[PATCH] i.MX8 crypto/fsl: Enable fsl CAAM rng driver
rng driver enabled to read random number using caam.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- drivers/crypto/fsl/jr.c | 8 +++++++- drivers/crypto/fsl/rng.c | 8 +++++++- 2 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index 85a3dac796..acd29924f7 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -767,8 +767,14 @@ init: return -1; } #if CONFIG_IS_ENABLED(OF_CONTROL) - if (ofnode_valid(scu_node)) + if (ofnode_valid(scu_node)) { + if (IS_ENABLED(CONFIG_DM_RNG)) { + ret = device_bind_driver(NULL, "caam-rng", "caam-rng", NULL); + if (ret) + printf("Couldn't bind rng driver (%d)\n", ret); + } return ret; + } #endif
#ifdef CONFIG_FSL_CORENET diff --git a/drivers/crypto/fsl/rng.c b/drivers/crypto/fsl/rng.c index 0636494805..b568c337a6 100644 --- a/drivers/crypto/fsl/rng.c +++ b/drivers/crypto/fsl/rng.c @@ -26,10 +26,16 @@ struct caam_rng_priv {
static int caam_rng_read_one(struct caam_rng_priv *priv) { + struct udevice *dev; int size = ALIGN(CAAM_RNG_MAX_FIFO_STORE_SIZE, ARCH_DMA_MINALIGN); int ret;
- ret = run_descriptor_jr(priv->desc); + if (uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev) || !dev) { + printf("No CAAM device\n"); + return -ENODEV; + } + + ret = misc_ioctl(dev, CAAM_JR_RUN_DESC, priv->desc); if (ret < 0) return -EIO;
Hi Gaurav,
if (ret)
return ret;
} #endif
- struct udevice *dev; int size = ALIGN(CAAM_RNG_MAX_FIFO_STORE_SIZE, ARCH_DMA_MINALIGN); int ret;
- if (uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev) || !dev) {
return -ENODEV;
- ret = misc_ioctl(dev, CAAM_JR_RUN_DESC, priv->desc); if (ret < 0) return -EIO;
This breaks the kontron_sl28 board. Can you check and fix it, please ? Thanks !
Best regards, Stefano
Hello Stefano
-----Original Message----- From: Stefano Babic sbabic@denx.de Sent: Friday, April 22, 2022 2:29 AM To: Gaurav Jain gaurav.jain@nxp.com; Stefano Babic sbabic@denx.de; u- boot@lists.denx.de Cc: Fabio Estevam festevam@gmail.com; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Varun Sethi V.Sethi@nxp.com; dl-uboot-imx uboot-imx@nxp.com Subject: [EXT] Re: [PATCH] i.MX8 crypto/fsl: Enable fsl CAAM rng driver
Caution: EXT Email
Hi Gaurav,
if (ret)
} return ret;
#endif
ARCH_DMA_MINALIGN);
int ret;
&dev) || !dev) {
return -ENODEV;
Sent v2 of this patch after fixing the error.
Regards Gaurav Jain
==== DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ================================================================= ====
Gaurav Jain
Stefano Babic
