INNOVATOR $
so the last two lines above set and test CONFIG_MACH_OMAP_INNOVATOR, while that first header file instead tests CONFIG_OMAP_INNOVATOR, for which there is no other reference anywhere else in the tree.
can someone clarify what's happening in cases like that, because it's not the only example i've run across. thanks.
rday --
======================================================================== Robert P. J. Day Waterloo, Ontario, CANADA
Linux Consulting, Training and Kernel Pedantry.
Web page: http://crashcourse.ca Twitter: http://twitter.com/rpjday ========================================================================
Robert P. J. Day
